View Full Version : Drag Racing Tech
  1. My first Roll Cage!!
  2. Wolfe Bar - Over the seat or to the wheel wells?
  3. turbocharged ls1
  4. do drag radials gain height back?
  5. What kind of time should i expect
  6. look what i just bought
  7. BMR or Wolfe rear parachute setup?
  8. Stick Shifters
  9. What times can I expect?
  10. can i remove this electronic box
  11. Which ATI Converter?
  12. 1/4 mile gains with cam swap?
  13. qa1 part number ???????
  14. lexan windows
  15. Summit Drag Wheels
  16. what should i do???
  17. More cage ???
  18. AFCO Drag Racing Shocks (need some?)
  19. Vacuum pump w/ stock pulleys
  20. What do you guys think of these wheelie bars?
  21. Do you think the brake lines running with the fuel lines could heat the fuel?
  22. Harlan 2 step, or something similar...
  23. 6pt cage and babyseat
  24. Air pressure street tires
  25. PS delete come in quick
  26. What spring rate to use?
  27. 5 points in street cars jump in here
  28. Installing Madman Torque Arm
  29. the effects of heat on a car
  30. Delay Box
  31. car isnt running what it should
  32. What vacuum pump set-up are you using?
  33. Hoosier DOT radials - when are they worn out?
  34. Wtf!!!
  35. 325/50/15 without a narrowed rear?
  36. BS3 Wiring question
  37. If you were gonna buy a new Torque Arm?
  38. Where can I find past weather data for calculating DA
  39. 15x4 or 15x4.5 ?
  40. Afco's - Do they come with the coilover kit?
  41. wheel hop and rear questions
  42. Narrowed 10 Spokes (pictures)
  43. Drag Brakes
  44. Why shorten your rearend?
  45. A4 Pinion Angle
  46. Can I remove these?
  47. Fuel setups
  48. whats a good goal to shoot for?
  49. Battery disconnect switch??
  50. I got the wrong tires... help me correct my mistake
  51. Front bumper cover help please
  52. Clearancing is a pain.
  53. Plug question and other
  54. overflow catch can options for LT1's
  55. LCA relocation brackets
  56. Can't seem to get my car to the track so how about a guesstimate
  57. Anyone need an EWP?
  58. Ladder Bars vs. 4 Link
  59. More gear?or Bigger Stall?????????
  60. Need help with shift points
  61. Looking for suggestions
  62. BMR Tubular Bumper Support
  63. M/T 305 35r18 ET street
  64. Street cars, how much can you stall on the foot brake?
  65. Where can I find a SFI balancer without AC pully built in?
  66. any tips/pics of 29.5's on non mini tubbed cars?
  67. Roll Bar Questions
  68. Battery Mounting Position
  69. should I go 26" to 28" tire?????
  70. Why extended wheel studs are good!
  71. Is it just me or is this a crappy 60foot?
  72. Aerospace Drag Brakes... brake line fittings...
  73. would it help ?
  74. MT drag radial not hooking need help
  75. optima question
  76. Anyone runing a chambered muffler with the texas speed duals
  77. Hans Device
  78. Please analyze my 1st run with vette.
  79. What would be the consequences.. .
  80. Mini Tubs???
  81. need ET guess for Magazine shoot (specs inside)
  82. dont have a rulebook, but need to know what i need
  83. batery kill switch
  84. Analize this race result for me please. How can I help my trap speed?
  85. Anyone w/ SJM line lock?
  86. what gear for 3650 weight auto
  87. Guys, I need help with choice of slick
  88. Clutch-Life Database
  89. Help me judge my ride..
  90. Strange front shocks
  91. Need help with tire pressure and shocks
  92. I installed the 29.5X10.5-15s M/T ET Drags
  93. How low can I go w/ mini tub and torque arm
  94. Meziere "race" electric waterpump
  95. Calculator: Air Density; Tires; Gears
  96. 8.69 1/8th at 82 mph, DA question!
  97. Ran Torquer v3 setup, broke nicely into 12s!
  98. pump gas Vs. race fuel!!!
  99. 60ft on rear tires
  100. 1/8 mile times, what do you think the cars capable of in the 1/4?
  101. If you run between a 11.0-11.5 what is your 60' time?
  102. Driving on QA1 RC7855P shocks
  103. I suck, my car sucks, what do you think?
  104. Alumastar 15x3.5 BS??
  105. What times are stock LS1's running?
  106. 500 HP low 11's?
  107. Wanted: Pinks All Out Reg. Ticket Bristol Tn
  108. How much RWHP to trap 120??
  109. Any tricks on lowering my 60' times?
  110. Drag Racer
  111. What is your WOT TCC lockup set at?
  112. Weight reduction--can this go?
  113. Launching!!!!!!
  114. Hey Guys Need Some Help
  115. Helmet?
  116. POR 15 users...
  117. Lowering tire pressure VS softening rear suspension
  118. What should I expect?
  119. Effects of Swapping Slicks?
  120. 1/4 Mile Time Estimate
  121. How much will it lower my 60'?
  122. Idle problem/staying on the stall bad for tranny!
  123. learning new setup
  124. 25.5 cage - what else/lightening questions
  125. recertification for a 5pt harness
  126. Help - Rear/Tire selection questions
  127. should i stay with the same tire size?
