View Full Version : Drag Racing Tech
  1. are swing-outs NHRA legal??
  2. Need wheels/tires for track... 16" TA wheels or 17" WS6? MT's....
  3. What will give me the best gains?
  4. Drag Racing Experts Get In Here Please!
  5. 93 cobra vs. 99 TA for $300 bucks
  6. a couple of ?'s for yall
  7. Launching with 4400 stall and ET Streets
  8. Z06's virgin 1/4m Visit
  9. Front End Frame modifications
  10. Tire opinion's please
  11. M/T ET Front Runners
  12. How much Tubing to order for 10pt cage install??
  13. BMR or SPOHN Swaybar
  14. 03 cobra with pulley and programmer?
  15. Tell me the REAL world difference between 275/40/17 & 315/35/17 drag radials..
  16. 2.73s to 3.73s
  17. What do you guys use to 'cut stuff out'
  18. rear sway bar???
  19. Red Rocket Update
  20. Rear sway bar removal?
  21. I think I messed up on my mini tub
  22. serpentine belt removal?
  23. mixed results with my qa1s Rs
  24. HVAC removal & still street drivng it.
  25. SYABs on a stock K-member?
  26. Theoretical what would it run nitrous question?
  27. Hows this setup sound guys?
  28. Intake coolers.
  29. Drag racing on Bilstein HDs?
  30. need help ASAP!
  31. Suspension set-up
  32. Enough for 9's NA??
  33. /rant Lost .4 off my E.T. need help.
  34. mileage?
  35. Parachute mounts that don't interfere w/ license plate?
  36. Madman: Motorplate Question
  37. Reducing curb weight
  38. Clear up trap speed question
  39. Guys with WOLFE bolt in 6 point inside please
  40. Weld in Roll Bar and gas tank
  41. do i have to have a linelock with an m6 at the track?
  42. "Late Model Shootout" at Drag Warz II
  43. Air Bags
  44. Icing down the intake.
  45. Best way to launch an Automatic at the strip?
  46. Mini Tub question
  47. which way?
  48. i've kept my one pass wonder on record the past 3 weeks
  49. Better traction with which tires?
  50. How much RWHP to break into the 9's?
  51. Daily driver- weight
  52. Putting a LS1 motor in an early 4th gen or v6 body...
  53. Rear Suspension Setup
  54. for all you hvac whiners
  55. What RPM's do i launch at with a stock car?
  56. 28" tire growth?? Trim bumpers?
  57. cobalt? 8 sec qmile?!?
  58. Sharing an idea(seat belt mounting)
  59. How to drive with skiny wheels?
  60. Where to get a bolt in roll bar?
  61. HVAC removal, but keeping heat?
  62. Which SPAL fan are you guys running?
  63. Newest project
  64. Mickys
  65. Pictures of my heater core removal
  66. heres my set up finally done *pics included*
  67. what are the nhra rules for fire extinguishers?
  68. pics of !AC?
  69. Copper Head Gaskets on LS Engines
  70. WHEEL HOP....next tip???? analyze this
  71. tcs guys with line locks...
  72. Help!!
  73. Those who slip a Ram HD
  74. 1000' times
  75. My new engine.
  76. help with suspension
  77. Time Slip reading *bad track*
  78. widest tire in wheelwell
  79. Best size slick??
  80. Wheel And Tire Question
  81. Hmm...ET Street bias or radials?
  82. Pics of my 6 pt. cage
  83. Need some pics on how to mount anti-roll bar
  84. Heat/Humidity adds how much to ET?
  85. Strange brake few question
  86. will they let me race?
  87. My "custom" cold air intake
  88. Anybody with 28x10.5's/325/50/15's lowered?
  89. poor runs at track-think i need some help sorting it out..
  90. driveshaft loop hit while making tight turns
  91. need advice on Spohn solids!!!!(long read)
  92. I'm an IDIOT
  93. Ice Dude
  94. NMCA Car Craft Street Race...
  95. Strange drag brake user inside please...
  96. Hot out so I thought I would do a few drag racing related transmission mods..
  97. Nitrous Cam
  98. Ordered 15x10 wheels with 5" backspace...how much to narrow rear?
  99. Suspension on race day.
  100. 60fts with street tires.What ones hook best?
  101. How light can you get a 93-97 Camaro?
  102. How much power is in stage 2 or 3 heads
  103. Finally Got some new Pic's. 28"s
  104. ET Streets + Stock GTO + stock Clutch???
  105. Need Drag radial input on best tire!!!!
  106. worn out dragradials?
  107. Launching an M6 with DR's??
  108. I need help deciding what to buy?
  109. Some of the projects that we have going on at the shop!!
  110. Launching off a transbrake?
  111. Where is SUX2BU???
  112. HVAC removal...
  113. I need help choosing the right gear ratio...
  114. Best 60' with DRs on stock stall?
  115. What size gauges fit A/C vents?
  116. Need Cage Install Advice
  117. Sneak Peak Project 02SilverZ
  118. racing seats, brands and ???
  119. Can I see pics of your front suspension travel limiters?
  120. Need info on Pete Z bars
  121. What kind of times?
  122. Goodyear Eagle SS 325-50-15
  123. Single turbo won't hook on street tires; advice please on my set up.
  124. Rebuilt QA1 front shocks
  125. 1.8 rockers not compatible with cams
  126. Open Headers, Why not?
  127. Ccw Drag Pack!
  128. apropriate 60' for ET??
