View Full Version : New LS1 Owners - Newbie Tech
  1. Metal or plastic gas tanks in LS1 cars ?
  2. Donuts in rain?
  3. What D.A ??
  4. What ios DOD, AFM, VVT
  5. Driveshaft question
  6. 5.3 intake swap?
  7. spark plug threads
  8. 5.3 accesories swap
  9. determining desired stroke - is this a good place to start?
  10. Torque Converter = More RWHP?
  11. Head/Cam Combo...
  12. ideas for hp gains on a ls1?
  13. stay away from cprracing.com they are a scam
  14. Help with a part ID.
  15. Looking for a place to buy A.I.R & EGR blockoff kit
  16. Help crazy things going on
  17. Not LS1, Intake leak.....
  18. LS1 Aluminum Heads Fit On 5.3L?
  19. engine block swap from ls1 to lsx shortblock - what parts can i theoritically keep?
  20. Lucas oil stabilizers
  21. 02 ls1 won't maintain idle after hitting rev lim
  22. ls1 runns rough
  23. does e85 make more power than 92 octane
  24. what to get next????
  25. tansmission swap
  26. how does a stall work???
  27. 2000 Z28 vs 2000 SS factory horsepower
  28. Just getting into the LSX scene
  29. posting question
  30. CEL...again
  31. O.D. of stock Y pipe? And recommend a new one.
  32. just got a 2000 z28
  33. safe to go full throttle cam only car no tune?
  34. quick question....headlight bulbs...
  35. How long will an LS1 last?
  36. Any Ideas???
  37. how does this setup sound?
  38. Low trap speed
  39. Why is my trap so low?
  40. Trying to see...
  41. Heads/Cam for SC LS1
  42. ported heads???
  43. ls6 parts for ls1
  44. What does it mean to hook?
  45. Injectors?
  46. Catalytic Converter Replacement?
  47. Can anyone confirm this please?
  48. Is this right?
  49. LQ9, Worth it?
  50. 2007 5.3l with 862 heads?
  51. So I shredded my stock driveshaft at the track yesterday...
  52. Questions about ls6 yellow springs.
  53. water pump question
  54. 13:1 compression
  55. not really a newbie but need help with an oil leak
  56. need help, what is this part called??
  57. paranoid n00b (o2 sensors)
  58. Heat shield removal?
  59. Am I Lowered?
  60. Support brace for exhaust pipe
  61. Newbie with O2 questions
  62. Beginner's Setup Help
  63. Ebay headers and ground clearance
  64. What was GM thinking ??
  65. Oil pressure drop
  66. Will it fit???
  67. Header Studs
  68. does a F body flowmaster muffler flow better then a stock SS muffler?
  69. newbie needing advice on a cam
  70. Ported tb/bumpstop mod cause issues with car at wot?
  71. LS2 build
  72. Security Light Haywire
  73. tranny making sqeeking noise - any ideas???
  74. advice please
  75. What is this intake from?
  76. t/a question
  77. truck intake help
  78. Is the corsa pro-series 4" ..product 14148 really worth $1000.00
  79. PLEASE HELP! Pulley/belt squeek I cannot solve
  80. Clunk in A4
  81. How & where is the HP?
  82. Frosty/wet windows
  83. Wheel Spin Feeling on Highway
  84. newbie help on connector identification
  85. "check gages" light is on, what does it mean
  86. MAF Interchange Questions
  87. my 99 z28
  88. Fuel Feed Line
  89. Another Newby Mistake
  90. how to ls1 to ls2
  91. cutout gains.
  92. 5.3 help?
  93. cme question
  94. borla exhaust question
  95. LS6 vacuum ports advice
  96. x pipe??
  97. Which engines will fit in a 94 firebird and with what modifications?
  98. I need hp!
  99. What should I look for? Buying help...
  100. Nitto Fitment Question
  101. Rear Shocks
  102. Flowmaster
  103. Tune results after first mods
  104. duration-PVC
  105. Need advice on car.
  106. Think I fixed my cars studdering!
  107. Battery dead on '98 Z28
  108. Part throttle flat spot in torque curve between 2500-3000rpm
  109. 243 with stock cam questions
  110. Autometer c2 gauge ?
  111. Newbie needs LS help in Tampa
  112. Ls2 intake ?
  113. headers???
  114. Car started having problems (misfires and almost dies at idle)
  115. LS1 second hand value and parts needed for swap to another car?
  116. what GM PN to get rid of cruise control on LS1 ?
