View Full Version : Drag Racing Tech
  1. happy and dissapointed at the same time
  2. cars with !back seat
  3. Is there a way to put....
  4. Fastest WRX w/Stock Turbo Record
  5. Need help
  6. New Message Board for GM Drag Racers
  7. New best, but...
  8. Lightweight A arms?
  9. Air bag
  10. Full slick for 16 inch rim?
  11. Do LCA's help with NON-hop traction problems?
  12. Which lightweight brakes??
  13. most recent track results, 12.9
  14. Guys w/ true duals what kindah drive shaft loop?
  15. Input for summer plans...
  16. People with k-member in here.....
  17. help! NHRA Roll cage tech question........
  18. Just took a ride in a friends new 04 WRX STI....
  19. slow and curious
  20. Question for anybody that has removed their driverside airbag.
  21. what to expect with skinnys
  22. Anyone daily drive with ET streets?
  23. Are the OEM Torsen take outs holding up?
  24. help me
  25. Safety loop rules?
  26. Metal Valve Stems
  27. 9.70 @ 139.8
  28. Weighed my 2000 Trans Am after some redux
  29. How do I mount this 5 point harness to my Wolfe 6-point roll bar?
  30. Suspension questions....
  31. Check This Out!!!
  32. Cut a 1.675 60' & only went 12.50@110.33
  33. how to do a burnout ???
  34. Anyone know about how fast a turbo buick is?
  35. Et Street Longivity??????
  36. 4:10's and m6 in the 1/4
  37. alright guys, I need some weights
  38. WOOOHOOO Who's your DADDY?
  39. Dissappointed in Mustangs
  40. Trailer Help Needed
  41. 1st track time's for WS6 M6
  42. good burnout?
  43. Paging East Side
  44. What should I expect?
  45. went 11.87@112 today
  46. anyone use centerline telestar wheels
  47. take a look at this c5 we back halved...
  48. YES, let's set the record straight.
  49. What is the best E.T. for N/A M6 LS1 ?
  50. Fastest Stock Rear Susp Record (including thirdgens)
  51. need help with drag tire/wheel setup
  52. 10.88 @ 123mph w/myLittle 346
  53. vs viper
  54. Help with sixty!
  55. guys with a 2800 stall
  56. ET streets 16X26X10.5 what psi for 405rwhp/365.5rwtq?
  57. Who is driving Bogarts on the street???
  58. problems starting car after batt. moved?
  59. NMCA at NPR
  60. do relocation brackets really help your 60'
  61. silly question
  62. HAL settings
  63. My new Track times....
  64. Crossing traps @ about 6200 rpm, can I go with a smaller tire?
  65. hOW GOOD OR BAD ARE THESE TIMES?
  66. 473rwhp/446 ft.lbs, not too shabby for an LT1
  67. air pressure in nittos
  68. anybody going to No Problem NSCA
  69. Video from Pepsi All Chevy Show @ Moroso last weekend!!!
  70. How much time did you drop with full exhaust?
  71. NEW LOOK for the 2004 season
  72. 12.74@108 in a 02 conv
  73. When should you screw the rim.
  74. Nitto's slipping on stock rims
  75. Gimme some good tips for an A4 (I already did the search.)
  76. Bald Nitto's hook better??
  77. Quick Na Lt1
  78. Review of the powertrax locker rear
  79. 410 gears at far end 1/4 ????
  80. No Torque Arm Setup - with ET Streets
  81. Where the Heck is the fifth belt supposed to go?!?
  82. Anyone have pics of summit racing seat mounts?
  83. Tried some E.T streets, here's the result.
  84. TRex track results from sbso
  85. T56 vs TH400
  86. Lets talk Trap Speed.
  87. Texas Speed & Performance Heads/Cam Takes Win in Factory Stock!
  88. Way To Get Heat in Car if HVAC is Removed??
  89. Any pics of dash removed?
  90. Which harness to get with wolfe roll bar?
  91. Want to see all track/dyno numbers with the TR224 cam only set ups!
  92. Official Results - Spring Break Shootout 2004
  93. nitto's and the stock rear
  94. which cam gets low 1/4 numbers
  95. Best rear sway bar??
  96. finally got my 11 second pass at SBSO
  97. New best and wasn't even tryin too!!!
  98. Spring Break Shootout - No Rain!
  99. 10's all day, new bests.
  100. New 1/8 times today, first time on sticky tires...
  101. AP Engineering wins again
  102. Early Reports From Team APE @SBSO
  103. Kirkey Seats , 9" Installed..
  104. What k-member and a-arms did you go with?
  105. FMS F11 Track times
  106. Why are Mach 1's quick
  107. Drag Racing School
  108. New Stock Internal Record !
  109. Suspension mods are a must!!
  110. New best before rains came
  111. i heard theres a new bolt on record today
  112. Clicked off my first 12
  113. 60' is slower going from 3.23 to 4.10?
  114. is it possible?
  115. Good Luck To Everyone Racing At The SBSO!!
  116. quarter times dissapointing for 422rwhp
  117. Will bilstiens kill my 1/4mi time?
  118. 2800 stall
  119. Strange Silver shocks
  120. stock 02 Z28 1/8 GOOD OR BAD?
  121. What happend to the old ET database?
  122. Just installed and MSD Shift light, FYI
  123. Someone give me a quick rundown on a nitto burnout??
  124. Beat my old best, but trap speed kinda low...
  125. Who holds the ET record for ........
  126. Props to Jay and Amber at Billingsley
  127. MT ET Street radials, 325's when available?
  128. Heating up ET streets?
  129. How many of you did a lightweight battery?
  130. Need help on 1/8th conversion...
  131. big improvement from 275 to 315 nitto drags?
