PDA
View Full Version : Drag Racing Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103
  1. 3.5" steel or 4" aluminum driveshaft?
  2. What's the best setting for konis at the strip?
  3. Anybody Running a Throttle Stop?
  4. Any problems with underdrive pulley and big HP?
  5. Who has run a stock stall on a cammed car?
  6. Trans Sheild
  7. Burkhart Chassis Bumper Support ?'s
  8. msd 2 step launch controller
  9. Battery Relocators COME IN!!!
  10. Rear end walks when shifting?
  11. Launching a M6 with linelock ?
  12. Best place to mount a tach without cage?
  13. Will the Eaton Posi hold....
  14. auto owners your NA times w/ NA stall vs NA times w/ nitrous stall
  15. Racers post up your vinyle wraps
  16. screwing radials
  17. Insulation removal for access holes for trans bolts
  18. Tinted windows
  19. Are alloys wheels much lighter?
  20. How about this gear/tire/converter?
  21. Glen burnie racing
  22. help me hook...
  23. Expected gain with ported heads?
  24. updated pics of rear tire clearance.
  25. Parachute Bumper Support Bracket
  26. pictures of speedglass windshield installed plz
  27. When the rulebook says,
  28. Really bad E/T's 14.1...... A4 trans
  29. lets talk water pumps
  30. Broke my Nine friday night
  31. Ugh, rear lexan install didn't go well, need advice
  32. Kirkey seats
  33. firewall plate after dash and hvac removal?
  34. When you switched from m6 to auto how did it effect your mph and times?
  35. Will 4.11 help my 1/4 ET, put me in the 10's?
  36. looking for seat advice
  37. Slowest LS-1 ever!
  38. Pics: Do I have enough clearance??
  39. LCA Question
  40. need help where to look why I lost over a second and 14mph loss at the track today?
  41. Electric Radiator Fan?
  42. TH350 setup to use all three gears in the 1/8 mile, quicker than just two gears...
  43. M6 TrueTrac roll call *Update spool>truecrap
  44. anyone modified the stock sending unit for #10?
  45. Why a somewhat lower stall is recommended for nitrous?
  46. my bumpstops are missing?
  47. I still can't understand why auto' w/ stalls would be faster than a manual besides...
  48. dream desk pic
  49. Gauge pointing to discharge after run
  50. car is slow :(
  51. 325 mt dr pics
  52. From 28x10.5/15S ET Drag to 325-50/16 ET Street Radial = Mistake?
  53. How hard is it to make your car work on 17" drag radials?
  54. ET streets when can you tell if they need replaced?
  55. 26 vs 28 vs DR's vs gearing = trap speed
  56. Are our horns like kidneys?
  57. 28x10.5-etdrag tire pressure M6
  58. stall ?
  59. Big thanks to MADMAN
  60. If I'm just doing 1/8th mile wouldn't 2.5 STR converter be the best option
  61. help with rear studs
  62. Suspension Unloading At Launch..? (Vids)
  63. how front SEAT BELTS come out???
  64. Talk to jim at jim racing tire
  65. Need help with my a single digit N/A setup.
  66. Help with Front shocks
  67. Drag racing change to either a PG or th350, I can't make up my mind
  68. UMI or Wolfe Drag Bar?
  69. proper mounting of 5 point harness
  70. 11 Sec. Bullet Proof M6 F-Body Build List
  71. How do people get sponsors
  72. rollcage rule
  73. wheel stud question
  74. Me vs a 383 stroker "tonight" need help!!!!!!!!
  75. Chassis table leveling questions
  76. Window net question and harness question
  77. Shoulds spool and 4.56's help 60 ft
  78. Need racing suspension help!
  79. Really Pissed At UMI
  80. Burkhart Chassis - Chuck's brother passed away
  81. Rear Bumper Brace
  82. Manual Fans Question
  83. Need help with rear wheels and tires?
  84. abs delete results.
  85. What are the inner rear fender vents for?
  86. front and rear shock and spring set up
  87. Aftermarket steering wheel pics
  88. 60' time difference between ET Streets and slicks?
  89. Can't seem to get a good 60' out of it.
  90. BMR Fabrication Launches New Product - 2010 Camaro Trailing Arms (TCA026)
  91. Rear drag shocks
  92. Beware of bogarts-May come apart at high speeds and low speeds
  93. LS1 Drag Racers: What Headers Are You Using?
  94. electrical pin out needed for drag harness
  95. Link-bar lifter question
  96. QA1s vs Strange single adjustable rear shocks
  97. A4 vs A3 Gearing
  98. IF you foot brake an A4
  99. Fuel Cell Questions.
  100. wheels slowing 1/4 mile time down??
  101. Drag Tire Help
  102. hookers vs. kooks
  103. tell me what i am doing wrong
  104. m6 launch, when do I shift to 2nd gear?
  105. Optimal Converter Stall Speed / Shift Ext.
  106. Mickey Thompson Drag Radial Tire Pressure Poll
  107. Mickey Thompson Drag Radial Tire Pressure Poll
  108. Questions on removing metal weight from interior
  109. Rear Drag Suspension Setup for high 9s/low 10s
  110. Remove ac but keep heater?
  111. MPH on gaunges went out
  112. Missing MPH in the 1/4...Help
  113. Before and After Pics of my Car With Weight Reductions
  114. wtb greg weld skinnys
  115. New best with bolt ons
  116. I need sugestions on a full race suspension
  117. Converting alcohol carb to gas
  118. what solid motor mounts for a PA k-member?
