View Full Version : New LS1 Owners - Newbie Tech
  1. stock Exhaust pics
  2. hey need i advice
  3. What do I need for a Header install?
  4. what gear set do I have
  5. I need help choosing a cam
  6. 2001 5.3L ticking
  7. TA buyer questions. A4 or M6? Convert. or T-tops?
  8. newb question on gears
  9. 139k miles change to synthetic?
  10. is this supposed to looks like this?
  11. AFR's +ms4???
  12. car not downshifting correctly help!!!
  13. My LS1 is toast
  14. question
  15. TSP 1 7/8 LT's...fitment good?
  16. Hypertech Programmer III
  17. Hey guys, going to check out a Firebird Formula tomorrow.
  18. Ticking noise at high RPM
  19. Caution: An LS6 swap could happen to you...
  20. What's it worth nib nos 30anni ta floor mats
  21. Looking for cam info
  22. Ls vs lt dilema
  23. pacesetter headers ory with stock exhaust?
  24. LS1 AI Heads Anyone running them ?
  25. Cluster and miliage
  26. mod question
  27. Best bang for buck?
  28. Selecting a cam
  29. LCA Relocation Brackets
  30. SLP Powerflo Catback/SES Light
  31. Mods to support a cam questions !!!
  32. I need help with my exhaust
  33. Pacesetter Headers
  34. Coolant Indicator
  35. Trick Flow head and cam kit ? LS1
  36. ls6 heads and cam on ls1
  37. Mmm can't decide help!!
  38. Quick and easy question
  39. What cat back exhaust sounds best with the best gains?
  40. 5.3 swap
  41. BBK header question.
  42. Converter question.
  43. Power steering pulley?
  44. Biggest Performance Increase?
  45. Smoked corner/running lights for a 02 WS6
  46. Interior Color question
  47. where is this noise coming from?
  48. Pace Setter QuickTrip Long Tubes
  49. headers!!!
  50. Painting Decals
  51. Header gasket question....
  52. Are these headers good/worth the $$$
  53. Deleted EGR now have question
  54. 04 GTO automatic
  55. Question about 98' camaro LS1 engine
  56. Stuck Lifter? Nope, Help me please!
  57. Slight knock on cold start up...2002 LS1 Z28
  58. yank em or keep keep em????
  59. Which headers to go with?
  60. Ls1 in Jeep
  61. LS6 Intake Manifold Questions
  62. Transmissions
  63. Keep the WS6 or buy a Z06???
  64. flowmaster?
  65. 2006 Aluminum truck 6.0 Question
  66. this is sad 1/4 time
  67. Cut out or not
  68. 160 stat
  69. in search of 11's N/A
  70. Need some help in the Charleston, SC area
  71. Storing a LS motor?
  72. power sterring return line question
  73. loud knock!!!!
  74. TSP Headers verses Pacesetter
  75. What my next mod should be???
  76. project car
  77. Turbo or NA
  78. about to buy ws6 question
  79. need some help lid maf question
  80. New heads/cam now it doesn't learn
  81. Couple of questions
  82. Losing fuel pressure
  83. LSX parts interchangeability
  84. Anyone running Long Tubes with SLP LM ?
  85. Ls1 test run?
  86. Valve Springs
  87. Electrical help please, fog lamp problem
  88. Will LS2 Fuel Rails fit a LS6 or LS1 Intake
  89. Charging Question
  90. What Mod should i do next ?
  91. Jet power control module (stage 2)
  92. Headers and suspension mod suggestions for my WS6
  93. FINALLY! Waited WAY! to LONG!
  94. I broke a plastic nipple off the radiator!!!
  95. new to ls1
  96. Gears
  97. Free Short X Exhaust For LT Headers Iowa
  98. headlight motor
  99. Need help!!!
  100. 5.3l supercharger
  101. how to remove RS spoiler?
  102. 408 Engine Swap [What else to upgrade]
  103. 500 RWHP the easy way?
  104. oil pan
  105. Question on Headers need some experienced drivers to give me some tips.
  106. what oil?
  107. Keeping a high mileage ls1 going
  108. what to expect
  109. new member needs help
  110. will a truck flexplate work on my z28
  111. Port and Polished Stock Throttle Body
  112. 2002 WS6 OEM Ram Air VS SLP Ram Air
  113. 383 Build
  114. Hand-me-downs
  115. need help asap
  116. smog?
  117. 04ls11 GTO Fuel Pressure
  118. Need Help C16?
  119. 1999 Formula WS6
  120. LS6 Intake Manifold Installation
  121. Another next mod thread
  122. New Guy putting a T56 into a RX7
  123. LS1 or Fast EFI
  124. 6.0 swap
  125. Do I need cutouts
  126. (need help) looking to get more power on a budget
  127. Strange vibration.
  128. Finally im in a ls1
  129. Do I have cruise control?
  130. Coolant and Oil Temp Sensors LS3
  131. Bullet Vs. Glasspack
  132. what could I do with 5-10 G's
  133. need help!!!!!
