View Full Version : Drag Racing Tech
  1. First wallet weight reduction mod (MWC bumper supports)
  2. 9" Rearend Housing/Axles
  3. Junior Dragster School
  4. How do I determine center of gravity point?
  5. droping half a second
  6. Disable Air Bags
  7. stock suspension
  8. Which throttle cable and bracket to use on 4150 throttlebody?
  9. when to spray
  10. High compression SBE experiment
  11. 28x11.5-15 ET Drags?
  12. Do Mickey Thompson ET streets require innertubes?
  13. What is the LSX True Street Record?
  14. Stripped Down Stock Steering Column
  15. Please help. No tach after new motor install
  16. Fuel line question - please help
  17. how street able are 4150 tb
  18. Exhaust
  19. 10.5w's In Stock Wheel Wells?
  20. Race Weights?
  21. Transamcoupe98's C5Z Build
  22. Burkhart 25.2 Camaro
  23. 1st Time!
  24. How fast will it go?
  25. Solid or Poly trans mount
  26. Best drag radial to drive 100miles and then make 8 second passes?
  27. Thumbs up for Spohn TQ arm
  28. 390 rwhp WS6 dissapointing 12.8@111
  29. THROTTLE position controller under dash ??? need some help
  30. Another Grant wheel and clock spring question.
  31. Help with tubing
  32. 4L80E who's running one?
  33. Planning stage - How much HP should I need?
  34. Our '94 Camaro Build
  35. 4150 Throttle Cable Bracket
  36. what wing length for a chute mount?
  37. How to Delete Traction Control?
  38. Wolfe 6 Point--Mounting to the tops of wheel well or above fuel tank??
  39. FTI Summer Blow out sale!
  40. mwc ?
  41. more horsepower
  42. buying wheels/tires, need advice
  43. Upcoming AFCO Price Increase
  44. Manual Rack and Kooks
  45. What should it run??
  46. 4150 TB IAC problem. How do I test this thing?
  47. how can i stop wheelhop after s60 install?
  48. Launch Data for an NA 346 M6 Camaro with Bias-Ply ET Streets
  49. Help with Drag susp wheel hop.
  50. Looking for input on better 60's. Trying different tires.
  51. Lemons12- 370/Ls3 nitrous build
  52. well i guess im a noob at rolling fenders...lets see if this is somewhat normal
  53. Where/How to mount 5th harness point
  54. A/c delete plate, can you retain heat?
  55. 1981 Caprice Classic 4 Door
  56. Remote oil filter housing
  57. race star dark star weigh in
  58. pickup 3-4 tenths
  59. Lets see your oil breather catch can set ups!
  60. What should i expect 60 ft?
  61. Race Fuel
  62. For those of you who are thinking of switching to a 4150 TB setup or E85 Take a look.
  63. Turning a bolt in 6 point into a certed 8 point????
  64. How many people
  65. Solid Roller Build Question
  66. launch question
  67. Battery relocation engine ground location (LT1)
  68. Meziere 119 What's Needed
  69. Modifying front bottom shock mount for new arms
  70. roll cage nhra regulations
  71. What to do to run 12.0??
  72. Drag radials or slicks
  73. What are my options for SYA bars with a stock k
  74. wheel hop
  75. QA1 fronts
  76. hightack questions
  77. Desired Front to Back Height Difference
  78. Anyone know the weight of a carbon fiber VIS hood?
  79. Brake drag question
  80. Affordable helmet
  81. Aftermarket Radiator Fans?
  82. can i hit 11's?
  83. Side mirror delete plates?
  84. MWC 6-pt weights vs Wolfe
  85. Gains from ditching tru trac and going spool?
  86. Help me 60 better
  87. Before and After of my car Re-wiring project
  88. Tires
  89. What causes fish doing
  90. Drag radial recommendation
  91. Parachute ?
  92. comp engineering roll bar
  93. Sparkplugs H/C/I TR6's?
  94. which rear gear ratio for a glide
  95. drag radials
  96. fbody trailer tie down strap question
  97. What would you recommend for options on a trailer?
  98. Welded roll bar in
  99. What track times to expect
  100. 18 Drag Racing Tips
  101. Hoosier QTP or ET Street
  102. Front seat weight...
  103. 25in or 26in front runner?
  104. Hood pin options
  105. Those with roll bars, keep airbags?
  106. New radial build
  107. Lt1
  108. Getting S60 & need bare essentials suspension, Stock Internal/M6
  109. Camaro Push pull battery switch, any installation pictures?
  110. Guys that run at Bristol Dragway Thunder Valley come in!
  111. torque arm talk
  112. Cage welding
  113. moroso 1/2-20x3 tq specs
  114. Travel limiters
  115. IHRA 11.49 cage rule? Altered floor or firewall?
  116. New at cbm
  117. Aluminum driveshaft good for 800-900 hp?
  118. What size tire for 4" skinny and 10 or 8 inch for rear?
  119. Roll Cage pass NHRA regulations?
  120. Delete AC Keep Heat
  121. What are you guys using to cap the heater hose nipples on the water pump
  122. Got question on sensor plugs when I buy my harness
  123. enclosed trailer Info
  124. how close will i be ?
  125. Rear Speedglass- Myth or Not?
  126. RJS 5-pt harness straps too long???
  127. Wheelstand oilpan baffling
  128. Wiring up a MSD 2 step in 99 Camaro???
  129. Will I still be able to race with a cracked fender?
  130. wiring one fan off the stock PCM and harness.
