View Full Version : Drag Racing Tech
  1. IHRA rules on t-tops
  2. autometer gages
  3. Are these the right closed ended lugs for my prostars?
  4. 420rwhp ss3600 stall 2.73's
  5. 4.56 4.71 4.86 All M6 Guys!!!!!!!!
  6. RCI Platinum 5-pt Harness
  7. LS Motor Plates
  8. question about torque specs and driveshaft???
  9. My new Burkhart 9"!!
  10. rebuild the 400 or go glide
  11. New distance for Funny Car and Top Fuel
  12. Bolton car, is a INTAKE MANIFOLD A BOLTON?
  13. how bad does a Dirty airfilter hurt performance?
  14. Help with how to launch.
  15. Stiff sidewall slick VS. Standard sidewall slick
  16. Little help on shift points for my setup
  17. ac delete questions
  18. 429 whp
  19. Which DOT tires for big wheelies?
  20. madman SYA bars
  21. Carpet?? Where to buy?
  22. Does any of sponsors offer MT tires?
  23. Hood pin placement - need help and pics
  24. Header extensions
  25. What Tire Sizes Do I Need?
  26. glass hood guys, any reason for rails vs brackets???
  27. Wheel Studs
  28. Stock length rear + Bogarts + 295's = ???
  29. Burkhart Chassis Housing sale
  30. Backhalf 85 RX7, need input.
  31. tire scrub..
  32. Shock binding on mount, better brackets?
  33. SYAB don't fit
  34. Which wheels? Telstars or Convo Pro's? WITH PICS!
  35. th400 shifter and light weight carpet, help me figure out what I can dump
  36. about to goto the track for the first time with this setup
  37. Need traction asap....
  38. Can I run DS2's with DR's?
  39. Remote/inline water pumps...
  40. driveshaft weights
  41. Another home made ram air kit (lots of pics)
  42. Pulled dash, car won't start
  43. any m6 guys use a tranny blanket?
  44. 28" tire, m6. gear selection?
  45. need some help/advice with Hooser 28x10x16 tires
  46. Burkhart 6 point bar with swingouts
  47. Track Temp and how it effects hooking
  48. ET Radial vs. ET Bias ??
  49. M/T 28X10.5X15S Tire Pressure
  50. New set-up, tell me your prediction!!
  51. VFN 4" Sunoco pin on vs 4" Cowl pin on
  52. 1995 camaro wont 60ft..
  53. Race only electric water ?
  54. 93-02 Camaro Spoiler
  55. car insurance coverage for racing!
  56. my new set up blows
  57. Cannot keep voltage up! Arrrrgh!
  58. Will an LS1 run without an alternator?
  59. [Drag radials]255/50/16 M/T vs 315/35/17 BFG
  60. ET Streets or ET Drags for M6?
  61. Suspension Help - Vid
  62. What skinny tire for fronts in Street Tire Classes
  63. MT 26 x 11.5-15 ET Street (Bias Ply)
  64. cheap dual bottle mount?
  65. wiring for srs
  66. proper way to prep slicks
  67. Pics of my Dual Nitrous bottle setup, Midwest Chassis parachute....
  68. Bogarts
  69. Building your own headers?
  70. 1/8 vs 1/4 mile
  71. Some track advice for a noob : )
  72. Front to rear weight ratio ???
  73. most you can narrow w, stock placement LCA's?
  74. What gain should I see from 4.10 to 4.56
  75. Would this battery work?
  76. tire/rim combos
  77. Race Craft Spindles installed! Pictures and Writeup.
  78. TH400'd Nissan Skyline GT-R33 !
  79. anyone tried the updated GM flexplate?
  80. Trying to get this 6 speed car to hook
  81. 60´ question
  82. ss3600 What kind of 60' times?
  83. what weighs more
  84. rip scott kalitta
  85. Had to cut this section out to clear my 325/50's, is this ok?
  86. Trans am VS SS question
  87. Carpet question, after cage...
  88. Need some advise on launching
  89. Car Hauler - Securing Car to Trailer??
  90. how much weight saving do i get from swapping....
  91. looking to buy race seats & harnesses in near future who all makes them?
  92. First time to track and some DTC's
  93. New Radiator Question
  94. Got some new toys today
  95. Any write up on Strange brake install? Front & rear?
  96. LS7 shift points ????
  97. Christmas Tree Tactics
  98. Wheel to Wheel powertrain go under?
  99. What to get - MT Drag Fronts, or just cheap 165 radials?
  100. Virgin Question
  101. trying to decide on what race seats and harnesses...
  102. Question about brakes.
  103. what length braided brake hose?
  104. Boosted 408 in a 95' Z28
  105. Installing seat belt harness question...
  106. Powertrain Control Module ?
  107. what paint do you guys use on your roll cages?
  108. best dzus fastener kit to use for VFN hood???
  109. rear coil over shocks without springs...
  110. fastest cam only cars??
  111. Wolfe Minitubs
  112. Battery Relocation Side
  113. help with R/T .400 pro tree
  114. I don't know what section to put this in, but I need help!!!
  115. Interior Wall For Fuel Cell
  116. 1" 7/8 or 2" header?
  117. Best flywheel for DRAG RACING
  118. Strange front coil overs
  119. transbreak not locking up??
