View Full Version : Drag Racing Tech
  1. is any one going to famoso the 18th
  2. Cheapest way to 10's
  3. Which platform would be best for an LSx-powered strip/street car?
  4. GOOD 6 speed drag racers please look
  5. What front Springs are the 6.0 guys running?
  6. Harlan Shift light help
  7. Rim Screw guys.....
  8. Front Sway Bar Delete
  9. trailor info
  10. Cage
  11. Shift light settings
  12. Using DR's and line-lock for first time soon.
  13. Looking for some advice on wheel stud selection
  14. Instant Center Question
  15. 325/50R15 MT on thirdgen?
  16. Which oil pan are you high HP cars using?
  17. Wheel Studs?
  18. Wheels or shocks?
  19. M6 to TH350 net weight difference
  20. anyone have times with different cams
  21. What about the 8pt ROLL BAR from Competition Engineering?
  22. Launching off the Brake - ET Street vs ET DR?
  23. F body weight/distribution
  24. Moser 9" & Strange brakes problem
  25. Line lock?
  26. What would lower E.T more?
  27. rear coilovers
  28. MT 275/60s??
  29. 3" true duals VS Magnaflow mufflers off the collectors
  30. suspention setup on iron block??
  31. 325-50-15 MT DR's + Bogart 15x9.75's
  32. Deleting power steering have questions>>
  33. Weight results...
  34. Stock Airbox Lid mod (Before and After Pics)
  35. ATTN caliper grinders
  36. Hawker Odyssey (PC680T) setups/tie downs
  37. What rim's & tires for front skinnies?
  38. ?????????2" header????????????
  39. Goodyear Eagle SS
  40. car haulers
  41. Chassis Cert at Miller Race Cars in Connecticut Tomorrow
  42. pulling timing based on elapsed time.
  43. Will the (LS1) run and drive with the dash out?
  44. Hood Fastener Question
  45. Broken adjuster knob on Strange shock
  46. Quick Question
  47. Third gen questions
  48. Who has Rewired their car?
  49. Burnouts only dark on edges???
  50. launch and shift skills at the track
  51. Is this trailer worth $2000?
  52. launching stalled auto w/ stock suspension?
  53. lightweight seat question...please help!
  54. Opinions on Wolfe 6-point bolt in
  55. What aftermarket harmonic balancer do you use?
  56. Drag Slicks Question
  57. Need drag radial recommmendation
  58. suspension suggestions?
  59. Rear bumper cover removal method?
  60. Madman....
  61. Solid motor mount question
  62. HELP-engine harness removal
  63. What size tires are you runnin? M6 guys
  64. Got slicks... what should I expect?
  65. how much will i pickup
  66. Roll cage, rear, control arms: My por 15 review
  67. Paging Madman
  68. How to determine what size primaries and collector you need for longtubes headers?
  69. tryin to get ride of some more weight
  70. rear qa's adapters?
  71. Oil pan removal question
  72. clutch dump or slip?
  73. these guys were movin this week,
  74. Need pics of where to weld tabs for anti roll bar
  75. best camaro driveshaft
  76. Question for Big HP Footbrake guys
  77. best weld in roll cage?
  78. is my converter off
  79. ? about NHRA Super Street.
  80. 12v vs 16v systems
  81. for those who have an aftermarket remounted radiator what size?
  82. full cage pics!
  83. Basic M6 Launch Facts Illustrated
  84. 315/60/15 on 10" wide wheel.......
  85. Tire Pressure
  86. The cost of Watching & Racing
  87. ET Front or DS-2 Front Runner Question
  88. Mini Tubbed and Small Set of M/T DR
  89. Need Some Help Please
  90. question about D/A and 1/4 mile E/T[Bristol dragway]
  91. back spacing on a 12 rim
  92. Non R-Type QA1 shocks prove effective for drag racing
  93. Madman Motor Plate
  94. need help with proportion valve
  95. Pacos done and ready for test hits
  96. Rubber on my fender!!!???
  97. Need Pics Of where Cage goes through Firewall..
  98. wheelie bars
  99. going to the track friday
  100. anyone heard of using turpentine and bleach to get better traction on street tires?
  101. Can you lower a trailer?
  102. Thunder Racing Track Day this Sunday!!!
  103. Need Help deciding what front shock/spring set to go with?
  104. Need Help deciding what front shock/spring set to go with?
  105. Chromoly K-member question
  106. Wanna talk to guys with DRs and stock rear
  107. bias ply slick vs radial slick
  108. need some frame/chassie guys please
  109. Looking for new rear drag shocks, need advice.
  110. Off the line with PG
  111. 6spd launch...advice
  112. Numbers
  113. Which shocks to get
  114. how much faster will i be
  115. Part 2 of my project (roll cage) finished. Lots of pics.
  116. Joe Vanoverbeek?????
  117. A few more Race Car progress pictures
  118. Ratcheted tie-down to keep engine from torquing?
  119. Who has the best price on Hoosier tires?
  120. Please Help!!
  121. got my QA1's on today, holy hell
  122. QA1 "R" series users inside please
  123. Weight difference in hoods????
  124. Something missing ....slower then i should be
  125. update part3
  126. should allignment be differnt for track only car?
