View Full Version : Drag Racing Tech
  1. How should I do my burnout?
  2. ok a3 guys what do you do at the end of the track????
  3. Are the 2.5" ARP studs IHRA/NHRA legal?
  4. A3 Guys, What Shifter?
  5. Front Springs- Swap or Preload
  6. Where to start tuning adjustable suspension, lots of questions...
  7. Race water pump
  8. Whats better: Front mount little battery or rear mounted big battery?
  9. Broken Oil pan
  10. 2002 camaro build up
  11. Strange Dual Caliper Bleeding, (Long)
  12. Bogart Issues
  13. gears and juice
  14. My car loaded up at the line.
  15. What valve stem do I need?
  16. question on bracket racing with a manual tranny
  17. What would you guys like to see? Everyone vote
  18. racing experts,i need help
  19. Kirkey seat bracket bolts
  20. Only A Week Left for Our Sale
  21. 9" tq arm bracket failure
  22. Wolfe over seat bars bad bends or just the way it is?
  23. FTRA and transmission cooler
  24. procharger or Big turbo for lt1 m6 car???
  25. Guess my 60ft CAM ONLY 230/230 cam 3350 raceweight??? MUST SEE!!!
  26. Will I fit?
  27. Moroso Renovation Pictures week one
  28. Bad wreck
  29. Thanks for the help w/suspension. check out vid
  30. what tire pressure in mid 10 second range
  31. Another SUX2BU Setup
  32. SLP Linelock Leaking
  33. Will the Alumastars clear a ground stock caliper?
  34. weight vs 1/4 time
  35. Low slung Wolfe door bars?
  36. More weight reduction question.
  37. questions about nuts and studs...
  38. sux2bu style ram air results
  39. Seat Belt options...
  40. Weld Racing Magnum Drag 2.0 photos request
  41. what is the date requirement for window net???
  42. what gear for my setup for the 1/4 mile?
  43. Long 1/2 in Stud Question
  44. Torque Arm Mount Question (The 3 Bolt Piece On The Housing)
  45. Car pulling driver wheel slightly more, also launches to the left. How do I adjust my
  46. Minimum wiring required for dedicated race car.
  47. M6 and 3.42 guy's 28" vs 26"?
  48. Madman & Co. Customer Appreciation Sale
  49. Help with front swaybar removal
  50. question for those with Flaming River pinto manual racks
  51. Initial QA1 Shock Setting For Heavy Car
  52. cheap quick release for 5bolt steering wheel
  53. Running 10's or faster? What size tires/springs?
  54. Smallest diameter LCA? Madman?
  55. Got any pics of inside an enclosed? Shelves, etc?
  56. What to do next?
  57. Battery Location - Main Wire - under car?
  58. Land of the 14 secs
  59. a little tire help with set up
  60. Possible dumb question regarding rim screws
  61. What does DA stand for?
  62. ET gains from skinnies?
  63. Enclosed Trailor
  64. drag radial info needed
  65. traction help!!!
  66. what would produce better 60's
  67. what's an approx time with this setup?
  68. launching with stock converter?????/
  69. How am I at 7000 rpms crossing the 1/4 w/th400?
  70. Fiberglass T-tops
  71. 600 foot ET to 660 foot ET conversion.. Anybody
  72. 6 point bar cost?
  73. Any Hoosier Guys?? Can I get your input THANKS!
  74. My car launching.
  75. How long are 5/8" rod ends used for adjustable torque arms?
  76. Wire bundle across fan assembly???
  77. Mopar master cylinder for manual swap?
  78. Drage Race Only LS1, What Weight Oil?
  79. Crank centerline dimension
  80. Wolfe minitub kits
  81. 325/50/15 MT street radials
  82. Painless Wiring?
  83. Dual 4" oval exhaust pics
  84. corbeaus or kirkys?
  85. Packing the tires with a 4L60E with a Transbrake
  86. Battery Relocation - Where?!
  87. launchin on dr's
  88. PA and Race craft spindle mount spindles
  89. Roll cage!?
  90. Narrowed 9" and Panhard Bar Question
  91. Roll bar question
  92. Back space for 3" narrowed rear?
  93. Questions about HC auto and 60fts.
  94. Some Pics of 10.5 Tire cars..... Post Pics you have!!
  95. rear coil over questions
  96. Just fired the car for the first time this year!!
  97. new 11in narrowed moser with 15x12s
  98. WS6 Ram Air Hoods Options?
  99. T-Tops
  100. Where to mount remote oil filter?
  101. 1/4 mile launch
  102. 9" Question
  103. How much is everyone paying for RP Oil?
  104. Auto-X Suspension at the strip
  105. New madman Susp. and car pics ....
  106. under F-frender metal removal
  107. poss twisted frame/body please help me out
  108. 25.5 guys inside
  109. best 60 ft on stock stall
  110. TH400 problem.. Help please, I'd like to go racing tomorrow.
  111. Pics of Formula's 10 pt, parachute and interior
  112. 25-2 Big tire hoss
  113. What does it take to run a LS1 car in NHRA stock class?
  114. My take on Home-Made Ram Air.
  115. Shock question
  116. Explain to me.. Bias Ply
  117. How do i get my 60' time down?
  118. Surging after burnout IAC serching
  119. Traction problems- need help
  120. What is the NHRA approved way to attach steel roll cage to aluminum frame C6Z06?
  121. Battery Relocation Question
  122. tire size help!!!!!
