View Full Version : Drag Racing Tech
- Rear Shocks, Afco vs Strange
- Drag Racing The 10-Bolt
- 1st time out w/ ws6
- 11's at 120+ n/a stock short block...whats it take?
- T-rex plus TnT150
- 1st time @ 1/4 track with new set up
- Sniff... Sniff... What's that I smell???
- How many of you drive on the street with a spool?
- Tranny blanket w/ 4L60E
- Gear choice H/C A4 27x10.5?
- Help Decipher Disappointing TSP 231/237 Track Results
- Kind of a wasted day at the track
- Please Help - Test & Tuning
- Anyone take the TCS off?
- AC??? Help.
- New Personal Best and broken parts....
- Tire size difference and effect on E.T. question!!!!
- lightning svt vs. t/a ls1
- North vs South slideshow
- Trap Speeds
- Two wheel up pics
- HARDCORE Drag Racers within!!!!
- First Run at Track, Help Analyse
- Car ran pretty good for summertime
- Track Questions
- D vs. OD
- Found the limits of the stock TQ arm!
- Almost got creamed by a racecar tonight
- New best for me after header install
- Where to get Kirkey seats??
- Convertible H/C guys - what are your mods and 1/4 miles times?
- Trans is holding back until second gear on slicks . . .
- drag racing suspension set up
- What size slick to I need?
- Track Rental was fun fun fun!!!!
- SFI flexplate needed for 10's or 9's?
- Would you support a bolt on only heads up class at the thunder shootout?
- How much does heat hurt track times?
- Who has a SFI approved TH400 scattershield
- Congrats Jenibella !!!
- Can you remove power steering yet retain the stock rack without damaging it?
- th350 burnout box ?'s
- Tragic day at Gateway Dragstrip
- First time to the 1/4 mile track
- Harness, which one? RCI or R.J.S. ?
- Do you toss car into nuetral after the traps?
- Is a 12.47 1/4 time possible w/ bone stock M6 C5 hardtop?
- Anyone running TSP 228R only?
- why am I beating these people?
- I need some help!
- R.I.P. Darrell Russell
- One more drag tire size question please.
- Looking to pick up a tenth and some MPH..
- Help me decide on lightweight brakes (street/strip)
- The O.F. rides again ...
- What kid of 60' should I see
- What to get? Need tranny
- moving to new suspension...question
- narrowed rear and the old ARE car...
- Help with front and rear bumper reinforcement removal
- New 1/8th mile time from IA
- 1st time @ track with new set up
- Madman motor plate questions...
- Hate to ask this question, but got to!
- Track Times
- Looking for the link...
- New best and launch technique
- First shakedown runs with new stroker combo in street trim
- Anyone drive on the street with no powersteering? How to remove?
- ABS questions.
- Fbody heads up racing
- what should i run
- Dynabatt/Hawker hold down?
- Well G5X3 results inside
- First track times
- NataSS is in a desperate situation please help
- What 60 ft on Nitto DR
- ET Database does not appear to be taking updates
- Anyone Racing this weekend?!
- Bench Racing question
- Who has the fastest cam only car record ?
- I hate this, only shaved .1 with the TCI3500
- TR224 cam only and NX 100 shot. Finally joined the 11sec club! (on nittos that is)
- Possible LS1tech.com Race III @ Bowling Green??
- Those running low 11s/high 10s w/stock LS1 heads/stock bottom end, post setup please.
- Best lightweight seat for the money?
- Another Texas Mile July 31-Aug 1
- The Colonels Car is Real
- So you wanna run heads-up, eh? ---->>
- Optimum shift points for an A4?
- Need underhood pics of pin location
- US41 on the 26th...
- 11.50's or better - what DOT tires do you run?
- Rear double adj. drag shock help please.
- Anyone that has been to Montgomery AL.
- Fastest stock internal MPH? w/power adder
- Insurance on Track Cars
- What else?
- What will i Run
- Pure Stock Class
- New NHRA Pure Street rules ..11.50 (even verts)
- Post times along with DA, Elevation & mods.
- Is the 10 pt t-top rule trying to make a comeback?
- For those running fast enough-check out NHRA Pure Stock rules!
- Rollbar/cage questions.
- quick questions
- GLD how's the track been this year?
- If you had to by a 26" slick to fit on a 10"wide X 15" rim what would you go with?
- Why can't I get my ET Street to hook up?
- Angies Car vs Trevor @ N v S
- Race Report for 6-19-04
- H/C people whats your car run in full street trim....??
- Thanks Joe O! new N/A pb for MPH.. 128.65 mph
- The new and improved N/A M6 record.
- 10.78@128.27 (1.56 60') -- cam only (TReX)/6-speed at N vs S Shootout
- $10 driveshaft loop
- Texas Speed & Performance Solid-Roller H/C Goes 10.20 @ 131!
- finally got some 10s with the STOCK heads.
- 231/237 track time W/O converter.
- PSJ, How'd you do?
- A Few Details About Our Factory Stock Entry
- Tire growth...
- The nations fastest NA LT1 1/4
- New Bests For Me At North Vs. South and Last Minute Award
- Thanks to Tom for setting up the race..
