View Full Version : Drag Racing Tech
  1. SFI ratings and recertification period?
  2. Skinny help PLEASE?????
  3. Stock Radiator and Fans
  4. front tire psi?
  5. Any reason why I can't......
  6. fitting prep for some big tires
  7. M6 Guys in the 1.4X 60' range
  8. Weighed a few tires & wheels tonight
  9. Skinnies up front on a LS1..where to buy?
  10. how safe is it to remove front + rear bumper support?
  11. need help launching
  12. What to do to lose weight
  13. First time at track, howd i do?
  14. is this reasonble for a 4link?
  15. possible to have good handling and good drag setup?
  16. My new weight reduction
  17. What to choose, what to choose...M6 or A4
  18. How to correct my time?
  19. guys under 4.60 in 8th
  20. A4 shift RPM
  21. Aluminium rods
  22. Cool 93-97 TA on Racing Junk
  23. Cool 2000 SS drag car on Racing Junk:
  24. Buddy claims 12.1 @ 96 mph? Is it possible?
  25. 9-8 sec cars fuel cells?
  26. Old School Corvette Rallye Wheels
  27. What RPM should I be shifting at?
  28. F body launching w/ street tires
  29. HAL Qa1 ?'s
  30. How to convert a convertible top to manual??
  31. 9.99/135+ rollcage rule?
  32. T350 Or 400 ?
  33. Im The Worst Driver!!! Need Help
  34. what should i expect to run in the 1/4?
  35. et street vs. et drag
  36. Billingsley manual brake kit w/Strange rear brakes & stock fronts?
  37. Removing Air Filter
  38. Qa1 Life span
  39. Bare Shell Weight
  40. 28" tire on 16" rim??
  41. Manual Brake Booster
  42. 60' not where I think it should be
  43. dreag wheels and tire
  44. Fiberglass Dash In a trans am
  45. my custom Wolfe 10pt, through the floors etc....
  46. My NEW Bogart Floyd RTs!!!
  47. What times from stock 01 Z28?
  48. How to get your daily driver under 3000lbs race weight.
  49. anyone know how to mod an A4 shifter?
  50. How can I slow my reaction times on a Pro Tree?
  51. 27 inch ET STREETS fitment?
  52. Best(inexpensive) rim/tire combo to hook with G2 springs?
  53. Need advise on launching
  54. 67 Firebird saftey tips?
  55. Gettin' closer, Hurst Pistol Grip Quarter Stick & custom shifter cover.
  56. ***Did I forget anyone? Step inside for a sec.***
  57. Lightest battery for daily driving???
  58. Anyone swap a new style gas tank into a 98 F-Body?
  59. School me on anti roll bars please
  60. BMR TA relocation mount worth it?
  61. Good place to tap footbrake wire for 2 step?
  62. Is My Car Retarded?
  63. Two step people????????
  64. Time Difference from stock converter/3.23 gears to 4400/4.10 gears?
  65. Differences from Z06's to 15" Welds?
  66. drag suspension
  67. Painless wiring harness
  68. Best Shift-Out RPM???
  69. Better times possible?
  70. Hal Vs. Strange Shocks
  71. LT1 Weight Reduction!!!!
  72. Racing Sponsorship
  73. Need some opinions on tranny....
  74. ok i am about to break 11.49 what do i need to change
  75. what should i run in the 1/4
  76. What is the benefit of a 2 step on an A3 car?
  77. Anyone use Slp line lock?
  78. Opinions
  79. predict my future times
  80. Damn, Car Appears To Be Crooked
  81. Harlan Two-Step making car misfire?
  82. 1/4 Question
  83. Having problems removing rear springs to remove isolators....
  84. Need a special drive shaft loop to clear BMR TQ arm??
  85. lite weight hood
  86. Line lock and ABS delete project is completed
  87. AC! question
  88. 12.7 so far, 1500 to spend, what should i do?
  89. Drag racing and a strut tower brace.
  90. Moving Battery to the back and Installing Main Cutoff Switch Tomorrow, any pointers..
  91. How fast can a bolt on only a4 be?
  92. How well would a lot of suspension stuff do on a basically stock ls1 car?
  93. Prostars on the car! *pics
  94. anyone do back to back track testing stock front tires to skinnies?
  95. What do you think my car will run?
  96. info on a roll cage
  97. Mix and Match brakes?
  98. Took the car track friday
  99. ? on stance of vehicle in relation to traction....
  100. Wheel weight reduction ?
  101. GF-5R in an F-body?
  102. Rear end OIL for a street/strip car with a spool?
  103. Which springs are best for drag racing?
  104. Anyone use m/t et street radials?
  105. Another Kirky mount question.
  106. Car is back from Madman's
  107. A4 Burnout ?
  108. how much will my et drop?
  109. Those w/transbrake, big stall, big gear, & big tires, please come in.
  110. Do settings change going from footbrake to transbrake?
  111. Slick equivalent to 275/60/15
  112. Tire pressure on 28" ET Drags.
  113. Chute Mounts
  114. A4 Drag Racers ???
  115. How do I find weather conditions for 12pm today in Jupiter, FL?
  116. Going to the track wed night, rear shock settings, stick guys??
  117. Battery relocation wiring
  118. Is there such a thing as TOO MUCH traction?
  119. mickey et 29.5x10.5x15 will they fit
  120. Afco DA rear baseline settings?
  121. Anybody using the 325 50 15r ET Street Drag Radial???
  122. Burnout question
  123. Are my times good for the setup
  124. People with Alston torque arm, please read...
  125. t56 or 4l60
  126. 01 Camaro SS weight
  127. how many run a 28'' slick at the track??
