- ET with Bolt ons and Cam??
- Hoosier QTP Size question
- 16th annual U.S. Army World Cup Finals (Import vs Domestic) Nov 5-6 @ MIR
- Suspension upgrades!!
- 6 Speed nitrous C5 Corvette goes 9.65@149 NA
- LCA angle how critical is it?
- Converted my 98 Camaro drag car to electric power steering
- ET possibilities? What'll it do?
- BMR Suspension Congratulates Judson Massingill for LS Fest All Motor Class Victory
- power needed to drop 1 sec in the 1/8th?
- Another build thread
- My lt1 trans am build
- looking for weight of 17x11 chrome zr1 wheels and 15x10.275 weld rts
- CSR Supershield for 4L60E
- Serious Racers only, no tire kickers please
- Car sits to high.
- The Burkhart shop car is ALIVE!
- Toyo Drag Radial?
- How hard to get below 3000 lbs?
- Cowl Mods / Relocating PS Wiper
- When is a drag bar necessary vs a regular sway bar
- some pointers for hooking on the street????
- Trans brake with 2 step, quick question
- 25.3 Camaro from TNT Race Shop
- Installed some CF door panels
- BMR Suspension Congratulates Anthony Manna on his Holley LS Fest Drag Radial Victory
- LS1 pistons
- 60ft problems, suggestions on my findings?
- 2inch drop spindels
- Trap speeds/rpm? 456's+6 speed+28" DR=?????
- BMR Suspension Congratulates Dave Childress on his Holley LS Fest True Street Victory
- 4l60e guys, questions on shift points
- Battery relocation woes :(
- 15" wheel question! HELP!
- weight transfer at launch questions
- Anyone NOT use SFC's?
- Strange SA or QA1 R fronts, stock springs or 300lb?
- rear spring question
- ET/MPH vs. Temp./Humidity
- Battery relocation - firewall wire hole
- Where to Shift? Based on Dyno Graph
- Where you locating your remote battery disconnect? ** post pic **
- what tire for my 6spd
- Couple of basic turbo questions..
- Wolfe Race Craft - End of Summer Sale
- LSX Shootout sale
- Any suggestions... first time to the track
- fuel pressure gauge
- headers and ory question
- What cutoff switch?
- OK So my T56 DR experiment first time out
- Front splitter/airdam question.
- nitto's vs mt's
- What valve covers for shaft mount rockers (tried bolt on forum - no traffic)
- proportioning valve or not for brakes?
- Cheeseburger Grudge Match Race
- 5 point harness or 4 point, what's needed?
- Please watch and critique my launches (VIDS INSIDE)
- CHANGING TIRE SIZE (street to slicks)
- 99 Z28 275 Drag radial build
- Not charging nough after battery relocate?
- were did the slicks/or DR on the street thread go?
- Driving on interstate to track on skinnies
- Omss race and stick shift shootout oct 2nd
- Join Team BMR at the Holley LS Fest!!
- Anyone using a scorpion t/b??
- V6 drag springs
- A Car that interests all of you...
- Losing tach signal at high rpm
- Softening some mildly aged drag tires
- Mounting a 5 point harness
- 5.3 builds
- SS wannabe drag car progress!!!!
- Moving the PCM inside the car?
- Add a chute or not?
- Hi...I am I looking for 10's
- 1" rear lowering springs
- LS FEST II is next week!!!
- mufflers mounted off the header folks.
- Suspension gurus come in here *VID*
- M & H cheater slick size help
- 12.7x's to 12.9x's guys
- A little suspension help with my launch
- running out of gear?
- HELP!!!!!! with this supid 4l60e
- spot in northern nj, lexan windows
- 2010 Camaro in x275?
- radial vs. slick on the street
- need 6 speed drag racing advice
- Can i get away with 4:56s and lots of spray?
- joe van overbeek wing
- Two step Qs....N/A
- Over all race weight vs weight distribution
- Driving Shoe Fitment and Suggestions?
- Rear drag brakes with e-brake
- Rear Firewall/Bulkhead
- Guys with sumped stock tanks
- k F*ckkkk dzus. where should i mount my pins?
- Best front runner to run? Anyone running a 27 inch front runner
- MSD 8733 2-step problem
- !!!!!!!!!Madman Summer Heat Sale!!!!!!!!!
- front crash bar removal....???
- manual rack...best place to buy
- Transbrake-converter question.
- Hoosier 28x10.5 with 6 speed
- rear spring rate
- I need help with PTV Clearence.
- heeeelp!!!
- Car is unloading about 40-50ft out.
- Engine lengths
- lightweight fan replacement ?
- 1134 whp and 963 wtq in a Jeep, Go 9's and Bring the kids!!!
- ac control panel hole measurments
- Help with intake selection?
- thanks madman
- Tire size for 1/4 mile?