  134. 2002 ws6
  135. Vehicle-Inspired Ls1tech.com T-shirts & Merchandise are Now Available!
  136. Advice and Answers welcome.
  137. Horsepower curves
  138. LSA Advice
  139. Newbie bolt on questions. (catback & ramair box)
  140. Whining noise?
  141. What should I do with my SS?
  142. Someone explain torque converter, stall, to me...
  143. Fan & Thermostat Question..
  144. 853 head porting.
  145. Question? DNA Motoring headers
  146. Cam or Bolt on's?
  147. Fram Air Hog?????
  148. honing question....?
  149. In the process of AIR/EGR need immediate responses PLEASE..yes I checked the stickies
  150. oil experts please help!
  151. timing chain
  152. Is this a good deal?
  153. where can I find rebuild kits for a ls?
  154. Intake Valley Dimensions
  155. What heads should I get ??
  156. rpo DECODING
  157. ls1 knock help
  158. What the hell is this?
  159. Need advice: Air induction on T/A w/WS.6 hood
  160. LS1 price question
  161. Higher mileage '98 Trans Am question.
  162. Modding a silverado?
  163. MAF sensor question
  164. good or bad idea?
  165. what's this piece?
  166. Rodent problem...
  167. Fast ToyS ram Air Kit.... help?!
  168. SLP lid = slower car
  169. Tried German Castrol 0w-30
  170. Where to buy body parts?? Need rear quarters
  171. Help with next mod
  172. Whats Up!!!!!
  173. Oil Pressure Issue?
  174. Replacing/matching/measuring correct headers for current setup
  175. Magna-Flow vs. Stock 98 Z exhaust
  176. Questions about LS1 rebuild
  177. not your average rattle
  178. Buying a Cam Need Suggestions
  179. Best Intake Manifold Setup For Cam
  180. LS6 Intake Manifold
  181. I wanna spin a 1st gear roll!!
  182. ATF In F-body Power steering fluid???
  183. 5.3 Alternator bracket options.
  184. Hey everybody, new Z28 owner from Ft Worth
  185. Wheel options...
  186. Regular ol' oil change. Regular ol' engine destruction. ...wait, HELP!
  187. First time mods
  188. coils and sensor pin layouts HELP !!
  189. ls1 intake on 5.3
  190. Door Question
  191. Key's remade from gm???
  192. My car wont start!! no fuel but fuel pump good Need Help Please!!!!
  193. General questions about GM motors?
  194. Coat hook removal
  195. springs?
  196. fuel rail covers for 5.3
  197. LS1 Crank in LS2?
  198. head and cam swap
  199. Silverado SS motor?
  200. LS3 dimensions along with attachment point
  201. 317 vs. 243
  202. !AC newbie question
  203. T-top/windows questions
  204. SLP Flowpac kit, Worth it?
  205. 94-97 Trans am taillights
  206. Looking @ a 98 tomorrow
  207. Rolled The Dice and Whew!
  208. What you guys think?
  209. Need LS1 motor
  210. Back in the game
  211. Need help
  212. Fuel tank question.
  213. Lost my key :(
  214. Chipped ecu
  215. may a dumb ?
  216. Remove crossmember and upper phr brace?
  217. Fuel injector connector ID's
  218. intermittent idle problem
  219. LS1 To LS6 intake
  220. Newbie questions about 383
  221. what to do next?
  222. 1998 Camaro computer question.
  223. No Spark!
  224. Recently Purchased Camaro!
  225. Questions about my 2002 SS
  226. Fidanza Short Throw shifter opinions??
  227. how to oil valvetrain for bolton(heads off car)
  228. Swapping Rear End Gears??
  229. thinkin about a 99 ss
  230. small list of parts to finsih build
  231. easiest intake swap for 5.3
  232. SES light with mass/volume low input code
  233. header combo? what to go with?
  234. Gas Mileage
  235. Did i just waste my money??
  236. instrument panel mil lights
  237. almost track time
  238. really stupid valve cover question...n00b warning!
  239. ls6 intake inlet
  240. Just bought a 2000 Pontiac Trans am Firehawk
  241. Backfire.. not sure what is causing it..
  242. Spark Plug Change In LS1 Camaro
  243. quick battery question
  244. whisking/rubbing noise in front left
  245. 02 sensor help....
  246. Longtubes and o2 question???
  247. Elusive Misfire in #7
  248. Cai
  249. I need help spending money
  250. power steering fluid question
