View Full Version : Drag Racing Tech
  1. MS3, PT4000 and the car won't 60 ft, WTF?
  2. prostars, grinding, complete process with 25 pics.
  3. Installed an Odyssey PC680 today
  4. Anyone make an SS cowl hood that goes to the windshield?
  5. engine fusebox relocation???
  6. Insurance question
  7. bumpsteer with flaming river manual rack
  8. where is your coolant overflow mounted?
  9. 16" tire suggestions....MT or Hoosier?
  10. what does it take
  11. drag wise: is the spherical ends LCA worth it !
  12. borla xr1 to headers
  13. drag racing seats
  14. Pictures of my Custom Pin on (56K NO Way)
  15. 325/50/15 fitment
  16. pulled steering wheel need help
  17. pics of collector mufflers
  18. It lives!!!!!!!!!!
  19. Part 1 of my project (mini tubs) finished. Lots of pics.
  20. Whats this for?????
  21. Weight reduction....
  22. Anyone have this problem when installing linelock?
  23. Prostar backspacing - question
  24. Something New to Help the Twins Turbos
  25. 3,540 lbs....
  26. 28" tire w/ 4.10- th350w/ 150 shot
  27. Help me with my wolfe rollcage install
  28. Pro stars need longer studs?
  29. Driveshaft safety loop???
  30. triple gauge pillar, pics of complete install process.
  31. Cage guys inside
  32. Basic Question on times and hp
  33. A3 guys w/aftermarket shifters IN!
  34. Evap box?
  35. Bogart ?
  36. 8.0 In The 1/8th With Nitrous?
  37. Is this OK to Notch out for exhaust Clearance?
  38. PICS of your upper radiator "strap"
  39. Tire combination help, please.
  40. Suspension for 500hp DD
  41. kirkey seats
  42. Kirkey Mount to cage Qs
  43. locar dipsick th350
  44. 02ws6 st car full weight which stall to go with?
  45. Traction Problems....long
  46. MT Drag Slick or BFG Drag Radial?
  47. Vehicle weight
  48. Getting ready for the 12s...
  49. Going to the track for the first time, few ?s
  50. Skinnie tires, what are the lightest steet tires for skinnies
  51. Fire jacket
  52. WTF madman!! Crazy dyno
  53. Pin on Hood Users
  54. Steering wheels
  55. 6-point installed
  56. pulling dash questions
  57. Is it harmful to run open headers?
  58. NHRA rules on gussets and incomplete welds
  59. What are the dimensions on Flowmaster 1 chambers?
  60. Rear firewall ideas
  61. 25.X Chassis cert
  62. Thoughts on cutting backing plates.
  63. Strange manual brake master questions...
  64. To those running mufflers off of the headers
  65. waiting for install on my stall and nitrous
  66. How to delete and properly remove all ABS/TCS???
  67. 325 MT drg radials
  68. Wheelie bars are mocked up. PICS!!
  69. Why do I get pulled down low but not top end? (I have a smaller cam)
  70. Whats next?
  71. Simple Rear sus for a Botlon car???
  72. light weight battery!!!!! And one question
  73. Chromemoly tubing
  74. Bmr Rules!
  75. Were to get Block off plates?
  76. Rule for Driveshaft loop (distance from yoke)
  77. How many have done the front bumper delete?
  78. Wheels spacer ?
  79. mounting vaccum pump to motor plate...
  80. Front suspension setup questions
  81. What is the bar above the panhard bar for?
  82. Bolt-on M6 pulls a tire!
  83. What do I need to mount this harness
  84. 4L60 to TH350 swap questions
  85. now i was told
  86. LS1 to powerglide flexplate
  87. Sonoco 100LL Aviation gas?? Good, bad??
  88. Titanium Drive Shaft
  89. ET Street DR's Tire Pressure ??
  90. Prep for Cage.
  91. Meats and skinnys mounted on bogart D10s
  92. Getting ready for MMP on the 31st. need some help
  93. Metallic Schmutz on my Drainplug
  94. how much time can hitting the rev limiter cost u?
  95. the formula gets a new cage.
  96. How do I remove the side impact bars?
  97. Front Mounted Fuel Cell....Legal?
  98. My plans for 2008 Racing Season - bracket racers inside
  99. 2001ss will 28" drag tires fit ?
  100. What all is needed for a powerglide from 4l60e?
  101. Weather Station
  102. Getting into the 9's?
  103. Fire Jacket needed?
  104. What safety equipment is needed to run a low 11 or a high 10??
  105. QA1 shock
  106. Need Advice.....car is loose at the track....
  107. Powerglide shifter && Seats
  108. M/T Drags vs. M/T Drag radials...weight issues???
  109. 15" Prostar & Draglite people inside please.
  110. ls1>ls2 oil pressure unit!!!
  111. I'm confused
  112. would you doe SFC if you had a 10pt cage?
