- Need info on Wolfe roll cage.
- Which slick:10inch ET Drag or 9inch Hoosier Drag?
- Launching
- I need some expert advice! Weather/performace related question
- Finally! My car is actin right.
- Just some Friday night racing results
- Fix one problem...gain another ;) New best anyway
- Wheel Stand from Hell!
- Another new best Wednesday night
- Just got back from Capitol Raceway Opinions Please on my run
- 26-8.5x15 ET DRAGS w/Vig 3600
- New R&D Car
- HARLAN! I'm about to scream!
- Tire pressure
- Thanks 383LQ4SS for helping me install the shifter and shiftlight..
- First time at the track results!
- Finally went back to the track
- Harlan's 2-Step for 98 M6's - Solutions?
- Anyone run Weld Magnums?
- PAGING DEAN!!
- How big is too big?
- does any body have any info on ls1 edit
- WHICH TORQUE CONVERTER??
- 15x10 wheels question
- 26 x 11.5 x 15 ET Streets
- Pictures of bogart drag rims
- shifting point/dead spot problem solved!
- Question for the racers.
- Need Racers for Track Day at Norwalk (Ohio)...Sep 27th
- What's a good T-Type website?
- Bolt-on LS1's w/converter in here please
- What clutch is the best?
- Theoretical Question.....
- (MMRA) Colonel's Z28 a street car again? Neat!
- upper end dead spot
- MMRA event @ MMP (Gas & N2O available)
- This weekends racing results.
- Good News for Southern California!
- HAL/QA1 ride height adjustment
- New times (Not bests, Bracket racing)
- what BS do i need for prostars? ordering soon!
- Drag radial users questions inside
- shifting points
- Can someone check out this tire and wheel setup for me?
- Some race results from TX SLP day!
- Best 60ft with M6 and Nittos
- 12.1@114 with a 1.8 60ft today at SLP CAD
- First time bracket racing - I won 1st !
- First 8-second LS1 at car show
- Darn 2-Step Wiring Nightmares!
- Results from Tx. SLP day?
- new best 8.78 in the 1/8!
- New best despite some more problems...
- Stock 02 TA WS6 coupe Vs. Stock 02 Camaro SS coupe
- New best today: Dual cutout results
- Tire/gearing experts in here>
- will i hit 12's?
- Need a roll cage and a rear end too..
- Will Drill Mod eliminate Clutch Smoking?
- Jegs tq arm Any one use one yet?
- New BEST! But i have a question?
- 1/8th mile help
- my mph is teasing me...and i finally got a new best in the 12s!
- Does any one Bracket Race on this site?
- Ok guys, help me out . . . my times SUCK!
- can i take a stock vette?
- Can someone post a pic of Harlan's 2-step installed?
- Sept. 28th. at LACR is next West Coast Corvette Challenge!
- can you get a 12 bolt w/ 5.13's? Would you make it 60' in 1st gear?
- What 3.5in tires and rims are you running for track only?
- my et tonight!
- How to launch??????
- ATTENTION: SIG LENGTH LIMT!!!
- BeastSS/Sonof BeastSS
- need help getting into 12's
- Darn Weld 15x10s! Anyone running a spacer?
- 2nd time to track and made it into 12's
- New Member: 13.Doh Club!
- Blew some serious ass at Track tonight....
- 3600+lbs + T56 + N2O=10.14 @ 135.11mph, 1.40 60'... almost there :)
- What slicks to hook up a sprayed 422?
- New Best
- cooler fuel better???
- Got some preliminary dyno results.
- Is there a new record for the fastest LS1 F-Body? Is it 9.29@142.4?
- Weight and F/I
- Tires for Bogart 16x4
- Thunder Racing is Great!
- Any Pics of Camaros with Rodlite wheels?
- ET Streets (11.5 vs 10.5)
- Any 16" Slicks Out There?
- Draglites XPs and lugnut questions
- I tried to dyno my car today...
- So...who's the fastest NA, internally stock, 2;73 geared LS1?
- Best Shift Point for My Setup??
- ET streets with stock rear end??
- Any one running MT ET Streets 26 X 11.5 X 15
- Vid of me racing against 510RWHP Vortech LT1 car
- seem right????
- new best, but is there more.
- Madman's Motor is IN!!
- 11's last nigh
- Speedtek shop car...1/8th mile shake down pass (video inside)
- Feathering the throttle........?
- New best with Z06... I'm still the Slowest Stock Corvette in History!!!
- 99 Cobra calling out Bolt-on LS1's - MMRA Race!
- 0-60; 4.95s
- The Hot Rod Wins this weekend!
- hook ground under hood back up?
- anyone using the dyna batt battery thunder sells?
- Texas SLP day - Who is going?
- removed styrofoam behind front bumper
- HELP! which lightweight battery WILL start car from trunk?
- Coach is a driving MOFO
- Operation TH350 is a bust.
- 4.30 gears w/ lightweight spool?
- Traction, G-Tech, 1/4 Mile, etc...
- Fun at the track last night!
- New Best @ Carlsbad
- Does this suck or what??
