View Full Version : Drag Racing Tech
  1. afco da shocks setup
  2. What am I doing wrong? Someone enlighten me!
  3. Loss of power et and mph
  4. Al Corda C5 Corvette LS1 NHRA C/SA Stock Eliminator
  5. New M/T ET Street Pro
  6. Hooking Up
  7. HELP! problem with TH400 shifter cable...
  8. Need some help with Wiring
  9. which rear tires for big power camaro
  10. Best tire for very bad track / no prep / old asphalt
  11. Edelbrock Fuel Rail Plumbing
  12. TH350C anyone?
  13. BFG G-force DRs
  14. SDPC heads ?
  15. Rear Wing on 98-02 Camaro
  16. Power cable, Driver's side firewall
  17. Motor Mounts....Solid or Poly?
  18. How to tell if I need adjustable lower control arms
  19. 02 camaro street car build
  20. Rear arm and chassis bracing
  21. Can I put a lightweight battery *here*?
  22. Going for the Record
  23. AFCO settings
  24. What size tire th350 and possible nitrous
  25. e.t. gain from removing front sway bar?
  26. ? Shock and spring
  27. Drag Bar ripped from frame. OOPS!!
  28. Lets talk about Nitrous 6 speed cars and Gear and tire combos.
  29. Smaller tires in rear than up front, is this safe?
  30. Burkhart Chassis Tax Sale
  31. Balancing a Drag Radial??
  32. sonoco extended lifting at top end
  33. After crash rebuild by Midwest Chassis!
  34. Dana S60 spool and gear set
  35. Cutting Dash With For Roll Bar
  36. NEW: Burkhart rear Bumper Support
  37. Why Is Concrete Better?
  38. Big discount on Rhino Ramps - car inspection/maintenance ramps
  39. problems with door bars hitting door panels
  40. Lightweight battery
  41. What kind of Motor Mounts
  42. What else do I need?
  43. Roll bar padding
  44. Using stock steering rack wo the pump in a race application
  45. Is 1 5/8 .134" ews 10point roll cage nhra legal?
  46. World`s Quickest ZR1
  47. Going down the 1/4 for the first time... Come give me tips
  48. Do slicks provide the same grip spinning at higher speeds?
  49. Driveshaft safety loop recomendations?
  50. Bmr Xtreme Rear Drag Bar
  51. blown 434 4th gen tubbed
  52. Optima yellow ?
  53. opening weekend of race season
  54. motor plate/mid plate question
  55. Compression/Boost
  56. Lighter ele. fans
  57. Chicago People or anyone within 100miles take a look! Chassis Seminar
  58. What Harnesses are you guys using in your cars?
  59. 98 Camaro Drag Build
  60. RCI trans blanket for TH400?
  61. Airbag delete w/out taking dash out?
  62. Kuwaiti 25.3 tran am @ burkhart chassi .
  63. Truck coils relocation places on a camaro
  64. removing powersteering with 17" rims...
  65. need help: drag wheel fitment pics inside
  66. Pics of pin on hatches.
  67. BBC, F3-r, on alcohol, HELP!!!!
  68. Champion wheels?
  69. Question on 6 point roll bar
  70. Feedback on helmet for autox
  71. 26x10.5 et street on 15x10 wheel
  72. GZ LSX Vaccum pump need help pls!!!
  73. 4150 air cleaner pics!!
  74. Made it to 11s but trap might be low, ideas?
  75. Drag Racers: Optimum gearing suggestion
  76. what is that canister on the back of AA fuel dragsters?
  77. moroso electric water pump drive for drag racing
  78. Reared gear selection? Need advice!!
  79. Those who have installed front AFCO's
  80. Hvac delete plate that bolts in engine bay
  81. Best drag tire on a stock 9.5 ws-6 rim to hold 500rwhp
  82. ACE Racing's Racing Season
  83. M6 Nitrous Gear Qs
  84. Radiator support/rules
  85. what trans fluid for race built th400
  86. Mig welding a chromoly cage? is it against nhra rules?
  87. 4.56 & 28in tire
  88. Skinny Wheels and Tires
  89. New suspension/rear setup, need advice on launch and tires
  90. Lower control arm brackets
  91. Remote mount water pump setups
  92. Vic junior, accufab and LS6 valley cover questions.
  93. Which muffler/bullet after flowmaster merge fits
  94. Vacume pump on stock motor LS1, and street drivien?
  95. How are you guys running your positive cables from the rear?
  96. M6 4:30's and slicks question
  97. How are you venting a sumped tank?
  98. 25.3 Turbo Camaro Build
  99. Kooks 2" and manual rack
  100. M6.. 28W vs28S
  101. Turbo 400 LT1 Gear Ratio for 1/8 or 1/4 Mile or Compromise for Both
  102. Transmission Lines for TH-400
  103. Extended Hood
  104. Seats For An F-Body
  105. Whats Next?
  106. Attn: in the pits.....
  107. lt1 m6 cross member for th350 swap?
  108. Hardware for ABS Delete
  109. Motorplate ?
  110. Tim99ws6 25.3 Real Street 275 Build
  111. c.b.m. -pacific street car association
  112. ac delete please help!
