View Full Version : Drag Racing Tech
  1. Am I expecting too much hoping for 10s from my setup?
  2. 4mph loss in 1/8 mile???
  3. anyone with 29 or 29.5 tires
  4. m6 with et street(bias-ply not the radial one) tubes or no tubes?
  5. fastest bolt on street tire cars
  6. Do you balance your drag tires?
  7. NA Tires - Radial or Radial Slick
  8. What Transmission Shield You Guys Running?
  9. project 370ci iron block aimed into 9's any pointers
  10. help with gear choice
  11. Chassis and suspension seminars in Texas!
  12. Any difference in 50 lbs of rear axle weight vs 50 lbs of car weight?
  13. QA1 12 way adjustables on the rear come in
  14. Just where am I at now...
  15. Who makes double adjustable spherical rod end LCA'a and PHB's?
  16. first time out, and not close to what was expected
  17. What tires for my setup??
  18. XS batteries?
  19. exhaust questions
  20. Please help w/60fts!!!
  21. Which Driveshaft Loop?
  22. VATS P/N number....?
  23. first "attempt" at a run
  24. What wheel tire combo do I need so I can hook?
  25. Question about tune?
  26. What shield for a TH400 swap and using M6 crossmember with it??
  27. So what tires can I fit on 17" SS RIMS
  28. Need help with my car
  29. Wiring Harness Race Mod
  30. Help with gear/rpm question going from 2.73 to 4.10's
  31. Intake Scoop
  32. atco tomorrow?
  33. 245/50/16 track psi ?
  34. Suspension: Shock settings & ride height
  35. Need some input, thinking I have problems....
  36. does anyone know...
  37. looking for pics of Glasstek 6" cowl hood
  38. Added the suspension then I slowed down. Help
  39. alternator mounting question
  40. Need help lauching my car!
  41. passing tech with a bmr battery tray?
  42. First time at the track
  43. The car in Kuwait :) :) ( pic)
  44. Weight sticky for the 2010 Camaro?
  45. My Trans Am Is Losing Weight...
  46. What times in the 1/8th
  47. Has anyone removed a speedglass window?
  48. Drag Racing Tires/Rear end Questions
  49. what harmonic balancers are people using?
  50. anyone interested in a BMR manual rack
  51. having a problem when leaving the line...
  52. Cage is in
  53. Will 305-45-18 fit my C5
  54. need info,
  55. strut tower brace
  56. Bogart racing setup
  57. BMR K member
  58. Need drag radials
  59. Rear Shocks ?
  60. What gear oil/additive for moser 9" w/ eaton posi?
  61. Will a steel drive shaft over stock lower dyno #'s alot?
  62. Need some opinions from Drag racers
  63. recertification on my UD pully and flywheel
  64. Narrowed LCA Bracket
  65. Lt1 stuck at 11.5
  66. Quick t-top delete question
  67. strange rear da shock mounting problem
  68. does anyone know the weight of jegs/summit stars
  69. 255/50/16 MT ET Steets enough???
  70. Toyo DRs....Any good?
  71. mt sportsman sr
  72. Shorten rear guys, what 15" drag rims with stock calipers?
  73. Fastests built 346/347 ls1?
  74. gear, tire, trans combination ?'s
  75. Carb intake,pic request.
  76. Question:QA1 Adjustible Setup for the track?
  77. crank height on different motors in stock suspension car
  78. Dr t/a
  79. Please Help Me With Traction Issues
  80. help
  81. whats the weight difference between a spooled 12 bolt and stock 10bolt?
  82. Will a 28x12.50 15 ET street fit?
  83. Almost Track Ready
  84. got HP but no Track time
  85. Will a 15x12 fit without mini-tub?
  86. Latest round of mods, QTPs, 2-step, Speedinc relo,MSD Dig 6+
  87. ac delete panel
  88. Engine weights
  89. Glasstek hood:need help with install
  90. How consistent is an LS motor?
  91. need advice to improve 60'
  92. Rate my passes! Lots of cool footage, angles, and kills!
  93. Any experience with Pro XS mufflers from Borla?
  94. Getting a good 60 out of a m6
  95. Serious launch and traction issues...
  96. Heating the tires
  97. best way to launch my turbo m6
  98. Out of the hole?
  99. radiator
  100. does nitrous effect gearing?
  101. Weight reduction - bumper reinforcement & brackets
  102. Setting up a Accufab 4500
  103. wilson or accufab
  104. muffler choices ??
  105. How to hit 11s with bolt ons
  106. well i hope all my buddies are right
  107. More gear and more tire better?
  108. C6 vette and C6Z in here
  109. Can solid mounts hurt the motor or frame?
  110. anyone use the jegs cage???
  111. ET calculator
  112. Gains with gears?
  113. Physics behind trap speed and horsepower correlation?
  114. Need help with nitrous problem...
  115. 12.6@104 for Bolton LT1
  116. How to tell when DRs done?
  117. 3.42's may be killing my setup, help me decide gears + tires.
  118. deleting wires, quick question
  119. Tire size difference
  120. 10.00@126...ok gurus inside please.
  121. suspension set up ??
  122. Line Lock manual trans launching
  123. Spool or TrueTrack ?
  124. help me with choosing seats
  125. Trimming rear bumper for slicks
  126. Aerospace drag brake sale
  127. What battery box?
  128. Ok to cut out lower and upper radiator support?
  129. Super Victor LS1 intake/408ci Direct Port Nitrous
  130. WOT Conveter lock-up?
  131. springs / tire question.
