View Full Version : Drag Racing Tech
  1. Lets Talk converters
  2. strange coil over shocks with QA1 springs?
  3. question on hood pin placement
  4. How much abuse can the stock aluminum driveshaft handle?
  5. Driveshaft recommendation Mustang/LSx/9"
  6. Catback to Duals Weight Saving?
  7. Light weigt body parts
  8. Help looking for the right tire and size for track use
  9. First time at the track. Gainesville Raceway.
  10. Coupla pics of my 9 sec WS6...
  11. Tire Pressure At The Track?
  12. k-member and steering rack?
  13. A4 Guys: help me sneak into the 10s
  14. 25mm rear sway bar Qs
  15. Racepack vs Autometer dash
  16. Track Tonight Again
  17. Carb Style intake guys??
  18. 15x8 or 15x10
  19. good looking street/racing seat.
  20. ABS delete question
  21. Any gain from Eaton posi to spool in 12 bolt?
  22. are my 1/8 mile times slow for what I have?
  23. has anyone bought any of these hoods?
  24. lightweight fiberglass t-tops
  25. 98+ Fbod manual trans racers inside
  26. Newb to drag racing
  27. Looking to fix my bad combo...suggestions?
  28. Shortened rear check
  29. Exhaust?
  30. how to cool down car between runs??
  31. Who picked up mph going to a drag radial?
  32. 2.73's to 3:42's worth???
  33. How many G's pulled at launch?
  34. Anti-rollbar install..
  35. ms4 cam time???
  36. I need help! Interior wiring ground???
  37. 26/10.5/16 mt 8.5" tread?
  38. Strength of 12 bolt vs. 9" posi....
  39. clutch setup with counter weights for t56
  40. Post your GTech competition logs here
  41. 28x9x15 ET Drags...
  42. spring question
  43. Which Mickey?
  44. Hoosier or MT stiff sidewall slick, preferences?
  45. best way to install a (on-off switch)?
  46. Carbon fiber hoods?
  47. 26" or 27" front runners for bracket racing?
  48. What size drag wheel and tire for my future setup?
  49. Reaction time
  50. Guys who have completely deleted HVAC, get in here...
  51. wtf is wrong now?????
  52. slipper clutch, but not clutchless shifting
  53. What Size of tire for A4 with 411 gears
  54. New setup in the works.....
  55. Steering wheel tilts when coming down from a wheelie, quick fix?
  56. lsx motors with msd ignition and aftermarket EMS
  57. Rear Sway Bar Review
  58. going to the track tonight
  59. whats it worth?
  60. Who sells the custom window net
  61. Tubes vs. no tubes (for me anyway)
  62. 600hp, m6, 25.6" tire, what gears for 9"
  63. Whats Up Wit Dat?
  64. m/t drag radials
  65. Removing TCC/cruise motor do-hickey, where do all these cables go?
  66. Correct McLeod Bellhousing?
  67. Need help with choosing a gear *YES I USED CALCULATOR*
  68. What cable to use? Carb style intake?
  69. help with traction
  70. Launching an A4
  71. Pin on WS6 hood options?
  72. nitrous converter
  73. stroked lt1
  74. Snell SA05 and M2005 whats the difference?
  75. people who race in high D/A and slower tracks...come in...
  76. 3050lb 555ci BBC Vs 2850lb 408+n02
  77. pulling out a few more tenths?
  78. 3350lb 555ci BBC Vs 2850lb 408+n02
  79. Newest RPM mag article on our team.. BIG PICTURE
  80. nitto drag radial question
  81. Has anyone with a 6-speed had trouble twisting yokes?
  82. What do you think?..
  83. Newbie here with safety questions
  84. Going 9", what posi?
  85. rear shock question
  86. For Those Of You Who Only Drag Race Your Car...
  87. Hoosier Drag 28x10.5x15 vs QTPs 28x11.50x15
  88. Can a 325/50/15 tire fit on 9'' rim
  89. 15x10 6.5"bs
  90. 4L60E transmission shields
  91. What would happen if?
  92. First time at the track!
  93. Whats my street/strip car worth?
  94. Why does my car 60ft slower after many mods?
  95. MT DR's or MT et streets (15" wheels)
  96. whats best tire pressure at the track/street?
  97. what will improve performance the most
  98. First race ever on the 22nd... I'm nervous!
  99. Missed out @ super chevy true street
  100. any1 know anythign about this?
  101. Maximizing Shifts and RPM - M6
  102. 3900 Lbs
  103. 9 second cars..... Torque arm w/ TH400 advice needed.
  104. My first slip!
  105. Install directions for a umi tq arm.
  106. What gear oil and additive for Strange 12 bolt with posi?
  107. Wheel Screws
  108. What else can I pull?
  109. quick little question
  110. going to the track what tires to use?
  111. First Time Ever
  112. 4.11. t56, 26" et drag-what mph have u trapped?
  113. Drilling harness tabs?
  114. my dad vs me.....
  115. Msd 6ls?
  116. MT ET Street Radial:
  117. another what should i expect question
  118. Driver Side Harness Firewall Bracket
  119. QA-1 shock question
  120. Any 3.90 geared 4000 stall set up's?
  121. First time at track in a manual...any help?
  122. LSX True Street Challenge - Oct 2007
  123. Will 3.90 gears net higher trap speeds in an M6 than 3.42?
  124. Wolfe 6 point w/ swing outs installed (pics)
  125. LSX Motor plate
  126. harlan 2step w/ nos mini controller
  127. what do stock corvettes run in the 1/4
  128. What ET should I run trapping 113?
  129. alignment specs?
