View Full Version : Drag Racing Tech
  1. Looking for engine and tranny weights.....(have searched and can not find them).
  2. How much did you spend to 4-link your car?
  3. Co-worker wants to race my camaro with his TT 300zx
  4. Will I be ok to use .746" shank length open end lugnuts at the strip?
  5. Do you think i can break 13 with these mods?
  6. BFG DR, A4, launching advice?
  7. 11.99 possible with NO engine mods cept Headers?
  8. sumped tank and fuel pump Q
  9. Has anyone pulled 17" wheels off the ground?
  10. Kirkey seat users, please post pics of mounting brackets.
  11. What RPM to launch on street tires?
  12. QTP 27x11.5 versus ET Drag 26x10
  13. need help please
  14. Need lightweight options/ideas on how to mount a Kirkey seat.
  15. Lowering springs vs stock springs
  16. Best Drag converter with the spray
  17. Decisions, Decisions...Need input please
  18. 26 inch slick enough?
  19. Where can I find 17in front runners?
  20. Need to prove someone either right or wrong, does a drag car need a rear swaybar?
  21. 12 bolt installed, what did yall do about the clearance on the rear swaybar?
  22. Need pics of lightweight carpet installed. (excluding Speed Inc. carpet)
  23. Launch pic from yesterday
  24. M&H Drag Radials ... Anyone here have any experience?
  25. need help with wheel sizes???
  26. Slow It Down
  27. Drag Springs and Shocks
  28. Ready for LACR 9/19
  29. Strange Race Brakes Installed....
  30. weight reduction, where to start? car must need slim fast!!
  31. air bag in RR spring...WORKS!
  32. The Clash of the Titans, and LS1's
  33. My 60Ft SUCK!!! 2.0, 2.3's-2.5's on nitto 5555R
  34. 28x11.5x15 QTP's... what rim?
  35. Third Gen LS1 Times?
  36. Welding in a roll bar. (rules)
  37. got a ? about 1/4 times
  38. Lets see your Towing Setups!
  39. what launch method
  40. Are E/T Streets Hurting my times?
  41. Launching Tips
  42. Line Lock Reccomendations
  43. What hook better, MT or M&H?
  44. quickest NA 6spd time through cats?
  45. what is needed to fit a 15x10 wheel in the back ?
  46. what do you think my car is good for
  47. Is this too big...
  48. need help with et time
  49. Cant get traction in second
  50. Help Me pick the right Track Tire
  51. What will I run in the 1/4?
  52. Drag Bar BMR or Spohn
  53. Launching with a H/C 150 shot M6?
  54. Any problems with removing inner fender?
  55. is there any way to turn air bag light off
  56. air bag or extreme duty rear sway bar
  57. PA Kmember and Aarm problem help!
  58. lightweight battery question....
  59. NHRA lucas oil drag series.
  60. QA-1 "R" series vs. Strange Silver series
  61. tips on a extremley cheap way to make a light hvac blockoff plate.
  62. Any write ups on QA1s for the front?
  63. what size rim
  64. Anyone put a 5gal Tank in the TTop Area?
  65. M/T E.T. Street or Street Radial ?
  66. Weight reduction... What to remove
  67. manual shift points....
  68. Quick opinion on this gearing/tire combo please.
  69. struggling at night!
  70. ur worst 60'...and why?
  71. considering a powerglide....opinions???
  72. What size rear sway bar are you using?
  73. need help.... sad day for F-bodies
  74. compulink autostart.... what does it mean?
  75. Spohn Torque Arm worth the swap?`
  76. What kind of #'s can I expect to run ?
  77. Spohn Rear Sway Bar.......
  78. Want 11's have 12's
  79. Any tricks to pulling the dash and air bag?
  80. 12 bolt or 9"......
  81. Transbrake users do you shallow stage?
  82. Full tree VS Pro tree question?
  83. A few HAL shock/spring questions
  84. Anyone using the velour cover for their Kirkey seat?
  85. what should my t/a run
  86. BMR & Pinto Manual Rack (Shaft Questions)
  87. Light weight batteries
  88. Question about battery relocation
  89. potential of these mods?
  90. 11's cam only?
  91. do i have what it takes to go 11s
  92. Is stock rear sway bar holding back my 60'
  93. Tire for H/C 150 shot?
  94. Roll bar padding questions.
  95. Weight Reduction
  96. What would I run?
  97. 1/4 mile time?
  98. lid or lca
  99. Behind the line RPMs??
  100. Wolfe 6 point weld-in roll bar & Kirkey Pro Street Drag seat, which harness?
  101. Weighed the LT1 last night...
  102. Anyone know the site to find weather conditions
  103. What do you think I will gain? ET/mph
  104. Still running 13.5
  105. What gear for 150 shot and 28" tire. Help.
  106. What gear for 150 shot and 28" tire. Help.
  107. guys with enclosed trailors...and use a winch to pull car in
  108. Fastest N/a Ls1
  109. True duals.. What torque arm?
  110. Does relocation bracket affect pinion angle?
  111. Fast MPH on VW tires?
  112. Kirkey seat questions.
  113. Weight savings from removing sound deadening from backside of factory carpet?
  114. Can't get better than 2.0 60' w/dr's - what am I doing wrong?
  115. I need a 11 sec Timeslip BAD!!!
  116. custom front bumper support.