  119. UMI Performance Releases 1.250" Rear Drag Bar
  120. Battery to the back...Drivers side??
  121. Need help with 60'
  122. Suspension Help! Unloading?
  123. Harlan shift light/Battery shut off
  124. LPE LNC-001 and M/T ET Streets, advice?
  125. Helpwith wiring accufab sensors
  126. Help my car 60 1.3X
  127. video inside. help my take off please!!!
  128. Master electrical disconnect problem, alt exiter not shutting off car
  129. Updated c5r pics
  130. NOS launcher- who's using it
  131. Cam only, won't MPH!?!
  132. Grinding calipers
  133. Constantly adjusting LCA's
  134. Attempted burnout in waterbox, UMI torque arm snapped, set off airbags...
  135. NOS mini progressive and 2 step help
  136. brake and tranny cooler questions
  137. Traction: Wider or Taller??
  138. Midplate and off the shelf headers?
  139. what flexplate for a 6.0/th350 combo?
  140. Thinking about taking roll cage out
  141. 15*10 drag wheel ?
  142. 28x11.5x16 ET Streets
  143. Rearview/sideview mirror options - Bracket racing
  144. i need some pictures of the mike moran hood on a camaro
  145. ? about springs??
  146. Front suspension question
  147. narrowed rear and 275 radials????
  148. M6 60' troubles, suggestions please
  149. M/T ET Street DRs.. Tire Pressure Questions
  150. Minimum pinion angle for the track
  151. BCM Delete
  152. Help! car unloading suspension after launch...shock settings?
  153. LPE LNC-001 Video
  154. Bolt-on guys what do you have for shift points and rev-limiter
  155. 27" front runners
  156. Opinons on rear support delete only for now.
  157. Drivetrain Vibrations
  158. Important info about using BS3 with 16V systems
  159. what transmission mount for th350?
  160. need feedback on Strange SA struts
  161. Which Tires should I use.
  162. Burkhart Bumper Support and Manual Master sale LSX Shooutout preorder
  163. quarter mile help
  164. quarter mile help
  165. Last question, A4 vs M6 weight?
  166. weight of stock front seats?
  167. Newbie with AC removal questions....
  168. Trans brake ? w/ spray on a N20 vert.
  169. Anybody run a clutchless? Liberty perhaps?
  170. NGK TR6 plug gap???
  171. 275 Guys...a little advise please
  172. Help with suspension!!!
  173. Shift points?
  174. The Rookie vs. the 25.5 project.
  175. Roll cage question
  176. Dzus
  177. Help.. where to tap Super Victor intake for vacumn
  178. This could be good Legal street racing
  179. whats a good tire pressure
  180. Help determine tire size 26 or 27. Info listed inside
  181. thoes who has a PA Racing kmember, i have a question
  182. QA1 rear coilovers
  183. Joe Van Overbeek parts?
  184. Kind of not thrilled with last track visit
  185. Meziere Race Water Pump Inlet Hose?
  186. Selling my car
  187. Non-electric seats...
  188. what gear to run?
  189. Warm Air vs. Cold Air
  190. Surest way to get my car into 11s
  191. Gear Vendors install started today on my '98 TA........
  192. lightweight carpet Q's?
  193. How Close Can Helmet Be To Rollbar?
  194. Is is possible? (without spending my years wages)
  195. BS tire size's from M/T
  196. More mods, better DA, but slower, confused...
  197. 672BBC Twin turbo O/L 10.5
  198. Subframe connector's question for the big boys
  199. Weighed My Pig of a Trans Am Today....
  200. stock 00' T/A shift points
  201. Did i need a DS Loop?
  202. About ready to order my rear end just had some questions...
  203. Welding A Rollbar To The Plates
  204. Couple quick pics of my Camaro project
  205. Madman or burkheart manual brake support bracket pics?
  206. Manual brakes on DD
  207. weird power steering issue
  208. Carborated motors whos running one??
  209. carb setup, straight or sideways what do you guys think???
  210. Burnout paint protection
  211. southern Il 275 race
  212. need help with car
  213. 6 point cage plate size needed my cage didnt come with them and need to know correct
  214. roll cage question
  215. How does "open comp" work?
  216. Virginia Speed Crank Trigger Bracket
  217. Feedback on Haulmark Trailers?
  218. Anyone Running a Super Shield?
  219. Article: Mark Koehler's 7 Second LSX Firebird
  220. What pinion angle works best for you?
  221. Budget LT1 race car build!!
  222. Lingenfelter vs MSD's 2-step
  223. Speed Inc Molded Carpet Weight
  224. What kind of certification is needed for going a little under 9.99(6.40)
  225. How much does the tube from a moly 25.2 weigh?
  226. Need setup help...
  227. How does this setup sound to yall?
  228. Help getting out of mid 13's????
  229. Help with bad tire rub.
  230. Hey JL ??? about PCV delete
  231. qa1 front springs?
  232. stuffing 28x10.5x15 Slicks ( needpics of were to trim bumper and rocker
  233. GM splined Grant quick release issues?
  234. What pin on hood?
  235. cutout before and after results..did you gain anything?
  236. QA1 settings...
  237. Need a cheap Snell approved helmet anybody know where to get one?
  238. Those with looped rack...come in!
  239. M6 60ft help
  240. Mcleod street twin. Aluminum flywheel or Steel? Wheres the best place to buy from?
  241. what gears for my turbo impala?
  242. which qa1's for me? F's, or R's?
  243. Carpet
  244. Going From ym 17" TTMs to my stock 16x8 rims..
  245. rt 66 speedway
  246. LNC-003 clutch switch hook up questions.
  247. Attempting to remove front swaybar...uh...
  248. Converter ?
  249. How fast have you gone on street tires
  250. What Drag Radials!
