- Needing some susp. advice..
- 1/4 mile estimate
- when should i shift?
- Dropping weight off 2000 Formula while keeping the AC
- First time out to the track tonight with my LT1
- The challenges of an LSX DR headed build... Help?
- looking for a few more tenths...
- Ford 9 Inch Swap In '95 Z28 Questions
- New G-Force Gear ... Helmet & Jacket
- Trimming lip for VFN pin on
- correct method and order for suspension adjustment?
- setting ride height up front
- first time with a trans brake ?
- Best way to launch?
- Battery relocate, now will not keep memory.
- LSX ProCharger 388 by VA Speed.. on dyno..
- 2011 Bickel Pro Stock Camaro
- 3200 lbs race weight?
- weight reduction ????
- What spool do I buy for stock 10 bolt
- bought drag wheels. questions about my setup
- afco da front base setting?
- F body weight
- is there a best place to mount trans temp sender
- Some questions on hurst 1/4 stick
- what has to be done for 10 inch wheel ? and life of ET front on the street?
- What air pressure works best in your ET Drag stiff wall slicks
- Is there any way to use stock front springs with afco shocks?
- bais M/T et fronts air pressure ?
- What can i expect loosing 125 lbs
- Racing seat? (curious about jegs or summit poly seats)
- Hoosier or MT Drag tyres?? 255/50-16
- Help with distribution block wiring.
- carnage pics
- First time at the Track.
- Anyone running 1" narrowed A'arms w/stock rack? Tuck pics??
- Racers: ~114mph trap speed but only 12.54?
- SYA Bars for Racecraft Inc.'s "Race style" K-member
- Please help me
- M6 to TH400 yes/no? help me out
- Front suspension help. Front of car not "returning"
- I’m looking for faults in my build. Help!!
- what do you guys torque your drag wheels to?
- Wheel Offset for Narrowed rear end guys???
- Is it too loud?
- Best converter for a NA LT1 W/4L60?
- WTB TCI Flexplate #399753 TH400
- What does this mean
- kirkey seat?
- Roll Cage Question
- Dashboard weight mod
- MSD 8733 2-step problem
- Anybody ever measure/calculate the center of gravity for an fbod?
- Opinions on lightweight battery?
- Help I am going tot the track tomorrow !
- best speed to roll race from?
- spacer under rotors on strange brakes, okay ?
- Tire and suspension
- can M6 guys pull the wheels?
- Do drag bags help?
- 300 # springs up front help setting compression
- Fuel Setups
- how do these door bars look?
- RPM's to take off in the 1/4 mile...
- anyone have pics of there a4 crossmember modified for th350
- DASHBOARD: Whats REALLY back behind there?
- DR Fitment
- Help choosing sway bar
- Any tricks to keep suspension from binding
- Where can I find these switches?
- 69 camaro cold air kit
- So, how badly will 500 street miles on brand new MT DR's
- Is there any gain from running open headers at the track only
- hoosier qtp or hoosier radial
- Where to get a good fire extinguisher?
- O.K. Dipstick For TH400
- Weighed my car at a CAT station tonight...
- NMCA race this weekend
- Solid roller?
- Drag Racing with Koni Strano setup
- which strange rear shocks for stock springs
- Gauges Sweep and trip resets everytime I start the car!
- Flexplate For TH400
- how to use a linelock?
- kill switch not killing the car.
- Torque converter reasoning question
- What's Your Set-Up For Racing?
- removing(clearancing)hood latch
- Questions On Screwing Slicks
- Quest for MPH !! (caution, ricer math inside) !!!
- Track time! Any tips on launching with SS3600??
- Raising tq arm mounting point higher up in chassis ok in lowered car ?
- 26" or 28" ET Drag slicks ?
- UPDATE PAGE 2...I gave in to the weight reduction itch. Weights inside
- Chassis Setup without four-wheel scales?
- Battery Cut Off
- 60ft times on 315-35-17 drag radial?
- anybody make a trans am steering wheel air bag cover(for air bag removal)
- Yellow box under console
- need help choosing between two slick sizes for the strip
- Advise needed - A bigger stall or a bigger shot??
- 97 TA 6" to 8" hood?
- Which Tire
- Advice on grinding calipers for weld prostars?
- What angles for engine/tranny and rear end for street/strip?
- Car keeps shifting way over to the right?
- lt1 rods, pistons ?
- Motor Dimensions
- How to hard launch a 2001 camaro z28
- Th400 with 4.11 gears?
- help help strange brake to moser axle bearing spacers
- 60ft w/95 posi with 3.73
- PICTURE REQUEST- 4th gen Modified cowl panels
- anybody run et drag stiff walls without tubes?
- ls1 throttle cable non cruise control
- Lowering springs?
- Mike Harris of B body Perfromnace in Dayton OH
- Lets see those F-body seat harnesses
- Question about expansion tanks???
- 17" Track tires for M6 car
- why stiff wall slicks?
- Rear brake line fittings... bubble flare?
- A few weight reduction questions.
