View Full Version : New LS1 Owners - Newbie Tech
  1. New 98 z28 problems
  2. header install
  3. removing plug wire boots?
  4. 260 for install pretty good price right??
  5. Help!! Engine won't crank
  6. LS6 intake help please.
  7. transferable parts
  8. Making a deposit today?!
  9. 00-02 dash to 93-97 T/A
  10. F-Body & CTSv Oil Pans
  11. Difference between front and rear O2 sensors?
  12. Cat Back Exhaust
  13. Hyperpac on a 02 WS6
  14. weird question about wire loom
  15. A/C busted, recommended replacement?
  16. newb needs help
  17. Intake manifold help please!!
  18. Don't know what to do next!?
  19. 98 Trans am weatherstripping
  20. Whats a mail order tune?
  21. blinking C.E.L
  22. New to LS1tech not new to ls1's :P
  23. idle and pcv
  24. 2K to spend............what would you do?
  25. Did I lose some back pressure
  26. ws6 exhaust
  27. my finished project-trans am WS6 mexico
  28. Lifted on fender tabs...
  29. what to do?
  30. DMH Cutout wiring
  31. Are These LT's Good Enough to Install?
  32. quick catback question(say that 5 times fast)
  33. Hello, new guy here, few questions.....
  34. Newbie wire question
  35. Camaro reliability?
  36. What did I do wrong
  37. Intake Manifold
  38. Quietest Loudmouth Direct Replacement?
  39. My install price from the shop
  40. Headers/stall install 600 to much?
  41. a-4 burnouts (power braking) safe?
  42. Instrument panel light replacement
  43. ms4 + nitrous?
  44. For us who don't know about Tune...
  45. rear end slip
  46. Swapping valve springs
  47. C5 corvette ECM issuses
  48. stuck knock sensor
  49. ls6 intake bolts
  50. lq4 desired compression
  51. what kinds of gears do i have ??
  52. What to upgrade my 99 z28
  53. Have $800, what mods to add?
  54. oil pan change
  55. Some one help me
  56. guidelines and research to get started?
  57. Radiator cover
  58. Cam/LTs vs Nitrous?
  59. 2008 5.3 and 4L60e: Will these two work together?
  60. SLP Package....?
  61. Sound clip needed.
  62. what big cam to use with ac
  63. Newbie looking to build.
  64. need some guidance on how to do a few things
  65. 862 heads
  66. Help with dual/dual install - how to mount rear tip hangers?
  67. '01 Formula Firehawk ?
  68. 16 year old + LS1 = ????
  69. Stock 2000 TA. 35000miles. NEED MODS!
  70. how can I tell if my 99 SS Is real?
  71. Rough Idle
  72. Will oil hurt IAT sensor?
  73. 2008 Aluminum 5.3 rebuild kit anyone please !!!
  74. Would buying an ls1 with 140k on it a bad idea?
  75. ws6 shift boot replacement with plate??
  76. camaro z28
  77. Is an aftermarket exhaust really that hard to put on??
  78. keyed ballancer recomendations
  79. need help with my exhaust asap!!
  80. question about 243 on ls1 gto
  81. front plate cover?..
  82. high idle/codes, possibly from tune?
  83. Best and quickest way to raise a lowered car
  84. ls1 to 6.0L ?
  85. Water pump went out...what's next?
  86. LSI Block Casting #'s & Head #Identification
  87. 2000 firehawk 6spd rpms at 70
  88. Tune after t/b?
  89. What is this engine bay piece called?
  90. what to look for buying used engine... need help quick!
  91. such thing as too much induction (not talking turbo)
  92. Port/polish t/b
  93. Falcon Performance 862 Heads
  94. smooth bellow
  95. 1998 Formula Heads
  96. Best Cam to Pass CA Emissions?
  97. Next mods?
  98. Car just hit 205,000 miles...
  99. 98 z28 steering question inside
  100. Need help LOSS OF POWRER
  101. Installing LS6 valley cover on 6.0L Iron block?
  102. pressure when taking off oil cap
  103. Thermostat?
  104. suspension
  105. Finally!!! A Cam Im Happy with... SOUND CLIP, NOW AVAILABLE!!! 7-17-11
  106. To all of you with autos and a cam
  107. Difference in 243 heads
  108. Special thanks to all you guys!!!
  109. Best cam and spring kit!... I can get an exchanged
  110. Chips and emission testing
  111. Need help please with cam situation. Only experience advise!!! Thanks
  112. Need some advise on modding
  113. 90mm/90mm worth it?
  114. 5.3L to LS1 swap Qs
  115. 400+rwhp
  116. Cheap/Best Super or turbo.
  117. Procharger or heads/cam/intake swap
  118. Spring Swap HELP!
  119. what shocks are you running with sportlines
  120. Help...What do I need to do to get my car to Start??
  121. Throttle body
  122. aftermarket Cam question?
