View Full Version : Drag Racing Tech
  1. How to remove backing plates? Tried search nothing!!
  2. Light (but quiet) exhaust?
  3. narrowing a rear end?
  4. Those with pin on hoods, please come in
  5. for drag racing is it better to have a shorter or longer torque arm? why?
  6. Where is all the weight at?
  7. Bad tire shake w/ MT 325/50s what to do?
  8. 275/50/15s or 325/50/15s?
  9. Just installed the MN12 into my T/A
  10. HVAC control delete plate
  11. Drag Car Start
  12. Damn Decisions
  13. back spacing question....
  14. What to look for in a single layer fire jacket???
  15. Pics of my new 383 mocked up
  16. what RPM do u shift at for a similar setup like mine?
  17. I need pics of the bracket for a kirkey with Kirkey bracket
  18. Hoosier QT-DOT question
  19. No WIPER motors, Is there a water drain???
  20. Battery mounted under bumper cover--pics inside--
  21. custom painted helmets.
  22. 12:1 compression and 104 octane
  23. 2 questions about this coming spring/summer...
  24. which side would you mount the battery on in the rear, pass or driver?
  25. Tires 4 launching w/trans brake
  26. MT radials ?????????
  27. opinions wanted
  28. now im trying a different carpet other than OZITE
  29. NHRA Rules Question
  30. Michelin PS2s at the drag strip
  31. 275 1st gear in th350
  32. Can sombody explain to a mustang guy on why a stock stalled LS1 traps lower on slicks
  33. what is the difference between stiff side walls and soft for slicks?
  34. M/T ET Street DR 325/50 15s..Anyone
  35. Do you need the BCM for the power windows to know when to stop?
  36. question about 4.6 mod motors
  37. Anyone running M/T 295.65.15 DR?
  38. Manual Rack Question...Where to buy?
  39. what size slicks are you running
  40. New shirts
  41. 4CYLH8R clear your pm's
  42. probebly a old question but...
  43. Update pics from Burkhart 10 pt install
  44. Need Specs and Dimensions of 4-Link Brackets, Coil over brackets etc
  45. Just installed my M/T ET Street Radials, and I have a few questions.
  46. My 25.5 Turbo Firebird buildup (lots of photos!)
  47. Remote oil filter kit?
  48. How do I choose rear spring rate?
  49. Whats the difference in a Pro Tree Tbrake and a Bracket racing Tbrake?
  50. Vigi 3600 60' Times?
  51. Who made the rules on having rollcages?
  52. Poll: What drag slick hooks harder Hoosier or M/T???
  53. M6 car - Can you be in 3rd while going though the traps?
  54. how big of a motor ls based will i need
  55. Cooling Requirement
  56. Eibach Prokit for Drag/Dig racing?? Is that nuts?
  57. How about Telstar 16 X 9.5 X 7BS, instead of grinding 15's???
  58. Oil pan for drag racing
  59. Might sell the nova to start new turbo camaro project
  60. Relocating the lap belts for 5 point harness?
  61. Race tire article
  62. Mad Mans Steering Rack
  63. How much cowl can be cut off with stock windshield?
  64. To thoes with pro mag RR's... come in!
  65. more important E.T. or 1/4 mile time?
  66. burnout question?
  67. Tire for street driving and street racing???
  68. Mini Tub question
  69. Got my Strange Brakes from Billingsley Got ?
  70. Motor plate vs Motor Mount
  71. big problem and im going to the track tomorrow
  72. STB in Drag Car
  73. Wiring in a delay box
  74. Would this make it lighter?
  75. the carnage continues.. love turbo power
  76. 2007 NHRA Rule Book...PDF
  77. Warren Johnson's new ride
  78. another "what should I run" thread!
  79. VHT Trackbite on the streets?
  80. can optima battery be mounted upside down?
  81. Where to find vinyl trailer panels
  82. How to launch a M6 with street tires?
  83. Battery relocation
  84. rockers: crower vs. pro mags
  85. can some1 explain to me adjustable control arms???
  86. MT Drag Radials
  87. some pics of my 6speed street car build/rebuild
  88. Mods and poss times at track...
  89. What is needed to convert to a fuel cell?
  90. Will this Throttle Body work??
  91. H/C or cam only A4, what's your trap?
  92. Torque arm decision...
  93. A little Progress *Pics*
  94. Aftermarket Valve Covers & PCV setup question
  95. Did I screw up getting a Moser 12 bolt?
  96. got my 28in tires to fit
  97. QA1's or Strange single adjustables?
  98. what rockers?
  99. Madman got a question...
  100. Wheel Hop hell vs. ford heaven
  101. How much space do you have?
  102. need help with carpet install in race car
  103. 2-step install
  104. help
  105. Quick/easy drag racing QA1 question
  106. ATTN madman tq arm users!!! INSIDE!!!!
  107. exhaust?
  108. Meziere Race Waterpump?
  109. Dropped the car off at Burkhart for a 10 PT today
  110. Which Kirkey fits best???
  111. 10 bolt w/aluminum driveshaft
  112. First race tonight. WTF do I do???
  113. Narrowed 12 Bolt .. Strange vs Moser
  114. 325's vs 275's & wheel set-up for my car
  115. Would 97 SS 17x9 wheels allow me to run a taller drag radial tucked in wheel wells?
  116. 16" Firebird wheel weight?