  123. speedo for drag brake and race trans
  124. KYB AGX Crew.
  125. Wiring Transbrake, 2-Step, and Nitrous
  126. Finally got some pics of my race car
  127. rear springs
  128. drag radials with screws
  129. help me launch *VIDEO*
  130. TCS removal/questions
  131. Weather Station/ET Predictor
  132. LSX race engines only
  133. Fast LT1/T56'S inside (bellhousing again)
  134. question on ET in 1/4mi
  135. 98 Camaro "Kerminator" 25.5 Build Thread - PICS
  136. Cage mounted switch boxes
  137. Used ASA ATI LS1 underdrive pulleys available
  138. 275/50/15's or 275/60/15's? for my bolt on LT1?
  139. drag brakes
  140. Moser or Mark Williams Internals for an 9 inch ?
  141. Stall Convertor. What size/What brand
  142. Too much "play" in my RT TA?
  143. Cert down to 8.50 question
  144. Qa1 R fronts ??
  145. Project finally finished!!
  146. How are you T56 guy's legal?
  147. BIG TIRE - back half cars
  148. Dyno Day!!!
  149. 50/50 weight ratio?
  150. Which Lightweight Battery?
  151. Need help improving et
  152. [installed] Mandrel Drive Setups
  153. 315 Sumitomo PSI
  154. LS2 Intake on LS1
  155. So Which Mickey is better?
  156. ET advice
  157. good launch w/ a M6
  158. 2in kooks hitting steering
  159. How fast have you gone on a 12 bolt posi?
  160. So does anyone run stock studs with prostars?
  161. Weather and ET
  162. Progress Pics
  163. no traction
  164. Suspension unloading ... need advice.
  165. Drag race guys... need clutch advice for my t56...
  166. Weird tire problem , need your input.
  167. 9.9x trap speed?
  168. Firewall Grommett... Where at???
  169. It appears I need some suspension help.
  170. Mounting Switches - Where At?
  171. Help with HEAVY A4 launch
  172. How to get autometer tach to work with BS3
  173. madman....black bitch's 60' times
  174. 28X11.5 16 MT ET Streets?..
  175. QA1 Shocks - Rebuild place?
  176. Help Me Out. Watch Video
  177. Cutting the Dash for a 10pt
  178. lexan wights
  179. What throttle cable are you using?
  180. H/c/i Guess My Dyno And 1/4 Time!!!!!
  181. Anyone running 15x10 prostars with 6.5" bs?
  182. 325's Got sold because they wont hook, Suspension Help
  183. Why does my car still squat/shitty 60'? Thought I covered all the bases?
  184. any cons to bullets off the collectors??
  185. lca relo brackets... start in middle hole or bottom???
  186. Loosing weight, adding parts and cleaning up the engine bay questions. Pics inside
  187. t/a in 1st gen?
  188. HOW GOOD DOES HOOSIER QUICK TIME PRO DOT's HOOK?
  189. 04 featherlite alum trlr
  190. LS1 in dragster, steam lines?
  191. How much are you guys paying for a custom made 10 point?
  192. strip newbie
  193. What Roll Bar/Cage are you running. (Pictures)
  194. Launching a 2002 Z-28
  195. Need a little help adj-suspension for better 60foots.
  196. what will i run with these mods:
  197. Guys with kirkey seats....got a question.
  198. Steering Issue on Long End of Track?
  199. Track Problems!
  200. Gear change, 60'?
  201. Better 60 fts but slower ET & mph
  202. Rear Battery Pictures?
  203. Finally managed to get track time on new setup..
  204. k member and manual steering ?
  205. New motor build wich way would you go?
  206. Rear QA1 Coilover experience?
  207. BMR Drag Xtreme Bar
  208. Battery Cutoff?
  209. Need some advice on rear set up...
  210. New set-up. Pics inside
  211. how do you take off the windshield washer tank?
  212. QA1's on....whats next???
  213. Dual-Disk Clutch Friction Material Selection
  214. Need opinions
  215. New order of MT drag tires
  216. 383 LT1 now, go to 383 LS1?
  217. strut tower bar should i remove
  218. Will it hook up decent or ??
  219. 2 step results
  220. wheels up?
  221. Drag Racing 201
  222. Moser Trutrac and axle problems. <500hp
  223. 11 capability?
  224. Density Altitude
  225. 11.99 possible?
  226. *Pics* TTP 4130 60" PRO Outlaw Wheelie Bar Set
  227. How bad is stock suspension?
  228. Tire Help
  229. 28x10.50x15 Et Drag clearance pics??
  230. Help/rpm Activated Switch
  231. got some completed pics of the car/motor
  232. Madman SYA bars dont seem to hand low enough
  233. Impact Bars (inside doors)
  234. Question about rim screws...
  235. Billet Coilover Brackets
  236. Part number for Strange rear brakes?
  237. Weight of stock seat?
  238. Rules for battery
  239. Dipstick Tubes
  240. sunoco style hood pin on up to windshield. anyone have pic
  241. what should I launch at?
  242. Beadlock rings
  243. I can't get it in the 11's
  244. 1/4 mile time for a 2000 stock z28 vert ?
  245. What exactly does it take to prep a track?
  246. Pics of screwed Alumastar 2.0's?
  247. suspention help!!!!
  248. Spinning?
  249. Possibility of hitting 11's?
  250. 230" dragster with LS1