  132. New best, but i'm not happy.
  133. competition....... inside>>>>
  134. Going to the track and...
  135. First time slip, what do you think?
  136. Pics of installed rollcages?
  137. N/A head/cam guys with 2.73s, what's your best times and what converter do you have?
  138. 230/236 107lsa cam results (track and dyno)!!!
  139. Building track car....what class/chassis?
  140. Would a Catback Make much Difference?
  141. Why do hoosiers have 1" more tread on ground for same size than M/T?
  142. Fastest LS6 Cam Trap?
  143. Colonels car- Does it exist, or is it an urban legend?
  144. Anti roll bar, but anyone try 25mm rear swaybar?
  145. Window Net and Safety Harness???
  146. What do you think I will run
  147. 98 Z28
  148. Help setting up suspension, QA1 Comp R shocks
  149. Bone stock 2000 SS times
  150. Suspension ruminations and request for comments
  151. Please help setup pinion angle on T/A!!!
  152. Help me hook up
  153. Need help choosing the right size slick...
  154. New best
  155. Removing extra sheetmetal
  156. New 1/4 best, questions inside
  157. 3-6-04 Bracket Racing Results.
  158. Whats up with my 60 fts?
  159. Crossing traps at 5700 rpm, is that right?
  160. New Track Results After H/C
  161. Went to the track today, let me know what yall think
  162. New Best with G5x2
  163. Pleasehelp? Sugestions? What Do U Think?
  164. How do you launch.
  165. New Best 1/8 LQ9 And Rev limiter Question
  166. Hal users, what settings are you running at the strip?
  167. 1/8th mile times
  168. Got some baseline times on my car tonight
  169. PP heads & TSP 231/237 track results
  170. Track times on new setup
  171. Oh no, rubber is caked all over the inner and out fenders, whats the trick?
  172. Vette ownersM6/half tank for traction?
  173. How many of you completely remove the front sway bar at the track?
  174. Anyone brace stock driver seat so it won't break on a hard launch?
  175. Pics of centerline Warriors??
  176. Went to the track and was not impressed.
  177. need some burnout advice!
  178. Wolfe Travel Liliters
  179. Fab 9 rear end?
  180. Could a track give wrong ET's?
  181. How Do I determine what Tire Height I need?
  182. What Is The Fastest Cam Only C5
  183. 1st 11sec pass in my FRC C5
  184. 6spd Guys with 3.73's come in!
  185. Anybody done lightweight carpet themselves(Cheap Stuff)?
  186. What 1/4mile E.T. to expect?
  187. Humidity Effect on 1/4 mile ET's?
  188. What times(ET) will win F/S at SBSO?
  189. Narrowed Rear Rim BS Question,
  190. need help, bad 60'
  191. Best 60' on 17"x9" rims, 40-50 series radial?
  192. Roll Bar Padding
  193. Drag Slicks How to's:
  194. Blown Moser @ Thunder, revisited, pics.
  195. Thanks to Jay Billingsly!
  196. Life of Hal Shocks
  197. Preloading rear safer for 10-bolt? Pro's and con's?
  198. Can you see my video against 2003 Cobra?
  199. New best with 4.30 gears
  200. Mid 11's for under 3k?
  201. What's it going to take to lift the front wheels?
  202. FMS LT1 Results
  203. Metrics in front + ET drags in back = Squirly?
  204. stock internal, stock converter new best (12.24@113.5)
  205. best e.t. for stock 98 up SS?
  206. Baselined 01 WS6 109+ mph stock odd ET.
  207. 9.00-9.99 upgrades (I think I have it all)
  208. Billingsley Racing Contingency Posted
  209. This Weeks Race Results
  210. www.outlawpontiacdragseries.com
  211. Cool bumper sticker..
  212. New runs - opinions needed
  213. Drags or E.T. streets
  214. will the stock driveshaft hold up to a 1.4x
  215. What gear do I need? (10.5 ET)
  216. Torco Race Fuels?
  217. At what RPM should I shift at for best e.t. with my mods?
  218. few ihra rule questions
  219. New times this weekend.
  220. Went to track for the 1st time w/new setup, but something isnt right. Please help!
  221. Where to buy Race gas???
  222. First time out with Street Car
  223. Something very weird haapened?
  224. BFG DRs can i hook or go back to ET Drags?
  225. What mods are needed to reach 11 sec?
  226. Anyone made their rims skinnier?
  227. First time ever racing my new car
  228. Finally went back to the track had a blast
  229. removing A/C ??
  230. Connecting a light weight battery?
  231. Installing my new tubular k member a arm and coilovers!
  232. sportsman pro's for the track
  233. Which Drag Shocks to Get Better 60's
  234. What wheels with Moser 9"
  235. What et reduction will I see?
  236. Running a 12 sec index with a 11 sec car...
  237. help returning GI
  238. Race weight.
  239. what are the main weight reducers
  240. Large Cube Iron Blocks post your times..
  241. eaton posi and 600+ hp?
  242. What Shocks N Springs
  243. 12.8 @ 115mph. TR224 114cam nittos headers and bolt ons. tell me how bad i was doing.
  244. Great Atco Video
  245. Still having trouble launching a M6 on street tires!
  246. Paging six speed 12 bolt guys
  247. Best drag racing suspension?
  248. Springs seem to be leaning backwards, after adj LCA??
  249. NHRA and doors
  250. vid of my passes...