  128. Anyone got any pics of Billingsley 9"/anti-roll bar installed in a car?
  129. Quick question on my DA correction.
  130. vert probs
  131. pin on rear hatch pics please
  132. Battery Tie Down
  133. 10-point cage pics?
  134. what tire size do i need for my new prostars?
  135. Free Tech info inside
  136. 28x10.5/4.30 gear vs. 29.5x10.5/4.56 gear
  137. No front sway bar?
  138. Front tire size?
  139. Shift light and launching ?'s
  140. McLeod Scattershield
  141. tire and gear choice for drag racing???
  142. Opinions needed on tire choice
  143. Weight differance in tires?????
  144. how should i launch my car??
  145. how much weigth would i save?
  146. Question for guys that have completly removed ABS harness.
  147. Hoosier 28x10.0-15 DO5 or 28x10.5-15 DO7?
  148. Drag Radial Questions...
  149. mdblackz28
  150. HAL QA1 - F vs R series...
  151. Solid Motor Mounts
  152. Car Trailer/Hauler Sale
  153. Drive Shaft Loop for True Duals
  154. Need Idea's for weight reduction.
  155. need advice on controlling the car on the spray.
  156. I"ve got pcm BUGS...
  157. Is a restall worth it? 5300 to 4???
  158. effects of 90* weather and high humidity
  159. I need some expert advice!
  160. woo hoo my car is a two seater again.
  161. Tubes for Et Streets
  162. Real slow with 9"
  163. Questions pertaining Strange rear drag brakes
  164. 26" drag RADIALS to 28" slicks?
  165. Shifting WOT
  166. Please help me figure something out...
  167. Black car + big burnouts + ET drags = big mess
  168. Do G-Tech's really work??
  169. Rollcages
  170. BIG LT1 headers?
  171. anyone changed to a carb setup?
  172. What would help best for cutting better 60's
  173. Newbie A4 racing question
  174. air bag help
  175. Launch advice for a newbie...
  176. Weird shake in 1st gear. Help!
  177. Strengthening "Torque boxes" .... Anyone??
  178. Opinions please-hooking on the street-W tire?
  179. Any good websites for adjusting et/mph from DA?
  180. Torque arm that will clear X true duals & retains a front driveshaft loop?
  181. weighed car again today 2995 pounds
  182. What's wrong?????
  183. Minitubs=stock tank?
  184. Gains going from 3.23 to 3.73, A4 car...
  185. Burnout and Rear Sliding out
  186. Bfg Kdw Psi
  187. Higher HP M6 help... Bog or Skate problem..
  188. getting cage NHRA certified
  189. Density Altitude. Interesting read
  190. Battery push/pull disconnect??
  191. Best rear sway bar? Madman?
  192. Considerations for unprepped tracks?
  193. aerospace brakes
  194. Does width matter
  195. 600rwhp with M/T 275/60R15 Radial, How do you hook?
  196. First run on slicks tomorrow, starter QA1 settings?
  197. seat belts
  198. Anyone know what kind of times the SSR will run
  199. Is it possible my suspension was bound up.....
  200. Need Opinions About A/C Compressor Removal
  201. Bog vs Spin: How will they look on a timeslip?
  202. Getting ready for BG
  203. Battery relocation wiring
  204. To those with comp. eng. shocks...
  205. trouble with shifting
  206. Wheels studs, did search, more confused than when I started..
  207. Suspension related, but tech info needed....
  208. Stock torque arm limits...
  209. Jack Stand Racing (what should it run?)
  210. Anyone running the BMR Upper Panhard Bar?
  211. LS1 or 03 Cobra
  212. Practice Tree's....
  213. I think i have the slowest Ls1 on earth:(
  214. made a lightweight Kirkey bracket and seat brace.
  215. Why won't my car 60' (vid)
  216. Proform Shift light, FLICKER????
  217. M/T Drag 28x10.5x15S, Do you recommend using Tubes or not?
  218. Launching an A4
  219. New Stewart Warner '4 shift' shiftlight
  220. Fitted my W's today
  221. Bump stops, Who has them?
  222. Madman..need some suspension help
  223. Will this helmet do the job?
  224. Drag only brakes on a daily driver.
  225. Problem with my headers
  226. NJ Drag Racing Action July 30 - Heads up and Bracket
  227. ls1 vette
  228. Good stuff to keep in mind.
  229. Need laptop strap or holder for hard launches??
  230. slide-a-link
  231. best drag radial
  232. Roll Cage
  233. Strengthening a rear end
  234. left wheel not burning out?
  235. 3000Stall, 150Shot, 4.10s???
  236. Which gears for cam/n20 M6
  237. Mickey Thompson $50 rebate on some slicks
  238. Where are all the racers?????
  239. Most HP: less Money
  240. How To Install Proform Shiftlight???
  241. LS1tech videos...69 corvette??
  242. disapointed with my first race.
  243. Tread width vs. Rollout???
  244. MADMAN... mind learning me a little?
  245. ONLY TWO WEEKS UNTIL NORTH VS SOUTH >>>>>>
  246. What hood is this?
  247. Will cutting 60' times raise my mph??
  248. Temp and humidity...
  249. Suspension...HELP!
  250. Tire diameter of a MT ET drag 26x10.0-15 at top end?
