View Full Version : Drag Racing Tech
  1. First time at the track, results, Q's, and vid
  2. what would happen
  3. Is it likely to get into 11's with bolt on's?
  4. Need: Strange Rear Brakes (Drag): Do They Make These?
  5. Gauging Intrest In Build Thread
  6. Chassis ?'s and Bmr xtreme TA
  7. Shiftpoints
  8. front sway bar question
  9. UMI lowers and Aerospace brakes....clearance?
  10. QA1 or Strange vs. Koni SA for street/strip?
  11. Weight Reduction: Removing HVAC/Heater Core
  12. SFC or TA for Full Bolt On
  13. rear view on lexan windshield?
  14. Happy Birthday Shawn Miller From Va Speed
  15. adjustable sway bar
  16. Front bumper delete. Did it help
  17. Shield needed on helmet to run 9's @ NHRA facility?
  18. How many of you are on 10 bolts?
  19. Cut 1LE Springs vs Stock
  20. New drag wheels from Centerline: Will not clear brakes.
  21. 1/4 and trap times
  22. The Nightmare Is On The Ground!
  23. MT Drag Radials in stock
  24. 13.6 at 107 then what about now....
  25. Completely stock other than weight reduction?
  26. How do you launch your stalled auto?
  27. What are your shift points/limiter set at ?
  28. 28inch tires
  29. New rear end housing for the Nightmare
  30. Rear End Housing For Sale
  31. MT ET streets with stock suspension?
  32. one goal.....a wheelstand
  33. Nasty gas tank replacement info..
  34. trans cross member bolt size?
  35. big block car weigth
  36. Ported TB
  37. Mods & Weight Taken Out Of Ss!!!
  38. Rim width Question
  39. Stand alone harness?
  40. Anything else to pull while pulling front bumper reinforcement?
  41. How much do they weigh?
  42. Billet Specialties wheels to fit STOCK ls1 brakes
  43. Got some parts!!!!
  44. Brakes Dragging - E/T
  45. WHat gear do I need for the spray?
  46. Whats my 1/4 mile time 99 ws6
  47. 60 ft KILLING ME. M6 guys help please
  48. Pin On Finally Painted
  49. Front Fender Mod?
  50. Got some new GOODIES!
  51. towing brake controller... tekonsha p3 or prodigy 2 or???
  52. How to minimize 60' w/ my setup?
  53. P/S Delete Pics?
  54. The 47# housing from Burkhart Chassis
  55. black bitch update?
  56. Burkhart A-arms
  57. TA question
  58. NE1 got any advice for wheelstands???
  59. Torque Arm Question
  60. Losing MPH
  61. Weight difference between a radial front runner and a bias-ply?
  62. new drag radial break-in
  63. Brake bias w/strange master cyl.
  64. plan on killing some myths...
  65. Best 60' on street tires
  66. Is it going to 60ft.?
  67. How Much Do Hotchkis Subframe Connectors Weigh???
  68. Racing without an alternator
  69. roll bar + SFC question
  70. Question About ET
  71. Electric wires removal?
  72. Spohn vs. BMR torque arm
  73. Will Adjustable Shocks make that much differnece?
  74. How much gear????
  75. New Madman & Co. T-shirts Are In!!!
  76. any sponsors carry M&H tires
  77. 4L60e and 4:11's w/ 325/50 MT's
  78. Cant get a good 60ft!!!
  79. what's the potential?
  80. red smoke coming out of exhaust.
  81. Technical Issues...
  82. How much N20 for launch?
  83. Launch rpm for 3,200- 3,800 converter guys?
  84. Going slower after TH400 install
  85. Help with ET Streets - Trouble Hooking
  86. Rim Screw Question
  87. Stroud Safety Harness and AFCO's in stock
  88. converting lsx over to a digital 7 ignition
  89. Qa1-r ?
  90. gained 40 RWHP why not 4 MPH
  91. My new project with minitub pics
  92. rear view mirror with lexan?
  93. got new toys the other day! pics
  94. MT DR 295/65/15 One set
  95. What RPM should i leave at??
  96. Y Are Cooling Fans In Weight Redution If U Need Em???
  97. Patching Drag Radials
  98. TH350 trans guys need some help here
  99. SHOULD I RUN 12s WITH THESE MODS???
  100. Whats the Fastest Twin Screw car?
  101. anyone with LSX 454 ET's yet?
  102. Traction Issue
  103. 1/8 mile question
  104. bias ply on back and radials in front
  105. Pics of my home fabricated LC relocation brakets
  106. DOT approved front skinnies
  107. Need LSx swap suggestions.
  108. Are 3.90's worth it
  109. Harlen 2step
  110. Burkhart housing for sale
  111. Biggest Drag Radial You Can Fit.
  112. Extended cowl guys come in
  113. Drag radial air pressure ????
  114. Carbon Fiber
  115. 28x12.50
  116. remote water pump, where does belt tension go?
  117. One Burkhart front end kit ready to go
  118. car is spinning!
