View Full Version : Drag Racing Tech
  1. Fastest/quickest on 10 bolt rear?
  2. What is the record for STOCK shortblock?
  3. Multi-entry race
  4. Anyone fit 29.5 M/T's ?(inside)
  5. How to get home
  6. 95 lt1 A4 track et's
  7. Is something wrong? 13.803@101.92
  8. Racing Seat ?
  9. Fast A4's with 4:10 Gears
  10. Bolt-on MN6s running low 12s or 11s
  11. Can you guys help with the 60' blues?
  12. Front Bumber Support Removal
  13. Billingsley's e-mail address?
  14. Bolt on times with stock converter?
  15. Aerospace Brakes (where to buy?)
  16. Setting up Hal's
  17. New best!!!!
  18. Congrats To Tom The Roofer -Winner NMCA EFI
  19. ARE's SIlver-Z Wins OSCA True Street w/ consistant 8.80's!!
  20. Znines is at PRO Cordova, made it through first round!!!
  21. Fellow Racers, What to stall the PT4400 at?
  22. 13.6 @ 103.51 . . . what next?
  23. woo hooo. 10.81...video inside
  24. Autometer shiftlight users .......inside please! HELP
  25. TNT is tha sh!t
  26. Anybody removed the drivers air bag?
  27. Fun day racing but lost in the Semifinals! VIDEO w/i
  28. New best with 200 shot
  29. 12's at Last
  30. A disappointing 13.4's (Need help!)
  31. Sorry... didn't know where to post... who carries helmets?
  32. This place is boring, boring, boring!!!!
  33. Beat a Mercedes C32 AMG 349 stock hp
  34. What RPM do I dump at??
  35. New times with stock 2002 SS M6 Convertible
  36. My traction sucks.......
  37. What times should I expect?
  38. My '03 Cobra Track Results
  39. The beast is breathing agian!!!
  40. first race on new engine...
  41. What PSI
  42. Who all has the Madman manual rack?
  43. Noz
  44. Help, backseat removal
  45. Anyone have pics of their trimmed rear quarters?
  46. About my Fast Toys Ram Air
  47. ET/MPH difference between these two motors??
  48. Anyone running 4.30's w/ 26" tires
  49. Need to eliminate lean at launch! (pic)
  50. Bolt-on m6's at Thunder Shootout?
  51. Rollcage with removeable bar?
  52. An 11s Stock A4 Trans Am!!!!!!!!
  53. what should i be able to run?
  54. M6 SI Thunder Shootout what will it take?
  55. Foot Brake and Trans Brake = same 60' =(
  56. Balance Drag Tires?
  57. writeups on removal of Front and Rear bumper supports?
  58. should i stick with a 16 in rim or go to a 15??Pros and cons
  59. Impressive new Cobra
  60. How much will these mods help me? Take a guess....
  61. How much will I gain from these mods...Take a guess
  62. Who is Racing this weekend?
  63. How to delete ABS?
  64. Need to find the weight reduction list!
  65. What kind of times should i be turning with these mods
  66. What lugnuts with Weld Pro Stars, S/S or SST?
  67. Lightweight Heater?
  68. most gain from the next mod???
  69. Is this a respectable time?
  70. never raced wut do i do
  71. Didnt meet my goal (8's in the 1000' OR 10's in the 1/4)
  72. Why is my 2000 T/A so slow?????????????
  73. Drag raced1/8 mile against Cobra
  74. Traction
  75. Looks like we have a new T-56 record!!
  76. Drag Radial Help
  77. List your 1/8 mile times with a Vig 3600 #7 NA or Nitrous
  78. Who's Racing this weekend.....
  79. i want prostars and et drags...help me with b/s and sizes
  80. battery reloc pics?
  81. New bests with a couple changes
  82. NHRA Rules On Valve Stems
  83. Car is down to 2400 pounds
  84. wat will my car run wit new mod?
