- gear help...4.30s or 4.56s
- seats and mounting
- MSD 2 Step plug n play Help
- Need help with strange DA shock adjustment.
- 1000+ rwhp lq4 on e85 with turbo spark plug reccomendations
- Race weight and 1/8 mile times
- turbo 6.0 drag race timing
- 2000 camaro suspension set up?? Need opinions
- Stock Eliminator: LS1 block VS Iron Block
- 60 feet is not good, NEED HELP
- Hole sawing Trans Am headlight brackets.
- grudge match with a mustang input needed!
- Rear main seals
- Weight Difference of UMI Torque Arm Relo
- trying to slow down for a class
- E.T. Gain after mods
- Need opinion.. slippery day at the track.
- Odessy pc680 and mounting.
- How much et from skinnys?
- might go to 1/8 track? any tips?
- Anyone know if TCI-980000 fits 4th gen floor pan?
- gears for the 1/4
- Which rear springs work best stock ls1 vs stock lt1 vs lowering springs
- solid motor mounts
- Hello from Pfadt Racing!
- Which Radiator?
- Help My 60' get past 1.6x
- Weight reduction... what else?
- suspension setup
- wolfe adjustable rear spring mount
- Wiring opinions
- radio delete plate
- Suspension binding!!! ball joint issues
- Any mods for sticking front brakes???
- Mechanical clutch linkage in a 4th gen help
- lightweight rotors oe replace
- Enough air flow
- Cheapest place to order MT radials from?
- Drag Radial Tire Pressure
- which tire tubes should i run?
- Panhard rod mount
- Race season sale at Burkhart
- Catalytic converters
- LSX Part Numbers
- Strip Tire Help
- quick relase steering wheel hub ?'s
- Will a drag brake stop better than stock brakes?
- Anybody using an odyssey pc925 battery?
- manual steering on street
- Creeping up on it
- clutch to auto, still no starter
- Anybody using the Midwest Chassis 8 point?
- is it normal for bias plys to loose air
- getting the weight off
- Switch panel
- sjm abs delete without ll, need pics please!
- Gauges for turbo car
- Oil Temperature
- Gutted stock steering wheel?
- What all can be removed once the dash is out?
- what will i trap on a 27' tire
- soft brakes
- DFW area CARB & TIMING tuning needed
- 26" tire vs 28" tire
- Pin on hood questions
- madman manual rack question
- Filled Blocks
- Removing 1 stock fan for track car
- Mt 345-35-18 vs Mt 315-45-16
- MWC or Wolfe Roll cage kit ?
- rear gear ratio for glide ????
- Help: Drag racing tires
- 6spd Qa1 settings
- Looking for 4L80E Swap Results
- belt size for ls1 with out power steering.
- Manual brake conversion
- Help me out with my senior project! exhaust statistics!
- Project JUICE 2 new build
- How much can you tuck the front tires in with a umi front setup?
- Wolfe 6 point and 18 inch kirkey issues!
- 11sec rec safety equipment?
- weight reduction whores please step in
- Is a safety harness needed with a roll bar to pass nhra or ihra tech?
- Roll cage build?
- quick stall question
- rollbar/cage issues
- 600 RWHP, 315/35/18 DR's, SLP Bilsteins...traction?
- What should my next investment be?
- Valve Lash Adjustments
- 2 step?
- Anybody cut the top part of dash out?
- Help me figure this out *broken driveshaft*
- Spohn drag bar setting?
- What could it have run?
- 8sec. nitrous cars. Do any of you or seem tge exhaust run out the fender
- Fox Body traction & twist help
- How lite can you get your car
- 98 Shifter wiring ?
- Oil weight ???
- How can I improve my launch?
- Rear end break in
- Pulling windshield and replacing with Percy's, any tips?
- Removing parking brake
- anyone using yella terra platinum adj 7/16stud solid roller rockers
- 15/16 Lug nuts
- Tire height help
- Turbo and th400 users step in? trans line ?
- 10 pt cage question, will this work?
- Looking for good swing out kits with window nets installed???
- Car swaying side to side on low pressure slicks vs radials?
- 9 In. Big Ball Bearing Conversion?
- Changed alot of stuff... didn't go much faster, why?
- gas level at track
- What changes can I make for better ET
- th400 users and speedo?
- Bdrc 29/03/2013 jassim alsolaiteen 7.230@215
- drag slick size change
- New Motor Start Up.
- why cant these tires hook.
- Lsx tr6060
- 12:1 CR... What starter?
- What are the TCC used for on the pcm?
- Suspension Adjustment Advice
- Weight Reduction 100lb goal on already light car
- Need help.. Car won't start after deleting some wiring
- VIDEO of my launch help**** NEW VIDEO WITH N2O post #72
- Deleted A/C and Heat, what should I do with the wires?
- Window switches and lightweight door panels
- Wounded Warrior vinyl wrap
- I want to delete un needed wires under dash, anyone done this?
- battery relocation parts
- Drag tire with 160 tread wear??
