View Full Version : Drag Racing Tech
  1. What rpm spread do you see on shifts? (10.20 or better NA cars)
  2. The stickiest tire poll.........
  3. need more down low
  4. tire sizing
  5. Autometer speedo
  6. K-member guys.. Stock front brake lines???
  7. Anyone with a moroso vaccum pump?
  8. Canton Oil Pan ?'s
  9. K-member guys will the stock perches work on a PA racing K?
  10. nitto drag radial tire pressure
  11. Help With Choosing Tires!!!!!
  12. Varishock Drag Shocks
  13. track times?
  14. new combo any advice?
  15. Lost Some Weight!
  16. Scale of 1 - 10
  17. just weighed my car :(
  18. Alcohol vs 116/110 power comparison
  19. !Front Bumper Support = Sag = Penny Mod Fix
  20. Rear Seat Bolt Sizes
  21. Hooking then spinning?????
  22. Tire vs Gear for 145mph in M6 car
  23. 2-Step Question...
  24. Removing burn-out rubber from wheel-well quarter panel? How?
  25. Accusump system and Oil Aeration issues
  26. 5 pt Harness?
  27. Went 91.02 mph in 1/8! Question?
  28. my car is becoming anorexic....hehe
  29. What is the stock suspension LS F-Body record?
  30. Lowered car 1.5" what problem will I encounter with a 15x10 rim?
  31. Rear Bumper Delete......AERO experts inside please.
  32. What should this run?
  33. Help Out Please
  34. Insurance
  35. should i go th350 or glide???
  36. c5 bellhousing blanket
  37. Front sway bar Q's.
  38. narrowed rear end
  39. how does madman like true stock suspension 4th gens to 60ft?
  40. HVAC delete with motor in car
  41. SFI 25.2 Mustang/LSx build "The Renegade"
  42. UMI Torque arm pivot adjustment??
  43. street tires
  44. Any big cam guys running PI Vigilante 9.5?
  45. Can I remove this?
  46. want 11.50s what do you think
  47. how much will this help me
  48. Lightest daily drivers? TRUE DAILY DRIVES!
  49. whats the rules for 10.0-10.9
  50. what motor to go with
  51. Wheel Spacing
  52. 15x29.5 non W
  53. Seat/harness mounting...
  54. Is this a decent time for an auto LS1?
  55. Cage all done, info on POR15 paints
  56. A4 SI guys? Launch help
  57. Is Madman Suspension Wheels Up?
  58. is it gonna be safe to run this setup without sfc,s???
  59. question bout rear spring/shock combo
  60. Roll bar on the street good or bad?
  61. roll over bar question
  62. What Rear Brakes do you run with a strange 12 bolt
  63. 275-60's on a TA with 15 x 10's???
  64. Good places to buy Roll cages?
  65. wanna see how fast your car is? come on last time of the year...
  66. when to jump to 325 from 275 drag radials?
  67. Relocation brackets
  68. TTP Wheelie Bars - Pics & Prices
  69. foohah
  70. NMCA EFI Class???
  71. Water temp guage install- need help
  72. AC delete question - 02 T/A
  73. Open headers????
  74. for thoes who are thinking about removing bumper supports
  75. LT1 60ft Improvements?
  76. 315/35/17 with 3.42 gears A4?
  77. Painless wiring questions???
  78. TTP Race Car Pics - Finished Cage, Working on Wheelie Bars
  79. Tallest rear slick without major hacking?
  80. lightweight battery
  81. These changes get me into the 10's???
  82. Preparation for the track
  83. Weight transfer / FT tire size ?
  84. Wheel Hop
  85. Shortening axles, stock length tubes
  86. 29.5's & 7" Back Space
  87. launching on 17" Nittos....few questions.
  88. how big are the cams they run in top fuels and funny cars???
  89. Workin the Box
  90. Lug nuts for Bogarts...
  91. Suspension help needed
  92. Panhard rod bar needed for drag setup?
  93. Where to get a set of wheels beadlocked
  94. M and H drag radial tires
  95. trouble w/ brackets
  96. summit roll bars?
  97. Fuel setup
  98. Weather/dial in/HELP
  99. Question on Madman Torque Arm
  100. 2 Step users step in please...
  101. how are you guys installing your pin on hood?
  102. Steering wheel airbag removal questions....
  103. what makes a car get to the 60ft?
  104. Madman Suspension ?'s
  105. disappointing night at the track
  106. My new IHRA Real Street RX7!!!
  107. Questions about madman Tq arm
  108. Why cant I trap for crap ? (Did a search, please help)
  109. looking for pictures of 4th gen fbody with motor plates
  110. Can someone measure their Kirkey seats for me?
  111. can i remove power steering without manual rack
  112. 12.2 sooooo close need advice to get over the hump
  113. Anyone Used Renegade Race Fuel?
  114. ABS delete: this block ok?
  115. Battery relocation questions
  116. using MSD distributor with factory computer
  117. Tinted windows???
  118. can you launch a 6 spd in second gear???
  119. PSJ get your ass in here please...
  120. Does Octane booster \ running higher octane fuel do anything?
  121. How to hook up a high HP drag radial car discussion
  122. Question for Madman....
  123. Plastic inner fenders?
  124. m6/trap speeds
  125. Researching interest in possible new Oil Cooler...
  126. +2 degree pinion angle?
