View Full Version : Drag Racing Tech
  1. Rear swaybar upgrade....I did search
  2. Began Fabbing up Fuel Cell, Battery Box, and prep for 10pt cage.
  3. launching off a 100 shot
  4. Guy's with E/waterpump- Ever run at the track with no belt
  5. a few questions
  6. What backspacing for a 12" wheel?
  7. Lightweight battery?
  8. Help !
  9. anyone run Diamond Racing wheels?
  10. Engine Quits on hard launch???
  11. Flaming River kill switch... which way is on and off?
  12. how to remove airbag?
  13. Anyone get rid of their headlight motors on a firebird?
  14. Did anybody else Get invited to the GMHTP Budget Shootout?
  15. Anyone make a lightweight alternator?
  16. Pin-on Hatch Pic's Needed
  17. What rear springs do yall recommend?
  18. Anyone Fab up a Sheet Metal Dash in a 4th Gen??
  19. Questions About 29.5x10.5ws
  20. BMR Xtreme Torque Arm
  21. What kind of 60 foots are you lowered guys running?
  22. Need help choosing wheel and tires for track
  23. Intake Manifolds for Street/Strip
  24. IHRA rules. Does this sound right?
  25. !Baffles & Sealing airbox worth it?
  26. Battery relocation benefit question
  27. my lca re-locating brackets have a top and bottom hole.which do i use for dragracing?
  28. 2 step???
  29. anybody running a vacuum pump with a race EWP?
  30. 15" DRs or 17" Drs?
  31. 15" Light Wheels
  32. Two-steps 101
  33. I want to hook!!! need advice from those who have been there
  34. Finally Got It!!
  35. Keeping oil pressure on wheelie
  36. Heads/Cam M6 Guys - What Are You Running?
  37. Th400 with Vig 3200 ok for spray?
  38. what sway bar is right for me?
  39. suspension question
  40. Switched to MT dr
  41. Rim screws???
  42. Slicks vs. DRs
  43. RPM launching tip?
  44. Do I need belts through the seat?
  45. will I get the wheels up?
  46. ATTN, Big Mike, update #2
  47. Tranny help!!!
  48. launching
  49. what safety equipment do i need?
  50. pics of wolfe door panel and parachute installs needed
  51. custom shock mounts?
  52. No Rear Sway Bar = better 60's???
  53. Long Night at the Track - ABS INOP issues?
  54. whats the most HP on stock bottom end
  55. what should i be expecting for an ET
  56. what shift point to go 93mph in 2nd gear with 3.73 gear
  57. any 4L60e in nhra stock elim/top stock?
  58. Cam only
  59. A4 racing in D or OD for Drag racing?
  60. NHRA Rules Help... Please
  61. Got my IHRA license today
  62. Tire Pressure on street tires/F-body track preparation
  63. can any one explain DA to me?
  64. Longer studs required in front with drag wheels and shank lugs?
  65. whats your current project?
  66. Questions about relocation brackets
  67. 4.56's to 4.88's
  68. what do you think i will run?
  69. looks just like big mikes..
  70. Question about tire size
  71. ???'s a3 swap
  72. Wheelie Bars
  73. what psi for 28" ET drags
  74. Lack of Swaybar question
  75. 3-Point Saftey Harness/Seat Belt if in 11s?
  76. drag guys, what radiator?
  77. I got my Mad Man SYA bars installed!!!
  78. Skinnies on street.. What PSI?
  79. 60's: stock stall and dr's
  80. Which K-member setup?
  81. Do you think this is worth 5 tenths?
  82. How long can you store race gas?
  83. ? about spool....
  84. Santhuff spindle mount
  85. Slicks/skinnies but dr's w/ skinnies?
  86. How do you launch?
  87. Whos got the fastest 6 speed <500 RWHP?
  88. Advice / Help wanted
  89. Best $199.99 helmet?
  90. Help wanted
  91. What's the best Chassis Engineering book for a torque arm set-up?
  92. so is my rearend going to blow?
  93. First timer tips* stock a4 drag race help???
  94. lightweight batteries
  95. Can't get my dash out
  96. Speedometer in f-body with turbo 400
  97. Grant wheel on 02 TA
  98. Higher 60 foots.
  99. Tire size help...
  100. I have got to do something...no traction
  101. 4.10s
  102. Tell me its possible to get better than
  103. Charging issues
  104. Decided to go with a fully welded sway bar instead of the bolt in
  105. m6 guys, any luck with the 275nittos 28"
  106. Convo Pros on a Trans Am?
  107. My Lt1 drag times
  108. Bogart's customized for a Firehawk.
  109. More progress pics 3
  110. Which launches harder..camaro w/ 9 inch w/ slicks, or awd EVO
  111. Whos running good times with stock heads?
  112. Thinking about changing up my mods, tell me what you think.
  113. typical loss from 100deg heat and high elevation?
