- Car Insurance
- cage is finally in
- trap speeds at higher elevations...?
- What is the largest, widest tire
- 15" Lightweight C5 wheels for slicks...
- Can a 2800-pound N2O car compete with the turbo cars?
- Before BMR TQ arm, used to hook nice on nittos now I don't whats next 50/50 shocks
- Safety Question regarding rear bumper removal
- weighed car at dump
- Does anyone make a two-step for a LS-1, since harlan is now closed?
- Shift points
- Since the search feature is down.. Wheel ?'s
- Will a 28*11.5 ET Street fit
- times and HP
- Help or suggestions on how to get my car to 60' better.
- Tire selection ET Streets for weight savings or Radial for trap speed/stability?
- Question for the track guru's??
- 29x10.0 vs 28x10.5W
- Finally! Longer 12x1.5mm wheel studs
- Running out of gear, now what??? Best launch with YPT4400?
- convo pro 4" skinnies/what tires?
- Heading out to the track for the first time...
- How much lighter is the race version compared to the street version of the Meziere WP
- burnout
- double check my torque specs please
- 2 step???
- Wolfe bolt-in opinions
- Is motor purging bad?
- WTF did I sign up for.....
- ET Streets questions
- Will drag gears live thrugh occasional street duty???
- Ultrabell Tranny bolts?
- can a 26" slick hold a transbrake launch?
- 30" street tires?
- ASR ? for M6 guys
- Do I need more gear for the track?
- Swaybar quick disconnect?
- Big (28"-30") tire people, please post pics of your.....
- has Harlan been testing already?? (vid)
- Next mod to break below 13.5
- nitrous times
- 60' got worse with Adj Torque Arm, What gives?
- What times should I expect with new mods:
- Gus that have Year one carpet, WHAT COLOR DO I HAVE?!
- Anyone else have trouble balancing thier welds?
- 10.5" NATURAL OUTLAW RULES
- Is this helmet ok? Or is it pi$$
- 12 Bolt question
- 500 hp?????
- How much stress does a tranny crossmember see?
- Quickest stock motor LS1 no power adder.
- Wheel studs sheard off last Friday night! Help!!!!!
- New drag tire time. Need help
- Tire size question
- some pros help me with this launch?
- How to launch in a M6???
- In bracket racing which is better F.I. or Carb
- I broke my 10 bolt today 98 10 bolt A4 3.23 93,000 miles
- Fastest stock motor F-body LS!???
- $1000 Match Race
- Well I installed the edlebrock adj torque arm....
- Attn: PPL w/ SY3500 converter...
- Going up to the Track
- ET and MPH difference in a M6 with 4.11/26” vs 4.56/28”
- Steering Shaft Pics (pinto manual)
- Where does this green wire go?
- 4th gen trans am question???????
- 1/4 times F13 w/stock heads A4
- Launching MT radials
- Finally found out what my cam only racweight was
- New to to the track
- You guys think the DS-2 is safe for street duty 1 time a week?
- Best Drag Racing Posi???
- Another Drag Racing Alignment Thread
- Billingsly ABS delete, just installed today
- skinnys/slicks
- What e/t's to expect from new mods?
- 28x11.5x15 e/t streets. will it fit on my 15x8 prostars
- AC/Heater control delete tip.
- What is the flat plastic box in front of the power antenna on an f bod?
- Posi vs. Spool
- line lock installed
- I'm tring to get in the 11's
- drag school
- Slicks and Rim Size
- How Do I Adjust My Mcloed Adjustable Master Cylinder.
- Finally Finished Minitubbing Project
- Topeka tonight
- Kirkey Seat Sizes - Need help ASAP!!!!!
- sorce on outlaw cowl hoods?
- Dry Sump Guys
- Parts list needed
- Need help installing Grant quick disconnect/steering wheel.
- Those w/pin on hoods, how did you fasten it down? Please post pics.
- what do i need to adjust to keep from unloading so quick?
- 01 Z-28 Rock'd!
- Anyone running 17" ET Streets?
- How much mph do you lose going from DR's to ET Streets?
- 275-50-15 mt dr questions
- 275/50/15 M/T DR fit
- two front bolts on these damn door bars driving me nuts
- harlen 2 step install
- Can I Cut Off The Bracing Under My Hood To Save Weight?
- first time
- Racing w/A4
- Countdown to ATLANTA!
- experiance and true fixes for wheel hop
- Time's should be better?
- Project car suggestions....
- Ordering Bogarts need tire selection help
- roll bar question & pittsburgh raceway
- Cut firebird springs...
- help me analyze my time slips. mph is gone.
- Race Suit??
- Drag Car Insurance
- Do all you M6 guys powershift at the track?
- Which 5 point harness....
- Decent ET, but what's up with my 60 ft.?
- Back in the Picture Boys....
- found an alternativeto the grant quick release steering hub
- do i need more tire with this converter
- help improve 60 foots
- Did you guys have to grind this much for Prostars? (pic)
- I want power!!!
- Snell 2000 helmet still legal?
- Preload stock rear swaybar?
- Do V6 Springs in the rear change ride height/quality??
