View Full Version : New LS1 Owners - Newbie Tech
  1. What kind of Heads?
  2. I want to be in the low 12's high 11's all motor no spray, Is it possble???
  3. Check engine light came on
  4. Setup question
  5. LS1 w/ some rust - advice on machining
  6. Intro NEW HERE!!!
  7. my 2000 z28
  8. Part Number 04 Ls6 Intake Manifold
  9. I need drag slicks!
  10. problems installing MTI clear lid
  11. question about exhuast systems
  12. Location Air Pump?
  13. Swap harness and PCM ?
  14. Magnaflow Bullet direct replacement for LM1
  15. thinking about a 408
  16. EGR removal ONLY (right now)
  17. Brake light grounding fault?
  18. Are all aftermarket throttle bodies the same?
  19. new mods for new guy
  20. cam only?
  21. Newb Question about a cam and heads
  22. 02 camaro PCM fuel pump relay
  23. it woundnt go into gear???
  24. drag truck
  25. ls1 ps pump work for a c5 pump?
  26. maf question
  27. Damaged 6.0L advice, please.
  28. Whats wrong with my car?
  29. back again
  30. Were to find trq. specs on a 6.0?
  31. converting a ls1 camaro to a regular SBC carbed motor
  32. open headers?????
  33. continuation of "just burnt a GSX-R"
  34. which heads to go with? (gota pass CALI smog)
  35. A little help on whether or not I should buy this car
  36. weird noise
  37. LSX/L92 Valve Spring dimensions needed
  38. A/C and Diff questions
  39. rear end
  40. Confused and down after my track passes..help please!
  41. Parts for header install
  42. Heat and AC
  43. Could this MAF be the culprit? Please read!
  44. what is a firehawk?
  45. more CU from my 5.3
  46. best cam for stock heads?
  47. ASR acting up
  48. FTRA and cut-out questions?
  49. LS1 Build Project for a capable noob
  50. 5.3 0r 6.0 vortec?????????help please
  51. whistle and clueless noob
  52. Gear ratio and RPM's
  53. Ported TB question
  54. 02 sensor going bad?
  55. Anyone have codes after mail order tune
  56. Help, need link to switch out ignition lock and blinker switch
  57. bottom end question
  58. So when you delete...
  59. anyone here wana guess
  60. cleaning heads
  61. Lifter preload?
  62. dexcool
  63. Reading Spark Plugs
  64. I have a basic mechanic question....
  65. ls1 motor mount clamshell ?
  66. Help need to pass emissions!!!
  67. low coolant light on?
  68. Catback vs. muffler only
  69. what would you do?
  70. Need radiator guidance!!!
  71. fuel pump question
  72. 8psi on a 10.5:1 motor?
  73. What makes arp head bolts better than gm?
  74. Why is my center console so hot...
  75. Bought a Trans Am, Noob needs help...
  76. 2000 trans am a4
  77. need help! 98 camaro ls1
  78. 2005 gto 6.0
  79. Just got a LS1 Trans Am (Couple of questions)
  80. roller rockers
  81. Wheel size question
  82. lost power in my ss camaro(help)
  83. New to LS life.
  84. Replacing Rear Seat Belts
  85. Cam Problem
  86. i need help!!
  87. epoxy piece recall?
  88. need some advice
  89. 2 questions. help me out.
  90. Which F-Body To Get??
  91. Dex-Cool?
  92. How can you tell if your LS1 has an aftermarket cam in it???
  93. 3 or 4 Channel ABS for New Rear??
  94. Good Deal or Not?
  95. Port and Polish stock 853 heads?
  96. Speedo is WAY off
  97. 97 t/a
  98. Jack Stands
  99. Fbody w/auto stock driveshaft length?
  100. LQ4 6.0l question
  101. ls1 heads on 5.3?
  102. what
  103. Just bought first LS1...do these times sound right with the mods...
  104. Injectors
  105. T56 suggestions
  106. How much would a tune help?
  107. what to do with engine
  108. LS1/Fbody gurus step inside, i have a mission!
  109. Open exhaust manifolds
  110. Car starting problem
  111. tb bypass
  112. service engine soon light came on today
  113. What godawful noise did my car just decide to start making??!?
  114. How do you fix the 02 issue???
  115. small filters on AIR pump?
  116. How much would I gain from this?
  117. newbie question.
  118. Cold Start Belt Squeal
  119. How many miles do I usually have left to travel once my CHECK GUAGES light comes on?
  120. 92 s10 Ls1 project
  121. whats wrong with the exhaust?