  117. o2 sims make car run bad
  118. Can my headlights be fixed?
  119. Torque spec write up? 98-02
  120. Crackling sound coming from engine when running higher rpm's
  121. help please new clutch install
  122. What motor mounts do you use?
  123. i just got a 2000 ss and having some problems
  124. TB coolant delete question
  125. Removing pilot bearing
  126. Suspension?
  127. high flow cats..newbie be nice plez lol
  128. camaro seat question
  129. Lq9 lq4
  130. Car feels like it's misfiring/ Banging y pipe?
  131. ls1 info
  132. My First LS6/LSX Need help on parts
  133. Spark plugs
  134. Weird nose coming behind dash/under hood when it rains
  135. How to tell a z28 from a SS
  136. Performance tuning - Expected results and is it necessary in my case?
  137. Christmas Shopping Early--Help
  138. exhaust install
  139. Does my tb blade look ok after bumpstop mod?
  140. What is "high mileage" on a LS1?
  141. Quick Question
  142. 98-02 v6 camaro to an LS2 question
  143. How to tell if I have a vett engine in my TA
  144. Oil pressure gauge ?
  145. Ebay Exhaust Tips
  146. torque spec on the 2 horizontal, 13mm bolts from bellhousing to oil pan?
  147. 5.3 nova
  148. help finding this hood
  149. a4 launch
  150. quick question...about these headers
  151. ported heads
  152. Post pics of bumpstop mod please
  153. Need help fast
  154. need help with flywheel bolts
  155. Stall ???
  156. My new Z
  157. Alittle Consultation Please
  158. is my waterpump going out?
  159. buying a gto question
  160. gas guage
  161. types of steel
  162. WTF: Weird throttle response...
  163. facts about 317 heads
  164. Couple Questions...
  165. Different kind of octane question.
  166. lids whats the diff betreen a stock and aftermarket
  167. how do i rip my back seat out?
  168. are lq4's the "same" as ls1's?
  169. royal purple oil ?'s
  170. dying rearend?
  171. Tune+stall
  172. 15 inch rims
  173. camaro advice
  174. hey guys is this normal or not??
  175. Is buying a higher mileage LS1 a bad idea?
  176. TR55's or TR6's on mostly stock car?
  177. is an alignment needed?
  178. 10s or 11s?
  179. Need help and parts
  180. Lid question
  181. Should I keep, part out, or sell my car? Or engine swap from a 215K V6?
  182. shaking and change of tone with exhaust!
  183. SLP Lid question
  184. Stripped Oil Plug
  185. SLP cold air intake
  186. Intake questions
  187. I'm getting FRUSTRATED!!!!! PLEASE HELP!
  188. Oil Pressure
  189. ls1 to ls2 swap
  190. what do you guys think
  191. changed oil, now "oil change light" comes on?
  192. Dyno disappointments HELP!!!
  193. Ls1 swap
  194. Water Pump Fittings
  195. Question!!! Is this normal???
  196. drive line noise
  197. Oh no, tick,tick,tick. Time for new engine
  198. SS parts
  199. New motor time
  200. More newbe ???'s
  201. Oil Pressure
  202. X or Y pipe? Long or short headers?
  203. Stock SS catback $?
  204. what to do next....?
  205. need help wont let me post anything
  206. Suspension Questions need help!
  207. need advice
  208. 00 WS6 stock heads?
  209. where should i post this?
  210. Throttle Body EFI question.
  211. 99 Pontiac formula?????????
  212. o2 sensor question, LS1 camaro problems
  213. Long Tubes VS Shortys
  214. Can you clean the IAC valve?
  215. 24/58 Reluctor question
  216. Window net question and harness question
  217. Help needed. Car won't downshift
  218. OK, need help.. Set me straight... LQ9, L92, & INTAKE
  219. driveshaft play?
  220. Someone please explain about Ratios
  221. oil change light on?
  222. convert power to manual?
  223. new
  224. Is this a good deal?
  225. List of Motors with hp, year, abbr., vehicle, etc
  226. HElP/ Radiator/ Rear Main Seal
  227. what you guys think? good deal?
  228. What TB to buy?
  229. newbie???
  230. vac booster hose to intake connection?
  231. Where can I get an LS1 tech sticker?
  232. head combination help
  233. Any suggestions?
  234. Is this car a TRUE Lingenfelter??
  235. MAF Sensor
  236. Help!!!
  237. Car Idles weird after Ported TB install
  238. o2 question
  239. How much of the LS1 donor car can I use?
  240. Newbie Hp/ Quarter Mile
  241. Engine temperature question
  242. Flywheel balanced????
  243. HP guesses with giggle gas
  244. 4l60e preformance questions
  245. ls6 HEADS? good or no?
  246. C5R Heads - Need Valve Cover "Gasket"
  247. Ls6 swap questions
  248. best headers
  249. need some advice on performance
  250. valve train noise?
