- Cage is in pics included
- 11.5" tire on 8.5" rim??
- What does an 02 M6 Z28 weigh?
- Southern Shootout grudge racing
- WORLDS FASTEST LS1 = ARE 9.17@153
- FINALLY MADE IT TO A 1/4 MILE TRACK
- 13.2's @ 118.5 ... I am looking for some advice
- What performance to expect from 422 in a 4A?
- More hood pin info and pics
- Another one bites the dust...
- Looking for: Black Magic
- Gained +4mph and .4et with JPR S2 heads.
- Southern Shootout rules National Record Holders.... Who's it gonna be!!!!
- 11.doh with hotcam & TNT
- The Quickest Stock Internal M6 in the country
- How to get a/c evaporator out
- Lower Control Arm's hurting times? PLEASE HELP!!!!!!
- What are FLP's, Hotcam, and HPP3 worth?
- What does it take for me to hit 12s
- New Best, but need some advice of experts.
- all motor 346 H & C owners...who has gone faster than 122mph in the 1/4
- Does RWHP always convert to ET??? (M6)
- MTI 382 all bore w/ stage 3 heads ordered!
- Finally met my goal.
- Getting my feet wet again
- new best time!
- Hawker Battery Installed
- Super Chevy Montgomery, Al.
- Will Drag Radials Help?
- Whats it take for an all motor 10-11 sec LS1????
- Cam specs---->Whatcha think?
- DS Loop?
- what size skinnies with out grinding calipers
- Magnum drag wheels from weld
- HELP! Sportlines with Hoosiers??? Will this work?? HELP
- Pics of the hood pin mod
- Hardcore guys, I need some input on weight reduction
- Richmond Drag Racing M6 Tranny?
- Fiberglass Front End
- Anyone thought about a tube frame car with ls1
- fuel system upgrade a GO
- Aluminum Frame possible?
- wheres the FI guys on top 100 list?
- Fastest Stock Block F-Bodies Updated
- Paging Coach!!!!
- A.R.E 9.67@141.90 with a 1.382 60'
- My crank pulley fell off last night!
- 28" Clearance Questions
- Results from NPR
- Guess my 1/4 Mile time
- Are comp TA drag radials any good?
- Colonel, how do those light weight front brakes handle
- What should I run?
- What does the GM ground effects kit weigh?
- 1/4 time
- Who's running the BMR Drag anti-roll bar?
- 112 mph w/TR220 cam and TTS LTs seem low?
- NE one running 28x9 with 4.56 gears?
- 11.doh
- How light can you go???
- Any tracks around Ft. Walton Beach, FL?
- Who's done hood pins? George C?
- Should I shift to fourth or go thru quarter in third with my mods??
- ST3500 and 400rwhp. What's your 60ft?
- Is anyone running Nitto 315s on a 9 1/2" rim?
- Too much positive camber hurt MPH?
- Stock internal M6-11.668@117.23
- Subframes....ya or nah
- Anybody know the weight of T/A ground effects?
- 29 x 10.0 x 15 Hoosier, my best option?
- Got bored, weighed my bone stock Hawk for you guys:)
- Need help finding things to remove for weight...
- Got my car on a lift...found some interesting things
- 440 rwhp 03 Cobra vs. Stock Z06 Video...
- GLD tonite anyone? (9-17-02)
- Calling out all northeast racers
- Gearing vs. 60' times
- Jegs makes a TQ arm??
- Does anyone make a SS style pin on hood?
- Are these times possible?
- question about top 50 lists
- fan usage at the track
- which is better?
- Any Corvette drag racers in here?
- ET Drags = bog
- why is my MPH so low for my mods????
- Weighed both bumper supports.
- Dynabatt jump-start problem
- How much will BFG's help
- Anyone running BFG drag radials full time on the street?
- No longer the slowest Z06...
- 1/2 studs with stock 16s
- The Hot Rod runs a new PR.
- NOS drag guys in here, is this possible??
- Another Thunder Shootout post
- Weighed my car today
- which drag radial
- 1.5's on Real Street Radials!
- skinnies??
- hELP ME VERIFY THIS TIME SLIP PLEASE..
- ARE 98 Camaro 9.32@150MPH!!!
- How do I get crash bars out?!?
- Finally some times worth posting!!!!
- Track results from today (Cayuga)
- Need help with 60'ft's...... On stock tires
- New guy here, with new track times.
- 8.001 @ 89.6.... What's wrong with my car???
- last night events at SIR
- Think i set street tire record
- WTF: Full bolt on M6 goes 13.1@103
- new best
- Thunder Shootout tech?
- PSJ?????
- Going to the track tomorrow :)
- 2002 Z28 1/4 mile times.
- How much would I lose?????
- Phase I underway.
- Put on the 28" slicks, now ABS light and Low Trac...
- I have the SY3500 and 3.73 what next?
- 28x9 seems to be too much tire for MN6 guys?
- lookin to shave weight
- How much ET might I loose with a slipping convertor?
- Slight new best last night.
- ESTIMATE MY TIME
- Finally a new best last night
- Need suggestions, please
- Post your best Stock Converter times.
