View Full Version : Drag Racing Tech
  1. Spring compress
  2. Alum Drive shaft whats it worth on your E.T.
  3. hooking a cammed and 4000 stalled 02 f-bod
  4. 9 or 10 second cars, school me on ur front shocks, i know nothing!
  5. Skinny fronts 26x4.5 that are DOT?
  6. help w/ 396 LT1 power/time problems
  7. how much is my stall hurting me?
  8. Best 60' on stock springs and shocks?
  9. help launching a manual car (desperate)
  10. Looks like MT DRs really do grip good!
  11. kirkey seat layback degree?
  12. What is a reasonable price for.....
  13. 60' on street tires
  14. anyone drag racing a pro shifted t56? what clutch?
  15. Carpet sound deadening??
  16. Launch RPM'S AND ET predictions
  17. ET Drop
  18. Do I need this useless shit?
  19. Fast 05 mustangs?
  20. minitubs
  21. exhaust help
  22. Need some info....
  23. Short belt part #
  24. what is everyone running on a 150 shot?
  25. What to do to break 11's? POLL!
  26. Where to get 4l60e trans blanket
  27. 60 ft question A4 vs. A3
  28. Line lock questions (keeping ABS block)
  29. What first, Rear or Tranny?
  30. anyone running without tubes in their slicks???
  31. Tips or tricks to fitting dash after 10 point install????
  32. Who has hurst line lock...
  33. Who has hurst line lock...
  34. What size M/T ET Streets???
  35. Is anyone running a Motor Strap?
  36. 9 inch rear hits fuel tank
  37. Possible to install mojave heater w/dash in?
  38. 27x11.5x15 tire clearance issues
  39. Header tube size calculator?
  40. where to buy m/t drag radials?
  41. where do you put your delay box?
  42. Which motor for 10.5" Natural Outlaw
  43. Better match race Bickelfirbird vs W2W Casper at N vs S
  44. harlen 2 step ?
  45. Anybody running a Manual Steering Setup?
  46. Line lock...
  47. BS3 or FAST XFI ?
  48. Need more launch...
  49. Engine Strap?
  50. Lots of questions for Project 96 LS1 SS Drag Car.
  51. Getting traction
  52. Drove MT dragradials in heavy rain leaving dragstrip
  53. Where do I get stuff acid dipped for weight?
  54. Just bought ET Drags, Advice on proper use please?
  55. Think i can get 12's? WHat for 11's?
  56. 2 Step help ?
  57. WTF, freak!?
  58. Is my race weight reasonable for a stripped-down, 1SC '02 Z28?
  59. Our light weight project SS.
  60. I finally got my stripped-down, 1SC '02 Z28 weighed!
  61. LCA's round or rectangular?
  62. ABS Block off plate?
  63. Hal/QA1 question
  64. Best Race Fuel ??
  65. What causes slicks spinning on rims and how do you know?
  66. LS1Tech.com enables free video sharing for its members.
  67. ET streets spinning on wheels>>
  68. Best way to launch on BFG's with a C5
  69. Dave Connelly 3rd points in Pro Stock team disbanded
  70. front lug nut and stud question
  71. Removing bumper supports front and rear????!!!
  72. Pinion Angle Help
  73. track times
  74. Lightest a F-body could be?
  75. Installed 12 bolt, now traction problems
  76. Whos a good drag racing tuner....
  77. Need a trailer
  78. Couple of Questions
  79. lite weight rotors
  80. Prostar wheels
  81. Lite weight flywheel.
  82. Need help on 1/8 mile
  83. Do I need bigger tires?
  84. bfg drag radials
  85. aerospace brake installation question...
  86. Why the HUGE stock/near mph differences?
  87. Where to get burnout guard blue tape?
  88. How much more?
  89. I-Helix Blower and Rootes
  90. i got problems, i need help fast
  91. Burnout Question
  92. Motor's done, just waitin on heads!!! (Some teaser pics inside) :)
  93. Looking for a better run.
  94. Why won't non TCS throttle cable fit??
  95. Looking for help.
  96. Experience with fiberglass doors?
  97. Playback tach results
  98. f.a.s.t intake burst disc
  99. vacuum lines?
  100. brake rotor question
  101. Spool with 3ch ABS?
  102. QA Coil over kit VS. Just QA adjustable shocks in front and back
  103. LCA relocation brackets
  104. What's Wrong With My Track Times, Something Doesn't Make Sense!
  105. Guess my RACECAR MPG!!
  106. Spohn tq arm???
  107. What type of race seat?
  108. A much better shift point optimizer
  109. DS loop with TSP duals?
  110. 26" ET Street vs 28" Hoosier rpm drop?
  111. Where to position Rear tires?
  112. Stock 2002 Z28
  113. anyone ever wear out a axle, i seem to have
  114. 0-60 calculator
  115. How is my time?
  116. Can you 'convert' a solid LCA to poly?
  117. Mini Tub Question
  118. What size front tire does everyone run?
  119. Mid-high9s@142mph w/ 450rwhp?
  120. The Red Rocket is back underway!
  121. driveshaft help!!
  122. Looking to get some real tires rims/skinnys what size's to look for??
  123. How much did you spend on your car Trailer?
  124. New Setup for 2005
  125. 1/4 mile times
  126. weird: what do you think?