  113. Drag bar?
  114. Vacuum Pumps
  115. Fitting a 325/50/15 successfully ? and options for rear coilovers?
  116. Slicks age?
  117. Check out my cage and seat brackets!
  118. set up/track questisons
  119. Bought a caged/9" RS roller, have some questions, PICS
  120. Car weighs 3700lbs...looking for ways to remove weight...by cutting?..
  121. Single Rear Brake and Rotor with Spooled S60
  122. Draglite questions
  123. Window Net Mounting??? Window net people come on in please ....
  124. Speed Inc Lightweight Carpet
  125. roll cage question
  126. What do ya think she will do after diet and tire swap???
  127. "Bulkhead" Rules?
  128. MSD 2 step question
  129. 6 pt or 8 pt rollbar
  130. Best stock LS1 A4 w/ 2.73's 1/4 mile times
  131. Draglite question
  132. 26" DR and gearing???????
  133. Mardi gras grudge race @ hub city Dragway
  134. 60' times
  135. What can i expect with my suspension and gear?
  136. rear end and wheels
  137. braket racing my stock lt1?
  138. HELP ME PICK A TIRE/Wheel COMBO for my setup
  139. Russell traction bar system
  140. Wolfe spring adjustment kit
  141. 26", 27" or 28" tire
  142. Wheel weight/HP
  143. Aftermarket Radiators setup
  144. Best way to get air to 4150 tb
  145. What oil pan should I get ?
  146. brake caliper question
  147. STUPID 10 bolt!!!!
  148. Gear Ratio Opinions
  149. I need a roll cage pic. Cant find what im lookin for.
  150. Torque Arm mount??
  151. Sliders with roll bar and harness
  152. What fly wheel are u running for a 60E
  153. No Console set-ups
  154. Street tires
  155. What's needed for a Bulletproof TH-400
  156. strut tower & fender supports
  157. wire removal
  158. Launch RPM's?
  159. Need some help...
  160. Shift points..Who's logged changes. What RPM?
  161. Yes, another exhaust setup question...
  162. Getting Tuned, 93 or 100 Octane
  163. Removing antenna from 1/4 panel
  164. Aerospace rear brake ?
  165. Panhard bracket removal/reconstruction.. maybe pics?
  166. 4th Gen Replacement Floor Pans
  167. Comp eng & jegster roll bars
  168. can I remove EBCM
  169. is it hard to srpay paint a roll cage that is installed?
  170. Who uses or used trans am seats with 5 points?
  171. 1/4 guesses and advice
  172. SFI Safety belt question
  173. 12 BOLT street opinions !
  174. Dummy Airbag
  175. Deleting power steering , quick question
  176. New LSX TH-400 JW Ultra Bell???
  177. driveshaft loop
  178. interior wiring harness pinout
  179. Quick release steering wheels
  180. Manual to TH-350 gear question
  181. Stripper build wiring help.
  182. Spring rate for rear w/ afco double adjustable
  183. Question for those running vacuum pumps
  184. My new RSD NHRA 10.00 135 LEGAL cage!!
  185. KY-Turbo Inc and Nitrous Cars
  186. drag brake pad options
  187. Cam ideas for 90% drag car
  188. New drag racing forum
  189. School me on 8" vs 10" converters
  190. Boosted 347 LS's
  191. Harness guides for factory seats
  192. Burkhart Anti Roll bar pics
  193. My buddie's newly caged 3rd Gen Vert
  194. Glass or Carbon Front Fenders ( 4th Gen )
  195. narrowing rearend and 315 tire?
  196. Th400 gains.
  197. F body Metal gas tank sump
  198. When is a glide better then a th350?
  199. 295-55-15 M/T's!! Fit real nice
  200. which backspacing billit specialty wheels
  201. estimated hp and et
  202. Drag car ride height
  203. Where to mount battery in the back
  204. Really cool vid! Traction with slicks, moving out, and tire shake example.
  205. What mods are next to get it to the 12's
  206. power to weight ratio for 10/9s
  207. Fuel Cell in T-top area
  208. t tops?
  209. Which individual EGT system?
  210. Bogart 15x3.5 with 2.25BS, clear stock ls1 brakes?
  211. Structural, or not so much?
  212. 10 sec. 370lsx 91 b4c build
  213. HVAC delete
  214. Negative effects of seam sealer removal
  215. What makes the back Hatch so heavy?
  216. Alternative to Percy's Speedglass
  217. radial to bias ply sizes
  218. Deck lid trunk lid
  219. Aftermarket bellhousing
  220. Good Enough for Mid Low 10's???
  221. wiring question
  222. camaro front grill
  223. Best Rear drag brake
  224. Advice For New Drag Racer
  225. Champion Wheel C1 beadlock reviews?
  226. We are Moving
  227. What drag stripes are open
  228. Trans shop called...Christmas came early!
  229. Aiming for low 7s 1/8th mile, how's this setup sound?
  230. Seat install help.
  231. wheel/tire/gear changes. any gains?
  232. What did you do to the steel part of the dash
  233. any weight difference t56 to th400 swap?
  234. hvac delete
  235. Few questions on power and gear setup
  236. Starting Line Ratio
  237. LS Hemi head
  238. Stick with 28" or go with 26"?
  239. Need VSS with powerglide and aerospace brakes!!! HELP
  240. M&H Racemasters
  241. Burkhart Chassis 25.3 pics
  242. Burkhart CHassis bolt in Chute mount
  243. Burkhart Chassis TA FireBird and Camaro wing
  244. switching from 26in to 28in tire how much will it hurt my times?
  245. Gear/Tire combo Questions
  246. Cages and Kids?????
  247. what would you like to see brought to the market?
  248. AFCO rear shocks with BMR Xtreme drag bar
  249. Trans Time Th-400 or Glide
  250. what to do for coolant over flow tank...