  114. Is it legal (NHRA) to rivet something to your cage???
  115. Safety Equipment for 11s
  116. Torque arms and rear ends
  117. AC box removal
  118. Need Help Bad!!!!!! Battery Relocation
  119. Density Altitude simple question, been a while!
  120. I have $6.5k to spend...need help/ideas.
  121. Rpm
  122. 9" question for high hp Manual cars
  123. Stalled A4 vs. M6
  124. I started my roll bar install.Pics.
  125. BFG DRs!!!!!!
  126. Edelbrock Performer Kit vs EFI
  127. A few questions
  128. Storage life of MT slicks.
  129. What Springs For Mti X1 Cam?
  130. WHAT TIRE PRESURE Drag Radials M/T 275/40/17.
  131. Is a dual-disk clutch ok for a 400 rwhp car?
  132. Head Wind
  133. Slicks+full thorottle transbrake launch=close call with the wall-need suspension help
  134. hinges for fiberglass doors 3rd gen
  135. Pulled everything!
  136. Launch Advice with new set-up
  137. Battery Relocation - Alternator Kill
  138. ET'S for my LS1
  139. competition engineering rear drag shocks
  140. sway bar
  141. Has anyone ever....
  142. Weather stations.?.?.?.?.?.?
  143. slick track techique
  144. New track Problem!
  145. Airbags to make up for rear shocks?
  146. power shifter
  147. ET Streets/speed correction
  148. New M&H DR tires for 15-17 in rims in INTERESTING sizes
  149. Tq. Arm and Koni settings for the 1/4?
  150. Anyone use a practice tree?
  151. any one use these
  152. air bag
  153. Air Shifter vs Electric Solenoid Shifter
  154. Can I remove the airbag and keep the radio controls?
  155. Car sitting funny
  156. help with suspension setup
  157. post some pics of your rear mounted fuel cells
  158. Quick instant center question
  159. Who rebuilds QA1's
  160. Mounting engine to BMR k-member
  161. average trans am times..
  162. what psi?
  163. Help with M6 Radial car please.
  164. Anybody ever have a problem installing Wolfe spring perches?
  165. car wants to bog....
  166. 60' Talk - If you're already hooking...
  167. 400 rwhp, stock 10 bolt on a t56. dr's a bad idea?
  168. Strange Rear brake install
  169. How Much Hp??
  170. Is 16' trailor long enough?
  171. T-tops shattering with slicks?
  172. Steering Wheel
  173. Please tell me I don't need Bead Screws
  174. What is the LSx NA/Hyd cam/A4 record?
  175. What Tq Arm Set-up are you running?
  176. Think i can hit the 11's
  177. New to the Manual (Need Tips)
  178. Show me your shut off/kill switches!
  179. conversion help
  180. header ?
  181. headers or gears
  182. Getting my T/A more consistent
  183. 28'' Slick for a N/A 396 LT1?
  184. whats the least amount of tire for a M6
  185. What kind of times could I expect?
  186. First time at the track...ever! Any more pointers?
  187. mufflers
  188. How @ risk am I to break something ?
  189. Who wrote the book on 4-links?
  190. big mikes killer..
  191. Inferiority Complex
  192. When to shift?
  193. Shifting at the track
  194. new exhaust
  195. How do you guys brake in a motor????
  196. 3.73 to 4.11
  197. tires contacting fenders on launch
  198. aftermarket steering column guys in here
  199. car hooks then unloads
  200. Th400/JW Ultrabell Users Inside, Questions???
  201. How many tenths will MT drag radials shave off?
  202. How much does the AC weigh?
  203. Goin' to the Track Next Weekend
  204. fastest factory shortblock ls1
  205. Daily altitude tool
  206. tires or suspension first? putting out over 400 hp
  207. Looking for pics of different drag wheels on F- bodys
  208. Tire weight question.
  209. Poor man's W2W standalone mount
  210. Lug nut question
  211. What have you stock lt1 guys ran in the 1/8 and the 1/4 ?
  212. New 1/4 Time For The Stang!!!
  213. How to lower 60ft times
  214. 347 vs 383 for Drag Racing/Street car?
  215. Weight question.
  216. Who's running The new Eagle SS Radials?
  217. Progress on my car
  218. ARP wheel studs on Back order what other options?
  219. Difference in area?
  220. 1/8 to 1/4 mile
  221. Which car to have the advatage @ the 1/4? mile?
  222. drag only guys....e-brake question
  223. slicks and transbrake obsolete?
  224. Santa Claus came early
  225. Drag Radial combo for C6 Vette
  226. Attention G-Force
  227. frontsway bar!
  228. 1/4 mile time and rear end ratio
  229. Lexan Windshield Install?
  230. how-to front bumper support removal?
  231. Shocks... Questions
  232. Moser 9" - 420WHP - M6 - 17" M/T DRs - Any chance of hooking??
  233. Hooking on the street
  234. Battery Relocation Cleanup
  235. When is it enough?
  236. Foggy Winshield????
  237. Battery relocation. How many fused?
  238. Latest pics of the race car - new interior
  239. 3600 vs 4000 Stall ET?
  240. Is it safe to drag race with Rear-Jounce-wheel Spacers?
  241. removing nose and rear valance
  242. Narrowed rears and parking breaks
  243. Question on Strange Rear BRakes
  244. How to unhook wire connector on driver's side firewall
  245. Ford 9" Rear Back Brace?
  246. Why DON'T We Want the Rear to Squat?
  247. some staging tips
  248. Tires for 4.56's to get it back to 4.10's?
  249. proper c/a angle?
  250. Thinking of getting some guages, need advice