  131. Building Low Budget Drag Car !!
  132. Trailering f-body, where do you attach your straps
  133. Noob 1/4 mile question...
  134. Best way to remove spray underliner
  135. Proper way to adjust DA QA1's?
  136. Finally hit 11s after 9" rear and 90/90 intake but lost mph?
  137. Does your lightweight battery cause your gauge cluster to reset on start up?
  138. Anyone using solid suspension bushings?
  139. Pics of your belly pans and rear tins
  140. 4150 Throttlebody with speed density tune or carb hat to MAF and air lid?
  141. Can I keep my HVAC with a full cage?
  142. Front spring question
  143. Venting valley cover?
  144. Wtb tach for camaro
  145. Speed Glas + Rear View?
  146. Race Readiness Health Check
  147. Can I expect anything better than a 1.9 60 on street tires?
  148. Floor pan strength.
  149. Here comes a new M/T DR!
  150. Strang dragbrakes rear, damn piston ?
  151. TH-400 Trans mount
  152. ltx turbo build?
  153. Why won't it run hard on the backside?
  154. Summit Drag Shocks
  155. Need a good shifter switch M6
  156. Fiberglass VFN doors and weight loss questions
  157. guys with Cheetah shifters, i got a question
  158. Drag LT1 pan
  159. Track on stock tires
  160. Thanks
  161. Looking for slicks. Any opinions?
  162. MADMAN torque arm setup
  163. preloading oem rear sway bar
  164. tire help
  165. Better 60 time is this a bad idea?
  166. MWC antiroll bar wont fit brackets that came on the strange 12 bolt housing
  167. issues with trying to install steel braided line.. wong line?
  168. Praise for an awesome setup
  169. battery cut off switch wiring...
  170. Who's running an M6 with a stock 10-bolt?
  171. Yep, another thread about 60ft times
  172. Help with strange adjustables. UPDATED 10/18
  173. T56 4.88 gears 1/8th mile?
  174. 2012 COPO Specs INSIDE!!
  175. lexan windshields
  176. hooking 2 step up to brake switch question
  177. 8.2 second 1/8th with 2.73 gears?!
  178. Drag Radial Classes?
  179. What alternater bracket with motor plate?
  180. Wolfe Racecraft rear bulkhead?
  181. Want to learn about methanol ??
  182. What all can be removed from behind the dash?
  183. 60ft time
  184. Heading Back to the Track on Friday
  185. Chassis work
  186. where can i get billet keys and rcetrnx htwre kit???
  187. I had traction issues @ MIR last friday
  188. wheel studs
  189. Motor plate 1 or 2 piece?
  190. How much ET would be lost
  191. Nitrous gearing, what neeeds to happen here?
  192. converting BMR control arms from bushing to heims
  193. All mods done ... "Quest for Better ET's & 60's .. Rear DA Coil Overs, 2-Step & LL"
  194. LT1 first start issues
  195. Are rollbars street legal? Also a few other Q's..
  196. can i cut my 5 pount harness?
  197. SA shock settings
  198. E85 questions
  199. PTC Transmissions TH-400
  200. LT1 alcohol carb
  201. To lock or not to lock
  202. Starting new build
  203. 16V Batteries? I'm regulating the stock PCM but what else?
  204. Going back to the track Friday. Tips, comments, suggestions welcomed!
  205. Spinning on Launch - Need Help!
  206. SETTING UP QA1's
  207. What does all DRIVE TIRES MUST BE MATCHED TO BE WITHIN 1/2'' ROLL OUT.
  208. Rear lower control arm question.
  209. fuel cell question
  210. Please Help with Suspension
  211. Hood weight
  212. Pin On Hood
  213. Fuel Line Routing
  214. Is there a exhaust db level restriction at tracks?
  215. scary back and forth wobble at end of the 1/8th
  216. Vacuum pump - how much vacuum should i.....
  217. Charging issue after battery relocate
  218. S. Fla - PBIR Musclecar Challenge 4-7-12
  219. The Grump dead at 81
  220. modified stock rack
  221. 2012 NHRA Rule updates?
  222. Dzus rails on lt body style
  223. weight reduction list
  224. lets play a game ...identify the BBC motorplates ???
  225. Bmr manual steering rack
  226. Deleting interior harness
  227. BBC Burkhart motor plate questions ??? Help
  228. fox boy vs. f-body race weight?
  229. F-body with Dry Sump !! lets see your setup **pic pls**
  230. Helmets!
  231. Do fabricated valve covers need to be vented?
  232. Want to slow car down
  233. If turbos are more efficient and make more power than a sc'er.....then.....???
  234. Another 10 bolt question
  235. Kurt Urban Water Vapor System mount for vic jr intake (pics & demensions)
  236. My modest 01 Camaro build
  237. Everything Out and Ready For Some Welding
  238. kirkey seats fit me ???
  239. Trans Am rear spring weight
  240. What's the didference?
  241. Manual Rack
  242. COPO Anyone?
  243. Rear Mount Battery: Which Battery
  244. Which carb hat are you guys running on your Vic Junior/4150 setup?
  245. Dumb question?
  246. snell m2000 helmet
  247. Front Runner Question
  248. afco da shocks setup
  249. What am I doing wrong? Someone enlighten me!
  250. Loss of power et and mph