  113. burkhart chassies
  114. 2 questions about QA1's and STB
  115. Wolfe bolt-in roll cage - help!!
  116. Help With Slicks
  117. Help with tires!!!
  118. First trip to the track...A4 '02 WS.6
  119. thoes with nitrous cams please, check this one out for me
  120. Drag race gurus needed (10's or faster only please)
  121. battery relocation "box"
  122. How can i raise my trap speed
  123. Anyone running sub 1.40 60's N/A with 4:10's ?
  124. HVAC block off plate?
  125. Good 60ft techniques?
  126. ET Streets Vs. Drag Radials
  127. New setup! launching rpm?
  128. New Centerline Convo Pro 15x9 wheels-Pics
  129. Got started on the 25.5 cage
  130. Drag radial guys
  131. Bought a Helment today!
  132. help getting my 60 ft down
  133. Can't keep my voltage up......
  134. Still spinning em'.
  135. maryland int'l raceway
  136. battery wiring
  137. 4 link rearend?
  138. Pics of the short belt mod. !PS& !AC
  139. What Fuel Components with a Fuel Cell?
  140. what rpm to launch at?
  141. Going to the track tomorrow with the vette, any tips?
  142. QA1 coilover question?
  143. Strange Brakes
  144. 1/2" Studs && Aluma stars
  145. LS1 Front Wheel Drive Conversion
  146. What size ARP wheel studs do I need with my Prostars?
  147. F-Body vs C5 ( Debate )
  148. Roll Cage
  149. one of my new qa1 shocks doesn't seem to adjust
  150. TQ Arm & DS Loop
  151. t56 guys wanting the McLeod SFI blowproof bellhousing
  152. Anybody set their car up specifically for the 1/8th mile?
  153. why doesnt my car 60' ?? video
  154. hoosier 28"
  155. ATL dragway - anybody been there for TnT?
  156. min. sus. mods for a sub 1.5 60'
  157. launch RPMs?
  158. lexan questions
  159. 6 point bolt in cage
  160. where can I buy a stall by next week
  161. I need to know what ET numbers
  162. motor plate vs. alternator
  163. Just weighed my car!
  164. caliper grinding? longer studs?
  165. kirkey economy install today tell me what you think!
  166. Putting a convertible into the 12's?
  167. ! rear bumper support
  168. Will this fuel cell work?
  169. standard cowl hoods, benefit?
  170. ET Drags.... L8 vs L4 Compound
  171. Minitub & Wolfe Wheel Well Bars
  172. Drag Coverage
  173. Chassis Design
  174. gears vs. tire size
  175. Burkhart 10 PT Cage is done
  176. what is the correct wat to setup a BMR extreme sway bar
  177. Cam Lock or Latch Harness?
  178. Front runners...
  179. Qa1 settings adj.
  180. Fastest SMALL CAM guys??? What are you running?
  181. Strange or QA1 coilovers DRAG
  182. OZITE Finaly Installed
  183. LT1 Mod/Track time experts inside
  184. Billingsley HVAC delete panel owners: quick question
  185. wolfe mini tub question
  186. update: 25.5, full tub, stock suspended!
  187. flaming river manual rack feels "notchy"
  188. best 60 on a 26in tall slick
  189. M&H Drag Radials
  190. pulley ???????
  191. Crotch bar diameter
  192. 29.5 x 10.5 Question
  193. Which water pump should I get???
  194. Cage coating?
  195. Who wants to go FAST... or FASTER than they are
  196. Parachute question
  197. Wheel Narrowing, Whos does it?
  198. Bolt on M6 short times
  199. average cage install price?
  200. Procharger Vs. Big N20 Motor
  201. pin on hood installed (pics)
  202. Where to splice in for 12V for Autometer Tach?
  203. 4L60e running faster than 9.99? Flexplate shield
  204. 4.10 or 4.30 gear
  205. Cage questions
  206. I can't find any pics of lca relocation brackects installed
  207. Bent Wheel Studs???WTF
  208. Shift points
  209. getting 15x8 pro-stars ... worth it?
  210. What guages are worth buying??
  211. Need help launching
  212. fuel pump question
  213. Not only Ls1Joe can rev to 8000
  214. Need to slow down :(
  215. silly question about drag wheels and drag radials
  216. Help!!! New cam, not much gain...
  217. about $400 to spend
  218. 10 pnt cage
  219. Something wrong with my setup?
  220. New Drag Radial car
  221. LSX TV needs you - NOS LS1/LS2 Billet Nitrous Plate System, FREE from SoCal Area!
  222. Realistic race weight
  223. Help my technique
  224. who has cage in front of dash??
  225. 8pt Cage Installed 56k DEATH
  226. Anybody running 5pt harness with factory seat
  227. Why larger diameter tires?
  228. Emphasis on Drag Racing - Why
  229. Weight Reduction? How much do YOU weigh?
  230. Anybody have SW Race Cars Cage?
  231. pin on hood bracket pics
  232. good start for rear QA1's??
  233. benifit of skinnies?
  234. worth the money??
  235. anyone running madman shock brackets or wolfe door panels?
  236. Pulling interior, need help
  237. jounce spacers, can i remove em completely????
  238. ET Drag vs ET Street
  239. Tubular T56 crossmember
  240. Any Tracks open in decent distance from MI?
  241. Found out how much car weighs
  242. Race car insurance
  243. 10 point cage ???
  244. needed Wolfe mini tub interior pics
  245. Props from Neal Chance
  246. bogart owners...
  247. Anyone know the difference in weight between these rims?
  248. thanks madman and thunder
  249. Welders inside
  250. wheel studs at all 4 corners QUESTIONS!?!?!?