  130. Time estimate
  131. Rim size
  132. Part# for quick relese steering wheel hub?
  133. Easiest way to get an auto C5 in the 10's
  134. Pics of my rollcage/kevlar seat install
  135. Question for People running BFG Drag Radials.
  136. 4th gen F-body race car switch panels
  137. Gauge Template
  138. Spacers or not?
  139. Torque Arm Length vs. 60' time
  140. Bracket racing guys. Which lane Right or Left? Why?
  141. 4:56's too much?
  142. You guys that travel alot, looking for suggestions for motorhome/tow rig
  143. Meziere Race pump what lower hose
  144. 8th to 1/4 conversion(search isn't working)
  145. 26x8.5x15 ET Drag???
  146. Anyone pickup anything by...
  147. Tried searching,but it's crap.What front skinnies to run?
  148. First time on track!! What i do wrong??
  149. How can I only have a 1.83 60' not spinning with 3.73 and 3,000 stall
  150. 1st time out 1/4 miles times, suggestions??
  151. nhra legal with swing out door bars?
  152. Frustrating Track times need some advice
  153. What are you using for a rear drag swaybar?
  154. best area to launch with stall
  155. Afco Rear shock installment question
  156. What springs?
  157. TH-400 vs Powerglide
  158. What size belt with p/s deleat?
  159. converters for 4l80?
  160. Did some rearranging today...
  161. Here are some pics of M/T DR 315 60 15 on car non mini tubbed
  162. 10-Seconds or better – What Clutch do you recommend?
  163. So how do I get this thing to hook?
  164. Aftermarket front brakes.....options?
  165. Aftermarket Fuel cells
  166. Grinding Calipers 101
  167. 27 or 28 inch drag radials for 9.5" TT2's without cutting bumper/ground effects?
  168. Post pictures of your roll bar/cage
  169. qa1 and stock spring ?
  170. crank to alt what belt
  171. Tire Clearance
  172. Wondering what E/T will be
  173. Adjustable front struts
  174. What Rpm To launch at?
  175. Subframes HEAVY!
  176. Where do You...
  177. PA Racing K-Member and Rack Issues
  178. line lock question
  179. 9.6 in the 1/8????
  180. Help! I am rolling through my brakes
  181. K member or cam cant decide
  182. Pics of lift off hoods, slicked firewalls
  183. Multi-Gear Shift Light
  184. summit rollbars?
  185. QA1 12 way + 28inch slick
  186. Outlaw SS.
  187. Front and rear bumper supports and brackets.. safety question
  188. Vehicle Reaction time
  189. Help with QA1 double adjustables
  190. Drag Radial
  191. Dr
  192. What is DA ?
  193. Racing with clutch that's slippin
  194. Weight Reduction Safety Q's
  195. weld pro stars
  196. Has anyone broken their LS7 clutch yet?
  197. Best racing seats?
  198. Burkhart Chassis LCAs and Panhard
  199. 26" or 28" tire (Cam, t56, 4:11's)
  200. special thanks to madman
  201. Part 3 of my project (cage,engine,engine bay painted) finished. Lots of pics.
  202. Whats it take to run 9.99 NA?
  203. Could be safery issue!
  204. On the line?
  205. what to modify for 28" tire
  206. worth mini-tubbing on my car?
  207. Newb questions on bracket competitions
  208. no squat looking at shocks to buy
  209. Brake caliper hitting the spring perch.
  210. LT1 backing plate and 12 bolt issue.
  211. bracing or reinforcing a 12 bolt ?
  212. Mizierre LS1 full race Electric water pumps
  213. 11.002 -- What type of time would I ran if
  214. Kirkey seat height?
  215. some progress pics and lots of pics
  216. VFN vs VanOverBeek Hood difference
  217. please post pics of hood fastners (dzus)
  218. Anyone run into electrical problems after removing the stereo system?
  219. Where can I buy the buckles used on Torque Arms?
  220. Can I get rid of this tube? connects to back of intake.
  221. Anyone Tried The Goodyear Ss 325/50/15 Drag Radial?
  222. My torque arm idea...
  223. Lokar 4L60E Tranny Dipstick
  224. Fabbed solid mounts...pics please
  225. NHRA/IHRA rule book on safety equipment?
  226. few progress pics
  227. Bog bog bog..help!
  228. 7 second engine recommendation
  229. Where do you have your transbrake button?
  230. Left front lifts before right front-sway bar question
  231. Moser 9 inch tq arm bracket
  232. Remounted my Wilwood brake proportioning valve
  233. Any tire growth on the 17" MT ET??
  234. some progress on my street car -56k beware
  235. Altitude...
  236. Your 1/8mile And 1/4mile Ms4 Cam Only?
  237. Bumper reinforcements
  238. Can I remove the upper panhard rod support?
  239. first time at track...any ideas on what I can run?
  240. M6 Launch RPM with a 9"
  241. Launch A4
  242. What's your Clutch Replacement Frequency?
  243. Competition Engineering Rear Drag Shock settings.
  244. S60 or 9"?
  245. No launch..decent mph
  246. Trans/stall options when running out of gear
  247. Check this out...
  248. need you help >>>backhalfing my car to a 4 link setup
  249. !HVAC guys how did you loop the send/return coolant lines?
  250. 315/60/15 F-Body Soon To Be Tucked