  85. Remove stock cooler with TH400 installed?
  86. How do you remove automatic shifter and console?
  87. Who drives around permanently on "drag wheels"?
  88. what size stall with g5x2 cam????
  89. Man there's a lot of crap under the dash!
  90. Please post pics of your drag wheels!!!!!
  91. 14.2 @ 3,440 feet above sea, is that good?
  92. How will 28" tires affect my dyno numbers?
  93. 452 RWHP From a Heads & Cam LT1
  94. Bog off the line
  95. Pics of my !ABS and !PS
  96. Guys With Bogarts - In Here Please!
  97. What can you tell me anout the Kenny Brown Cage?
  98. TCS and ABS Delete???
  99. Which tire size to upgrade from 26x11.5x16 ET streets?
  100. which one?
  101. Who Would Have Thought
  102. New Best Nitrous ET from a stock longblock LT1
  103. Looking for website with drag etiquette info...
  104. Anyone made any braided brake line, or custom brake line?
  105. Is my et slow for my mods?(9.019@81.142mph) 2.107 60'
  106. Cam only guys,how are you cars running in the heat?
  107. How much does my car weigh stock and with stuff removed?
  108. why does my T/A weigh so much?
  109. Can the hawker battery be jumped??
  110. Help, I'm inept at drag racing.
  111. Bleeding brakes question.....
  112. What are the best times for A4s w/ bolt ons and DRs
  113. DS Loop with X-pipe? /Cage Q
  114. How have you guys routed the hose to your airbag?
  115. how much lighter is a 6-pt Chromemoly cage vs Mild steel?
  116. What's the Record??
  117. 97z28
  118. Quickest STOCK INTERNALS List - 11.951 bump!
  119. Calling out ALL Bolt-on Stock Internal Cars
  120. Disable the converter lock-up
  121. Radial fronts and ET rears
  122. !PS, Loop the lines or just plug the holes?
  123. At the track mods....
  124. Post your best ET after Longtubes Installed ..
  125. Where did you get your T56 built for Drag Racing?
  126. Ohhh, the T56 saga gets better yet
  127. what will this set-up run
  128. A4+ET Streets
  129. Okay, another quick question.
  130. Got a quick question.
  131. So you have a converter, how do you......
  132. MPH QUES?
  133. 12 bolt people, I have a few Qs....
  134. WHERE TO GET LINE LOCK?
  135. DARK SIDE........
  136. NHRA rules for rear-mounted battery?
  137. First 1/8 Times with 383 stroker!
  138. New best today!
  139. Fun with the solid roller motor...
  140. Will I be able to hook these tires at all?
  141. Another T56 Down!!!
  142. Help!! Timing Question at the Track
  143. 2002 ZO6
  144. 1st place @ Clash of the Titans
  145. I need a PHB dimension.....
  146. Anyone at Thunder Valley in Noble Oklahoma last nite?
  147. Anyone going to the CamaroZ28.com Nationals at Stanton, MI?
  148. WTF?? went to track last night HELP!!! DRAG EXPERTS get in!!
  149. Dyno #'s
  150. what clutch are the fast cars using?
  151. what happens if i take out a/c and heater core?
  152. What to get?
  153. First time down the quarter!
  154. what happened to lightweight T-Tops?
  155. I'm going racing this weekend.... anybody else???
  156. More bad times
  157. New G-Tech pro comp
  158. Questions on front skinny tire's rolling resistance & weight
  159. The Turbo Fords are FAST...
  160. In BAD need of a line lock!
  161. Hawker/Odessy lightweight battery?
  162. Question about mini-tubbing an f-body
  163. New times!
  164. Harlan Doesn't Exist
  165. ARE C5 Video Archives 2001,'9.25@153' Hyd Cam/LS1 Head/Block
  166. who makes/sells ... (rear bar, for 5pt harness)
