- About to bite off, well a lot.
- New to LS's
- 2001 Z28 108K LS1 Engine Vibrations
- Chip Changing Questions
- Best crate engine for 500 RWHP
- engine swap question.
- alternator replacement question
- Easy power adders?
- T/A gauge in vent
- Cost of building a 408ci 6.0L
- Important Question!
- ? about fuel rails!
- 2002 WS6 brake ducts
- lid?
- Motor Mount Shopping
- are stock rockers different from year to year?
- What is this?
- How does this list of stuff sound that I want to do to my car?
- Looking for some GM Literature..
- What valve covers fit the PRC 5.3L stage 2.5 heads?
- Pre LS1 swap preparations
- whats the original color???
- Thinking about doing a Lt/ORY install soon, but need advice.
- bent drivers axle on '00 ws6...
- What consists of a "top end" and a "bottom end"?
- Buying a 1999 SS and have a couple questions
- TA trunk space
- P0430 engine code TSB 5513
- looking for exhause parts for LS1
- Torque management?
- aftermarket radio (want to return to stock)
- exhaust question
- which oil pan
- Spark plug wire testers
- high milage and mods
- radiator fans
- Sounds like theres a saw cutting a piece of wood on rear end diff?
- Increasing Horsepower in my TA
- Speedo wiring
- Need help identifying proper name
- SLP Oil Pump...
- Exhaust Clarification
- Lt1 to 6.0L swap
- slp loudmouth install
- Looking at a 2001 Z28 soon: common problem areas?
- dead battery?
- power steering pump pully???
- LS1 PCM removal?
- what does a dying water pump sound like?
- Longtubes and stock catback
- Whining Saga Continues
- BBK Headers
- WOuld this hurt the car..
- just bought T/A
- oil leaking between engine and transmission
- Porting mas and throttle body
- What is the part number for a front turn signal light socket on a 98 TA?
- new t/a owner-help
- rebuild
- Front wall thing?
- Oil pressure issue please help
- 50 posts/6 months membership for classifieds access.
- Production Number
- 04 SAP Goat Virgin!
- LQ9 t56 flywheel and clutch?
- Just bought 3 5.3s and have a few swaps planned but need help.
- cats.
- question
- Ram Air Intake for an 02 WS6
- air/fuel ratio gauge
- X-pipe vs H-pipe
- grinding off the throttle body
- Y-Pipe suggestions
- 243 heads
- Looking for this hood please help!!!
- heads
- Change timing chain?
- Engine Swap
- lsx intake
- Need an LS1
- LS1 Camaro Rust proofing Question
- Intake/Heads/Throttle Body
- LS1 Power+Plus Typhoon vs LS6 Intake??
- Header decision- name brand or ebay ones
- You MUST have 50 posts or 6 months membership for classifieds section access.
- Cam or stall or just stock
- emblams
- sarted up the z28 on open headers and it surges like crazy?
- Couple of codes
- Gas Cap. vent or non vent?
- fuel and air gauges and 5in monster hook up help please
- rpo code ws6
- new ls1 owner, 99 ws6
- Shift Kits?
- manual valve body
- Possibly buying 2000 Firebird
- h/c questions
- zex
- evidence of nitrous?
- 1998 Z-28 LS1 Injectors not hitting, Computer!?!?
- Runs like crap
- Speedo off by 10mph
- TA shimmies a little on the front right side when in reverse, any ideas?
- Can you guess my wheels width's by looking at this picture?
- LS6 conversion
- newb
- Chrs1313 Ram Air Questions
- 1999 camaro build Question
- 01 Vet front turn signal socket fail?
- V3 cam
- what is a good cam for my build
- rear end noise 2
- What Spark plugs to use???
- Need LS1 Serious help!!!
- 1999 Camaro Z28 RS M6 Question?
- How do you pass inspection!?
- What is this connector for?
- ls1 running too rich.
- z28 performance?
- supercharge ls1 z28 camaro
- help
- Headers BBk PaceSetter
- Looking for advice - lq9/l92/fc rx7
- tsp dual springs ?