- NEW 346ci ALL MOTOR RECORD! 10.26 @ 132 MPH
- I won Factory Stock @ LS1tech N vs S race :)
- engine temp question
- K-member,upper and lower control arms and skinny's up front= How much off your time?
- Dipped into the 11s today.
- when did you decide not to street drive the drag car anymore, i have had enough.
- What would cause a car to do this...
- MIR: June 19, 2004 Shakedown runs - (10.2 - 10.4) 2300' DA
- Rec'd my Lakewood DS Loop
- Bone stock LS1 RX7 track results
- first trip ever to track...tell me what you think please!!
- ET differences between 224 cam and G5x style cam
- K&N Supernationals @ E-Town
- Need pics of an F-body floor, without carpet...
- Drag raced my newest vehicle!
- Tire Question (Need answer quick)
- Saw M/T 295-65-15 Drag Radials on John Cunningham's Nova
- Lightweight T Tops, who's in?
- What hooks best, M&H, Hoosier, BFG, or MT?
- Jim Filipowski's 4th gen runs 8.31 @ 175 on drag radials
- First time using Hals at track.
- Best ABS delete option?
- Anyone making a 10point cage to FIT?
- what to do?...Gear choice for 385
- Driveshaft Loop for True Duals
- M/T DR 275/60/15 Vs. ET Drag 26x10x15 size for size?
- need to gain a tenth
- Put your screen name in your back window at N vs. S!
- my new best times tonight cam only almost 10's
- PSJ,can you enter my new 12 sec. pass?
- Improved a little bit more
- 11.08@125.47, 1.63 60' - TReX cam/stock heads
- Going to Lebannon Valley tonight
- Any ET/MPH guesses fo LS1 RX7
- Good list of stuff to bring to the track.
- Question about wiring a "race" car.....
- S+W 6 point pics anybody got them?
- Custom dash setups... I gotz q's
- What do you think I will run?
- Quick easy question
- New race set-up
- Slomaro is back
- results with my grand-am cup cam
- To cam or not to cam
- This weeks(6-12-04) race report NEW BEST!
- cheap trick for the heat
- How to launch an A4 with Nitto DR's?
- Saturday Nights at Rockingham
- Need some info??
- Good weekend of racing, netted 6's in the 1/8th
- mickey thompson or nitto dot tire ???????
- Anyone with Midwest 2800 stalls get in here!
- does this sound right?
- Twisted frame? can it be fixed?
- Need Help Now!!!!!
- Track times from 6/11
- Gotta love drag racing :-)
- FMS 346 SR- Shake Down Runs Complete
- Will SFC's help my 1/4 time?
- Roll bar question........??
- FASTEST LS1/LS6 (No C5R, AFR, or Iron block)??
- 231/237 PP"ls6" track times
- TEA 1.5 guys.. whatcha running???
- BMR vs PA k member: exact weights?
- So, lets get this straight. Whats better for a 1/4? AT or MT?
- Anyone have pics of Speed Inc.'s lightweight carpet installed?
- Will Front Skinnies Help with ET's?
- tubes or not with ET drags
- New best and some observations
- Lightest adj. torque arm?
- Rollbar Modification
- are et streets for me
- New Best!
- Finally hit 11s..woohoo
- if you crash on the strip...
- BFG G-force TA drag radial in the 265/40/18 size anyone runnung?
- What should it run???
- First time at the track, Best time i've had in a long time!
- First pass ever
- Guys running 10's, post your RWHP numbers and raceweight
- Will tracks allow me to run a 1350 carbon fiber driveshaft w/o a loop?
- A/C Removal?
- Looking for pics of swing out door bars
- 440ci with a 600 shot @3900lbs = ? ET
- Anyone running a gear higher than a 4.10 in an auto.?
- First time at the strip tomorrow!
- Shitty times for my first visit to the track.
- 10's Galore
- anyone ever weighed an aluminum seat?
- What the Hell is Madman Up To Now??
- Times on road surface
- Some Q's about Harness with 8 pt rollbar
- 1/4 mile strip in western WA?
- New times.
- Some 8sec videos
- ??Where can I get T-handle pins for my swingouts??
- 245-45-16 to 275-50-15 drag radials...
- mph improvement?
- Can the upper panhard be removed, if so, how many of you have removed it?
- Anyone have pics of the brace needed for race seats?
- Can the powersteering cooler be removed and if so, what are the weight savings?
- Lightweight carpet and seats.
- Tire Pressure for BFG DR's ?
- S&W 8 Point Rollbar
- My stock ls1 times at Milan dragway in Mich.
- Finally in the 12's on street tires...
- Our 1/4 results from NFME in Indy
- New PB on street tires
- Summit Part number for Convo Pro skinnies?
- S & W racecars cages quality & fit?
- New best, but still not happy.
- Race Track says i need a roll bar. which one.
- help! my track times suck
- "Stick-on" dial in numbers............
- horrible ls1 times at track last nite
- 8000foot DA, does anyone
- help!! my LS1 running 14's all night!!
- Does this sound right?
- Barometer?
- My two 11.7 runs/ I can see where i went wrong
- Short time
- Not Happy! Any Ideas?
- Track day New Bests! (Video Inside)
- x-pipe to 3" dual bullets= how much HP&TQ?