  167. Can you help me set rules/classes for a SW Fbody Shootout?
  168. Thunder Shootout ... Final Rules are up!!!!!
  169. Madman is a TV Star!
  170. Need some advice for 60' on street tires...
  171. If you ran the Super Chevy at Bristol, post some times!!!!!
  172. M6 racers help please...
  173. If I didn't have bad luck this year I wouldn't have any!
  174. Indiana Drag Tracks
  175. Roll Cages in street cars?
  176. BEWARE of NMCA Racing!!!!
  177. Ok.... who wins this race? (after cam install)
  178. TRACK RESULTS!
  179. Stock Style Suspension
  180. HELP! car is getting slower
  181. First time on the strip!!!!!!
  182. Show me your guages , and give some ideas
  183. which is better Turbo 350 or 400 ? both with Tbrakes
  184. New best 7.69 @ 179!!!!!
  185. M6'ers Inside -------->
  186. Anyone know the where to find info on weather conditions DA?
  187. How should I get off the line in my automatic?
  188. Who's your Daddy?
  189. What could cause my ETs to be THIS bad?
  190. Nothin like a crappy track
  191. DOH! Hurt the motor today
  192. M6 breaks A4 'cam only' record-10.93@125
  193. Faster then 12 sec w/out roll cage
  194. Need pinion angle advise
  195. Wolf Race Craft New Web Site
  196. ET: 27sec @ 32mph
  197. how do you remove the bumper supports?
  198. Where are all the fast cars at????
  199. Will SLP Eibach springs w/ a .75" rear drop hurt 60ft times?
  200. Questions about a time on the 1/4 ET list(#5).....
  201. Congrats to ScottWS6 - 10.30@133.85mph at GLD!
  202. Will my 10-bolt hold??
  203. NEW BEST
  204. Cam/headers/bolton guys in here
  205. Crossing the line @ 5500, 6000 & 6500rpm, et/mph difference?
  206. ~3600lb Race Weight Cars... plz post ur ET@MPH/60ft & Dyno#s
  207. Humidity!
  208. New best for low mod `02
  209. Jegs Cage yea or nay....
  210. 27" or 26"
  211. "Speed Shops" in NY/NJ/CT
  212. Pro Mod drag cars
  213. Installing cage ... need help with 5-point harness install
  214. Nice gain at track last night with MTI tuning!
  215. Back to the track FINALLY !
  216. Ran the car tonight, time for clutch and tires.
  217. 28's with 26" skinnies or 28" skinnies??
  218. How in gods name do you wrap the "wrap around" 5pt?
  219. Big Dog race
  220. ET Streets are here!
  221. Bracket racing at no problem
  222. Help with shift points in edit with an a-4 and 4.10 gears.
  223. Any pics of Formulas with 29" tires out back?
  224. Do I need longer wheel studs back and front?
  225. Best Rear Springs for Drag Racing...?
  226. Attn.- HELP with video...
  227. How to use VHT?
  228. Help!! Can't Race until I get this fixed - Updated June 18th
  229. ARE's New Pit Bike!!
  230. Anyone make a plain old 90/10 front shock for our cars??
  231. Chalk Up Another Win for LS1's at a Heads up Race!! 8.73!
  232. ASA + gutted cats = new best
  233. New Best!! Two of em actually!
  234. 10.42 132.85mph at LID
  235. East Side Goes 8's!!!!
  236. Battery relocation to the trunk
  237. If this doesn't get me low 11s, I don't know what will......
  238. 2003 Thunder Shootout Rules posted
  239. TOO FUNNY: You thought your car was a stripper!!!
  240. Afco Double Adjustables question
  241. 5 point cage NHRA legal?
  242. Optima Yellow Top weight vs. Odyssey 925 weight: test inside
  243. 1970 Chevelle
  244. Whos running tubes in their 28" ET Drags?
  245. Did the search..no luck..are 17" ET Streets being made
  246. Anyone have any results with the Strange Drag shocks?
  247. Rear Hals setting for street and strip?
  248. ET Streets tubes or no tubes?
  249. To those who have ground their calipers to fit a 15x10 rim:
  250. Light weight brakes and aluminum driveshaft
