- Just got back from track, new Best!!!
- New best with ET Streets!
- what do you think
- Density Altitude(DA)?
- 99 SS - longtube track results
- Does anyone have a link
- I ran a 14.0 at the track whats wrong?
- Hey Madman
- Quest for the 10's update
- anyone use v6 rear springs
- 11.doh!!!
- Hot Cam track time's
- Help me out here, something doesn't add up
- Finally Did It!!!
- High 10 sec H & C car adds nitrous...what to expect....
- Nitto 315/35/17's Air Pressure??
- Need launching Tips ASAP for M6!!
- 1/4mi Improvements with a HTPPIII?
- Welds?
- weight reduction
- Longer wheel studs ??
- 12.20@114, stock internal/converter new best
- I need to launch better...
- New track times
- Roll Cage Pics (tell us what ya think)
- SS 4000 track times
- 11.5 at 119mph 1.62 60ft. stock clutch!!!!!!
- alternatives to t56...
- Going drag racing this weekend
- PA/Pro Fab K-member & Lower A-arm weights!
- to air bag or not
- 2.73 to a 3.42. How much faster?
- My new best... but still not quite what I wanted
- Why so slow??
- Launch tips for a4's
- first time at the track with the tow vehicle tonight.
- launching tips
- Staging?
- Is this a new site?
- What 16in. tire do I need?
- What happened to the NFRA??
- OPDS Race#2 April 18th at Mason Dixon
- Well got some times... looks promising of more to come.
- What do you guys think my car will run with this setup?
- How fast do you think this 5.0 is?
- Question for those that have converted to manual brakes
- to dry hop or not with drag radials
- Suggestions to get the Hot Rod into the 10's
- question about how long to get from 1/8 marker to 1/4 mile marker
- Car sat all winter, now won't start.
- K-member on a daily driver. Opinions?
- DAMMM!!!.....here i go again
- What belt length for race water pump and no power stearing
- New best 1/8 mile
- How bad will 3.42's hurt me at the track?
- What should I run in the 1/4 after these additions???
- New Best !!!
- Cam only A4 help
- Which wheel studs
- check out my 11.5 pass at E-TOWN NJ
- New best for near stock Z06 11.81 but costly
- 1.44 60', 10.91 @ 125.30 mph...... finally! :)
- Everyone respond
- Anyone put take our power windows and put rollup in car?
- 60 ft question?
- Another slight new 1/8 mile best
- Jason's "I8AFORD" new cage done by Louis Gigliotti
- FASTEST w/ TR224 A/4 STOCK HEADS
- Damn that MADMAN
- Advice on getting out of the hole
- Guys using Burn Out Guard or equiv.......
- help me with my times
- Bracket results for this weekend
- What gear in burnout box?
- 1/4 mile time with cutout open vs closed?
- 10.989 @ 123MPH--I'll take it
- Tire Pressure difference at the track
- finally in the 12s!!! 12.65 @ 106.25
- Torque specs for Strange Drag Brakes?
- What do you think?
- New Bests along w/ new worst
- Where's the best place to buy slicks ???
- Whats a good suspension combo for street car with 3,500lbs?
- Should I go 12s?
- How fast in the 1/8 2000 a4 WS6
- 11.80 @ 120.5 on street tires...
- Need Some Advise on my times please!!!
- Another FMS/TEA combo. Very happy.
- New best for 346/single stage (6.0 @ 113mph)
- How many rpm's will I tach at 122 mph?
- Drag Race Fuel Tank
- Torque Arm Opinions
- New Best 1/8 6.66 @103.26
- what is wrong with my car?
- FMS/TEA Combo's Maiden Voyage @ the track
- ? about removing the front bumper
- I might need ET Streets now 426/396
- Where can I find an accurate LED shift light?
- Norwalk, OH Friday april 9th, who will be there?
- ***video*** 1st N/A 9 SEC. VETTE CARTEK 441
- Those with 10" Welds come in
- Picked up a new set of Goodyears.
- Having trouble launching!
- Why are my times so slow?!?!
- Roll Bars : NHRA requirement and pics please??
- looking for STOCK ls1 camaros,t/a's,GTO(houston area)
- Tubes with slicks?
- first 9 second N/A C5 by Cartek?
- Driver's seat position and it's effects on traction, 60ft. ET, etc.
- 12.72@122mph LOL
- launching
- Launching with SS3800 and Nittos?
- First time at the track!
- which tires hook better...
- Trapping 117; Should Be in 11's Right?
- Need Help Racing a 01 Cobra Soon
- What gears for 9's in an M6?
- New Times, How do they compare
- Alright Dudes. Where ya racin at this weekend?
- How do you think I did?
