- Hurst quarter stick pistol grip/ 4L60 type installed
- for thoes who have a EFI vic jr intake
- which helmet
- Which tire to get?
- Any other Rear suspension needed?
- stock weight
- How many of you use a "blinder" at the tree?
- LS1 TH400 flexplates...
- cowl reinforcement?
- Door bar/support removal
- Need Help with Weld Draglites
- midwest chassis th350 crossmember **pics**
- Cracked my windshield, questions on Lexans glass
- Give me your guess
- Changes in the shift pattern...
- ICE Ignition Components and Electronics
- C5: While replacing the clutch, what else should I replace while I'm down there?
- Our custom HVAC delete panel
- Anyone have pics of lexan "side" windows?
- Anybody using these Kirkey seats?
- m/t drag radial question
- 325/50/15 MT Drag Radials
- The truths on dash/heater box removal!!
- Best price on MSD 6010?
- Comp Cams Joins EFI Hot Street for 2009!!
- WRITE-UPS:wire mod-remove DRL and EXPRESS down WINDOW module
- Anyone have the door bar bolt "tool" I can buy or loan me?
- Driving in the Rain with No Wipers
- Wolfe 10 point install starts Saturday a few questions
- Look here for drag tech stickies, they are in here!
- Weld 2.0 one piece stars
- Tip, Lightweight Battery on the cheap
- 2000 trans am backhalf build(pics)
- Those of you with 347's that are NA
- What spares do you keep??
- 1,417 HP Naturally Aspirated
- Rear Drag Wing
- torque arm, long or short?
- What should he run
- trans brake questions
- How to hook on 17" wheels
- Called Burkhart and AJE = Nothing
- 1.5 backspace prostars
- OK, got motor plate in, what about WP, Alt., etc...
- quality drive shaft?
- Does this sound possible? Cam only vert
- strange vs. qa1
- Burkhart Anti Tax and stimulus package
- Parachute protocol?
- Help with battery relocation! jumping gauges
- lexan install/stock removal
- Ozite
- Street driving a Wolfe Anit Roll bar
- Winter Mods need input
- help with cam selection
- How low can I go????
- verts at the track!
- Rear Cover Hitting Upper PHB support
- How much do you guys think ill gain ??
- setting adjustable front a-arms
- manual brakes question
- 2002 Black SS Camaro Rolling Chassis with LOTS of parts!!!! 3500.00!!!!
- 2004 GTO ABS/Booster delete
- Water Pump Studs for a Motor Plate Set-up?
- Is this rear seat brace legal??? LOOK!!!!!
- Converter Stall Help
- Legal valve stems for ZR1s
- question on a fast 90
- Need 2 get in touch w/ Madman!
- Billet Specialties Comp Series Race wheels
- strange front shock install
- Shocks ????
- What did you pay for your TH400?
- Burkhart site has been updated
- LPE 2 step users come in!
- Englishtown crew....
- Anyone have pics of weight they have took off the fron of there TA
- anyone have there valvestem locks fail?
- First steps into messing with the suspension.
- Gears for MWC FAB 9
- Anyone run these new Centerline wheels yet? or atleast tried em on?
- Need a 10 point roll cage
- ET difference from Trans Am and Formula hatch
- F-Body Engine diaper pics are up
- rule book handy? exhaust location
- Changing tire size ?
- Trans & Rear gear help
- noob slick questions...plz help
- cromemoly cage ?
- drag setup
- Switch panels....
- weight reduction question
- Hoosier 335-30-18 vs. MT 345-35-18 DRs
- Motor plate, from whom?
- Help please on launching.....
- ??? wanna REMOVE the BCM like some have. anyone have PINOUTS to the BCM.....
- Best place to get a strange 12 bolt from
- Fbody windshield
- those you who wennt lexan what did you do with your old windows?sell? keep?
- Percy's front drop-ins
- Weight transfer
- Help w/ adjustable settings on my set-up
- Light weight spindles
- inverter vs generator
- cutting metal undr the hood questions
- DOT radial or bias ply?
- Fabricating sheetmetal Intake??
- 5 point harness guys
- Battery Relocation Wire Help
- 25.2 started...Pics of flooring & suspension
- almost done with mini tub (pics)
- Lightest "race" Battery but still good for summer DD?
- Braille battery or relocate?
- Burkhart LT1 Camaro Bumper Support
- how to get 60 a foot in the 1.5's?
- Best throttle body setup
- Help with rear suspension set up!?!?Please!!!
- kirkey seat cover wanted. please!
- carb with stockcomputer
- Paul Majors Updates Revelead
- getting ready to install wolfe 10 point a few ??
- Fastest doorslammer 5.738 pass?!?!?!?!
- Will a Mickey Thompson produce a better 60' than a BFG?