  128. Launching at 5K?
  129. 295/35/18 vs 305/45/18
  130. Jegs Rollbar
  131. Another what will it run thread
  132. Converter Issues
  133. best hooking DR's on a stalled a4?
  134. Value
  135. Question about gearing for 1/4
  136. Rear tire size Question?
  137. More 325 pics, LT Camaro
  138. Which drag tire are you running
  139. 3.23 gears with 325/50/15 M/Ts
  140. what skinny tires...
  141. Harnesses with stock seats?
  142. Double adjustable Koni's for drag racing?????
  143. perfect reaction time
  144. Fiberglass T-tops?
  145. "Cross Bars" vs. single Door Bar?
  146. battery relocation question?
  147. removing inner door fiberglass...
  148. What's the fastest anyone has gone on a STOCK 4l60e?
  149. Need manual rack setup pics PLEASE.
  150. Whats It Gonna Run??
  151. NHRA is sold!!
  152. guys with 1.5X 60 foots....
  153. Lazy Convertor / Madman HELP!!
  154. Track policies for sound at etown and atco
  155. Recommended tubing size for misc...
  156. Picked up a new T/A.. What's she run?
  157. Stock front shocks/sway bar and a 1.50 60'
  158. 2000 Z vs 02 T/A Street style track race
  159. What am I going to need to be legal to 8.00
  160. T/a's W/ Rear Bumber Support Gone!!!!
  161. I need a practice tree
  162. Clutch "slip" question
  163. what is the best 60ft i can pull with this set up
  164. got a converter question with my set up
  165. first timer at the track! wahoo help me out! haha
  166. Custom radiators
  167. Is this overkill for a low 12 second car?
  168. C5 Corvette Adjustable Pedal Stop
  169. Please help!!!!
  170. Would a 255/50/16 hook better than a 275/40/17?
  171. M/T ET STREETS shocks settings qa1s
  172. Att:! 28 inch slicks on a camaro!
  173. Made it to the track... few questions for new setup
  174. ABS & PS removal
  175. what is the weight difference from factory seats to the summit plastic seats
  176. Wheels/tires and Gears...Please help..
  177. Which trans for bracket/index racing?
  178. rear bulkheads
  179. Traction/Suspension Help
  180. 0-60mph calculator?
  181. Billingsly anti roll bar mounts, need pics.
  182. Density Altitude/Temperature
  183. Removing front bumper support have ???
  184. Rod End Spacers/Wolfe Rear Control Arms
  185. Corbeau users....anyone weigh the sliders?
  186. Driving to the track 100 miles away...
  187. Rotating mass weight savings questions ?
  188. BBC questions
  189. Best way to launch a stalled nitrous car
  190. 5-25-07 TNT Results. Tried light driver mod.
  191. Where is my mph
  192. Why am i so terrible at launching?
  193. whats the sweet spot to launch at on street tires
  194. 11.30 at 119 wanting to go 10.90's Thinking its time for weight reduction
  195. update on my car
  196. Front sway bar removal
  197. Looking for a previous post, help
  198. mt et street ???
  199. Subframe Connectors help
  200. TA rubbing on tunnel.
  201. need help gettin into the 11's
  202. Front suspension/shocks for drag racing
  203. Car won't go down track straight...help!
  204. Double pass vs Single pass radiator
  205. Ideas on suspension for 50/50 street track car...
  206. Looking for a good in car vid set up....
  207. What can I expect???
  208. Finally! She's track ready!
  209. Spun Nittos on the rim!!!
  210. Streetable drag shocks
  211. Would Kevlar drag racing seats be rice?
  212. Progress on my 25.5 conversion
  213. Can't get my car on the Trailer
  214. where to get chute' from??
  215. Check it out!
  216. Suspension Setup?
  217. How many run a thermostat?
  218. Slow Z???
  219. Who has a CSR transmission shield for 4L60
  220. M/T drag radials VS ET drag
  221. Suspension questions
  222. Getting ready for teh track, helmet Q's
  223. Rollbar install question
  224. All motor guys with 4l60e, what converter are you running?
  225. How do I hit 12's the hard way in my 00 Z28??
  226. Chicago Guys---get Your A$$ In Here
  227. Rear wheel width?
  228. MS Excel DA Calculator
  229. NHRA rules on wheel studs?
  230. how many people street drive on there front runners?
  231. a little input here n there
  232. First time track questions
  233. Am I due for a change of gears?
  234. ET help?
  235. Why shortened rear ends?
  236. First time out with slicks... were my expectations too high?
  237. getting rid of power windows
  238. 325 DR Band wagon
  239. Suspension question (scaled car)
  240. Need Drag Tire Recommendations??
  241. Rookie launching an M6 car
  242. Q:WOLF sway bar users!!!
  243. Get KR when I pull the front wheels
  244. Going to the track ADVANCED?
  245. meziere electric water pump race version
  246. Power Steering Delete
  247. Will I HIT 11's....
  248. 5 pt harness question
  249. Roll cage tech questions
  250. what to expect?