  120. Adj.Torque Arm?
  121. tire size. What si the biggest drag radail you can fit under a T.A. WITHOUT NARROW OR
  122. Questions about 1/4 times related to HP.
  123. Motor Plates
  124. Drag radials on hot track not hooking
  125. Hood Pins???
  126. Suspension guys.... what is wrong with the way this car rolls out?
  127. roll cage info
  128. Alcohol and LSx Fuel Injection
  129. Mickeys wearing out?
  130. rear shocks
  131. 28x12.5 or 28x13.5 pictures?
  132. Where to get ozite?
  133. Charging issues
  134. Does Altitude affect boost pressure?
  135. Solid Roller Guys, Step inside
  136. Sealed battery in hatch, box required?
  137. Lost ground to starter relay
  138. Exhausted
  139. SFC question
  140. TH400 Guys - Problem with converter?
  141. 60'
  142. BOLT ON guys, describe your suspension set up to me
  143. putting a new 12 bolt in o2 camaro help
  144. anything i should know when drilling and using tubes in the rear
  145. Tube Bender
  146. Drag radials and 10 bolt?
  147. Trans Brake, and stock rear end...
  148. Springs Suggestion
  149. My trap speed is low. What are H/C A4's trapping?
  150. How Much to Cut Rear End?
  151. Racecraft June Promo
  152. Going to the track tomorrow for the first time with TA... ??'s
  153. Cutting radiator support
  154. great lakes?
  155. anyone have problems with getting VS from front WSS?
  156. Can I leave this unplugged...
  157. Practice Tree
  158. timing ?
  159. How fast will I go???
  160. Sheet metal or Vic Jr w/ 4B TB?
  161. Lets talk 60fts. & ETs.
  162. STRANGE front shock, do you run the shield/jounce bumper????
  163. Slick Come apart on the dyno
  164. Log of my 10.99 @ 123 run....looks ilke something isnt right
  165. Back-Halved guys, come in....
  166. Orlando Speed World Sucks!!!
  167. where to find NHRA rules and regulations???
  168. temp affect track times???
  169. 4.56 gear a good for 1/8
  170. people with 15x3.5 welds... street drive them alot? or no?
  171. QA1 settings... adding weight?
  172. my 60's are slower help!
  173. Burkhart Chassis Let's make a deal sale
  174. who sells a rear nhra legal battery on/off kit...
  175. wheel hop??
  176. Low drag cars, anyone ovaled tubing
  177. What is the loss in track times for elevation?
  178. nhra class question
  179. looking for tires for the 1/4 time
  180. Bracket racers inside (cooling question)
  181. crappy 60s, and a newb with drag radials
  182. 4130 In So. California
  183. Spohn 1" sway bar,will it be enough?
  184. how to remove e-brake shoe?
  185. Parting out ... how far would you go????
  186. Should I get slicks?
  187. Turbo vs. Blower
  188. Guys with the GMPP carb intake...
  189. On/Off Switch.. How to keep the computer hot 24/7??
  190. ARP vs TCI flexplate
  191. Wheel Stands
  192. Whats your torque arm and60'?
  193. first set of slicks....
  194. 2001 ws6
  195. pictures of front half cars
  196. anyone tried the m/h 275/45r18 dr yet?
  197. 502RWHP M6 needs traction/tire Help!
  198. everyone running lexan windsheild
  199. C5 TRACTION?LOOKING FOR 9s BUT CANT HOLD TRACTION
  200. Mickey Thompson gave me some junk ET Street Radials
  201. Kerminator's New Shoes - Bogart Goldstars w/ M&H Radials
  202. Clutch technique
  203. SLP line lock craped out...
  204. Burkhart Chassis will have a booth at the NMCA race in Joliet
  205. BS3 and RacePack user, What senders are you using?
  206. Rebuild or Swap
  207. anyone running this setup?
  208. SLP line lock question
  209. What else do I need to be legal?
  210. added full exhaust - no gains - do I need tuning??
  211. LCA relocation brackets besides Spohn?
  212. good, cheap hood pins
  213. plate(s) under your shifter and electric solenoied shifted
  214. dumb quick question..
  215. show me all your carbon fiber race car stuff!
  216. Video of my all motor 10.62
  217. Battery Relocation Wiring
  218. full tubs or mini tub?
  219. Moroso 20141 Oil Pan..Will it fit?
  220. rear coilover kit
  221. Are 1.8 60fts. doable with 3.50 gears/6sp./MT Radials?
  222. Finally Made It To The Track
  223. track results for my new setup
  224. Martin, Michigan Roll Call ... ADRL Race
  225. guys using factory power stearing rack as a manual rack
  226. What time should I see
  227. Harness on stock seat?
  228. Need the gears now or not?
  229. Question about removing accessories
  230. So here is what the new combo is starting to look like.
  231. Gathring interest in Strange products GP
  232. What Do You Think It Will Do??
  233. Kirkey Pro Street Drag Seat
  234. 28x10.5 hooiser 18155 or MT 3055S
  235. 28" tire question
  236. steps to a 10 second vette.
  237. why is my motor crooked (PIC) help!
  238. 4 link adjustment
  239. Accufab guys, linkage question..
  240. any imore pics of the black bitch?
  241. Look what showed up at Performance Auto Fab yesterday!!
  242. drag chute size
  243. Madman Customer Appreciation Sale Almost Over
  244. Results of a heavy spring up front?
  245. madman afco special
  246. Got the car running with the new spooled rear, pulls left?
  247. ATI damper, can you just run it without the A/C pulley?
  248. hey madman last ? before I go to the track
  249. How many yards?
  250. Launching a Stock WS6
