- 10.59@128.68, 1.43 60' - 346ci 6-speed ALL MOTOR!
- Working it down 10.09@136.80
- New Bogart RT series, gauging interest
- WANT TO GO FAST, HELP!
- Removing the power steering pulley...
- Weight of Car???
- Open headers , is it worth in 1/4 mile ??
- 26x10.5 x16 vs 26x10.5x15
- SLP Custormer Appreciation Day in Ennis.
- Going from A4 to a 400T, what's your ET difference?
- Hoping for deep 10's
- Thunder Shootout.... High resolution pictures????
- has anyone...
- 11.51 @ 121!!! finally
- What would my 427 run?
- 28" slicks on lowered T/A...
- 2/3/03 Hey Terry...
- How much can running rich affect your times?
- Need some help on another board from those with 230 or bigger cams w/ stock LS1 heads
- Tire and gearing question
- A4 Heads/Cam/YANK TQ Converter guys-or guys with knowledge of them, please come in!
- Any performance updates on the TCS or TCI 4400 convetrers?
- Racing in Arizona?
- 26"x11.5" ET Street vs 28"x12.5" ET Street
- Help me go faster......
- I have some BAD problems!!! HELP!!!!!!
- Gears and Tire
- Will the fans still blow with no A/C?
- First Bogart P2 series on an F-body
- Line Lock help?
- So what's the deal with the backspacing on the Convo Pros?
- Guys w/400+ ...what ET to expect with.....
- Time for larger tires...need some opinions
- Starting stock again! What to do first?
- 11.5975 @ 118.04 (1.5969)
- Anyone know the gains/loss's of true duals on MAC headers?
- Woohoooo. Hit 11's by a hair...
- weights in case your interested
- Another new best
- Anyone know how much Welds weigh with tires?
- Childrens Home Benefit Track Day at Steele Moved to Saturday Mar. 1
- Problem with 9" any insight?
- "Hardcore" racers- what is your suspension setup?
- What would a car reaistically weigh with these mods?
- Got a new best out of the vig 3200
- Wheel Size and Tire Size
- What pressure to run in nittos?
- Fastest SS-LS1? Power adder.
- Bieffe Integral GT helmet
- First Runs With The Gas -- Knocking on 9's
- Search does not seem to work---!front bumper....
- Paging Terry B.
- Drag rims....convo pros, draglites, or pro stars???
- Race Gas
- How much does your car weigh?
- Everybody's quite in Houston... What's up???
- What is a good run out of a stock full option 99 Z28 6 speed?
- Weight reduction of small steering wheel and no air bag?
- crossover / delay box
- How does this sound?
- Paging William Ritchie>
- No traction but still ran 11.8
- 03 Mach 1 runs 13.15? I guess ls1's have a challenge now?
- Help me get my car from mid 11's to the 10's!! Need a modding list!!
- Madmans steering rack and daily driving?
- Can I get 9s with this?
- Hoosers Drag slick 29-11x15?
- Instrament panel light delete mod and light weight heater install pics
- hoosier vs drags
- where to place my LCAs for Drag Racing...
- So the quickest MN6 346 CID car is 10.66?
- 9" vs 10" slick on an auto
- Anyone here claim Drag Racing as a business on their taxes?
- Hey Mistah George Coffey got a Q for U
- ABS light in the instrament panel needs removed.
- Opinions on: Eibach Drag Launch springs and CE drag shocks.
- Kuwait : Comparing between TR 230/224 & MTI X1 in 1/4 mile
- Will this spoiler hinder my MPH in the 1/4 mile
- Thoughts on Billingsley lightweight 12 bolt for daily driving
- 4500RPM in 6th, what speed?
- M6 to A4 Swap Success..... New best times...
- What is the fastest bolt on nitrous car??? (can't get the 1/4 list to work)
- WHAT TIMES DO U GIVE ME???????
- Would I benifit from bigger headers on a 393?
- What exactly is "DA"?
- It sure gets slow in here this time of year...
- Can I safely cross the traps at 6500-6600 RPM's with my stock motor?
- What is the perfect weather for Drag Racing?
- DA Question
- lid, catback, stall, tire car e.t.'s?
- M6 Guys....Best 60ft. w/ 3.73 gears????
- Who Has the Fastest M6 Convertible and what was your raceweight?
- new best today
- Buy or don't buy a 98 Z28 vs 99-00
- ricer claims that cam only 10 second LS1 is a freak and will never be repeated....
- what would benefit my 60' more?
- Solid mount torque arm and noise
- broke into the 11's, video inside
- New Bests!!!!!!
- 750 HP & 3300 raceweight, guess the QM time:
- poor dyno results
- Finally a 12
- My video...
- Let's give some thought to driveshafts...
- Switching to a drag setup from a street setup
- GM long whl stud part # ??
- Moser 9" Install Question...
- New Personal best in Stock 2002 Z06 - 11.596@118.53
- Callng out Billingsley Racing
- Will these Weld Prostars fit my setup?
- what hooiser compound?
- Lockup problems with the Thruster Pro series?
- Density altitude -3824ft!!!!
- HOW BIG CAN I GO ON TIRES?!?!
- takeoff
- Why not just use the spare rim(s) for up front?
- do rod bolts take you out of internally stock?
- Weight difference in BMR and PA Racing Kmembers?
- Can you stop/maneuver with skinnies?
- Weight difference between a weld and a weld XP
- Spohn Torque arm? Help or not
- My new LS6 427 solid roller is done
- Where can I get some pics of ARE's silver car?
