View Full Version : Drag Racing Tech
  1. Age-old hooking Q (no 60' time)
  2. 6-8 point rollbar f-bods come in
  3. Any way to preload driveline with an M6?
  4. Shift kit and ET?
  5. Tach recall kit? Anyone ever use?
  6. V6 Fbody springs vs V8 Springs is it worth the swap?
  7. Who's glide?? Who's do you use?
  8. My friend swears reactime time affects your et. How can I prove him wrong?
  9. Help me cut 1.30's instead of 1.50's (Fbody)
  10. Lexan glass windshield???
  11. Fixed my slow as hell stock tach today...
  12. Just finnished the BMR K Member, lower A Arm, Poly mounts and rod bolt swap
  13. How fast do you have to run before you have to have dash bar?
  14. looking for some help to get a 6sd to 60' better(bolt on car)
  15. vac pump.
  16. DS loop help...
  17. AJE Struts...Anyone tried these?
  18. Finished up the wheelwells for the 28x10.5x15W tires...
  19. Shocks?
  20. Ultrabell on 400: Uses 5 or 6 of the 7 trans-to-block bolts?
  21. solid motor mounts
  22. Weight reduction ????
  23. Went too fast, now I need ???
  24. K-member weight question?
  25. My small claim to some fame
  26. will M/T 28.0'' drag radial slow me down
  27. lightweight alternator???
  28. did bunch more weight stuff prepin for tomorrow
  29. just an idea...
  30. I lost 3.5 lbs of fiberglass out of my door, dremeled and hole sawed
  31. How did you run 7.50 in the 1/8th
  32. How light can it go.
  33. Wheel studs and lug nuts for welds?
  34. At what point is a Glide faster than a 350/400?
  35. What should i run now at the track?
  36. tuning, E.T.
  37. Screwing the rims
  38. guys please help me pick out a torque arm
  39. Any problems fitting 28"s?
  40. No one else ever wondered this? (MT DR's vs ET Streets)
  41. Think i'll need a 28in tire?
  42. Rear sway bar: Spohn or BMR
  43. Headers and expected results????
  44. M/T 22.5x8x15 slick with stock 3.42's?
  45. Decision on tires for this season...
  46. Radiator support options (tubular?)
  47. Autometer Water Temp gauge
  48. New class for Ls1 cars to run in.
  49. Pros/Cons of manual brakes
  50. Door bars-rear plate did you remove this?
  51. Pumpgas VS Racegas
  52. Rear brake kits? lightweight, drag/weekend street racing?
  53. Competition Engineering Formed Rear Rails
  54. removin the spoiler a bad idea?
  55. What kinda outcome should i expect?
  56. Race gas question
  57. Car feels twitchy and is loose
  58. where to find hd rear swaybar for 68 camaro w/ moser 12bolt?
  59. Madman rack Kooks Headers
  60. Adding ABS braket for 12 bolt? What's required??
  61. Metallic popping noise after Moser 12 bolt install?!?
  62. Removing wiper motor?
  63. Wheelwell cut for 28x10.5W tire
  64. dash removal questions...
  65. Relocation Brackets
  66. Helmet
  67. Anyone know what happened to to wieght reduction guide??
  68. E.T prediction
  69. Am I correct?? Street/Strip
  70. camlock harness selection help/how about this?
  71. is a sfi bellhousing required
  72. need front suspension help and part ASAP
  73. They're heeeeerrrrreeeeeee!
  74. Is a drag racing rear sway bar worth it for my targets?
  75. RIP Papa Norm (US41)
  76. Anyone got pics of where to grind front calipers???????
  77. going to 99 fuel tank from a 98
  78. best rollcage
  79. !PS line looping
  80. Will I be able to trap 110+
  81. NHRA Tech: Crosstalk or Crossover?
  82. people running 30'' tires. have question??
  83. Someone with an NHRA rule book - safety question
  84. Rollcage Conversion Pics
  85. Who races w/ TH350 with a brake?
  86. Anyone running the new BMR Trans crossmember w/ Tq Arm relocation?
  87. 5 Point Camlock Harness
  88. have a gear problem, need a suggestion
  89. What guage wire for "battery in trunk"
  90. Pics of "battery in rear" setup, and switches?
  91. Spohn 8 point roll bar?
  92. **Racers Poll** Who's removed their bumper supports? Does your front clip sag?
  93. everytime at track
  94. EFI Nationals Magazine Ad
  95. rear bumper core
  96. How to hook on radials 101
  97. Lakewood driveshaft loop and BMR TQ arm!?!
  98. Attention---->!PS Delete procedures!!!
  99. Anyone know this 8 second 93 Z/28?
  100. Inner Fenders on T/A
  101. Question about Madman's motorplates
  102. NHRA rules for 1/8th mile
  103. Thanks to HK and HPE
  104. Predictions? 125 shot
  105. opinions on what else needed suspension wise.
  106. how much weight saved by going to lexan/polycarbonate rear window vs oem hatch glass?
  107. Status & Pictures of my winter upgrades...
  108. Ever wonder what the bumper supports looked like? Pics. (weight reduction)
  109. Removing a/c but not heater
  110. (552 RWH in a M6) Need advice before racing!
  111. How do I find out the stock weight of my car?
  112. S&W Bolt in cage?
  113. qa1's adjust at different rates???
  114. Billingsley Fab 9" weights broken down
  115. roll bar?
  116. What length drive stud for Weld Magnum drags?
  117. Lightweight alternative for stock fans?
  118. Front bumper support replacement?
  119. Driveshaft Safety Loop Guide + Prices
  120. Weight Reduction Help - Whos the lightest?
  121. anyone changing there Power steering resovur
  122. Drag radial question
  123. TC advice needed
  124. Notched vs not notched roll cage kits?
  125. opinions on semi-budget suspension i just ordered.