  127. Hoosier or Mickey Thompson
  128. Shift point calculator
  129. Southern Nationals in Commerce...
  130. How many lock up the TCC in 3rd at track???
  131. What weight reduction can I do?
  132. Best hood that fits, is strong, and very light?
  133. Shock Question
  134. Seat weight?
  135. 60' techniques...
  136. How much does a stock steel Z28 hood weigh?
  137. rear end sway on N20 Only
  138. [VIDEO] 10 sec N/A Vette needs suspension mods to lower 60 ft.
  139. tried some MT DRs tonight
  140. 28x11.5 vs 26x11.5 Hoosier QTP’s?
  141. headed to phoenix to drag race tonight
  142. Think I need better weight transfer!
  143. Do it now or wait?
  144. Launching Help!!!!!!!!!!!
  145. Legal wheel stud
  146. Why does my car trap so low?
  147. Thinking about changing springs
  148. What should I be launching at??
  149. 700hp on the street- slicks?
  150. how many guys run t-top cars
  151. TR224 and similar M6 guys, where are you shifting at?
  152. How did I get slower with a cutout?
  153. Harness Help!
  154. Thermostat change
  155. ? about removing dash....
  156. A/C delete. Need new belt part#
  157. Best way to launch with auto?
  158. Driveshaft loop question.
  159. Well its been 2 years, but she is on the Ground again
  160. pics of my MT 325 50 r15's DR's on my TA
  161. Does heater still work if I remove the hvac box under the hood?
  162. Need help quick!
  163. Light weight windshield?
  164. drag radial
  165. Burnoutbox.com Drag Racing Forum back online
  166. Proven Suspension Combos (Best of both worlds?)
  167. t-rex guys
  168. NEED HELP! i dunno wtf is going on with my drivetrain now
  169. HVAC plate
  170. Got the interior back together
  171. How much of a burnout with ET Drag radials?
  172. Whats the cure for Squatting?
  173. Trying to find a tuning shop...
  174. Fuel cell rules?
  175. NHRA Roll cage to framerail requirements?
  176. Front end weight in relation to ride height...
  177. Race exhaust Bullet only
  178. anyone have a pic of 275/60/15 on 8" rim?
  179. P325/50R15 MT's, will they fit with bogart D10's 15x10 and stock length rear?
  180. P325/50R15 MT's, will they fit with bogart D10's 15x10 and stock length rear?
  181. Rookie inside, with a few questions...
  182. For those that cut low 1.2 60's and maybe even high 1.1's
  183. Putting in a harlan two step?????
  184. Launch RPM?
  185. Car Cuts Out
  186. Street Car, !Front Bumper Support?
  187. tire pressure
  188. Draggers, Battery Relocation Question...
  189. Anyone have a write-up on how to remove the front bumper support?
  190. how much did the short belt knock off
  191. What size are rear brake fittings? Need adapters to strang rear brakes
  192. Does front ride height affect 60 ft., 1/8, or 1/4 mile?
  193. Hitting the bump stops on launch
  194. Suspension/Tire help.
  195. fastest stock internals?
  196. Spring Rate
  197. Removing a few things to help save weight, need help!!!
  198. Ever have this happen?
  199. Some1 help me out!
  200. help with A4>
  201. torque converter question?
  202. bfg drag radials = garbage
  203. WHy the hell cant I hook??
  204. using undertrays-reducing drag
  205. Race related exhaust question...
  206. HVAC Question
  207. Why is my car moody?
  208. anyone know what steel T/A hood weighs?
  209. Wheel studs question
  210. Realistic 60-foots on 17-inch drag radials?
  211. Rodney! (and anyone else who wants a parking brake)
  212. HVAC removal complete....question on harness!
  213. Shift Point Question
  214. Feathering the clutch?
  215. Order of Destruction
  216. Raptor shift light installed!
  217. How much hp or trap would it take to run a 10 with........
  218. In the process of dash removal....questions!
  219. 13.0 @ 111 Wtf
  220. Cheaper Saftey Gear??
  221. Is this typical?
  222. Drag suspension Question
  223. My last trip to the track.
  224. Used liteweight battery
  225. How much do v6 springs help with the launch?
  226. Check out my lightweight custom TH350 cross member
  227. so far the 4.56's are quiet as a mouse, only took 4 hrs,haha
  228. MT drag radial, 1.55 60ft tonight.
  229. Yeah, In the 10's......
  230. Roll Cage is done!(Pics inside)
  231. wish me luck!
  232. Rear seat brace and harnesses
  233. 9" is in, but have problem's please help.
  234. Drag radial rule question
  235. Suspension Help!
  236. Anyone out there drag racing with a 2004R
  237. How to measure for new DS???
  238. helpful hint for all those with the meziere race pump
  239. Does elevation effect FI cars as much as N/A cars?
  240. What are you guys using for radio delete plates?
  241. ET estimate please.
  242. What do you guys thing I will run with my combo?
  243. 5 Point Harness
  244. What kind of gains to expect?
  245. need serious help with launches, 60's, and car pulling to the side hard during a pass
  246. whats the best brand, strange,motive,richmond?
  247. new numbers soon
  248. Car Insurance
  249. cage is finally in
  250. trap speeds at higher elevations...?