- Tubed front end
- what is causing this *VIDS*
- Question about MSD window switch and NOS
- coil relocation
- New Drag Wheels are on: Weld 15" RT-S Black Anodized Wheels
- Need some help on narrowing my 12 bolt in a fbody
- Manual rack help
- two step
- KYB w/BMR drag spring help
- What 1/4 mile should i expect??
- rear coilover pics ...
- Carbon Fiber Door Install
- Headers Question
- need some info
- Battery relocation - Won't activate the starter - help
- Reaction Time Question
- Shock Travel Tricks
- 25. cage and exhaust
- Ice air box: worth trying or retarded
- 4L60E lockup on a switch any benifits to keep it off at the track
- Manual Brake Conversion ????
- First time dragracing.. 8/12
- Et drag diameter question
- Spool and ABS reluctor ring removed?
- Can I run green slime in my slicks?
- Best sponsor to order Shocks/Drag Bar from
- O.K. pics of 5" VFN Non Sloped WS6 Hood
- tire size input
- How much will weight affect et
- anyone going fast with the 5.3 NA?
- Drag Bar Purchase
- Short tq arm...Pinion angle question
- carbon fiber driveshaft...worth it?
- launch problems squat in rear front sway bar connected lifting left tire only
- Pics of 5" VFN Sloped WS6 Hood
- 5.3 converter and gears
- harness and racing seat support insight
- what rpm limit?
- BBC motor plates ...pics ??
- Mozez meets Goliath on Firemutt!
- "Built Like A Brick Shit House" Procharger Bracket For The Big Boy's!
- co2 shifter for hurst pistol grip(rmvb)
- Fast 4150 or Accufab 4150
- Front Motor Plates
- Bulkhead help please
- Fabricated Dash
- How to make car more consistent
- SI RULES and spring questions
- Front Sway Bar
- Vacuum pump trial and error
- mini tubbed 4th gens.
- solid roller valve spring tool
- 02 SS build
- 95 LT1 strip setup help
- finishing up smiths 275 car
- M6--->TH-400 swap, predictions?
- Super Vic and WS6 Hood
- DOT legal bias ply skinny's?
- 17inch front drag rim. 5,6inch wide?
- th350 swap and car will not turn over...
- Confused about battery rules....
- Car is finally hooking up nicely. What's up with my numbers? Vids
- Solid Mounts - Reduce Vibration & Drone?
- Vert question
- 99 ss camaro lq9 build
- How bad are heavy wheels?
- mounting kirkey seat?
- Help...running SLOWER after engine rebuild??
- New X275 Build
- 7531 box w/COP
- aftermarket steering wheel
- Can't run DR and stay in my class, next best option??
- Battery Cutoff Switch Location
- I know im slow!!! what do you think?
- LOL How can I get this car lighter????? PIC INSIDE
- starting issue(key on)
- The 36 hour thrash session...
- drag car exhaust setups
- Wheelbase settings/suspension settings
- Thanks Madman and Nitrous Outlet
- extended wheel studs for moser 9''?
- Best way to take off the line?
- radiator AN lines size?stock pump
- Tick Performance Battery Relocation Kit SPECIFICALLY for LS1 F-Bodies - FINALLY HERE!
- Put the car on the scales ....
- Why do i have such a big wheel gap in front (pic)
- how do i get the factory tach to work after pulling out the factory PCM?
- What tire and gears for my cam only A4
- any 6speed cars running a hoosier DR?
- Time to up the Nitrous..or Gears?
- Taking out the Rubber stuff in trunk area
- Reducing IAT for racing
- How tall of a front runner tire
- Going to the track for the first time tomorrow
- '95 Z28 LSx Drag Build
- MWC anti-roll/torque arm pics with 12 or 10 bolt !!!
- Lazy 2-3 shift.. How much time lost??
- Weakest link?
- Ice box to intercooler lines
- Help with picking parts out
- Question about 2 step and stall
- Help: Blowing through my converter???
- Weight Reduction for street car ?
- 8.2 sec 1/8 mile car at 91.7 mph??? haha
- how much does altitude affect times?
- weight of 4 gen camaro door & glass
- Ozite instructions?
- 10 point c/m cage
- Double Afco help?
- question for the six speed guys
- Trouble with centering BMR manual rack
- critique this setup. video inside
- Just one of those, "which tires?" thread
- Launching Methods
- cutouts or u/d pulley??
- cutting out the floor boards.
- is there a ride height you guys aim for?? looking for more traction
- Vic jr vs FAST for my set up
- F-body rear drop-in windows in 3/16" !!!!
- Hood pins or Dzus Fasteners?
- Removing My Door Bars
- Tach, temp, and fuel gauges not working
- first transbrake got a couple questions...
- oil air separator? for PCV
- Guys who cut inner fender wells out.... come in here
- educate me on tires!!
- Need help with a suspension issue
- How To Delay Without A Delay Box?
- Driving around the water box...
- How many drag racers i'n here run a ram air setup
- Needing some susp. advice..
- 1/4 mile estimate
- when should i shift?
- Dropping weight off 2000 Formula while keeping the AC
