- Why is "big gear/big tire" combo better?
- Cost of aftermarket steering wheel conversion
- Why only a 13.8?!?!
- non roll down windows
- A3/A4 users, what gear/tire combo are you using?
- Should i put on DRs and make a few passes?
- How much will heads help?
- camaro guys taking 2 firebird AC vents?
- Pinion Angle Importance
- pictures of C5r Indvid. TBs with stacks needed!
- who has removed the bumper supports?
- New drag wheel setup Pics (~56k)
- Need drive shaft loop soloution
- Weight Saving Ideas?
- Any known issues with meziere street pump not pumping enough?
- Any fitment issues with BMR k member and 1 5/8 long tube headers?
- Strange brake install question??
- Stall help...
- Best times on 17" or larger tires?
- Who would win now?
- Gearing question for racing...
- A few launch questions....
- How should I launch?
- AFCO da shocks vs QA1/Hal da shocks???
- BMR K member vs AJE K member (solid mounts and header clearence)
- Those with Ws6 or SS i have a ??
- i need a roll cage for drag racing.
- pro shifted tranny questions
- Narrowing and backspacing.
- 60 Foot
- Why not steel wheels?
- Drive shaft lenths on TH350 and Glide
- Getting closer...........cage pics
- Any pix of weight removal from Dash area?
- tire height questions
- DS-2 or MT ET Fronts
- Race tomorrow need simple, free mods...
- Manual Brake Conversion
- 800-210 Strip Annihilator Instructions?
- help, people running M/t 325/50/15 dr inside
- Time?
- M/T ET Street question
- What to fill in foglight holes of TA after !bumper
- The car is finally coming together here are some pics
- woo hoo Aerospace brakes, hals, kirkey and A arms are in.
- New setup getting closer to completion, need some help. (200-4R to TH350)
- Wolfe minitubs are available for Fbods.........
- Is my roll bar legal???
- Does anyone have experience with HAL’s Double Adjustable?
- All out race car Fuel question
- M6 guys, which MT 28x10.5x15 tire do your recommend?
- Just dropped the Z off to get my final suspension pieces installed.....
- Need a driver side wheel liner
- 185x25x15 to go on a 15x4 rim?
- M/T 28x10.5's Cheap?????
- Pics of Progress
- what size slicks fit with no mods
- possible issue for racers.
- Burnout - one side????
- Traction Probs..need advice
- Question for people with the hawker odyssey batteries.
- Aerospace brake pads?
- The new Proshifted tranny is in
- Anyone that knows anything about dragging come in.
- Anybody run Competition Engineering 3way drag shocks?
- roll bar/cage question
- How much mph difference between 26" & 28" slicks?
- Anyone have this combo....LTs, TCI3500, 3.23s...
- who makes a 'glide trans mount?
- Based on my graph, where to shift at?
- Popped my drag racing cherry.
- Need Help! Drag brake bleeding and pedal feel ?`s
- What do the SRT 10 trucks run?
- Front shocks
- altenator or multiple batteries
- Swapping from metric 165R to ET Fronts, what size?
- Gtech sucks, track tested.
- Need help ASAP w/ QA1's
- Pissed about cam only problem!
- Does a high trap speed suggest a lower time?
- How much mph are you picking up after the 1/8th
- Change from F series to R series, any results?
- anyone try synthetics in there proshifted trans?
- Tbyrne Motorsports North vs South Aug 6th!!!!!
- 1/8 traps vs. 1/4 traps
- how much does a 350 iron block weigh
- So many sizes, so many brands, etc. which lightweight fan?
- A4 410 Or 456 Gears
- How do you get the black mat off the bottom of carpet?
- Heating Tire Problem....
- Is This Legal
- Generally... wheel weight effects on et?
- Weight of a 2000 trans am
- 2.75 1st gear ratio upgrade for a TH350, worth the $ or gain?
- anyone ever wore a set of ET Streets out to the cords?
- Flycut pistons/Cam only?
- 10's POSSIBLE???*VETTE*
- I'm dragging for the 1st time this Friday.
- (438 RWHP)Going to track for the 1st time!
- How many pounds do you think i have shave off?
- NEW F-Body "Drag Only" alternator mounting kits
- joint different between lt1 cars and ls1 cars for steering rack?
- Lightweight Project SS update
- What kind of times?
- please help me get better times
- Best shocks for drag racing
- Lightweight Fans
- how are you guys cleaning the rubber of your fenders?
- Sound Deadening Removal
- Small pin hole in et street>>>
- Guys with fuel cells....pics?
- Lauch practice, how different is street vs. track?
- TH350 reverse manual valvebody users, what shifter are you using?
- What do you think of Protorque converters, any of you using them or have in the past?
- what should i leave at
- What is the best lightweight car battery?
- ET street keeps loosing air>>>
- Wish me luck!!!!
- MT Drag Radials, you use them? Get inside!
- Hoosier Slicks Tubes or no Tubes?
- will i hit 11's?
- What Flexplate ?
- NE1 running lightweight rear and stock front brakes?