- VFN non-cowl WS6 hood?
- People w/ a 3300 # raceweight what did...
- what is good track prep
- Fastest 346 NA LS1 in midwest?
- Timeslip help?
- !ABS NEED HELP!!!!!!
- Torque Arm Gains
- 28" x 10.5" x 15" ET Drag.....use 15" x 8" Welds or 15" x 10"?
- Paging all Big Cube TH350/TH400 guys
- Will Telstars fit ls1?
- Removing Driver's Air Bag???
- Yet another one of those GUESS MY TIMES!!!
- What to expect...
- BMR K Member: Lower frontend?
- Best 60' on the stock clutch?
- Purchased my rim/tires, have a question for the next set of tires...
- spark retard- 4.0- where from?
- My roll cage passed NHRA inspection :-)
- Help me analyze my track results....28" tires work!
- Skinnies Y/N??? + Slick Size???
- SO my grandmother made her first 13 second pass in her M6, now she wants wheelies!
- ft wheel studs to pass tech?
- Results from new headers.....
- Times from a friends Eclipse GST on DR's this weekend..
- Getting a pin-on hood, and I need to know some things
- Speed Inc Lightweight carpet question
- New Best Sat Night
- First time at drag strip.Not too bad!!!
- New Best with B1 cam/Vigilante 3200
- Broke 10 bolt today
- Can someone evaluate this run w/ a decent 60'?
- ....a new pepper mile-stone.
- Most inexpensive line loc?
- th 400/4000 stall - w/bolt-ons, 11.97 @112 n/a
- NE1 with Holeshot wheels?
- Launch advice
- Who's yo daddy? (New best 346 A4 w/ST3500)
- New bests in the slow 4.6 GT....
- Who has BOGART wheels and M/T ET streets?
- Project SS now has the gas....
- Front suspension travel Limiters???
- Eagle wheel & M/T ET Street question
- 15x8 prostars with 5.5" backspacing
- Help me pick out the correct Prostars and slicks
- Looking for pictures of 26.5 tall slicks on a 16 inch rim.
- Can I get some info on removing the firewall insulation?
- Stock Internal M6 on Radials???????
- ProStar 15 x 8's
- Paging ROB'S SS, JS, and Tom the Roofer: one more PS cooler Q
- NMCA EFI Quick 8 dates finalized w/in
- Maximum Top Speed
- Great Video WS6 double wheelie & save from wall
- Fastest LS1 in the 1/8th mile?
- Strange Drag Shocks>>>
- Please post pics and info on your skinnies and slick...
- Jay Billingsley, Madman, etc, Regarding Rear Springs...
- How long does it take to get used to a shift light
- ET drags or Street ????
- Harwood hoods
- What Hal Settings do you use at the track?
- Rear Sway Bar
- first heads/cam car in 9's
- 15x7.5 convo pros o.k. with 26x10.5x15 E/T streets ???
- list of fastest internally stock power adder cars
- The name of the game today was "weight reduction"
- Got some carpet weight figures here...
- anyone run Bogarts w/ ET Drag 15x10.5x28?
- eliminating ABS??
- Will convo pros w/28x9 et drag fit
- Spacer size for 3.5" rim?
- front sway bar
- Did anyone try The Yokohama A032R
- which gear with a 28" tire?
- some one help me go fast and figure some things out!!!
- approximate # of passes on BFG or nitto
- opinions on powershifting
- New times at the Rock
- Poly motor mounts? Is there one for the LS1?
- A description of my 28" tire fitment woes...
- Paging JS-- what convertor now?
- Racing seats
- Lightweight car... easier to hook up or harder?
- Can someone tell me how to remove the PS cooler? JS?
- Do we need the fan shroud or both cooling fans?
- Where can I get a drag racing helmet?
- Anyone using G2 race suspension parts?
- 1/4 mile time
- Drag wheels that fit ls1 brakes and lowered??
- Will a bad rear end really hurt your 1/4 mile times?
- Weight Reduction question
- are any 6 speeds in 11's with just boltons?
- Project Wife's Car II" makes it debut at NPR!!
- How much will these susp. parts help out
- TCI 3500 1/4 mile results!
- New Best With ET Streets!
- First ¼ mile run with the TR224/114, stock heads and boltons
- Hardtop or T-tops? So many t-tops to buy
- Racing at OUTLAW tracks? Should we be concerned?
- Can I get some more specifics on what exactly to cut/grind for 28" tires?
- Has anyone done a 7 second 1/8 run N/A on stock convertor?
- Is this helmet good enough?
- Home Fuels
- Getting moderate to severe wheelhop. This sucks.
- is my car a beater? stock times suggestions?
- Will I run in the 10's with my set-up????
- All right, now, before I go back to the track this weekend...
- 9s possible with pump gas and NA?
- What's the limit on being hardcore?
- GET MY CAR INTO THE 12s
- New parts a coming
- New to drag racing a few questions..
- safety question - pertaining to airbags
- Fastest Torque Arm Racers Beware
- Paging Terry Burger....
- Paging Top 6 NA LS1s
- Anymore info on the CF WS6 hood?
- Final question: Can my 99 firehawk do lows 12's with just LS6 cam, srngs,intake+ LT's
- IHRA drag racing info inside :-)
- New Times with Vig 3000...Very Impressed
- ARE K-member weights
- Help me bench race here and pick my next mods!
- Lightweight 12 bolt / 9" options
- Newbee
- Finished Write-Up for Hood Pin Install
- Poor and Inconsisten 60's....Think it may be trans brake
- Harness help