- alternative ground locations for fbody / battery relocation
- needs some help please
- Realistic wt. Diff Hardtop vs T-Top?
- who makes the best nicest lca relocation brackets?
- looking for an f body specific hood pin kit
- DIY lightweght door panel
- Efi for turbo set up
- Kirkey Pro Race Seat with RaceCraft bolt-in bracket
- Vacuum pump, Which valve cover?
- belt size for no power steering and asp ud
- Wolfe 8.50 cage chomoly???
- Tire help
- stock 5.3 flexplate and th400 converter?
- When are beadlock wheels required or recommended
- setting up MWC torque arm
- 4150/super victor guys how do u mount the map sensor and brake booster line
- Stall Converter or different rear gears??
- External voltmeter and battery disconnect install
- Wolfe, s&w, mwc, or MIA roll bar
- What else to remove while dash is out?
- Weighed my car today (Race weight)
- Need help on gear and tire size
- what will be the best for a 346ci
- What options for heater after you remove it
- Aerospace brakes on a 4th gen.
- looking to buy front/rear drag shocks
- Need some wiring/plug pinout help
- Here's a Diagram For Battery Relocation
- hp and 1/4 mile estimates
- 2002 Trans Am Front Bumper
- what should this set up run on the 1/8th
- Where to start with front DA strange settings
- who makes light weight race doors without door handle revisions
- How does this layout look?
- Quick Disconnects for front sway bar
- 4150 guys where do u mount ur IAT sensor
- QA1's 275lb front, stock v6 rear(springs)
- Where can I find a chart with weights of good looking racing seats. Corbeau etc....
- Battery relocation question
- nhra Super Street class
- Radial front, Bias rear... ok once?
- Bumpstop on strange coil overs?
- Anyone using a lakewood driveshaft loop?
- project "Shop Rag" 1965 El Camino drag car build
- Strange Front Drag Brakes On The Street???
- Super Victor Torque Specs
- New combo, ET prediction?
- 5pt harness
- Who has a TA and has deleted the head lights need help with making brackets please
- Jake's D3 transbrake instructions?
- burkhartchassis car in the 7.66 190mile in the 3rd pas for it .VID
- My new Travel Limiters
- Odd oil leak?
- 28 tall front runner
- !rear bumper support!, what do you guys do about the bottom of the bumper flopping??
- 25.4 1970 Chevelle Turbo 427 build
- Am I the first to do this??
- anyone cut the cowl and just leave it open
- Opinions on Champion fronts, prostar rears ??
- What tire height? 26" or 28"
- Speedyws6 build thread
- Super vic intake gaskets?
- Aeromotive 340 Fuel Pump '99 - '02
- What are the pros/cons to running a lightweight spindle on a street car?
- hoosier front runners with White out or not
- wiring clean up.
- Line lock install questions
- what is going wrong here?
- How fast have you been with no cage?
- Manual steering rack... Normal?
- Trailblazer ss vs. Silverado ss tow vehicle
- Main hoop 10pt cage angle
- 4L60E 28" TALL TIRE 4:10's or 3.73's?
- Tricks for SS Braided Hose & AN Fittings
- Has anyone removed there HVAC through the firewall?
- real street build
- teach me how to launch
- Ride height guidelines?
- Building a 414 solid roller with 245 heads which 4500 TB IS BEST
- 275 60 15 and set up questions. I've searched
- What is a realistic 60' foot time to expect? Best so far is 1.35 on a 200 shot!
- Aftermarket Fuel Pump, Which One?
- what size single fans do you guys run at the track, lighter than the stock ones
- Slip on mufflers
- Best way to remove inner fender metal.
- LS or LT powered rail dragsters?
- Tire and rim weigths
- help want the widest tire 29x11.5W
- looking for a write up on the 4150/vic jr swap unsure on linkage and sensors
- Project Because F***king Race Car
- Hoosier or mt pro
- Cutting Up Radiator Support Metal
- Removing the 12V button from a Hurst shift knob
- LS1 starter
- Can the rear bars of a rollcage go into the hatch on an f-body?
- Time to turn the Page
- who makes the lightest front runner tire?
- 509 bbc
- identifying chromoly or mild steel cage
- Top Post Battery Terminals for 1/0 Wire
- what should I expect from this setup?
- Wrong tire height in computer
- Driveshaft Loop to fit my 3.5" PST aluminum driveshaft?
- Valve cover options
- DIY: ABS delete
- 1/4 time question???
- What else do I need to be NHRA and IHRA legal (low 7's 1/8)?
- will 5/8 studs fit in weld RT-s wheels?
- who has switched from a fast setup to a 4150 and vic jr set up
- bone stock suspension good for 11.50's?
- Whats the lightest way to set up my exhaust w/o hurting performance I have true duals
- Need Help With Racecraft Dzus Rails ('95 Camaro)
- Pulled air bags and module... how to get rid of light?
- Help figuring out engine rev limit
- Low pad Weld RTS clear strange drag brakes up front
- TA guys weight reduction help please !!
- Racecraft left out one of the plates..:(
- Anybody a math wiz??