- Street/Drag car build
- First few passes on new motor ?'s
- NHRA Hose requirement
- 347 build (lots of pics)
- Don't know if this is where this belongs
- beck intake throttle bracket
- Aerospace Dual Caliper rear Brake sale
- Who's runnin hoosier or mickey 275/60/15 or similar with a manual trans
- Powershift with a 2 step ??
- New LSX MOZEZ Nitrous Combo Pictures!
- What spacers is everyone running on billit specalties fronts w/ stock brakes ?
- setting pinion angle with jegs non adjustable TA
- Torque Converters??
- Help me pick gears for nitrous
- painful wheel hop
- Car not 60'ing like it used to... Help!
- Running mid 11's in stock motor LS1 98-02 Firebird???
- Aerospace dual caliper rear brake sale
- help me choose a tire.
- 27 and 28" front tires
- Recomendations on QA1 setting
- Fitment questions MT Radials 315/50
- Need tips and pics of pin on hood install
- Why is my th400 running so hot? UPDATE 6-27-11 Page 5
- nhra wheel stud rules
- Anyone experienced with Kestrel 4250?
- summit's magnum look a likes.
- Low Voltage need help
- slick with a nail in it?
- is this a good Proportioning Valve for abs delete?
- Trans blanket cause trans to run hot? Aluminum flexplate worth it?
- Any recommendation for front end alignment with skinnies?
- NHRA license?
- Lower front end better for racing?
- What should i be running? haha
- Double adjustable shock help
- quick question
- Good Idea??
- VFN fiberglass front end
- remove rear sway bar too?
- Removed Hvac system now 1 question??
- Removing Heater Core
- Not stock seat belts = Airbag light problem?
- Should I try Bias M/T streets instead of radials on the street ?
- whats everyone using for front runners on the street?
- How to alt & powersteering with elec pump?
- Help me find an 11 second pass?
- ignition box bypass harness?
- Quickest w/stock converter and bolt-ons?
- Those running 275 Hoosier Drag Radials
- Proper/Best way to set up PCV system ?
- tuning
- wheel stud length to be nhra legal?
- quick question
- advice/help removing AC
- Oil Cooler and Temp Gauge Install
- May 7 & 8
- MSD 2 Step Wiring question.
- 3000lbs was heavy, had to lose more weight
- SFI JW Bellhousing fitment?
- drag brakes on stock 10 bolt possible?
- Fuel lines for Vic E??
- Wiring 4 post kill switch
- bought a stripped out camaro and want to run mid 5's in the 1/8th
- Rear drag sway bar setup
- couple of pics of Agent Orange with the rear axle narrowed 4.5 a side
- Power Steering Questions
- Metal battery relocation boxes - hold down?
- Just got back from the scales, this thing is a PIG
- Whats the most RWHP cam only LS1 w/ heads please post up and track times
- What PSI to start with on Hoosier DRS?
- Roll cage Halo orientation?
- Basic physics for those who don't like reading
- QTP Hoosiers or ET Drags??
- 6 speed drag racing tips
- Burkhart Chassis 25.5 pics
- Best of both worlds?
- Unable to launch 6 speed....suggestions!?
- 25.x rollcage pics needed.
- using lead substitute in your gas?
- Anyone driving on the street with a manual rack?
- trouble with some traction at strip.
- Are Cut-Outs worth it ?? / Where to install it ?
- Carb/emission ?
- trailer size?
- help with my launch please
- 11.03@124.93 with 404rwhp and Level 2 Monster
- Gutting the dash? pics anyone
- Installing 4.10's and triple nickels
- Which 2 step? MSD 8733 vs LNC-002/003?
- front suspension height side to side????
- Needing Cage and Chassis Work
- firebird headlight delete??
- Air bag modual
- What else to do during carpet swap ?
- Disappointing numbers at track
- QA1 R-series shock question
- cam too much? ?
- What do you guys recomend for SFI belts?
- Which torque arm is best buy for the money
- bumper cover loose with support out?
- HVAC Delete with Heat.
- cruise control delete?
- Problems, Are You guys using a different batt. for rear relocation UPDATE!!
- How can I maximize my set up, bigger stall converter or trans break?
- 28" front tires rubbing the fender?
- 9" aluminum or cast iron case ?
- 60fts suck, analyze my launch please
- After market heater core?
- V6 Shell for 25.3 build?
- 4l60e to glide same flex plate ??
- which 2 step do you guys us?
- Drag Race RPMs
- Anyone have a NHRA tech book? How thick does a fuel cell have to be?
- Car keeps getting slower...What should it run?
- Can I run no alternator in my LS1 drag car?
- Wire cleanup in progress, got a question or two.
- Is this gonna be OK? alternator battery relo question
- those who went A4/A3 to Power glide
- Track today...what adjustments should I make?
- whats the weight of 4th gen door glass
- post up your light weight f-body
- Moroso DS2 on bogarts on DA STREETZ?
- M6 on DR's and Bias ply (stock 16's) please come in
- New obdll Race Pak kit. Anybody used? Who sells them on here?
- The n00b weight reduction itch...