- fastest tci 3500 bolt on times
- Shake down passes w/Patriot heads
- Guys on ET streets
- MIR 4/3/2004 Pictures
- New best-231/237 "cam only"
- How to lower my ET with current setup?
- Ordered TA and subs!
- What's the record for Cam only/nitrous?
- No Torque Arm suspensions..
- Uti
- Anyone running 28X10-16 Hoosier slicks on stock wheels?
- Raced a Supercharged Marauder
- Uh Ohh!! Bone Stock Mach 1 Goes 13.1@107
- My car won't 60' worth a damn!
- Vig3200 to Yank 4200 track results
- New best, 12.1 at 107 mph w/ 1.5 60 foot!
- New times 11.34 @128.3 what do you think can I hit 10s
- 3 bests in a row and new record
- how much growth?
- Any of you guys go out to Bowling Green KY 4-3?
- New Best
- How to remove the AC?
- New best today!
- 141.51 Mph N/a Lt1
- first day out, first break of the year! lol!!!!
- Could you drag guys help me out....
- Race Results 4-3-04
- SS4000,new best today. no traction!!
- Good,Bad or So-So?
- Won the EFA shooutout!
- Pro Stars and lug nuts and studs, oh my ...
- 11.87@118.80 Cam only car
- new goal!!
- 4/3 Vette Doctor Pro 8 Shoot out Results
- ran my 653 horse stock bottom end car this weekend...
- New best last night!
- short belt w/ asp crank and alt pulley same?
- New best then rear let go!
- 03 Cobra runs 9.47@142 (video w/timeslip)
- What 1/4 times should be with 118MPH?
- new 1/4 mile times!!
- What would happen if I take my belt off?
- how to get 2step
- Bracket results
- New best at Hallsville tonight
- First time at the Track!!!
- TSP231/237 Stock Heads 118.17mph
- Think I can pull front tires with my setup?
- how hard are line-locks to install?
- Who owns the record for TOTALLY stock internal LT1
- What would I run?
- Ordered the M&H Musclecar Drag tires!
- Just lost my Track Virginity...
- You guys see this? NHRA iCard?
- octane @ track
- 18 Hours Until My First Time at the Strip...
- Don't drag race with the stock torque arm...
- Should I be worried about my time?
- Track gains from LSX?
- What psi for et streets?
- Which 6-8 point roll bar?
- Shift points for my cam.
- Slight new 1/8 mile best
- How much time cut when lowering 60ft`s
- new best tonight at orlando slipworld!
- 60 fts. arent up to par, whats wrong and how can I improve?
- ET Street radials VS ET Drag slicks articals in the new hot rod
- New Best in bone stock 2000 SS
- Tom The Roofer's 10.07 video on his new set-up
- New tires, F1GSD3's How many miles should,
- Norwalk track date - May 7th
- Slicks?
- Trap speeds?
- Pic of Tom the Roofer from Saturday!!!
- hood latch weight
- Track times on new setup
- gears with an A4??
- weight trans fer problem.
- MT ET Street Drag Radial Update
- Times + A Problem..
- how to figure da?
- 6.26@109 with a 1.38 60ft.
- New times what do you think?
- take off's
- 03 Mach-1
- A few bench racing questions...
- new car
- SRT-4 times??
- New best in 71 BB Camaro
- anyone bent a weld wheel?
- 3-27&28-04 Race Results
- BMR Torque arm question for you guys
- Pinion angle described...
- My TA 60's like a slug and I have no clue why...
- New Best!!
- patriot stg 2 5.7 heads-224r cam 1/4 times.
- Newbie help someone?
- Avg. times for cam only, 150 shot M6?
- New Track Times!! I Can Believe It
- Lightweight steering wheel - how much weight removed?
- Track results after the cam
- Ran a 11.6 at118mph--help me improve
- New 1/8 Times!
- Stock Eliminator Classes?
- Joe Overton's LT1 Goes 9.57 @ 140.10
- What suspension parts to buy?
- Is it possible?
- Wheel Hop Issues
- Need some launching help.
- Which front runner fits?
- HELP ME 60ft
- good and bad...
- Who is racing this weekend 3-27,28-04
- New track times for the Z
- My latest 1/8 trip
- Transbrake??
- Fast N/A cars
- Tell me what you guys/gals think.
- MPH is up, but wheelspin is a problem...
- New best 11.42 @ 119.75 383 LT1
- Listing of US dragways???
- How much harder to launch with aftermarket clutch?
- M6 Guys With Greater than 4.10 Gear Step Inside Please..
- happy and dissapointed at the same time
- cars with !back seat
- Is there a way to put....
- Fastest WRX w/Stock Turbo Record
- Need help
- New Message Board for GM Drag Racers