- 346 Cube Guys, Whats Times are they Going?
- Pin on hood questions
- Drilling Injector Bosses
- Pic of my launch at the track
- People who have removed their dash..........
- ?'s on removing ABS block.
- Fbodies are Pigs! (weight reduction)
- My new custom 6-point cage
- How does pinion angle affect traction and launch?
- Weighed my Wolfe 6 point before installation.
- Should be receiving pin-on hood next week, need to prepare, best hood pins?
- How long can you store race gas before it goes bad?
- New Best and a Question
- GUYS WITH MINI-TUBS INSIDE(interior question's)------>
- Need a lightweight steering wheel, need help.
- Help with Drag radials(size and opinion)
- Keeping tags on 'Race' car
- C5 Vette Guys - Need Help!
- Kirkey mounting pics
- I,ve decided that I have more motor than suspension
- cage cert.
- what 2 or 3 step do you use?
- need some more weight reduction ideas from you featherweights
- whats the best way to add alot of ballast?
- Easy way to check those hard-to-reach plugs...
- problems with 60 ft.
- What size fronts are you running?
- Best affordable K-member?
- Street tire for 408...
- Best Launch Technique for Basically Stock M6 Cars
- Where to find carpet?
- Anyone using hood pins and removing hood latch?
- Experiences with ET Street Drag Radials
- Off .8-1 second and 8-10 MPH AFTER ALL BOLTONS/ DR's! H E L P!!!!
- Rear springs
- Dash is out.......
- Harness info needed...
- Manual Rack
- Custom seat brackets
- How often do you change your plugs & oil on a drag car?
- What MAF are you use with Fast 90 intake & TB?
- Slowing down in the 1/4 from 1/8
- HAL’s 300lbs. front springs?
- Is a Wolfe 5 point Rollbar IHRA and NHRA legal??
- Too much traction! Need launch help!
- Any newbie 1/4-milers near Temple, TX interested in crash course?
- Quick door bar removal FYI.
- What am I doing wrong? (Launch ?)
- Electric Water Pump, how much ET drop?
- When to add subframe connectors?
- Remove front bumper?
- 28x10 QTP’s on Bogart’s fit?
- Removal of front Bumper?
- Race gas worth it?
- 2 Questions about Front Sway bar
- How much will a shop charge for a 6 point roll cage?
- track tips
- What is the absolute best first step is suspension mods
- BMR Front Sway Bar weighs in at 20lbs!!
- aftermarket panhard bar? just for lowered cars or what?
- '98 Z28 vs. other years
- is my car light?
- Horsepower & Torque Formulas
- .4 sec off 60'= what in the 1/4?
- Van over !!!!! carbon fiber parts
- drag race battery and elecetric fan switch???
- 1st night at the track with the 325 50 15 MT drag radial
- My car is a PIG! 3500 lbs. with me in it.
- Which combo would launch better?
- Car Number Question
- Tach
- anyone running header muffler and turn down?
- bumper support removal on a T/A?
- 99 SS Speed Q's
- What slicks to run with new combo?
- Some Car Pics
- Car wont shift, just kinda sputters??
- Whew, finally got the rear wheels on
- Is there any weight savings converting to manual locks and windows?
- kyb agx 8 way adjust for track ?
- rim screws with M/T Drag/Street Radials???
- How much is my new 12-bolt going to slow me down?
- need hood fastener help please
- Lightweight steering column
- 10's on motor possible - will I run out of gear on spray?
- Turning Car Drag
- What should my MPH be?
- Big street tires vs. smaller DRs
- Roll Cage Helps in an Accident???
- Hawker Odyssey PC680 questions.
- Who has a light weight battery?
- um, i need help on Strange Rear brake lines please
- Nitto's & 4.10's....How much off et?
- What does a cammed SS run??
- What are doing about driveshafts?
- 1/4 Mile Math analysis
- Hoosier 28x10's
- What helmet are you using to protect your mellon?
- Cartek Customer Accolade
- possible frame twist with rear or mid engine v8 dune buggy?
- Those that have removed the HVAC, what did U do w/the heater hoses on the water pump?
- what more can i remove off the nose to loose weight?
- How fast on a 16" or 17" radial??
- anyone kwow this car?
- Burnout ?
- $24,000 in payouts - EFI Nationals SPONSORS!
- What HAL's and Springs for my Setup?
- 430rwhp but don't launch hard and want quiet chassis...which TQ Arm?
- Woohoo! The dash is finally out. What all can be removed?
- Choosing the right gear and tire size
- M+H drag radial
- Bickelfirebird car for sale??
- 15X10 Prostar + 275/50/15 MT DR?
- Curious, anyone use the stock fuel tank for balast?
- BMR Torque Arm Relocation Kit, just as good as the Xtreme Torque Arm?
- Elevation correction chart
- What's the highest stall you would go with on a bolt on only car?
- Coolant Overflow Question?
- What setting does everyone run their rear Hals?
- How to disable ABS at the track?
- fastest drag radial car in the world.. for sale
- Anyone running dual rear calipers???
- Removed driver side air bag, what else can be removed?
