View Full Version : Drag Racing Tech
  1. Simple Spring Rate Question
  2. Detachable Steering Wheels
  3. Track guys...Carpet question??
  4. Stiff sidewall vs Regular sidewall
  5. Question on Cmotorsports
  6. Insurance and racing
  7. Looking for how to !AC, or any pictures u guys have
  8. do i have a chance?
  9. Daily-driver friendly cage/bar?
  10. Time for drag springs, need input.
  11. Alternator only... spring tensioner how?
  12. Balanced Flexplate??
  13. Helmet question....
  14. TH350/TH400 Guys.. What gears are you running?
  15. whos car
  16. 3300lbs First Weight Reduction
  17. Narrowed 9" or 12bolt question
  18. experimental setup Mk. II
  19. cracked windshield... need ADVISE on Lexan and glass!!!
  20. Burnout tips?
  21. Iron Block....Spring is in the air.
  22. 12 inch wheel guys
  23. 315/60/15 (30x13.5x15) MT Drag Radials Pics on car!!!
  24. What am I doing wrong???
  25. Hood modified for Victor Jr and 90* elbow
  26. WHAT 2 STEP WORKS FOR STOCK IGNITION??(for turbo)
  27. How strong is the stock DS?
  28. 28x9x15 ET Drag or 255/60/15 ET Radial
  29. just picked up ET STREETS.... have ??s
  30. Are 4.30 gears and a 28" tire too much with spray?
  31. roll bar
  32. Drag Shock setup
  33. 295/60 Mt Drag Radial Fitment
  34. M/T ET Drags Tire Pressure
  35. Question about Classes
  36. LS1Queen on the bumper with drag radials!
  37. Help front bumper brace
  38. Wheelstand
  39. Aero question.
  40. Under Coating Question
  41. Estamited 1/4 Mile time
  42. how far can i push these 28# injectors and stock pump
  43. Who runs a 275/50/15 MT DR?
  44. My car is in GMHTP Apr issue
  45. work to fit welds
  46. Drool....rolling chassis in Dallas
  47. Suspension Setup
  48. S&W 8-Point, Kirkey's, and a few custom things...
  49. Weight Reduction
  50. Hoosier QTP vs E/T Streets...
  51. Tires vs HP
  52. M/T, Hoosier or Moroso
  53. Does anyone make a stainless "non electric" exhaust cut out?
  54. Pictures of my newest custom modification
  55. Racing
  56. Lets see those cutoff switch pics
  57. shock setting starting point
  58. Question for 17" MT dr users !
  59. Strange Single Adjustables
  60. LT1 vs. LS1 front brakes
  61. Shift Points
  62. Anyone used a Turbo Action Cheetah shifter
  63. request pics of 29.5x10.5w
  64. Hey Madman am I screwed with my Spohn TA?
  65. front swaybar removal??
  66. Harlan 2 step setup
  67. Is a bolt-in roll-bar even worth it?
  68. My car is sitting wrong....
  69. vacuum pump pics and setups
  70. need some opinions
  71. How much are my airbags worth?
  72. How can i get to 11's?
  73. preliminary fast 90 vs vic jr results
  74. Headwind and E.T.
  75. Drag Race Sway Bars?
  76. Best height for QA1 Coilovers
  77. Drag Racing Alignment
  78. Madness at MIR times?
  79. front wheel height ?
  80. Went to MIR today. Need opinions.
  81. Is removing rear sway that bad?
  82. B.S. question for narrowed rearend
  83. Battery relocation Question
  84. relo. brackets with stock springs?
  85. Any reviews on the new Hoosier drag radials?
  86. Any one hook so good then bog it out??
  87. Need Cage for C5...........
  88. ET streets
  89. Narrowing a Rear
  90. pics of modded cowls in here please!!
  91. Trick for windshield wipers?
  92. Few photo updates of my pig...
  93. Narrowed 9"
  94. weld in vs. bolt in cage
  95. Launching on street tires...
  96. What is this?
  97. Can I get rid of this box?
  98. rear battery main fuse?
  99. What to RPM launch at??
  100. Wheel Well Cutting?
  101. TH400 driveshaft. how much longer?
  102. line lock ?
  103. TH350 or T56 Which will be faster?????
  104. Bench racers in HERE! Test my beta drag simulation software!!
  105. Dana 60 ?
  106. arp studs and weld lugs
  107. lexan weight?
  108. anyone make a guage pod that fits the HVAC control?
  109. SUSPENSION to reduce ET: what to get first?
  110. going to the track for the first time this weekend
  111. Hooker 2455 header fitment? What are the mods?
  112. LG Motorsports Harness Bar?
  113. Helmet
  114. BFG Drag Radial Psi.
  115. Anybody have a black Kirkey cover they can spare??
  116. Photo updates
  117. Wheelie bars and front end limiters
  118. Light weight carpet
  119. 60' Times
  120. Tire size vs gearing for the strip
  121. Dsuz fastners
  122. My First Time to the Track
  123. Anyone know who makes this hood?
  124. ho much slower will i go
  125. The interior is finally coming together!!!*PICS*
  126. rear springs
  127. Snapped some pics with the dash out....
  128. Does this look ok....
  129. Strange or Moser
  130. guys with th400 or 300 that run 9.80 or faster
  131. What would I need to yank the tires?
  132. m/t drag radials + transbrake anyone? come on in!
