View Full Version : New LS1 Owners - Newbie Tech
  1. shifting.....
  2. dyno help
  3. bhp vs hp
  4. vinyl decals
  5. Questions about rust, emissions and mods on a 2000 Trans Am
  6. SLP Cat back touching exhaust..will it melt?
  7. High RPMS in 5th
  8. Custom cam grind with yellow ls6 springs
  9. need help.. loss of power at high rpm.
  10. Inner door plastic crap
  11. Identifying a motors year and vehicle
  12. beest mods to improve MPG?
  13. Left indicator not working
  14. Rear ends 3 or 4 channel
  15. Radio help
  16. crank gear seated fully?
  17. Opinions? What's Next?
  18. Just ordered a Loudmouth!
  19. Trying to find out info on Crate Engine
  20. cost Carbed LS vs EFI
  21. Which engine to get? Many questions....
  22. Almost a costly mistake 04 GTO
  23. Bolts-Ons
  24. LS6 intake question
  25. 98 Z28 for a 00 WS6
  26. Reusing stock metal spark plug boot heat shields with headers BAD IDEA!!!
  27. newbie
  28. Misfire and car won't down shift
  29. Hose to no where
  30. size pushrod??
  31. uh, should I tell this guy his camaro is waaay overpriced?
  32. Picked up a 1998 SS Camaro... few questions
  33. ls1 rod bolt ????
  34. LS6 Springs
  35. looking for stock ws6 springs f+b
  36. Headers + K memeber
  37. engine cleaning
  38. sea lvl
  39. what should spark plugs be gapped at?
  40. injector question
  41. Do i have Tcs??
  42. XS headers?
  43. ported/de-screened maf
  44. Oil question
  45. problems with ported throttle body
  46. security light?
  47. Price quote for some rims..
  48. Torn seats,what is my options?
  49. over torqued flywheel??
  50. Soldier coming home from deployment needs help on purchasing vehicle!
  51. spark plug diagnosis please help
  52. Lq9 same as ls2? Also looking for some heads.
  53. 99 ws6 worth it?
  54. Storing my SS
  55. Lifter Trays?
  56. Economy help needed...
  57. Tranny Mount
  58. Newbie cam question
  59. ls2 swap
  60. Real SS or not ?
  61. Cut and Paste Exhaust, need help
  62. Arh
  63. need guidance hooking up 3 gauges
  64. Underdrive pulley question LS1
  65. GMMG, mod to accept TD?
  66. Do I need a tune after ported tb install?
  67. '79 Motor mounts, HELP PLX
  68. Best size for my I pipe?
  69. Triangle Pillar cover
  70. help lost just dont know
  71. 2000 6.0l
  72. Intake Manifold
  73. Need help to the right direction
  74. What should it run??
  75. Rear o2 sensor question.....
  76. Do the tb bump stop mod or not?
  77. sensor heatsoaking?
  78. Sos need help asap
  79. Front Brakes Dragging
  80. 98-02 Firebird Differentials
  81. power steering delete
  82. Casting numbers/part numbers???
  83. Open headers?
  84. Temp guage moves
  85. How far to push in clutch with racing
  86. 427 in a ls1???
  87. LCA and PHB hardware.....
  88. best way to protect wires from header heat?
  89. Fernco coupler
  90. budget 400rwhp build, HELP!
  91. WTB: Door Panels, Where?
  92. I need advice
  93. Which parts are unsprung weight?
  94. Looking to get my tb ported. Who does them?
  95. Swap out 00 parts with what 02 parts ?
  96. Pros and Cons of Exhaust systems
  97. 1999 Trans Am non-WS6
  98. newbie needing help
  99. Newb question on air lids
  100. Smog Question
  101. tranny match up
  102. how to gain more power
  103. 6sp new rear 4.30 or 4.57
  104. M6 Grinding 1st and 2nd gears at 1st start
  105. Is this a good tuning price?
  106. forced induction
  107. Shifting early
  108. my lt1 project
  109. LS2 6.0L aluminum block???
  110. 515HP build
  111. o2 sensor question with Hooker LTs
  112. LS1 Carb.
  113. Window off track?
  114. Car overheating while running a/c!?
  115. Show or go? What first?
  116. What is a 6.0 LQ9?
  117. what to do
  118. Mid-Low 11's..how tough is it?
  119. LS1 Engine Drop
  120. need help fast on pinion angle
  121. How to remove the heater hose lines
  122. New to GM..
  123. Blue smoke!
  124. TSP Rumbler installation
  125. guys i need ur advices
  126. new to the ls1 world.