- 5.3 or is it a 4.8?
- Engine Indentification
- I want 400whp 98-99 or 00-02 Camaro/Firebird? Need a base to start from.
- LQ4, L33, or LS4? Newb ?
- Oil catch Can Diagram
- Do I need a tune?
- Help high oil presure and engine chatter
- Blinker and lights
- new to LS1 oil change
- Need Some Help
- significance of 1998 firebird
- Gas gauge sucks ...time for aftermarket
- Headers
- windage trays
- gear ratio
- Ok, not sure what engine I have now
- Mods
- Oil Pressure?
- Jack stands or car lift?
- What are good choices for a mild cam?
- MSD blaster coils
- plug gap help
- Anyone on yellow bully? Need your help
- OEM manual
- Questions about headers?
- Need advice with spark plugs
- Professional Products Damper
- 2002 WS6 front wheel bearings
- Should I wait?
- New
- Is this dented?
- Fuel pressur question
- arrow on catalytic converter
- newbie
- throttle bodies
- Vibration issue...
- changing spark plugs
- How much for a cam install
- MY first LS1!!!
- Help goal of 6.8-6.9's in 1/8th
- true dual regrets
- Supercharger Question
- Production Numbers?
- mobil 1 , royal purple , valvoline
- Couple intake questions...preparing for ls6 swap.
- Head studs
- Hot Rod LS motor article and advice...
- Too late for a cam?
- cold weather rough start up
- Newly purchased 2000 WS6 M6. What now?!?
- help
- 99 firebird ram air box 3.8 l
- exhaust Borla or slp
- Waterpump & GM Techs... Yuck.
- budget racing
- Y-pipe help!!
- Which Clutch?
- LS376/515 Oil Pressure
- 1999 Formula production #s breakdown?
- Wich one turbo or heads and cam ?
- HELP!!! Water Leak in rear hatch. :(
- breakin her in....
- MAC L/T Headers?
- Car doesnt pull like before?????
- LS1.. LSA.. LSX.. Difference
- Lift Plate template or dimensions?
- brother bought a 00 z28...got 1 question
- Car won't start
- need some ls1 advice for future engine
- what does it take to get in the 7s
- Full Bolt-ons?
- replacing bushings
- changing plugs
- Need input, LS1 TA vs GTO as a DD
- Exhaust Choice?
- What mods to start out with
- 97 camaro borla to 99 TA?
- UD pulley really worth it?
- LS1 MoTec M4
- RPO help can't find these in the sticky
- I'm considering a Trans Am
- Would this be a good idea (cut outs)
- oil pressure
- what is D/A
- BBK ssi manifold/TB much better??????
- 5200 ft above sea level.. mods?
- Ws6?
- question on installing power steering pump pulley
- need help
- trick flow top end kit
- need help bad
- convertible or t top
- T56/M12 differences from Vette and F-bodies?
- In search of an lq4
- My LQ4 swap.
- Questions for new parts to 02' z28
- 99 Trans Am - Good daily driver?
- When should i get a tune?????
- GM key fob for my camaro
- New LS1 Owner!
- Damn fans!
- I want to learn to use OBD 2
- New to the Ls1 world. 02' z28 help.
- couple random questions
- Pontiac Trans Am VS Chevrolet Camaro
- Cam/stall
- LS3 into 2001 Camaro
- Did the 99's come stock with Hurst shifter?
- Halo lights on T/A
- two questions
- Help with stuck intake.
- cousin drove my car today now my car has a problem
- HELP! I think my car is about to blow!!!
- Advice please!
- Need some help here guys!!!!!
- Noob from across the water, needs ls1 help
- Need help! ls1 Power Steering noise/Rattle?!
- Park /lock cable replacement
- 2001 trans am help
- I need a trans am!!! Help!!!
- Hot girls on Trans am!
- need help finding right heads
- Time for a new water pump and looking for opinions
- Believe i have the build
- porting the throttle body
- 1st Gen LS1 CS130 alternator conversion