  126. The roll bar I built this weekend
  127. Question about the diagonal bars coming off the main hoop in a rollcage
  128. anyone put street miles on afco shocks?
  129. HAL F or HAL R for daily driver
  130. Is it ok to paint over Powdercoat for a rollbar?
  131. Nineball 69 Camaro inside
  132. Pics of 4th gen cage in progress
  133. Launching Off a Two Step
  134. Drag Tire Maintenance
  135. Help with two step (M6)
  136. Mojave heater setup pics
  137. How much help would LCA's & a Panhard rod be?
  138. 2 step questions
  139. Racing Classes
  140. Belt routing with manual rack??
  141. Spindle Mount front wheels...
  142. assuming car hooks....min. rwhp to get 9.99ET?
  143. Anyone have chronological albums of their drag buildups?
  144. Picked up a Lakewood DS Safety Loop and have a ?
  145. Need pics from back of 26x11.50x16" ET streets
  146. Outlaw car forsale
  147. racing advice needed
  148. 6 point cage question
  149. Another Cage Question
  150. Aerospace brake kits? anyone useing them?
  151. Just installed autometer quik lite shift light
  152. What Torque are you using to install your race wheels?
  153. Heads-Cam Trap Speed (Opinions Wanted...)
  154. Moroso battery box ?
  155. Some interesting info about the QA1 drag springs. Thought I'd pass it along.
  156. Slick question.....
  157. any books about suspension tunning?
  158. Anyone ever broken a factory driveshaft slip yoke?
  159. QA1s...Drag spring or STOCK???
  160. question for all who swap the kmembers on there backs
  161. Naake converted me to "R" series....
  162. Which Rear Anti-Roll Bar with 12 Bolt?
  163. Jegster Roll-Bar 4pt????
  164. 17" Mickey Thompson Drag Radial
  165. lid and a cut-out?
  166. E.t. Estimates
  167. Sub Frame / Cage?
  168. What you think of this? yes its a lil insane
  169. 29.5" tire fitment
  170. Hoosier DOT Drag Radials
  171. HAL’s Front Springs, how much do they weigh?
  172. Sorry to ask..what slick for 4.11's + M6?
  173. Solid Motor Mounts Users, do you get false knock retard from them?
  174. So what is the rule for my car and roll bar in the 8th mile
  175. Drag Wheel Weights
  176. Question about my MPH?
  177. Getting ready for spring!
  178. Should I wire my Transbrake with a relay for spray, or not with TH400 and 200 shot
  179. Aerospace brake questions
  180. Drag tire comparo question...
  181. Mild Steel VS Cromoly cage
  182. Has anyone tried out any of the new Hal springs that QA1 offers?
  183. 4L60E 1/8th shift points.
  184. Cage question
  185. Going to the track saturday and i need help with front bumper support removal??
  186. Home Built Rear Anti-Roll Bar/ Pics
  187. Racing & taxes??
  188. slight problem with linelock
  189. Advice on wiring SLP line lock
  190. on the street largest converter you get traction with ?s
  191. Anybody running TTT5 this year?
  192. DL10 high speed data logger?
  193. Quick question.
  194. Drag racers with Dumps???
  195. 18" drag radials
  196. Liability Question...
  197. Anyone have weight comparison of drag wheels
  198. how to get my car to the 10's
  199. Jounce Bumper..w/ Prostars?
  200. Breaking spot welds?
  201. whats with all the crappy southern weather.
  202. New Phone Number!
  203. Car Trailer Sale!
  204. Question for cars with No AC, No Heater
  205. drag racing tracks??????
  206. anyone use a car dollie for a trailor
  207. possible to drop from 7.7 to 7.3 in the 1/8th with just a cam?
  208. 17" ET Streets or BFG
  209. Lightweight battery vs battery in trunk?
  210. Aftermarket gas/brake pedal assemblies
  211. Here's some progress on the car
  212. rear end movement on my 68
  213. request pics for swing out door bars on a cage
  214. Rear End cover/support/girdle Guide + Prices
  215. c5 guys whats your set up?
  216. hoosier dot quick time pro's
  217. what am i missing weight wise to get to 3100lbs
  218. does anyone know height of elbow intake from Wilson???
  219. What kind of 60's you think?
  220. what transmissions do the pro drag guys use?
  221. Thinking about manual rack
  222. fuel cell, what are the advantanges??
  223. Which Drag Radial?
  224. How much hp to trap 115?
  225. Some recent pics of the YSi bird
  226. Taller Tire vs. Less Gear...
  227. Pure Stock Racing
  228. Vacum pumps and brackets question
  229. Those with Comp 50/50s out back.
  230. How much does your car hauler weigh?
  231. Here's the Pics i promised of the 325 et radials on the car
  232. Racing seats
  233. Weight distribution ?
  234. Radiator for a drag car, size question
  235. Agostino Racing Engines moving?
  236. What does your car weigh??
  237. Roll bars can save your life
  238. Pics wanted -Wheel wells cut for 30" tires
  239. Hooker CB to HookerMouth?
  240. ? about driveshaft loops
  241. Those that disabled the PS - how did you do it
  242. m/t 295/65/15 dr's some q's
  243. Anyone running Spohn Cage??
  244. help with drag project- need junk block& heads
  245. Chevy Truck and trailer
  246. Help choosing cheap drag seat. (Did many searches.)
  247. will 3.73's help me?
  248. Where can I find a Drag Racing School?
  249. any tracks open near tn.
  250. Some pics of !hvac and !airbag