- tubular k member question
- 29.5X10.5X15, what rim size, back-spacing, & how much narrower?
- WTF is wrong with my car?
- basically stock M6 guys come inside
- need help
- Thinking about getting a trailer
- QA1's ride height
- License question? need help.
- shifting question
- Pros/Cons of both....
- QA1(HAL) SHOCKS and spring combo question
- Custom (locally built) HD torque arm installed (*pics*)
- How Do I Fit 10 1/2 W's on my '99 Camaro
- PLEASE HELP...Which size MT ET Street/ET radial street?
- anyone ran a 28w on a 4.56 geared m6, need mph info
- bigger tire bandaid fix for me?
- Anyone wanna take a guess at whats wrong with my car?
- What will my improvements be?? opinions needed!
- Project Short Bus
- What's required to fit a 29.5x10.5x15 ET Drag?
- how are you guys fixing the problem of your tranny mounted torque arm mount bending?
- Tires for dragging...
- need SERIOUS help!!!
- comp engineering rear shocks or what? advice on setting relo brackets?
- What do stone stock A4 cars 60 foot?
- Question on Nitto drag radials
- bye bye tranny, so much for making forward progress
- Hookin on Street Tires
- finally making some progress on the car, pic inside
- Lets Guess 1/4 Times with New Stuff
- FYI: $50 rebate on 26-28" Mickey Thompson ET Drags
- Madman`s "drag race" alignment specs and aftermarket A-arms??
- e-brake aka parking brake.. help please!
- 29.5x10.5W Tires -- How Do They Fit?
- DR's help me?
- With battery mounted in rear, has anyone..
- Need a belt size, any help appreciated!
- Can you drive with the dash removed?
- Update on the project!!!
- 325 DR guys!
- Fastest Heads and Cam LS1s?
- License Requirements?
- nitrous and 60'
- Wolfe rear spring perches
- How much HP does it take to gain 1 tenth...already going mid-9's.
- Serious question about BMR TQ arm and Moser 12-bolt (cutting maybe involved)
- Strange rear brake question
- Finally Finished all my Suspension
- Rear coil overs....
- SFC??????????????? 'ssss
- will the harlen 2-step help pick up et in the 1/4mi?
- Those with 11.5+ compression
- *What if question* I know, I know...
- my updated MT DR report
- Nitrous Cars with TH400, what size converter?
- Launching of the REV LIMITER w/ strange 12 bolt. is it possible?
- lifting the wheels off the ground?
- hal shock question
- Pics Of BMR Adjusatable Lca's
- !Air Conditioner
- $30,000.00 10.5 outlaw race Sept 17 at HMP
- How important are 60 foots ?!
- Rear quarter panels/fenders ?
- Battery Relocation ???
- Need help identifying make of this K Member and Arms
- First time at the track
- Tranny, converter, gear, & tire swap, need help.
- need help with tach install on chrysler
- All GM EFI race series shoutout at Englishtown July 9th
- how much weight in the trunk?
- Suspension questions. Torque arm & rear swaybar related.
- Recirculating Coolant Tank...?
- 1/4 mile time and RWHP
- Spohn T/A Alignment Problem
- Will bigger converter drop a tenth?
- Front bumper support made **PICS**
- Pinion angle????????
- What race only tire are you running
- Removed rear spring isolators and lowered front end, have some questions.
- M6 guys. 60' times.
- Who does NOT run an alternator?
- Weight reduction for FAT daily driver
- *fix for leaking slicks*
- Removing washer fluid pump
- Any weight specs for k-members and a-arms
- Density Altitude
- Is my car a dud? Track times within...
- off season mod list...
- MT ET street 26 x10.5 or 26 x 11.5 on 16"
- Sfc???????
- Racing tonight. Have a question
- 8 Point Cage
- Best rims for drag racing F-bods
- Lauching w/10 bolt and 4.10s. YES I searched
- To those who have removed their airbags...
- A4 guys How do you launch
- Advice on Et street radials.
- Lightweight radio mod
- DA calculator
- car is rolling.....*PICS*
- Had my car on a scale today and WOW
- Removable wheelie bars??
- when should i be worried about no traction?
- braided stainless brake line question
- What is the fastest rod bolts, rings, and bearings car?
- stock internal bullshit!
- can you keep a/c but leave heat out?
- which drag radial
- Rear QA1 shocks clearance issue
- Torque arm mounting question
- Race car or street car?
- weight reduction mod.. windshield wipers are stuck on!
- Aumstar 2.0 fton runner which backspacing?
- 325.50.15 MT DR Peepz... Some Q's
- Will I hit 10's w/ my new mods?
- ppl running 10's w/ m6's HELP
- NHRA firesuit regulations
- Launching on a t56
- Smaller radiator question
- Anyone run 12.5x28x15 ET steets on a t/a?
- does heat and humidity (DA) affect NITROUS cars as much, not at all, etc..?
- Question about trap speed vs 60'
- what front shocks qa1 f's or r's
- More MINITUB PICS for ya......
- What do you think?
- Spare tires as skinnies