  127. HVAC Condenser Question
  128. Got a question about the new 2010 camaro SS's
  129. LS1 and transmissions?
  130. 2001 Z28 Convertible Top Question
  131. Help please
  132. Gas Cap
  133. How do i remove the plastic piece on the back of a ls6 intake?
  134. Ls6 intake
  135. Throttle Response?
  136. secondary A.I.R. system?
  137. Were to find these stripes?
  138. 99 camaro A/C works but air coming out is warm?
  139. Tranny ?'s
  140. rear question?
  141. how to fix my speedo
  142. A lose cable!
  143. thumpr cam
  144. Low Temp Thermostat
  145. slp cold air kit vs slp ram air kit
  146. Quick Catback Question
  147. How far off will speedo be?
  148. LQ9 price?
  149. 2.73 to 3.42? Worth it?
  150. stock y pipe hangs
  151. New car
  152. How May I Modify My LM7 Engine ??
  153. 120
  154. Changing Fuel Filter Problem
  155. Anyone know CA smog limitations???
  156. just an idea
  157. ls6
  158. hub assembly questions. f-body vs vette
  159. iat sensor check engine light, after installing slp lid
  160. header size?
  161. whats a decent price for a ported stock throttle body
  162. ls1 crank pulley bolt
  163. Still more stall questions
  164. My tunner told me he can't tune 98 ls1's true?
  165. interior light question
  166. trouble installing LID
  167. Good receipte for ~500whp LS1
  168. homemade relay box
  169. 02 sensors question
  170. What needs done?
  171. few questions about my new Z28
  172. Ram air... Does it work or just for looks?
  173. Can't get Oxygen sensor heator monitor to set
  174. Stall and cam dilemma
  175. key fob
  176. Fuse box Question
  177. Engine Build Question? Long Read
  178. should i buy this 10 bolt?
  179. NOOB shifting RPM ?
  180. New to the LS1.....
  181. what are the problems that can come with free ram air?
  182. Squeezing 350hp ?
  183. What gears and stall to get?
  184. newbie ? bout torque arm removal
  185. Ls2 engine harness questions.
  186. Stock 3.42 Rear Questions
  187. Does LS1 bolt to 700r4 transmission
  188. Header types
  189. Reverse / Backup Bulb Help
  190. Light motors NEED Advice
  191. Vaccum lines!?
  192. just installed SLP lid, trans is rough
  193. Camaro clear signal lights
  194. Exhaust banging on Crossmember
  195. Clutch or Gears?
  196. ground behind the head?
  197. hmmmm, L92 or Ls2. HELP!
  198. LS1 piston slap issues.
  199. Don't know what to do with my ls1!!!
  200. L33 - Trans options?
  201. Frankenstein motor/car - Which factory service manual do I get?
  202. How many Cat(s) on stock exhaust?
  203. Lookin for some sweet thunder mufflers for my WS6
  204. A/C Issues, need advice
  205. gto torque thrust?
  206. Dropping a Cylinder
  207. How many miles..?
  208. WS6 Hood Struts
  209. new to forum
  210. What year head gaskets to buy
  211. looking to put down 400rwhp
  212. Exhaust talk!
  213. Should I be concerned about buying an 80k mile car?
  214. Did the 2000 SS come with ZR1 chrome wheels?
  215. ls7 clutch disc?
  216. Volant Cold Air Intake
  217. knock sensors
  218. 317 head question for FI
  219. goin from a 98 ts rear end to 02 WS6 rear end
  220. Angel eyes hid bulbs?
  221. off the line?
  222. ls6 intake manifold
  223. Help, all my seatbelts have stopped working, WTF?
  224. Whats the weak link ??
  225. Best tools to change spark plugs?
  226. LS2 into LS1 camaro swap problems
  227. Fuel Pump replacement on a 1995 Trans AM question.
  228. Why won't the fuel stop flowing?
  229. Oil pan template.
  230. Build and price, whatcha think?
  231. Is my problem VATS??
  232. Need HELP! Gabriel Air Shocks
  233. 87 ok or 89 needed ?
  234. fuddle 3600 stall
  235. price of menike exhaust sytstems
  236. ls1 swap }{ ls1 swap ls2
  237. What size is the crank pulley bolt?
  238. New to ls1tech. Looking for ls1 performance help.
  239. Rebuilding LS1 after spun bearing, how to clean parts?
  240. Torn btwn selling the Cobra and buying a Ws6
  241. borla exhaust question
  242. Valve cover compatibility question
  243. Compatable with FIPK
  244. Possible Bad Cat
  245. mileage....
  246. What heads for MTI X1?
  247. power steering pumps
  248. so i offered this guy
  249. tps loses referance
  250. What kind of Heads?