- What size ET streets
- Anyone with 15x8 welds/26x11.5 ET Street? 60ft. times?
- Lightweight Battery
- Help me pick a new converter!
- Hey Joe Kizzire w/in
- ET streets on freeway
- crash...and...speed...kings
- which front runners?
- Paging Trevor D....
- ARE 422 LS1 + 67 Camaro = 9.76@137
- Roll Cage
- 2 more 9 second LS1 cars?
- Westcoast event in Sac Fall of 03
- LS1Tech's NA fastest list...
- Holding stall too long?
- Links to web sites that keep DA info history?
- F-Body Gathering - - - - - - Tech Rules
- need help with wheel tire combo
- How do I figure out DA for Cecil Dragway back on 9/7?
- Anybody take air filter out at track?
- 126.6 MPH and get into 11s on REAL street tires the first time out with my ARE 436…
- what race seats are you using?
- Tranny goes boom!!!
- Testing the new engine out...
- drag slick size question......
- Need to put on some weight!
- Installed my delay box...
- Closest race I ever lost (bracket racing)
- Heads & Cam Runs At 5000ft DA!!
- coolant reservoir removal for weight, bad idea??
- help I cant 60 ft to save my A$$
- 15" rim question
- Orlandos Fastest Street Car Shootout
- New Best In 5000 DA!!
- IS THIS A GOOD SIZE FOR ET STREETS 26X11.5X16?
- ET Street psi....
- Thunder Shootout...... something to think about....
- what will I run now?
- Orlando guys...
- Bolt on race: Looking for the list
- Weird track incident.....
- state mods and shift point
- ? on Nitto's and a M6
- Awesome night at the track, and another new best!
- Big thanks to the Madman!
- First time at track with my new M6
- Need Input (Track and Street) on SportsmanPro & QuickTime DOT's
- First time at the track
- Paging Joe K or whomever re: thundershootout rule
- Paging JS
- ? About 11s in an M6?
- West Coast Corvette Challenge at LACR on Sept. 28th.
- Bad news guys....
- Help! Paging guys who have trimmed bumpers to fit 28" slicks(GeorgeC,etc)
- Supra vs K-car
- Fastest N/A and P/A with 4L60E?
- I'M A GIRL!!!
- Hey 1.3-1.4 A4 Peeps How you set your rear shocks?
- How much weight does drag wheels save?
- Walked a Z06 at the Track!
- New Best - Need Your Opinion ------->
- how big a tire should I run?
- Any A4s running 26x10 ET Drags with 3.73s?
- here are dealer cost on gm hot cam kits
- wil my 60 suffer any with the cam?
- check out what i ordered from speedinc today
- Two in a row for the "other" car!!!!
- My Harlan shiftlight and tach is too slow!! Can't keep up with the rpms???
- Thunder Shootout... 57 days and counting down!!!!!!
- Should I buy bigger rims/slicks or invest in some HAL's
- Are there any BIG fbody events coming up before the end of the season???
- Anyone know about HiTech Motorsports?
- 10 sec guys/ what headers?
- Shakedown run with Grotts and ST3500...!
- Had a great time at the MMRA race, but.....
- smallest diameter slick?
- New best at MMRA!!!!!
- Summer time ET's for H/C cars?
- Drag times on new cam:
- 01 LS1 in 91 Z28: Back to the track with 3.73's
- Any updates from the MMRA race?
- The Hot Rod wins the Turkey Shoot.
- No racing this weekend
- 2003 COBRA Makes 536 RWHP / 644 RWTQ
- SON OF A B****!!!!!!!
- Looking for info on the Thunder race
- ET question
- 1/8th mile question? what's a 7.80 in the 1/4 equal out too?
- Need info on Wolfe roll cage.
- Which slick:10inch ET Drag or 9inch Hoosier Drag?
- Launching
- I need some expert advice! Weather/performace related question
- Finally! My car is actin right.
- Just some Friday night racing results
- Fix one problem...gain another ;) New best anyway
- Wheel Stand from Hell!
- Another new best Wednesday night
- Just got back from Capitol Raceway Opinions Please on my run
- 26-8.5x15 ET DRAGS w/Vig 3600
- New R&D Car
- HARLAN! I'm about to scream!
- Tire pressure
- Thanks 383LQ4SS for helping me install the shifter and shiftlight..
- First time at the track results!
- Finally went back to the track
- Harlan's 2-Step for 98 M6's - Solutions?
- Anyone run Weld Magnums?
- PAGING DEAN!!
- How big is too big?
- does any body have any info on ls1 edit
- WHICH TORQUE CONVERTER??
- 15x10 wheels question
- 26 x 11.5 x 15 ET Streets
- Pictures of bogart drag rims
- shifting point/dead spot problem solved!
- Question for the racers.
- Need Racers for Track Day at Norwalk (Ohio)...Sep 27th
- What's a good T-Type website?
- Bolt-on LS1's w/converter in here please
- What clutch is the best?
- Theoretical Question.....
- (MMRA) Colonel's Z28 a street car again? Neat!