  119. Clearance Rear Fender for 28x10.5W's
  120. Weighed my car!
  121. M/t 295/65/15
  122. on the average
  123. wheel studs
  124. Switching to Weld draglites/325's and skinnies.....
  125. Anyone using the QA1 Stocker R front shocks?
  126. helmet ??'s
  127. 29.5x10.5x15 on a Trans Am inside please
  128. Looking for traction, can I get some help
  129. 28x10.5x15S et drag
  130. Best glue to bond aluminum to carpet? Ozite users?
  131. Aluma Star and 5/8 wheel stud issuses
  132. can i take the rear spring isolators out with 28x10.5's
  133. When should I shift?
  134. Going to the drag strip in 1hour 30mins
  135. Best Style Safety Harness?!
  136. Burn out help Please>>>>>>>>
  137. Atlanta Pinks All Out Air Date
  138. MT 28x10.5W vs. 28x13.5 ET Street... any big difference in durability?
  139. Battery Relocation Problems! Please HELP!
  140. Where can I find Mickey Thompson's et street radials for sale?
  141. stalled autos, do gears help much?
  142. Question about my drag setup
  143. Can anyone tell me what a stock C5 Z06 runs?
  144. pics of your charging lugs on outside of car
  145. ? about 10 point cage in 4th gen F-body
  146. One Burkhart stock length housing ready to go
  147. Changed Mind!
  148. fastest
  149. Drag datalogger
  150. Fast Drag Radial guys...looks like SFI is addressing the 3200 lb issue
  151. roll bar question
  152. Hoosier QTP Drag Radial??
  153. What steering wheel would you go with?
  154. 18" Drag Radial Times
  155. Mickey Thompson Drag Radial Back Order.
  156. Battery in trunk pics please
  157. PCV System
  158. What spring to run for rears?
  159. Just installed V6 springs/comp engineering shocks
  160. Question about AFCOs?
  161. Leaky reservoir on Strange master?
  162. Fire Surpression systems, mounting nozzles
  163. Currecting Pinion angle?
  164. stall and rear question?????
  165. 60 ft help over all et help dial in
  166. Could Use the Opinion of Some Veterans
  167. Suspension Gurus, in here.
  168. Any pics of rear brake lines with Strange brakes?
  169. Bogart - Washers?
  170. Still have wheel hop "& its worse now"...
  171. Weld-on 6 pt. rollbar install...HELP!
  172. Wheel Stud Removal
  173. Moroso Update - Great News on Track Surface
  174. loosing .2 and 4 MPH = getting new brakes (long story)
  175. Anyone running MT 29.5x10.5 @ 150mph with a manual tranny?
  176. first time with a 6 speed
  177. ABS Delete - Any computer changes required?
  178. quick drag bar ?
  179. My SS is Gone, and I got ANOTHER Blue SS!
  180. Help Please with my Batt Relocation
  181. aluminum radiator question
  182. 1/4 times? What size mt would help?
  183. ASR delete?
  184. TH350 vs T56
  185. Remote mounted water pump fittings?
  186. Burkhart Chassis will have a booth in Joliet this weekend
  187. 5 point harness question
  188. More voltage issues...could I be slipping a belt?
  189. Pinion Angle yes i searched and read and
  190. ms4 owners help me figure my launch
  191. Where to get Carbon Fiber sheets?
  192. Battery Relo and CCA?
  193. Guys running Nitrous and a PowerGlide Trans *Need Opinions*
  194. will the SS hood slow a car down?
  195. Flowmater Delta Force mufflers off pacesetter headers..dumped
  196. What RPM will i be crossing at in the 1/4...
  197. whos car is this?
  198. Just another way NHRA has their collective heads up their collective asses.
  199. C5 rear drag tire option.
  200. 6 point bar and stock seat?
  201. So what do you think of the new 1000ft racing
  202. Balast
  203. tire chioce for 16" rims
  204. Tru Dual peeps...
  205. Update to my voltage issue....
  206. BBC 4th Gen What Oilpan??
  207. Time estimate for my 1SC?
  208. Wheel stud of choice? 1/2"
  209. Rear Hatch Lexan
  210. travel limmiters
  211. Rear firewall
  212. fender lip issues
  213. Door support bars
  214. Going to the track soon
  215. Luck with Mickey T's? NITTO's DR sucking right now....
  216. Sway bar Question
  217. 11.50 camonly
  218. NHRA announces Safety task Force...
  219. Crank Trigger Input Needed Please
  220. Burkhart now carries Chiseled Performance Intercoolers
  221. LCA Relocation Brackets
  222. What should my car pick up between 1/8 and 1/4
  223. Got my car scaled!
  224. Should I take this bet?
  225. Racecraft Inc. Group Purchase
  226. Price Increases
  227. ET problems
  228. !front sway bar? Will it hurt anything?
  229. quick release steering
  230. Who builds a TH400 that fits a LS1....
  231. help identifying car
  232. 2009 CAMARO PRO STOCK? Check it out!
  233. Help on adjusting a 4link susp.
  234. Belt for bypassing A/C, Pwr Steering, and alternator?
  235. 1/4 Mile ET Improvement From Cutout?
  236. Burkhart 6 point bar with swingouts KIT
  237. Help with getting my 60' better and stop some spinning.
  238. Lookin for 325's
  239. Radials w/ Bias Ply
  240. m.t. sportsman fronts - 26"x7.5" radial - speed rated, 4 ply
  241. 28x11.50x16 ???
  242. Anyone use a fuel cooler?
  243. Qa1 fronts ride height ? need input from you racers
  244. "Quiet" 4" muffler?
  245. transbrake slicks
  246. Tire Height ????????????
  247. Is this Mojave heater the one everyone is using?
  248. Anyone ever race Stock/Super Stock with an LSx based car?
  249. Greg Weld Weight
  250. IHRA rules on t-tops
