View Full Version : New LS1 Owners - Newbie Tech
  1. Injector Flow testing?
  2. Finally pics of my $2500 trans am - yeaaaaa
  3. Bloomfield Compressor?
  4. Ported LS6 heads, w/o cam or TC??
  5. Air lid question
  6. Hello. New here with power question
  7. DIY RamAir Hood = Hydrolock?
  8. 241 heads? Any good?
  9. polishing is it a wast of time?????
  10. Help!! TSP code and O2's
  11. so i just swaped out my cam and need help!!
  12. GM Ls6 intake on 241 2000 ls1
  13. How to reset Change oil light?
  14. Opsu???
  15. Serpentine belt
  16. newb- asa ls1 questions- heeelllllppp!
  17. cam with stock pistons?
  18. HI, Newb here.
  19. Would like some feedback =D
  20. Soon to be Ls1 owner.
  21. time slip
  22. car lag
  23. Have 4000, need 400-450 rwhp
  24. m6 with 2.73?
  25. Ignition problems, I think?
  26. doing my first cam swap need help
  27. Cam question
  28. bolt ons for a 5.3
  29. WS 6 Mods any Advice??
  30. Cruise control?
  31. Help pulling radiator on 2004 GTO
  32. Stand alone harness conversion.
  33. legroom question
  34. Just picked up an ls motor have a couple questions
  35. Cayenne Metallic Red Camaro 4,300 Miles
  36. t56 transmission question
  37. camaro i looked at had painted fender bolts and hood bolts??!?!
  38. which hood
  39. Looking on some parts..
  40. switch oils?
  41. MagnaCharged GTO Headers advice!!! HELP
  42. 69 camaro ls1 motor mount conversion
  43. Questions about the God under my hood?
  44. An Exhausting Question!
  45. Oil Pan Gasket
  46. ls6 cam, intake
  47. New Oil pan, what filter??
  48. Best Performance Option for LS1
  49. where install oil pressure gauge
  50. Should I get a high-flow cat?
  51. New SS owner with some questions
  52. LS1 Carb setup for '69 Camaro
  53. 90mm throttle body. Need new manifold?
  54. HID install
  55. 4L60E remove and install on 2000 camaro ls1
  56. Gasket set question
  57. WS6 Ram Air Turbo
  58. Front headlights keep going out WTF!!!
  59. Need some buying advice
  60. LS-1 pulleys w/o A/C or powersteering.
  61. My first LS1, 02 ws6.
  62. Should I get full coverage on my camaro?
  63. air bag light
  64. OK, what to look for
  65. turn signal control switch
  66. V6 transmission into my Formula?
  67. would this be a good buy
  68. "A true SS is a Z28 that came out from SLP" True or False ?
  69. ? power steering:(
  70. B&M Quicksilver shifter on 4L60E
  71. Rear End Gear Help, Please
  72. Fluidampr installation on LSX engine?
  73. Is there such a car as a 98-02 hardtop Trans Am or WS6?
  74. newb question on voltage drop testing
  75. my new ride
  76. Dead spot help
  77. Ram Air Questions
  78. Cam install?
  79. special way for balancer to go on?
  80. How to tell if it's a true slp car?
  81. Catch Can Pic
  82. Hello, Glad to finally get an LS1!!
  83. Can i sawp coils?
  84. power steering hooked up right?
  85. muffler thats a x
  86. stall speed selection...help needed
  87. How to tell if its a WS6?
  88. torque arm mounts
  89. Formula or Firebird??
  90. Hatch Swap
  91. Driver Side Window Problem
  92. Help and guidence with my Build
  93. Camaro acting extremely wierd.
  94. Help me choose my next mod!
  95. piston swap/head question
  96. LS1 lokar dipstick question
  97. alternator..
  98. more pics of TA
  99. I am impressed. Need a little assistance here.
  100. new ride
  101. Headers and Y Pipe Question
  102. My first vid
  103. stock cats price?
  104. Headers (New to the LS1 scene)
  105. Oil pressure
  106. torque converter recommendations
  107. Normal temp on ls1
  108. need help picking an engine 07 ls2 or 08 L76
  109. *STOCK* LS1 Dyno Numbers POST! (Do A Search)
  110. RevMax converters
  111. lq4 starter
  112. Trader rating???????
  113. Odometer Question
  114. 4th Gen F-bodies. Is there a best year?
  115. It feels good to be back
  116. soft clutch
  117. cam help
  118. Race Gas
  119. Rear end replacement help.
  120. how do you remove the fuel line from the fuel rail?
  121. ever used a metal lid?
  122. transmission..gear?