- bracket racers please come in
- skinnies vs 90/90
- 1SC stripper build
- AFR 225cc Small Bore With 233/239 595/603 Cam
- Question best bang for the buck? LS2, 6.0 truck?
- Need some help hooking up
- 14.3 very slow camaro !!!!
- stock suspension rules legality
- My Camaro racecar build
- th350/cheetah shifter question
- 17-35-315 BFG T/A VS 15-60-275 slick
- Ford F250 & fuel mileage
- ORSCA Hot Street Registration
- Sad
- Susoension Guru's Inside : Madman, BMR, etc.
- lemme see them 4th gens with wheelie bars
- double adjustable rear coil overs
- Hoosier QTPs scarey!!!
- Engine Diaper, where to get one?
- Whos in for a LTX vs LSX Grudge match
- welding in a bolt-in 6 point roll bar ?
- A/C delete
- Pics of your Lexan front window and advice
- Extended TA hood
- Switch panel and gauges in radio compartment
- ABS delete help
- 15x9 ?
- After Market A4 Shifter
- Brake line Kit?
- Just a couple basic LSX N20 and drag race ?'s
- Switches on Pedals..
- side mirror removal plate?
- Tubular upper a-arm weight savings
- Set my pinion angle today
- Diagram for Body Wiring Harness
- ???more weight removal questions
- narrow no tub
- welding and painting rollbar?
- what studs?
- What slicks on my drag car?
- S-10 etc.
- SFI approved Engine Diapers
- need help
- quick release steering wheel?
- Percy's tinted rear group purchase
- Comp Engineering Front Motor Plate
- iron block alternator tensioner
- new 6 pt rollbar
- What do You think is it worth it?
- m-6 to th350
- mini tubs
- Cold weather launching
- To Much Voltage I Need Help
- Any sponsors sell a full battery relo kit?
- how to remove sound deadening material and...
- Show me pics of your VFN cowl hood..
- back spacing help
- BBC Question
- Kirkey seats
- Dimensions on Sunoco hood?
- NHRA Legal Battery Relo... Questions
- Morel/Lunati pre-load.
- Enclosed or open trailers. come in
- My Big race
- anyone have radiator mounting pics?
- Fastest cam only guys...10 bolt/12bolt/9"?
- 24ft trailer question
- S&W roll cage 10pt
- Billet Specialties street lites powdercoated black
- So I have a question (seems slow for the mod list)....
- 8.50 cert without struts from main hoop?
- project dumbass,finally done
- 2500lbs will i hook or wheel hop??
- moterplate question
- Torque Arm Pivot Plates
- th350 crossmember
- Registration is now open for EFI Hot Street!!!
- Can i see a few...
- 15X8 vs. 15X10 wheels...
- Are 325/50/15 overkill for my setup?
- You with me on this????
- ls1 n 90 coupe mustang ????????????
- Steel VS Cromoly rollbar?
- Steering Wheels
- Corbeau Forza Seats
- 315 17's tt2 vs. 16" snowflakes
- What are the average Time's for a bone stock 02 SS A4
- any of you guys removed your trunk area?
- 275 Nitrous Class for 2009 Shootout????
- question on these motor mounts
- what's the smallest radiator size for street driving?
- This section is dangerous
- Want: Low 10s, but can I w/what I have
- Mount pics of BS3 or XFi box(s)?
- strange DA front shocks - where to start ?
- 8 point going in..pics
- Accufab 4500 Carb Style TB or 115mm TB on front of intake??????
- Eibach Drag Launch Springs
- Looking for ANY and ALL suspension tech threads you may have saved
- Got torque arm/shocks/lca/suspension questions about Fbodys? READ ME FIRST!
- Removed your visors? Check this out
- Could it be the weather?
- Stock internal header size?
- who makes this seat?
- noise when turning
- removing gas tank for rollbar?
- Does anyone make this fuel fitting?
- Too much weight on RR caust it to drive left?
- Raptor camshaft from Thunder Racing.....who has info on it
- comp engineering shocks?
- got awesome dyno numbers and now off to the track
- Bassani Race Mufflers, anyone run them?
- Mini-Tubbed Cars... What Carpet?
- Going to the track tomorrow in my H/C z28
- Installing Spohn drag bar tommarow. Question!?!
- STOCK INTERNALS setups
- Bump stops
- Why is flashing your converter off the line sometimes better?
- 10pt Wolfe RollCage Install w/pics
- ls1 two step installation
- where have you raced and how was it?
- Torque converter questions
- 2009 Chevrolet Corvette ZR1 Vs 2008 Shelby GT500 Super Snake
- My car run 12.5 what will this cam do
- gutting the underside of the hood
- Accufab 4150 TB applications
- drag stall setup ?
