PDA
View Full Version : Drag Racing Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
  1. Well I installed the edlebrock adj torque arm....
  2. Attn: PPL w/ SY3500 converter...
  3. Going up to the Track
  4. ET and MPH difference in a M6 with 4.11/26” vs 4.56/28”
  5. Steering Shaft Pics (pinto manual)
  6. Where does this green wire go?
  7. 4th gen trans am question???????
  8. 1/4 times F13 w/stock heads A4
  9. Launching MT radials
  10. Finally found out what my cam only racweight was
  11. New to to the track
  12. You guys think the DS-2 is safe for street duty 1 time a week?
  13. Best Drag Racing Posi???
  14. Another Drag Racing Alignment Thread
  15. Billingsly ABS delete, just installed today
  16. skinnys/slicks
  17. What e/t's to expect from new mods?
  18. 28x11.5x15 e/t streets. will it fit on my 15x8 prostars
  19. AC/Heater control delete tip.
  20. What is the flat plastic box in front of the power antenna on an f bod?
  21. Posi vs. Spool
  22. line lock installed
  23. I'm tring to get in the 11's
  24. drag school
  25. Slicks and Rim Size
  26. How Do I Adjust My Mcloed Adjustable Master Cylinder.
  27. Finally Finished Minitubbing Project
  28. Topeka tonight
  29. Kirkey Seat Sizes - Need help ASAP!!!!!
  30. sorce on outlaw cowl hoods?
  31. Dry Sump Guys
  32. Parts list needed
  33. Need help installing Grant quick disconnect/steering wheel.
  34. Those w/pin on hoods, how did you fasten it down? Please post pics.
  35. what do i need to adjust to keep from unloading so quick?
  36. 01 Z-28 Rock'd!
  37. Anyone running 17" ET Streets?
  38. How much mph do you lose going from DR's to ET Streets?
  39. 275-50-15 mt dr questions
  40. 275/50/15 M/T DR fit
  41. two front bolts on these damn door bars driving me nuts
  42. harlen 2 step install
  43. Can I Cut Off The Bracing Under My Hood To Save Weight?
  44. first time
  45. Racing w/A4
  46. Countdown to ATLANTA!
  47. experiance and true fixes for wheel hop
  48. Time's should be better?
  49. Project car suggestions....
  50. Ordering Bogarts need tire selection help
  51. roll bar question & pittsburgh raceway
  52. Cut firebird springs...
  53. help me analyze my time slips. mph is gone.
  54. Race Suit??
  55. Drag Car Insurance
  56. Do all you M6 guys powershift at the track?
  57. Which 5 point harness....
  58. Decent ET, but what's up with my 60 ft.?
  59. Back in the Picture Boys....
  60. found an alternativeto the grant quick release steering hub
  61. do i need more tire with this converter
  62. help improve 60 foots
  63. Did you guys have to grind this much for Prostars? (pic)
  64. I want power!!!
  65. Snell 2000 helmet still legal?
  66. Preload stock rear swaybar?
  67. Do V6 Springs in the rear change ride height/quality??
  68. 346 Cube Guys, Whats Times are they Going?
  69. Drilling Injector Bosses
  70. Pic of my launch at the track
  71. People who have removed their dash..........
  72. ?'s on removing ABS block.
  73. Fbodies are Pigs! (weight reduction)
  74. My new custom 6-point cage
  75. How does pinion angle affect traction and launch?
  76. Weighed my Wolfe 6 point before installation.
  77. Should be receiving pin-on hood next week, need to prepare, best hood pins?
  78. How long can you store race gas before it goes bad?
  79. New Best and a Question
  80. GUYS WITH MINI-TUBS INSIDE(interior question's)------>
  81. Need a lightweight steering wheel, need help.
  82. Help with Drag radials(size and opinion)
  83. Keeping tags on 'Race' car
  84. C5 Vette Guys - Need Help!
  85. Kirkey mounting pics
  86. I,ve decided that I have more motor than suspension
  87. cage cert.
  88. what 2 or 3 step do you use?
  89. need some more weight reduction ideas from you featherweights
  90. whats the best way to add alot of ballast?
  91. Easy way to check those hard-to-reach plugs...
  92. problems with 60 ft.
  93. What size fronts are you running?
  94. Best affordable K-member?
  95. Street tire for 408...
  96. Best Launch Technique for Basically Stock M6 Cars
  97. Where to find carpet?
  98. Anyone using hood pins and removing hood latch?
  99. Experiences with ET Street Drag Radials
  100. Off .8-1 second and 8-10 MPH AFTER ALL BOLTONS/ DR's! H E L P!!!!
  101. Rear springs
  102. Dash is out.......
  103. Harness info needed...
  104. Manual Rack
  105. Custom seat brackets
  106. How often do you change your plugs & oil on a drag car?
  107. What MAF are you use with Fast 90 intake & TB?
  108. Slowing down in the 1/4 from 1/8
  109. HAL’s 300lbs. front springs?
  110. Is a Wolfe 5 point Rollbar IHRA and NHRA legal??
  111. Too much traction! Need launch help!
  112. Any newbie 1/4-milers near Temple, TX interested in crash course?
  113. Quick door bar removal FYI.
  114. What am I doing wrong? (Launch ?)
  115. Electric Water Pump, how much ET drop?
  116. When to add subframe connectors?
  117. Remove front bumper?
  118. 28x10 QTP’s on Bogart’s fit?
  119. Removal of front Bumper?
  120. Race gas worth it?
  121. 2 Questions about Front Sway bar
  122. How much will a shop charge for a 6 point roll cage?
  123. track tips
  124. What is the absolute best first step is suspension mods
  125. BMR Front Sway Bar weighs in at 20lbs!!
  126. aftermarket panhard bar? just for lowered cars or what?
