View Full Version : Drag Racing Tech
  1. Where am I losing time
  2. 2008 parachute rules
  3. lt1 calipers on ls1 rotors?
  4. Okay I need a Joe van O wing money in hand
  5. What ET ? With My Set Up?
  6. Lowering the rear
  7. Street driving a stripper?
  8. Anyone other than wolfe making mini tubs?
  9. 28x13.5 ET STREET, 325/50 or 28x10.5 W?
  10. Pontiacs new G6 GXP Pro Stock body unveiled
  11. Confused: Battery cutoff switch
  12. trans brake/2 step ?
  13. traction, Comp or back to stock shocks??
  14. steering wheel
  15. 27" M\T ET streets, anyone using them?
  16. Front Dristibutor Conversion
  17. Toyo Slicks
  18. How long are 5 point harnesses good for
  19. How fast?
  20. Street tyres what PSi ?
  21. How fast is fast now??
  22. Which bolt in sub frame connectors?
  23. K&N air filter removal and added airflow?
  24. Aluminum cage
  25. Routing Fuel Lines
  26. Mini-Tubbing & Wheel Lip Clearance With 29x10.5W?
  27. Kirkey Knock offs??
  28. STREET swaybar selection??
  29. strange single adjustables and 275 lb spring question
  30. How to Mount Kirkey Pro Drags
  31. Now I have more power How do I get down the track faster?????
  32. How many guys are running Fuddle converters and how do you like them?
  33. my 60fts SUCK!!!
  34. Could This Be Some Sort Of Lane Walk?
  35. Pics and specials from Burkhart's booth at Drag Expo
  36. If you could build a drag strip...
  37. New best 1/8th mile time...
  38. Need help concerning lightweight batteries.
  39. gutted cars
  40. rollbar question?
  41. Drag Suspension
  42. m6 on M&H anyone?
  43. LPE 2 step considered "electronics" ?
  44. How's this for a starter kit?
  45. 28''x13.50x15 hoosier quick pro's anyone??
  46. what holes for lca relco brackets
  47. pinks filmed my camaro at the strip
  48. cars been setting for a long while, what things should i check out b4 running it?
  49. THE Bulletproof 7.5" 10-Bolt! =)
  50. A4 w/PT4400 stall, time drop going from 3.23 gears to 4.10s?
  51. 8.50 chassis cert!
  52. How many of you have crashed on the track??
  53. c5 convertible full cage is in!!!
  54. 25.2 firebird update
  55. project dumba## about to begin
  56. Can you ID this K member?
  57. AFR vs. TSP 2.5 LS6 Heads
  58. 33 spline Gun drill?
  59. 15x4 fronts with 2.25" BS on Camaro?
  60. What would you consider "full suspension" for a DD?
  61. fayettville NC
  62. anyon use/try these wheels??
  63. stock rear suspension rules
  64. cut in 9" moser axle
  65. Front spring rates, aftermarket options?
  66. Drag wheels > what do you think of ET difference?
  67. so i need a little help.... tires....
  68. Save our local drag strip. PLEASE SIGN
  69. Who makes an abs delete or who sells them
  70. really dumb newb question
  71. older drag wheels ok??
  72. Front Bumper support removal help. Trans Am
  73. best 60ft. 6 speed cars chime in!!!
  74. whats a good time?
  75. Battery box install tips?
  76. roll cage
  77. "Weight Reduction List" Fully Updated!
  78. East coast source for 4130
  79. What anti roll bar to use
  80. Kooks And The Nmca At Atco With Lsx Shootout
  81. Weighed some MT DR 325 50 15's after 3 runs
  82. Post pics please of where you guys mounted your aftermarket tachs in your f-bodys...
  83. Wiring? What can go and what needs to stay?
  84. torque arm help
  85. Removing A/C, but keeping heater?
  86. A Little Call out
  87. What will it run? 1998 A4
  88. Auto Gear Calculator
  89. Interior trimming for mini tubs
  90. What does it weigh
  91. lowered car and drag tires?
  92. How many people have trimmed the steal under the windsheild?
  93. mickey thompson drag radial questions
  94. Question?
  95. Front brakes are killing my ETs?
  96. S&W suspension
  97. How to measure torque arm angle?
  98. Carb style intake,Show me your Hood Scoop!
  99. What! Broken teeth on ring gear/pinion & twisted slip yolk!
  100. 26" vs 28" vise versa
  101. M/T 325/50 on back order
  102. what lokar throttle cable for accufab 4150tb
  103. At what point are 275/50 m/t dr's not enough.
  104. Torque converter experience for 800 hp F-body
  105. jegs rim ?