  117. Lightweight batteyy mounting
  118. Should I be able to run with this car?
  119. making my own DS loop, need opinions/ideas
  120. Are there any rules pertaining to the seat?
  121. Questions pertaining to rear Hal shocks.
  122. Subframe install
  123. Would the Wolfe anti-roll bar be overkill for a low 11/high 10 sec. car?
  124. Which M/T ET street radial for 8" rim?
  125. need help quick, OD of stock aluminum ds
  126. Decent, cheap rear shock for strip use?
  127. M/T or Hoosier drag tire...which hooks better?
  128. Libertys 5 speed installed
  129. Shifting questions...
  130. Thanks to everyone here!
  131. LACR have helmets to borrow?
  132. Drag Radial launch help please
  133. anyone running a 4.88 gear or have some input
  134. Cheapest Drag Fronts For 98+ F-body
  135. Need lightweight seat and harness suggestions.
  136. What psi works the best for Nitto DRs??
  137. Which Header Muflers for FLP headers?
  138. Those without HVAC inside.
  139. What is my problem?!?!?
  140. who has the fastest vortech car with a stock 346 ls1
  141. Torque Arm/LCA/bracket questions
  142. Limitations of Street Tire Traction?
  143. Shake down passes!!!!
  144. 28 inch tire guys in Camaro
  145. help with setup....please!!!!!!!!!!!!!
  146. 6 speed guys, tire growth, and RPM thru traps
  147. Info on the ESP Silver Bullet and ARE Silver Z
  148. 402 Stroker, TH400, 150 shot - 9's possible?
  149. differents between wolf roll bars and jegster roll bars.
  150. Clearancing for tires, need help removing ENTIRE bumper support bracket
  151. BMR vs. PA K-Member and A-arms??
  152. What psi for Drags, Tubes?
  153. Need Help What Should My Car Run
  154. Weight Reduction Help
  155. Front bumper support more information
  156. O.K., I'm pissed..this 6 speed is outta here!
  157. G5X3 M6 set the rev where?
  158. 14 sec Z28 WTF HELP
  159. Anyone have a pin-on hood on their street driven car?
  160. TSP228R cam only times
  161. what happen
  162. need a little help
  163. my 2002 SS Bone Stock Track Times
  164. AP Engineering Shop Car Update
  165. Can I run standard studs & still run my Bogarts? Anyone have this combo?
  166. Two Step Switch Suggestions?
  167. removed the AC do i need to block off?
  168. Alignment for drag/street car?
  169. Best launch method??
  170. What do you guys think 3.73 or 4.10s for a 408 with spray?
  171. Need help ASAP. Not sure what all I need 2 send in so that Strange can start my rear.
  172. Urgent: What length wheel studs do I need, to have enough to be legal w/open lugs?
  173. Whats it take to break the stock rearend?
  174. 383 vs 408 for drag racing???
  175. Sep 4 - Vette Doctors Pro 8 Heads-up Invitation
  176. 10's On Stock 10 Bolt?
  177. How many in the 9's???
  178. Need Some Thoughts on My Gear/Tire Change
  179. I expected better times, how much does weather affect ET
  180. Autometer Gauge Cluster Pics...
  181. What should I be trapping N/A?
  182. Roll Bar or Cage
  183. 15" ET Fronts....what psi?
  184. Does removing the front sway bar really help?
  185. Taking off front support......is it safe???
  186. Bad track times
  187. burnout
  188. 410 or 430?
  189. Where's the Hammer???
  190. Need help w/ draglites
  191. Some pics of a motorplate with electric water pump.
  192. Track advice
  193. Will I ever see a decent 60ft???
  194. picked up a vibration/noise at track
  195. Battery Cable
  196. What Drag tire to get?
  197. Madman R & D car for sale
  198. just lost 52lbs
  199. Proper rear spring adjustment for launching
  200. Stock 16'sd ve Light weight rear wheels.
  201. Cam & Longtubes at the track = 12.70
  202. 11.5's hurting my time?
  203. Drag radial question
  204. Rear 12 way HAL QA1 adjustable shocks arrived
  205. Pin on hood
  206. What torque arms are those w/ 1350 Carbon Fiber ACPT shafts using? Clearance issues?
  207. 5 point harness question
  208. Front fascia sagging & sticking out on corners, how 2 fix? (!front bumper support)
  209. Rear Coil Overs?
  210. Disappointed with time, help needed!!!!
  211. Any Mojave heater updates?
  212. What is the fastest Drag Radial time?
  213. I need launch tips.
  214. Gas tanks: metal to plastic swap...
  215. LACR vs. California Dragway?
  216. Anyone running an oil pressure warning light?
  217. Can I Removing All In Car Wiring?
  218. at what Horsepower level do yu pull the front tires up off the ground
  219. will i go faster if I change my .......
  220. What is the difference?????
  221. Paging Jay Billingsley!
  222. 12.5 stock...How can I tell what this guy is hiding?
  223. HVAC Removal Without dash removal?
  224. Well its official
  225. ABS Delete...What is street driving like?
  226. nitto drag radials???
  227. T/A & 21mm sway bar or Anti roll bar??
  228. Do Nitto's grow at the end of the track?
  229. Need help hooking up!!
  230. Every want to line up on a Viper? A Z06? Here's your chance!
  231. Launch/limiter/B1 questions
  232. What is the "Record" for stock bottom end?
  233. Need some pics of 29in tires on F-bodies.
  234. Burn Out & Take Off
  235. Need Help With my RACE-READY TH-400-Please read
  236. new best
  237. cam only 12.8 @ 106 ?????
  238. Whats the rule about wheel studs, lugnuts, and axles?
  239. running w/out sway bars
  240. How fast did ARE's Silver Z go?
  241. What is the 346 N/A 6 speed record?????
  242. What drag rims/skinnies when using wilwood brake kit and 9" rear
  243. Just need some opinions
  244. How many have PA K members?
  245. Attention C5 M6 drag racers. Don't let this happen to you.
  246. how do I put my 11.40 on the list
  247. where do I start my shock setting at?
  248. TC and Trans Brake for racing???
  249. what 60' with 3.23 gears and 3850lbs?
  250. NHRA Requirements