  133. Post Pics of !bumper supports
  134. Short belt mod ?
  135. Cage install prices?
  136. Aerospace Front brakes, and modifying spindle???
  137. Any1 have kirkeys with out a cage??
  138. What's the proper way to fasten a harness to a bar/cage?
  139. My STENOD 6pt
  140. M6's that hook on the street
  141. Nitto Drag Radial Poll
  142. Limitations of the stock aluminum drive shaft
  143. Short belt
  144. MT ET Streets Marshmellows??
  145. Strange brakes vs aerospace?
  146. Tire size on a A4 on nitrous
  147. Paging MADMAN Adj A Arm Questions
  148. Started pulling dash and now i'm confused....
  149. 6 speed advise-->in here
  150. door handles?
  151. Drag Radial size difference
  152. how come most preffer the victor over the GMPP?
  153. How are you guys mounting your chutes?
  154. Octane Vs. A/F Ratio
  155. M6 Drag Questions.....
  156. Perfect Gear for TSP Magic Stick
  157. Subframe connectors: 2 point VS 3 point(triagular/diamond) worth the extra cash?
  158. What should I expect with 600 rwhp?
  159. Send me your drag wheel/tire pics!
  160. going to the track for first time...what to expect?
  161. Speed Glass on the street?
  162. M6 guys do you launch in 1st or 2nd?
  163. Skinnies
  164. Hotpart.com triangular subframe connectors....(too cheap?)
  165. "Throttle ON" Shifting.... ??
  166. Driver's Side Tub
  167. Question for chassis gurus on torque arm location?
  168. Pics of your trimmed fenders for tires!
  169. age at the track
  170. Wiring Question
  171. Wheels Question
  172. Yeah baby, dash pullin time!!!!
  173. et street radial size? and metric front runner?
  174. 315/60R15 ET Street Radial, will it fit?
  175. Pics of true dual exhaust
  176. Plastic type race seats
  177. DR question:
  178. Tubular k-member weight?
  179. Times?
  180. Installed K member/ A Arms???
  181. Unusual 'how much' question
  182. Trans Brake
  183. rear air bag question
  184. Interest?
  185. Looking for opinions
  186. New Stall, New Tires - "Bad Day"
  187. 4 link design
  188. Have you lifted em on Radials???
  189. Madman, have some more questions ?
  190. What next?
  191. Anyone Running A 2 Step With Their Fuel Cutoff????????
  192. ws6 not performing.... help!!!!!
  193. Have any of you ran out of gas at the track?
  194. Cutting 60' down
  195. Advise for RWD newbie
  196. Anyone running 12 bolt with an M6 and low10/high 9 sec E.T's?
  197. Is there a How to Launch a A4 at the track?
  198. Pro Stars, no more grinding?
  199. Bolt in roll bar and the fuel pump access mod
  200. removing heater box
  201. stupid question but Im new
  202. Anyone have S&W Racecars Rollbar pics?
  203. Weld Alumastar Fronts????
  204. Super light weight Kirkeys!
  205. Anyone Install SLP Line lock Come UP!
  206. Aftermarket gas tank and stock style exhaust?
  207. Race cars and single plane intakes, what size TB?
  208. 408+stock heads+TR236+carbuerator=?
  209. GMHTP Wants Quick Budget GMs
  210. Anybody see the new Hoosier drag radials?
  211. roll cage?
  212. Will new shifter make a difference?
  213. Best use of 500 dollars
  214. anyone running a track pack torque arm with through the floor SFCs?
  215. mt drag radials with m6 please come in
  216. Can I get some help MADMAN ?
  217. Pushbutton switches
  218. loop weight ??
  219. T/A Drag Radial 2
  220. Pics of install QA1s R series anyone?
  221. Check out this thread
  222. what size tire do i need to stay in 4th thru the traps?
  223. what cage
  224. Fastest Anyone has Gone w/4L60E?
  225. NE1 running a 4L80E w/ Brake?
  226. NHRA Pro Stockers still running old spec cage
  227. Anyone running a 16 volt 3 post battery?
  228. proper batt. relocation wiring?
  229. Drop Spindles?
  230. BMR DS Loop
  231. Torque Arm help
  232. Will it rub??
  233. Best drag race setup?
  234. RPM's to dump at??????
  235. How do i get the front wheels to lift off
  236. lightweight spindles
  237. Mounting 28" on the new Welded Floyd Bogarts..
  238. Aftermarket radiator questions
  239. Rossler 'EZ stage' option
  240. More progress pics 2
  241. Which front and rear drag springs?
  242. Not impressed with the MT DR's
  243. Slammed S10, Hooking questions
  244. what do u think i can run?
  245. Driveshaft Loop Owners... IN!
  246. Who sent in Hot Rod Pump Gas Drags entry form?
  247. Do any sponsors sell Weld Pro Stars?
  248. experimental Induction setup
  249. roll cage
  250. Rim screws