  127. Addco vs. Spohn 1" rear sway bar.
  128. Camaro 98 VS Corvette C4
  129. which k member is lightest?
  130. What you Paint your Rollcage with?
  131. Need LSX help
  132. people with cut cowls, how does the water drain off the windshied?
  133. Sway bar removed
  134. OK I tried search, need help and parts #'s
  135. th400 Swap Q's please help!
  136. Anybody using fiberglass?
  137. Jaz Vs Kirkey seat
  138. QA1's; but no weight transfer!
  139. Fitting 28x11.5?
  140. Light Weight LS1 Spindle?
  141. Car is slower after some mods??
  142. Whats first for carnage?
  143. putting on hoosier quik time pro's will my rear end break
  144. Help my Engine Bay look like this!
  145. what should i run?
  146. Taller tire?
  147. A little dreaming on engine setup
  148. Where to get QA1's
  149. NHRA or IHRA classes for LSx cars
  150. fuel tank
  151. 9 second suspension??
  152. Accusumps
  153. BMR Xtreme T/A
  154. Front tire Air Pressure
  155. Camera mount for noncaged Camaro?
  156. 28" tires for a 15x8 460rwhp M6 car??
  157. single vs double adj. LCA's
  158. does my mph seem low
  159. Lb to actually 1/4 mile gains??
  160. Need thread pitch for crossmember bolts for lakewood DSL?
  161. custom gauge template
  162. Pro Tree practice?
  163. help me out with first run
  164. fire extinguisher systems for top fuel dragster
  165. Tips for hooking up a turbo/drag radial car
  166. SFC question...
  167. Doing recon on the enemy
  168. K-Members & ET improvements ?
  169. 275 40 17 MT drag radials
  170. how it will gains ?
  171. Carbon Fiber/Fiber Glass body parts
  172. New set up coming together
  173. What will I run?
  174. Wanting to start my suspension build
  175. Is my time far off from what it should be?
  176. Cranked windshield question
  177. So how many of you Drag Racers recieved there LSX Block yet?
  178. update on build.............
  179. Different 10-pt Cage Manufactures
  180. air pressure 325/50/15 on nitrous
  181. 3 Suspension Questions!!!!
  182. setting pinion angle
  183. Hoosier Drag Radials
  184. rear wheel spacer
  185. cage question
  186. MY new setup. help on launching
  187. what would the outcome be??
  188. AJE Spindle Mount
  189. Looking for advice on lightweight glass / lexan
  190. Pics of non stock Dashboards!
  191. Best way to launch 6-speed on 200 shot?
  192. 99gt vs 02 trans am
  193. Pinion Angle ??
  194. Carb Vs FI (not what you think)
  195. Tire Pressure ?
  196. Thunder Spring Track Day
  197. Going to the track for the first time.
  198. IHRA Rollbar Rules (1/8 mile ET)
  199. Finally brought my new project home!
  200. Aerospace front drag kit?
  201. Kirkey seats w/o cage?
  202. WOLFE sway bar
  203. car slower with 4.10s!
  204. Does this need to removed before the track?
  205. Trying to decide on a set of front runners
  206. What tire Pressure in Mickey ET Streets?
  207. Opinions on new setup
  208. LS1 A4 with MS3 cam, spray & drag radials: what will it run?
  209. Potential??
  210. Spring/shock concensus for street/strip car?
  211. Friend giving me springs/shocks off his 02 V6 Camaro, of any use to me? (Fronts?)
  212. qa1 setup question
  213. another launch question
  214. 26 vs 28 inch tire?
  215. About, what should i run??
  216. 5pt harness mounting question
  217. A couple pics of my Cage. Not complete yet.
  218. What battery do you all run?
  219. What kind of things should i expect
  220. Using 300lbs front springs, inside!
  221. Roll Cage
  222. How fast did you start at?
  223. Open Trailers, what are you using hassle free?
  224. Offset LCA's
  225. Jegs Roll Bar?
  226. nitrous converter on motor 60 ft
  227. Where to shift
  228. launching help
  229. drag, ride hight
  230. C6 Drag Set Up ????
  231. Need to keep front sway bar and still reduce 60's.
  232. RMVB Transmissions
  233. Rod ended LCA's and PHR overkill for my car?
  234. 60' help/advice from you guy's
  235. A4 WOT shift point settings
  236. heads cam set up
  237. 29.5x10.5x15 tires mounted
  238. *Update to Mufflers off headers*
  239. Stripped wheel screws ?....Here's the fix !!
  240. 9" narrowed 1"
  241. Another 25.5 build
  242. Strange Shock ?
  243. 325/50/15s
  244. Head options...
  245. The clear answer on fitting 10.5W
  246. Susp HELP
  247. whats your street/strip susp set up ?
  248. will a 3.90 gear with an a4 be to much on the street
  249. Another et question??
  250. Tire press.