  106. Remove the headliner for 6pt Wolfe bar install
  107. Before I go to Summit...
  108. Driveshaft speed
  109. Remote Cooling System Setup?
  110. American Racer tires? (formerly Mccreary)
  111. Is it worth it to change out from my Spohn Drag bar to a Wolfe?
  112. wilwood rear drag brakes
  113. Evaluate my set-up.
  114. Need Help With Head & Cam Setup
  115. Removed rear bumper support and rear ride height is up over 1/2 an inch!
  116. stock suspension ride height front and rear
  117. Good Lanuching tips and a good target time?
  118. Air Bag Or Sway Bar???
  119. Cage install prices?? (I know, again)
  120. For you guys that run a radial type frontrunner, I found a better size.*PIC*
  121. Are my sidewalls toast? Bad tire shake!
  122. is a panhard bar needed for drag racing
  123. Flashing the converter.......
  124. NHRA Lug Nut Regulations?
  125. first time on slicks
  126. Progress pics on the Camaro from Burkhart
  127. Roll Cage
  128. Thank you MADMAN!!!!
  129. slicks
  130. Another cage install question. Working on it now
  131. Strut bar or not?
  132. Setting realistic goals.
  133. Which slicks??
  134. Help Quick!! cage install Question
  135. Carb/elbow guys, come in.
  136. Anyone using the 295/45/17 MT's?
  137. Guys with 360-380Hp what's your Track Times ???
  138. Drag City, Banning CA
  139. Mod advice for Better Track times this Spring
  140. Installing Hurst Quarter Stick have ???
  141. Moser Alluminum third menber???
  142. Wolfe Anti sway bar question.
  143. Wheel offset after minitub?
  144. 15x10's w/ 4.5" BS For Mini-Tub?
  145. Best converter for my application
  146. Press release from Madman
  147. Aeroquip socketless fittings?
  148. 6pt roll bar install price
  149. stock 1/4 mile times
  150. Ultimate Air conditions?
  151. anyone run a 5.5 or 6 inch wide wheel on the front?
  152. Pics Of Wolfe Raceing Upper Rear Spring Mounts
  153. Switching from 325/50 to slicks, what size slicks?
  154. How do 28x10.5x15 slicks fit?
  155. Aftermarket Tach - Where did you install them?
  156. what does everybody think about goodyear slicks?
  157. Any reason my car would be faster on slicks than DR's?
  158. Front a-arm issue/k-member
  159. Radials or non W slicks, need help.
  160. More Gutting!!!
  161. wtf is my car doing?
  162. Sway bars, and Strut tower braces
  163. Pics of Hoosier 325/50 mounted on the car
  164. fyi for all who run jeg/ summit stars...
  165. Its time for the 2007 mega-gallery (need your pics)
  166. WHo else makes a street based front runner beside M/T?
  167. lakewood 50/50 rear shocks
  168. Exhaust for 8 second car
  169. good shift light?
  170. bumper supports
  171. new fronts
  172. anyone gone "fast" with an slp dual/dual catback or full muffler? (no cutout)
  173. Vic Jr,4150 TB guys, what do you think of this air filter?
  174. question about my setup and results.
  175. what will a gear swap
  176. Passenger Air bag removal????
  177. Hoosier Drag Radial vs. Slick life?
  178. First time out on Drag Radials Jan 5 08 - TIPS?
  179. et streets, got a question
  180. good setup?
  181. need installed pictures of arc flat touch switch panel
  182. rollbar question
  183. 383CID or less N/A race engines
  184. gear choice, 12 bolt, H/C/Stall/N2O?
  185. How much does the width of your tire affect performance?
  186. AC! HVAC! PS! Last minute checks
  187. My car should be a pile of ashes right now....
  188. What wheels are these??
  189. NHRA legal Line Lock
  190. Just when you thought you had seen it all, LS1 heads on a smallblock FORD!
  191. any NMCA Xtreme street racers here?
  192. Accessory Setup - Help Needed
  193. question about oem computer in a dragster and NHRA rules
  194. Fuel Cell
  195. Air shifter install pics
  196. 325/50s on 10s or 12s
  197. Video of lauch need suspension setting recomendations
  198. Do you need an ebrake?
  199. help me to run the best
  200. Makin a list, YOU check it twice
  201. "LSX" Lightweight Motor Mount Bushing Stands
  202. Spring Rate ? and install pics of Wolfe housing mounted adjusters?
  203. windshield washer reservoir removal
  204. Bad vibration after coming home from the track
  205. Those w/Hoosier Radial Slicks, please come in.
  206. cut or not to? Opinions please
  207. Rim Screws: Summit Racing or Hardware store?
  208. Removing cross-member off floor to fit seat?
  209. l92 drag results
  210. Going rear coilover.
  211. Should i go with 28's???
  212. I weighed my 02 SS
  213. Gear help
  214. Torque Arm Angle.
  215. Determining gear ratio for race car w/big stall & no lockup?
  216. Por-15
  217. Aftermarket Rev Limiters
  218. Which 28"ish tire on 8" wide rim for 10.0s in the 1/4?
  219. Lower front air dam removal.
  220. How much gain from mods? 7.08 Cam only
  221. Any of you guys running a Race EWP on the Street
  222. 5th shift
  223. New torque arm out, link inside
  224. SA or DA Strange rear shocks?
  225. Another solution for carpet
  226. BMR alternator bracket & procharger
  227. Do I need a new stall??
  228. thanks madman
  229. Spring Seat Adjustors or Shocks?
  230. 275/35-18 BFG's
  231. Correct my time for DA
  232. Tire Recommendation Please
  233. g-force/pete Z bars, any breakage?
  234. Do You Run Tubes In Your Slicks?
  235. I found this Video ( funny )
  236. Chassis people, alignment question
  237. Help With Tire Choice For Big and Littles
  238. lightweight carpet?
  239. Nitto NT-01 for drag racing?
  240. POR-15, how much for 6pt?
  241. 2009 Camaro Pro Street pic
  242. My new exhaust...
  243. 16 position QA1??
  244. how to calculate
  245. Quick C5 DR tire question
  246. Rear Coil-over Shocks
  247. lightest rear brake setup?
  248. 25.5 race weight with out any ballast
  249. Stock wiring harness question
  250. proportioning valve front or rear, where is yours?