  123. What's this wire?
  124. Your thoughts on ported TB?
  125. New LS1 Owner, bit o advice needed
  126. Help me spend my money...lol
  127. cam and head set up
  128. EGR/AIR Delete
  129. What arp head botls are these?
  130. Trans Am bird rear decal
  131. Info about my Stage 3 SLP ?
  132. Help Me Decide
  133. in the market
  134. 85 mm maf ??
  135. B.C.M. Problems?
  136. Start of a swap/build
  137. 92mm fast instake manifold on ls1
  138. Need help on putting my ls1 in!
  139. oil pressure
  140. 1998 z28 or ss?
  141. power Steering fluid in my coolant???
  142. No carfax requests on this site. Please see sticky above.
  143. metal hooks
  144. N/A vs. Nitrous
  145. Alternator
  146. price opinions on some cars i'm looking at?
  147. Newbie 1st time LS1 build
  148. New LS1 Trans Am Owner with a problem
  149. New ls1 owner...Finally!
  150. Need advice quick!
  151. Possible to replace Oil Pressure sending unit WITHOUT intake removal??
  152. LT header install questions
  153. Camshaft Advise?!?
  154. Where are you guys getting Ozite carpet???
  155. Ignition Issues
  156. MTI lid??
  157. SS Hood help
  158. Newbie with a WS.6
  159. Engine stand ?
  160. AMSOIL vs. K&N
  161. I need info on this turbo kit please!!!
  162. Newbie tech for a reason, H/C/I help!
  163. am i getting a good deal??
  164. 2001 Trans Am WS6 vs. 2001 T/A
  165. Exhaust Help!
  166. Quick intake question
  167. what other oil pan for L92?
  168. e-cut out help,
  169. ls1 help?
  170. What do you guys think of this setup !?!?
  171. Intake Question
  172. Best bolt ons on a budget
  173. ls2? 07 trail blazer ss motor.
  174. OL/CL question
  175. ls1 conversion
  176. Is it considered
  177. Running Rich?
  178. Factory LS6 WS6s?
  179. cats vs ory?
  180. dirt fell in my heads!!!! help!
  181. Dead battery
  182. How low can you go?
  183. first time spark plug replacement with headers
  184. Lower end rebuild
  185. powersteering fluid leak!!
  186. 12v plug in
  187. why #7 piston break? help!!!
  188. LS2 overfilled oil 8 quarts
  189. What Size Are My Heads?
  190. What wheels are these?
  191. Gas Mileage? Reliability? for Heads Cam LS1
  192. Redirecting Floor Heat
  193. 2000 LS1 Camaro: Looking to invest 2k in mods...for now
  194. My first ls1
  195. LS1 Purchase Questions
  196. Dont laugh nitrous question
  197. nitrous install directions?
  198. AIR vaccum tube underneath fuse box
  199. Buying advice
  200. Strange Clutch problem
  201. New to muscle, convert.
  202. Bore and stroke L-92
  203. lq4 and ls1 swapable parts.
  204. LQ9 price?
  205. broken studs!!! help
  206. Need help on compression tester
  207. Got a LQ4, now what next???
  208. ls6 cam would be ok for an stock ls1?
  209. i got a question about the unlock button on the clicker.
  210. Camaro sideview mirror question?
  211. Formula / Trans Am shopping
  212. 11.1-11.3 mild heads/cam?
  213. newbie valvetrain question
  214. underhood clean up
  215. 02 Ls1 cam in a 5.3l ECRB 4wd Silverado?
  216. Thermostat
  217. Which Grind?
  218. which muffler to use on ORY
  219. Looking 4 A Good Site To Buy A Yank 3600 Converter
  220. How to tell SLP Ss
  221. probally a dumb question
  222. need help with my lid
  223. To Build or Not to Build
  224. Needing advice on a cam for my trans am ws-6
  225. MAF wires
  226. ls1 to ls2 or 243 heads??
  227. Noob LS question on DTC and PCM
  228. headers coming soon!
  229. Help to build LS1 from Camaro
  230. Almost salavaged my car last night :(
  231. Length Question
  232. motor question
  233. Dimension
  234. LS6 heads question
  235. Engine info?
  236. 2 sound questions (exhaust) (cam)
  237. need help asap!
  238. MAF Exchange, "service engine soon light"
  239. ways to get more horses oout of my ls1
  240. going to look at a z28
  241. Best Hedders for 98-02 LS1 TransAm/Camaro????
  242. exhaust cme question?
  243. cant post FOR SALE
  244. LS1 Buyers Checklist - What to Look for on the Lot?
  245. Motor plate
  246. Quick Question
  247. Need some help for a new LS2 owner
  248. New to ls1. PLEASE help me!!
  249. Engine Swap??
  250. Powe steering??