  132. Stuck in mid 11's
  133. brake light on after sjm line lock and abs delete
  134. Need advice about my new tune
  135. Clutch issues need advice
  136. Im looking for part numbers
  137. WARNING LOTS OF PIC! 370 CI build
  138. Percy's Speedglass
  139. Finished with the scales. Let me know your thoughts.
  140. Question about fbody Convertible race cars???
  141. MT DR's vs MT Slicks
  142. Pinion angle help please. In the middle of setup
  143. Best deal on front drag brakes?
  144. Wolfe Race Craft - Mid Year/ 4th July Sale - 10% OFF
  145. Delete all PCV system?
  146. Front swaybar!!!!!
  147. What tire pressure for skinnies
  148. installing carpet around cages
  149. What Gear Oil is everyone using in there 12 bolt rearends
  150. Trans cooler????
  151. is this tolerable?
  152. Tucking 325/50/15s...
  153. Finally, new 2009 Nitrous combo is done.....Pics within
  154. set caster as far positive as possibe??
  155. 355 LT1 break in! What oil to use????
  156. Wiring to Air Bag Module Delete
  157. unleaded racing fuel
  158. Carpet
  159. power steering?
  160. Got our new trialer. Big!
  161. 126mph trap speed....
  162. Come inside 6 speed drag racers
  163. Mickey Thompson Et Radial wear markers
  164. 26 or 28 inch tire?!?!
  165. I may be joining the darkside(m6 to Auto)
  166. Front skinnies? what tire
  167. 25.5 "6C" bar question.
  168. any stock consoles and electric shifters?
  169. ET reduction with 1 7/8 headers??
  170. How much gain from a little weight loss?
  171. As you burn fuel, what happens to your sixty foot?
  172. Drag bars. Weld in or BMR setup?
  173. are rubber hoses nhra legal?
  174. What kind of 1/4 mile time would you expect to run with these mods?
  175. ARP-2000 LS main studs
  176. top end speed way down ???
  177. 02 Fan wire?
  178. need help w/ 60'....vids inside
  179. Wolfe Race Craft - Sale on In Stock Roll Bars and Roll Cages
  180. 12 Bolt what E.T. do they start to break?
  181. What do you guys think?
  182. lost power?
  183. Made first passes at a track last night
  184. MSD box
  185. what size front wheels?
  186. anyone sell block adapters for a remote ewp?
  187. Launching without twisting
  188. 5pt harness certification
  189. Burkhart's Dog Days of Summer Sale
  190. 3.70 or 3.89 with 150 shot with....
  191. Anyone know board member "1cdub"?
  192. Shifter Wireing
  193. Proper way to scale a car???
  194. 10 Sec Street Build
  195. help please need advise on lifters lt1
  196. Carbureted or EFI
  197. Besting a 1.8 second 60'
  198. What is a Good Harness?
  199. am i getting my tires too warm?
  200. Is it possible
  201. Properly cooling down between runs?
  202. A goldmine of info on launching a drag car in here! Very long.
  203. racecraft drop spindles
  204. Ordering a Spohn Drag Bar
  205. UMI TA Location on BMR Trans Crossmember Relocation Bracket
  206. have torquer 2:now ms3 or ported 92/92
  207. 6.0l 427?
  208. Cruise Control For Line Lock Button?
  209. LS1 water pump heater core hose block offs
  210. Our new Jaz seats have covers now!!
  211. wheel spinning and tires off the ground???
  212. Do I need an underdrive crank pulley when running an EWP, no AC, or power steering?
  213. Finally going to the drag strip
  214. k-member gusset
  215. Battery relocation with pics.
  216. wolfe spring relocators
  217. Suspension Guys, put subframes on the car=hard as Heck to hook
  218. Rod End Size on Wolfe DA LCA's
  219. Q's on 275-40-17 DR's 6spd cars
  220. My car is in the August issue of GMHTP magazine.
  221. Finishing my suspension mods - Springs/Shocks, Bags/Sway Bar?
  222. how to launch with radials and moser 12?
  223. Another guess my time slip
  224. weather da difference
  225. 28x10.5
  226. From 440 to 300 lb. front springs on a 50/50 shock, difference?
  227. Which Race Shifter to buy for 2000 Camaro?
  228. trapping 125mph in 1/8
  229. Any pics of Burkhart rear w/sway bar option installed?
  230. Roll bar foot/floor plates.
  231. Heater hose mod and 28" Slicks
  232. 4000 stall / 100 shot.
  233. hoosier qtps
  234. Stealth Pro Ratchet Shifter YOUR THOUGHTS
  235. New rear coming, what else would I need???
  236. T-brake button mounted on factory steering wheel?
  237. Another spring rate ?!!
  238. new tires worst 60 foot.
  239. Grinding Calipers.. (Thinking about 15" Setup)
  240. 10.5 EZ Street build
  241. True Street Set up...
  242. Night Racing
  243. almost there: part 3
  244. drag seats in a street car
  245. Can you patch a MT Drag Radial???
  246. 2006 EVO IX MR, 128,000 miles, at the drag strip
  247. NA 347 Exhaust Backpressure Measurements
  248. Back Half, fab 9", 4 link Build (with pics)
  249. What do you think?
  250. New Drag rims on Greg Welds all around :)!!!