  117. What brake setup are you using?
  118. weight diff. between Mild steel and Chromoly (6point bar)
  119. QA1s...adjust
  120. Bumpsteer Kit help
  121. M/T Drag Radial or Hoosier DOT Drag Radial?
  122. How long has your project car taken?
  123. Opinions on Gforce, Force 1, and Proforce hybrid helmets
  124. Lights and turn signals
  125. any one got pics of 28in tire
  126. Quick Tire ?....
  127. Getting rid of ABS...whats needed?
  128. whats next?
  129. what will i run?
  130. LT1 Z28 Body "vs" LS1 Z28 Body
  131. Ed Curtis website, phone # ?????
  132. NHRA regs for T-Tops.
  133. 10.99 on radials in full weight m6 car, possible?
  134. My Track Star Wheels Finally Showed Up
  135. Actual weight of WS6 hood........
  136. gotta head question
  137. jegs wheels
  138. How much was your Rollbar Installed?
  139. What tires you guys having the best of luck with?
  140. guys without consoles
  141. AJE K-members
  142. Crank Windows?
  143. need help with a spool
  144. Switch Pannels Post up some Pics
  145. What's the average weight?
  146. Eibach Drag Launch Spring Kit
  147. Guys running Hal Qa1's /w stock springs whats your 60'
  148. "Racing" Colum
  149. Hey guys vote for your favorite pinks show
  150. pics of the clearance on 28" ET Drags
  151. Custom Harness
  152. Shake down video
  153. Sphoon Solid Mounts
  154. what are my options for 2step on ls1?
  155. broken parts pics from today
  156. few pictures of my cars progress
  157. 1st time at the track dissapointment
  158. finally closed on property in South carolinia, wohooooooooo
  159. Starting on roll cage, where to start?
  160. Madman is da shit!
  161. strange/aerospace drag brake rotor diameter??
  162. looking for pics of lightened front ends.
  163. TH400 and a gear vendors?
  164. msd retard box question
  165. Does gearing play into HP calcs?
  166. Manual Trans and MT ET Street Radials
  167. weight reduction-worth it?
  168. Paging Harlan (y2khawk): How to hook 2-step in with delay box?
  169. Please post Vids for a DVD!!
  170. Squeezing the most out of my setup... help
  171. Can I see some pics of your cage/harness set up??
  172. how much am i giving up not going to the 325 MT radials from the 275?
  173. making some real progress on my car 25.2
  174. underdrive pulley worth it?
  175. Calculating shift points...
  176. What 60ft Should I expect?
  177. Finetuning street/strip shocks and springs
  178. Oil and Filters
  179. rear springs question
  180. Propane and NHRA rules?
  181. metal/plastic gas tanks, weight loss
  182. Question about the cage in a car I might buy...
  183. Whos got gauges mounted in a camaro dash
  184. Is 12lbs good for a molded carpet?
  185. launch in a vette
  186. Any recommendations on powerglide
  187. Sheetmetal intake opinions please?
  188. M/t 28/10.5-15S Et Drag
  189. SJM PHB and LCAs???
  190. front bumper reinforcement
  191. how to launch in an A4
  192. Need pics of car with mini tub & rollcage:
  193. anybody here from, south Carolinia
  194. anyone with an 8.8?
  195. Simpson 5pt harness???
  196. updated pics of my 81 camaro
  197. Am I asking for trouble? (12 bolt+ 700+RWHP)
  198. Launch question/problem/solution
  199. Stock Internal guys: What gear, converter, & tire combo are you running?
  200. Seat mounting/NHRA tech question - Madman?
  201. Trailer / Generator Question ??
  202. Drag strut rebuild
  203. MT ET drags 29.50x11.50x15~~ have you?
  204. Comp. Engineering drag shocks
  205. Got my panhard bar today.. pics inside
  206. Solid Mounts & Manual Rack
  207. Street Setups, hooking up decent
  208. Congrats Tom Kempf! (and me) - GM High Tech
  209. any body using a grant wheel with 2 switch holes?
  210. how to line up rearend with adj. panhard bar
  211. Ls1 Trans ?
  212. drag brake kits
  213. coil relocation pics please.
  214. new department
  215. pro stock wing
  216. got some ozite carpet on the way!
  217. QA1 R Series VS Strange Coil Overs
  218. Cuttin Bump Stops
  219. Kirkey mounts
  220. Lt1 Brakes
  221. rear axle bump stops?
  222. Who will win/ estimate time
  223. Electric vacuum pump help-recommendations
  224. calling all suspention kings!!!
  225. Need help keeping front end down
  226. Roll Cage :)
  227. A Question for guys with aerospace brake kit
  228. Stiffer/rougher ride normal with Spohn drag bar?
  229. Universal fit racing radiators- what is right size?
  230. New Hoosier slicks. Squirrely up top??? Scary
  231. Bigger Is Better
  232. anyone run their LS1 Z28/LS1 firehawk at the track 100% stock?? or dyno??
  233. Aluminum or steel billet flywheel???please help
  234. A few pics with drag and street tires.
  235. M6 guys with gears... got a ?
  236. Stock Manifolds and catted y to LT headers and ORY weight saving??
  237. New cam installed car does not seem much faster.... Input?
  238. New NHRA Rule?
  239. QA1 "R" front springs
  240. Anyone know the weight of a 4th gen rear hatch?
  241. Harlan 2-step
  242. S60 Narrowed, Weld Prostars w/ MT 325/50's *PIC'S*
  243. Torco Concentracion Vs. Race Fuel
  244. Traction control when racing.
  245. Hooser 315-35-17 drag radial vs MT ??
  246. How many have had to cut floorboard for T/A?
  247. Anyone using a spool on the street?
  248. New Product
  249. Noob here, Going to the track tommorrow.
  250. Engine Package