  122. How does a 4 cylinder keep up with a V8??
  123. Tensioner pulley a difficult fix?
  124. speedometer question
  125. Water Pump on 5.7L
  126. Complete DIY's on starting, charging, engines, trannys, etc.
  127. Trans rebuild/rear diff.
  128. Plugs, wires, heat shields.
  129. Tranny and motor mounts???
  130. Catalytic converter??
  131. need help on installing an autometer guage.
  132. why do I have horrible times?
  133. Why cant I reply to classifieds???
  134. coast to coast trip question
  135. Here she is! Thanks to all that helped out.
  136. What is the filmy streak on the windows?
  137. Question on Stock shocks and Springs
  138. MAF causing shifting problems???
  139. New here, Looking For Cat Back Exhaust Info
  140. Complete DIY's on starting, charging, engines, trannys, etc.
  141. Speedometer not working...
  142. How Do you test the coil packs ?
  143. 2001 SS A4 4l60e not downshifting right PLEASE HELP!!
  144. stroker rotating assembly for LM7
  145. custom build mid-engine
  146. lid question
  147. is this camaro worth it
  148. Where is ASR located on a 2000 Z ?
  149. performance chip worth it?
  150. Correct fuel pressure reading?
  151. ls2 402 stroker- high oil consumption
  152. Sequential tail lights? Anyone know how to do this? Video inside!
  153. Rear-end products
  154. PRC Stage 2.5
  155. confused on intake.....please help
  156. How to Find Build Number.. Search didn't help
  157. newbie question
  158. not new to LS1's
  159. what oil?
  160. Overheat questions
  161. Is a ported tb worth 100.00 and...
  162. Lid vs. CAI setup?
  163. I have a few questions
  164. whats the first step?
  165. how much can i expect out of a programmer
  166. bassani or borla xr-1 or stay with flowmaster
  167. Your Exhaust Set Up
  168. 98 vs 99-01 programmers
  169. almost like manual valve body??
  170. tcs
  171. water methanol
  172. Went and looked at a 02 SS for sale
  173. What next?
  174. Crank Pully puller
  175. Please identify this device...
  176. Question on Ls2 motor and trans from vette
  177. 160* stat
  178. intake question
  179. cam question
  180. keys in the car
  181. Predator Tune improve MPG?
  182. Symptoms of bad PCV?
  183. Can I add GM keyless entry to my 2000 NHRA Formula
  184. 853 stamped on head
  185. Valve spring help
  186. seat belt retractor
  187. Pros and cons on a 98 LS car vs a 99-02
  188. LS6 intake porting
  189. just got a ls1
  190. headers
  191. ls6 heads
  192. What to cover when cleaning engine ?
  193. Bad Lifters. How long?
  194. Behind stock grill
  195. Fast 92
  196. seafoam question
  197. ls1 tuning
  198. Swap a 5.3 Vortech Intake to a LS Intake - Worth the Hassle?
  199. ls6 intake ?
  200. Places and Prices to get rims Powder coated... Chicago Area
  201. Are headers actually worth it?
  202. How much to be gained with just ported 241 heads?
  203. C5 or Camaro? Need some advice
  204. Smooth Bellows
  205. Question on installing LTs and ORY
  206. Moroso Spiral Flow muffler rant
  207. free ram-air mod
  208. Where to tie into for a vaccum gauge??
  209. 98 SS worth $$$???
  210. Keep getting service engine light since header install!!
  211. fuel injector size??
  212. Camaro ls2 402- engine smoke concern...
  213. changing the air filter
  214. Removing the plastic grill up front is it really worth it?
  215. 6.0 oil pan on an ls1.. will it work?
  216. Overheating camaro ss
  217. Help!
  218. How do you guys clean your intake manifold?
  219. SS Hood
  220. hydraulic roller?
  221. rebuild cost?
  222. Whats the best stall for roll racing?
  223. Pop in Rearend
  224. Spoilers
  225. Giving a 240SX some balls
  226. Will Poly motor mounts fix my banging Y pipe??
  227. Chasing a vacuum leak
  228. New to LS1 tech
  229. Used Car warranties
  230. How do i disconnect the fuel line from fuel rail?
  231. 02 sensor
  232. what to do about long studs for stock wheels
  233. How much would you pay for a 00 ss camaro?
  234. please help real quick
  235. oil pressure after my oil change.
  236. Electrical Wiring
  237. Help me pick headers
  238. Best place to buy a used PCM?
  239. 10 Bolt rebuild or 12 Bolt replace??
  240. Vararam vr 3? does it work or waste of money?
  241. Broken radiator drain plug?
  242. Cruise Control
  243. Do most 2000 A4 z28's have 2.73 gears or 3.23?
  244. LS6 Engine management
  245. 5.3 question
  246. Soo many questions, any answers?
  247. wat to buy next
  248. hello everyone.. just bought an 00 ss camaro.. few questions from a muscle car noob
  249. help
  250. help