  127. '98 Z28 vs. other years
  128. is my car light?
  129. Horsepower & Torque Formulas
  130. .4 sec off 60'= what in the 1/4?
  131. Van over !!!!! carbon fiber parts
  132. drag race battery and elecetric fan switch???
  133. 1st night at the track with the 325 50 15 MT drag radial
  134. My car is a PIG! 3500 lbs. with me in it.
  135. Which combo would launch better?
  136. Car Number Question
  137. Tach
  138. anyone running header muffler and turn down?
  139. bumper support removal on a T/A?
  140. 99 SS Speed Q's
  141. What slicks to run with new combo?
  142. Some Car Pics
  143. Car wont shift, just kinda sputters??
  144. Whew, finally got the rear wheels on
  145. Is there any weight savings converting to manual locks and windows?
  146. kyb agx 8 way adjust for track ?
  147. rim screws with M/T Drag/Street Radials???
  148. How much is my new 12-bolt going to slow me down?
  149. need hood fastener help please
  150. Lightweight steering column
  151. 10's on motor possible - will I run out of gear on spray?
  152. Turning Car Drag
  153. What should my MPH be?
  154. Big street tires vs. smaller DRs
  155. Roll Cage Helps in an Accident???
  156. Hawker Odyssey PC680 questions.
  157. Who has a light weight battery?
  158. um, i need help on Strange Rear brake lines please
  159. Nitto's & 4.10's....How much off et?
  160. What does a cammed SS run??
  161. What are doing about driveshafts?
  162. 1/4 Mile Math analysis
  163. Hoosier 28x10's
  164. What helmet are you using to protect your mellon?
  165. Cartek Customer Accolade
  166. possible frame twist with rear or mid engine v8 dune buggy?
  167. Those that have removed the HVAC, what did U do w/the heater hoses on the water pump?
  168. what more can i remove off the nose to loose weight?
  169. How fast on a 16" or 17" radial??
  170. anyone kwow this car?
  171. Burnout ?
  172. $24,000 in payouts - EFI Nationals SPONSORS!
  173. What HAL's and Springs for my Setup?
  174. 430rwhp but don't launch hard and want quiet chassis...which TQ Arm?
  175. Woohoo! The dash is finally out. What all can be removed?
  176. Choosing the right gear and tire size
  177. M+H drag radial
  178. Bickelfirebird car for sale??
  179. 15X10 Prostar + 275/50/15 MT DR?
  180. Curious, anyone use the stock fuel tank for balast?
  181. BMR Torque Arm Relocation Kit, just as good as the Xtreme Torque Arm?
  182. Elevation correction chart
  183. What's the highest stall you would go with on a bolt on only car?
  184. Coolant Overflow Question?
  185. What setting does everyone run their rear Hals?
  186. How to disable ABS at the track?
  187. fastest drag radial car in the world.. for sale
  188. Anyone running dual rear calipers???
  189. Removed driver side air bag, what else can be removed?
  190. Who has an HO alternator in there drag car?
  191. Too Much Gear?
  192. Hoosier QTP`s & fitment? Need some opinions please.
  193. Anybody regret using Hals for a street car?
  194. Better traction: 26x11.5x16 vs. 26x10.5x15
  195. Soon to be LS1 owner for the first time.
  196. Improvement going to HAL QA1's?
  197. Vette Question
  198. roll cage vs sfc ???
  199. A good question for real racers !!
  200. Need help w/HVAC & passenger air bag removal.
  201. question for all with 1/4 turn hood fasteners
  202. Any pics of the travel limiters ?
  203. Motorplates help
  204. Pulling carpet, anybody?
  205. Help with Race Seat installation
  206. 60's foot, HAL’s with stock springs VS HAL’s with HAL’s springs
  207. Removing Door Bars?
  208. New product
  209. Is anyone running a Mark Williams Ford thru Bolt Aluminum Case??
  210. Best tire pressure
  211. Need help running car's best time
  212. M&H 275/50/17 28" tall---who has used these?
  213. Tipped the scales at 2,850 last night
  214. need help for drag set up
  215. What PSI to set street tires for strip?
  216. Poppage with a 2.x 60'?
  217. Ditching e brake right now... question on huge spring on rear brakes
  218. 28.0 inch tire with 4.11 and juice in A4
  219. Cage Pics
  220. Ken @ Eastside, come out, come out where ever you are....................
  221. Draglite Frontrunners
  222. Aftermarket Gauges w/ stock PCM?
  223. found some gtec pros cheap!!!!!!
  224. ET Streets vs. Street Tires
  225. Question on air bag module under center console and removal
  226. Madman Manual Rack????
  227. My New Setup
  228. Could someone evaluate what I've got/where I could be, please?
  229. Are 9's possible??
  230. Launching??
  231. CONGRATS Joe O
  232. What cam to go 10s with nitrous?
  233. Rear drag shock question
  234. A Noob question
  235. What rods do you use to weld chromoly?
  236. Harness w/stock Camaro seats legal??
  237. Ran today...
  238. Single digit guys, what wheel/tire combo do you have?
  239. Times?
  240. will a 16x10.5 or 16x255 m/t hook me???
  241. Best ETs with stock 98-99 exh manifolds?
  242. abs delete
  243. Need a street 10 sec car.
  244. PSI for 17" ET streets
  245. Launching with new converter.
  246. How strong do you think this will be?
  247. ok vett or trans am people??????????
  248. Will I be faster or slower this year?
  249. Weighed the car today...
  250. First time on slicks last night...