  129. Edelbrock Victor Jr LS1 intake???
  130. Write up for !washer fluid?
  131. The fastest people have gone with an A4 tranny?
  132. Quiet Mufflers for the Street which work??
  133. weight?
  134. 4 link setup
  135. Help me pick a gear ratio please!!
  136. What in the world do I need to do to hook? (long)
  137. Removing AC -- throw a code?
  138. Can't Hook Anymore
  139. How to launch my stalled car on radials
  140. 5500 stall a good match
  141. Pics of 29" MT Sportmans on my '98 TA
  142. 6 speed launch on slicks... HELP!
  143. Can't Hook? M/T DR's 275/45/17s
  144. Best wheel combo?
  145. Will the cowl hood help my aerodynamics ?
  146. Will 3.73s,stall & DRs cut a second off 1/4?
  147. 28in Slick Rubs Fender, How To Fix?
  148. What sealed battery box for spare tire well?
  149. rules on stock suspension?
  150. Launching my M6 W/ Hoosier Drag Radials
  151. Magnums back from powdercoating
  152. Poor man's Ram Air pics
  153. Pics and specifics on how your 5 point harness is mounted
  154. who do i finish my wiring??
  155. first time to drag race...
  156. Battery Tiedown Suggestions?
  157. Any LT1 guys with SYA bars out there????
  158. How Low is to Low on the front end?
  159. How good is a 1.5 second sixty?
  160. Problem with Harlan 2-Step, anybody else have a similar issue?
  161. Need help with division rules
  162. new to track scene help!
  163. Will sfcs help my times at all?
  164. Do you carry a fire extinguisher in the car?
  165. MT drag radial or Hoosier QTP??
  166. Transmission
  167. Pics of my Aerospace lightweight Brake conversion
  168. Has anyone tried the new Hoosier P335/35/17 DR’S?
  169. Joe Van O Race Car Body Parts available at Stenod Performance
  170. what is the difference by adding subframe connectors?
  171. 2 Step?
  172. Sponsored cars Owners
  173. Going on a diet! (car)
  174. Tips for a new 1/4 mile racer?
  175. Hal shock settings at the track
  176. A3 center Consol
  177. V6 springs vs Stock V8 springs
  178. What is the NHRA 5 Point safety harness recertification frequency?
  179. Prothane motor mounts and trans mount...what's your opinion?
  180. what makes my car inconsistent???
  181. Help Installing Pin-On Hatch
  182. Must Optima's be enclosed?
  183. Ticket for Hoosier QTP's?
  184. Pro Stock Wing's
  185. Wolfe mini tub/narrow rear??
  186. How to fold a parachute
  187. ET Streets fitment
  188. Castrol Blue Hydraulic Fluid
  189. please help me get my suspension setup & car faster!!
  190. how much of difference w/ relocation brackets and LCA
  191. Stenod Performance weld-in 6 and 8 point roll bar kits!!
  192. DSL requirements?
  193. Getting licensed/certified for <9.99
  194. Gears/Torque converter launch
  195. 1.4x (and lower) drag radial people....
  196. Got new gears and I'm not sure how to launch it JUST right...
  197. what am i going to run???
  198. 60' with 17" MT drag radials?
  199. need input on my set-up
  200. anyone use or make a throtle cable?
  201. 28 x 9 slick... which one?
  202. LT w/AIR and E or O2 Bung
  203. 2nd gen camaro suspension
  204. Harlan wiring?????
  205. 1st Gen camaro or LS1 T/A make a better drag car?
  206. Lift off hood on a TA?
  207. people with alumastar/magnums/etc - lugnut question
  208. Trailor Queen?
  209. Air Filter Poll
  210. pin on hood question
  211. crash bars in the doors
  212. rpm/tire speed correlation
  213. Fully tubbed 4th gens?
  214. shocks
  215. WTF Where did the Wolfe tub thread go?
  216. anyone running the synergy 2 step yet?
  217. How do you stop?
  218. How hard to learn to weld Chromoly, kinda bummed with the car
  219. Spohn drag bar WORKS!
  220. Better launching
  221. 13.089 with headers ???
  222. Need Specs and Dimensions for BBC motor Plate in a 4th Gen...!
  223. Packing a Simpson Drag Chute.............
  224. ET gains from LT header install
  225. SLP Linelock Kit Installed
  226. M/T drag radials....What pressure are you running at the track?
  227. what size stall = m6
  228. Which Angle For Madman's Torque arm?
  229. Books on setting up a modern Fbody to hook..?
  230. Wolfe... You are needed here
  231. tech inspect. question.
  232. Anybody need some drag front end parts??
  233. Ride Height Help!!!
  234. I'm an idiot!
  235. Front bumper support on TA
  236. Wolfe 10pt install pics
  237. anyone with comp 3-way drag shocks??
  238. What battery relocation kit, battery box, kill switch, and battery should I buy?
  239. gutting now in process, *pics inside*
  240. Lightest drag radial?
  241. Drag race car won't start periodically!
  242. What's the next weak link?
  243. Water Wetter or Purple Ice
  244. Rear Sway Bar
  245. Rear swaybar upgrade....I did search
  246. Began Fabbing up Fuel Cell, Battery Box, and prep for 10pt cage.
  247. launching off a 100 shot
  248. Guy's with E/waterpump- Ever run at the track with no belt
  249. a few questions
  250. What backspacing for a 12" wheel?