  127. Having my 1st nitrous run 2nite need advise
  128. How does ride height effect launch?
  129. Pinks Pranks and Pics Thread
  130. LCA relocation brackets?
  131. Auburn ECTED?
  132. Where to buy 4130 chromoly tubing?
  133. Saw an extended wheelbase Camaro for sale. Check it out!
  134. Narrowed rear questions
  135. rear glass delete kit?
  136. S & W or Wolfe cage??
  137. Drag radial rule change?? (for the LSX shootout)
  138. Attn:all Central Texas Lsx Racers
  139. Dash Board Pros.....inside please...asap
  140. mt drag radial size??
  141. What kind of results to expect with new rear setup/tires
  142. Just Broke Spohn Torque Arm # 3 - NEED HELP
  143. calling out PSJ pinks car
  144. removing front bumper support and air bags
  145. help with my set up 402 stroker
  146. every little bit??????
  147. 853 vs 241 cam only track gains...any?
  148. We did not race on that TV show Pinks
  149. Do any of you guys run nitrogen in your tires?
  150. Installed a Burkhart Fab9...pics..
  151. What REAR brakes do you run with your 9" and 15x10 prostars?
  152. Need input on hooking at the Track
  153. Similar combos times
  154. SFI Cage Diagrams?
  155. Cage question
  156. when street racing or at the track
  157. cooling between rounds
  158. Starting to look like a racecar...pics
  159. Street Tires at the Track
  160. battery relocation pics please!
  161. 1.2ers, 1.3ers or single digit cars
  162. Power for line lock...
  163. anyone made the swap from hoosier qtp's to et drags?
  164. a lil weight reduction
  165. Drag Race Alignment......ASAP Please....
  166. Gauging Interest - Billet Cover Street Converters Custom to Your Specs - $659 Shipped
  167. comp eng shocks and relo brackets and worse traction???
  168. What time should i expect?
  169. Burnout length with ET Drags
  170. What Trans for my LS1 RX7
  171. Let's see pics of 25.2 setups
  172. removing heater..
  173. Rake and launch...?
  174. Gearing for my 460rwhp Bird, for the track.
  175. new steering wheel, got pics?
  176. good 1/8th mile cam
  177. About what does 112mhp trap in the 1/4 make in the 8th
  178. 3.9 gears and BFG drag radials
  179. IHRA legal 10's
  180. Mustang GT500 question
  181. Need lug nuts pics on car!!
  182. All 408 n/a strokers' times
  183. Do 28" MTs fit without modifications
  184. 6 point cage?
  185. What Should I Be Aiming For?
  186. At a Crossroad....Torque Arm Short vs. Long
  187. how hard can i push 16in MT DR's?
  188. purple trans am @ State Capital Dragway
  189. Mouting PHB with 1/2" bolts
  190. Torque Arm Question - "Instant Center"
  191. Racers, Trans-Am headlight weight reduction?
  192. Braked TH350 Racers?
  193. 30x10.5x15
  194. E-Commerce Platform (software)
  195. seat mounting brackets
  196. pic of my launch and results
  197. FootBrake Racers-What's your method for cutting a good light on a Pro Tree?
  198. Best Drag Radial 60'
  199. After New Tires/ Decreased Performance
  200. m/t et streets:275/40-17 VS. 255/50-16
  201. Going to be my first time going to the track
  202. driveshaft loop questions....
  203. traction problems
  204. ac belt removal...
  205. How low can you go?
  206. Window nets + swingouts
  207. front shock/spring install/setup
  208. Picking front shocks and springs
  209. 95 Z28...stock
  210. Suspension guys what do you think???
  211. Car Trailer Tools/Accesories
  212. Painting cage?
  213. finally weighed my car tonight
  214. Line Lock question
  215. What to expect?
  216. ? on cages, roll bars
  217. Mt Et Sreet Radial 315/35/17 vs. 295/45/17
  218. Wheel stud help
  219. Ohio Boys T/A Pics? Anyone
  220. Torque arm Pinion
  221. M/T Et Streets 315 vs 325
  222. How to launch on near stock 00 A4 3.23 with drag radials ?
  223. Would this cage be legal?
  224. Guys with 325's what gear are you running?
  225. Brake lights come on in between shifts?
  226. Anyone using an aluminum driveshaft 9sec or quicker?
  227. Cooling problem..
  228. Anyone Removed the Front Bumper on Their DD?
  229. Helmet?
  230. suspension gurus
  231. track tips
  232. att madman we are ready for youuuuuuuuuu
  233. How much power to trap 120+mph through a stalled auto? What Heads/Cam are you running
  234. Anyone running MT ET Streets on 16" wheels?
  235. motor plate question
  236. No upper panhard rod?
  237. Madman in GMHT
  238. Accufab 105mm TB Users inside please!!!!!
  239. mini-tubs and Moser 9"?
  240. How much does a 98 WS6 vert weigh?
  241. Octane Booster?????
  242. Lets Talk converters
  243. strange coil over shocks with QA1 springs?
  244. question on hood pin placement
  245. How much abuse can the stock aluminum driveshaft handle?
  246. Driveshaft recommendation Mustang/LSx/9"
  247. Catback to Duals Weight Saving?
  248. Light weigt body parts
  249. Help looking for the right tire and size for track use
  250. First time at the track. Gainesville Raceway.