- Damn it was hot and humid today...went racing anyway
- New Best - Look out 9's Here I Come...
- New best with the PT4200 in the heat.
- Another New Best Last Night!
- 9.1 rut, is this normal?
- I have an A3 again.
- Spare Tire...
- Question: Spraying 100 shot with Stage II heads and cam with SY3500..
- First Dyno (graph inside) - How can I lean the A/F?
- (sigh) another new best...
- A-arms...which better/lighter? BMR or PA
- drill mod
- MMRA event Labor Day weekend...I hope you guys can make it!
- Tire size and type help.
- LS1 Cutaway Image???
- M6 guys....please post your quickest 60' with an aluminum flywheel
- ROLE CALL, "SOUTHERN SHOOTOUT"
- What's involved with a new steering wheel?
- 28x9 ET Drags have arrived!
- Stock shifting RPM
- A4 launch at track
- Need help sizing the right rim and tire combo for the strip
- Convince me to get a spool
- Got new times, need a little input...
- Tried my hand at bracket racing!
- The 'Hot Rod" goes to another Final.
- Where can I get info on the Super Chevy shoot out?
- Cutting rear springs
- What should I run in a 1/8 ????
- Going to the track Thurs . . . .
- You guys know where I can find a decently accurate HP calculator?
- wilwood drag brakes
- Finally in the 7's ( in the 1/8)
- which bushings for LCA's?????
- Short belt analysis,what do you think?
- Typical bolt-ons, TP4200 - help me pick a tire.
- Clutch info needed???
- hmmm..., 03 Cobra vs 02 SS ???
- where can I get a two step for LS1??
- any gains going from 3:73's to 4:30's
- et streets + stock Ls1= BOG
- what do you all think????
- et's??
- 28x9 ET DRAGS,anybody run 'em?
- How much do stock leather front seats weigh??
- full tank or near empty when drag racing?
- New bests last night, Powerglide may stay in.
- Paging Dave Dubberly (The BeaSSt)!!!!!
- M6 Bracket racers?
- How fast is this car???
- Full Bolt Ons M6, 12.57 at 111.9, Whats wrong
- What a FUN day at the track :)
- Nitto has a screw in it
- Question 1/4 mile
- New Best Last Night!
- New motor has some balls...but I need to learn to drive
- More new bests, still cant figure out this 60' thing though...
- more crap weather, some new best, and KILLER VIDEO!
- Billingsley Racing torque arm?
- Playback Tach?
- Back to back identical runs?!?
- Madman's got Power!
- How much weight will this save?
- I'm Alive and Kicking
- Taking the car for some shakedown passes tonight
- Paging Terryble Burger
- ET gains w/ short belt?
- SOM Z28 M6 results
- Tach lead for 2002 Z28?
- What is DA
- Submit a video for MMRA TV commercials.
- Nitto DR's on 16 x 8's vs. 17 x 9's
- More shakedown runs last night...
- What is a radial slick?
- Project LS1 Monte SS earns it keep at the dragstrip tonight....can you say 12's!!!!
- My First Run Ever Good Or Bad
- Import vs Domestic Shootout
- need answers for bad night
- Track rules...
- Has anyone run a radial Slick?
- What Brand/Size Wheels & ET Streets are you running?
- LS1 Motorplate Design Finished!!
- Stock internal M6-11.72@116.59
- New Summer Best!
- 26x10 ET DRAGS on an 8" Draglite rim...will it work?
- Harlan 2-step installed today!
- speedshifting?
- 15" vs 16" draglites
- LS1 Motor Plate almost finished...
- Cant race my SS anymore
- Some summer time passes and a new best mph
- !rear swaybar? good mod?
- what'll my NEW mods run> mti stage 2.......
- Got that 10 sec pass finally!! Video!!
- My first time at the track
- My first shake down run on my new setup.. I am rusty..
- Where can I get a trans temp. gage?
- ET Street vs ET Drag (or any other similar comparison)
- New best 1/8 mile time with my small cam combo
- Drag Racing on a Plugged Nitto
- Whats the best slick available?
- I raced the tow truck today!
- New best with Hotcam+TNT!!!!
- Ford 9" center section weights for ya
- 2003 Cobra at Bristol Dragway
- Best drag only little mufflers?
- paging 9ball....
- Lets talk torque arms.. Need suggestions.
- A night at the track
- need sealed battery box to fit in spare tire well...
- Bogart wheel/tires mounted ..pics inside!!
- What's the biggest tire I can run on a 15x10 Convo Pro?
- ST3500 kicked butt at the track tonite
- Got some shakedown testing done tonight...
- Anyone with BMR Kmember and A-Arms please help
- Louisiana Viper/Vette Shootout! Come out and play!
- Optima battery
- 15x10 Convo pros-Spacer,grinding?
- What angle should I set my BMR tq arm at?
- Short Belt
- thoughts on this setup...
- Paging Terry Berger
- What Gain With Welds ?
- Today's progress report
- Who has run 11's Stock Internal with no weight reduction?
- VIDEO of my 3598lbs T/A
- The BEAST is coming along! :-)
- World's Slowest 2002 Z06??? IAT Sensor to blame?