  123. My first ls1
  124. LS1 technical data from GM
  125. Crackling noise under hard acceleration?
  126. Head and Cam Kit
  127. Foglight points up!
  128. Advice on what performance parts next...
  129. SES Light on and Flashes under acceleration
  130. Power Steering leak?
  131. bbk LT header install?
  132. 3" exhaust piping
  133. UD Crank Pulley
  134. whats going on with my car
  135. power steering whine :-(
  136. Cutout and cam question
  137. What connector is this?
  138. 5.3l ls1 swap questions
  139. Speedometer&Odometer Not Working after Cam Swap?
  140. Plastic tank fuel level question
  141. detriot locker situation
  142. exhaust question?
  143. Project Black Pearl I need advice on building my 02 camaro ss
  144. gauges?
  145. body weight
  146. 2009 5.3 turbo swap afm?
  147. Ory
  148. corvette fuel rail covers
  149. Need help quick, security light flashing wont turn over
  150. Driver side Power Window
  151. Bleeder valve?
  152. hello every one got a question !!
  153. is my idle too high?
  154. Internals swap from LQ9 to LS2?
  155. oil pressure gauge??
  156. Fuel injector problems LS1 to LS@ swap
  157. oil mix up?
  158. torque converter problems??
  159. rear end swap
  160. Which throttle bodie
  161. cloths hanger
  162. Help!! T/A won't start :(
  163. What happened?
  164. Quick question!!
  165. Check engine light after rain/wash
  166. Crank pully..
  167. Stock cam
  168. where do these wires go
  169. stock specs
  170. exhaust cutouts yes or no?
  171. trying to make a torquey street car
  172. Pacesetters, No cats, ORY = which Muffler?
  173. slp maf...yes or no?
  174. What PCM do I have?????????
  175. ms4 cam
  176. LS1 Injector pulse
  177. Budget power steering pump?
  178. Anyone know where i can get some true duals for my 02 camaro ss
  179. no start
  180. Headlight issue?
  181. Fuel Injector Cleaner Frequency?
  182. Disconnected Plug in Engine Bay
  183. ticking noise please help
  184. Need advice on buying my first F-body Ls1!
  185. My gas pedal gets "heavier" when driving in rain.
  186. Engine light on after WOT
  187. Knocking noise
  188. Ran my 01 ws6 177,000 mile car
  189. What is it?
  190. DIY Ceramic Coating?
  191. Convert 5.3l return to non-return?
  192. ported throttle body problem
  193. How Rare is a "stripper" 4th gen?
  194. Help with dsl and torque arm relocate
  195. !AIR! !EGR! relays and fuses
  196. dumb cutout question
  197. Bone stock 2002 Camaro SS- I have 3 grand to spend on mods what sould go on first?
  198. high RPM rattle
  199. New WS-6 owner...is this car right?
  200. 402 build
  201. weird engine noise
  202. Drivshaft
  203. headers/ ORY
  204. suspension and brakes for street racing
  205. Rear oil pan bolt snapped
  206. 1999 LS1, low on power, rich on fuel, poor idle
  207. question about new car
  208. Help:Annoying noise
  209. Ram air hood?
  210. problem after car wash
  211. Street-legal '02 SS exhaust setup...
  212. How to tell if you still have EGR?
  213. Rear end starting to take a walk... What to do?
  214. tuning
  215. Bought a 2002 NBM WS6 6-Speed..... :D
  216. F#*K! Oil Pressure Gauge is all over the place
  217. Little bouncing when accelerating at low speeds
  218. Ls2 help
  219. newbie gearing help
  220. Detonation Issue!!!!
  221. kooks true duals
  222. Removing Cat Converters!!!
  223. need to know how to take air bags out of car.
  224. Looking to get into a WS6...
  225. LM2 Exhaust question?
  226. 5.3 to 6.0
  227. tranny problems
  228. nitrous safe shot
  229. O2 sensor ???
  230. 5.3?or a 4.8
  231. diablo/predator tuners
  232. Rare trans am
  233. white face gauges camaro
  234. What length tips for TSP Rumbler?
  235. 243 Head gaskets??
  236. Need help with throw out bearing
  237. Sensors never ready cannot pass emissions
  238. first c5, have 3k for mods, what should i get
  239. Intake manifold reversal
  240. Looking into getting a 4th Gen. Looking for advice
  241. louder exhaust
  242. Found a blower - Can someone help me ID it?
  243. Gauges dont work right.
  244. 4.8 with LS1 cam ?
  245. Bolt torque specs, need ASAP
  246. whats is this
  247. Couple of questions regarding SS~~99 and 02
  248. Torque Specs for PRC 5.3l 2.5 heads?
  249. Exhaust is cracked (pics inside) Need suggestions
  250. How does Horsepower/Torque relate to physics?
