View Full Version : New LS1 Owners - Newbie Tech
  1. EGR code from exhaust leak?
  2. Tuning help on new cam and intake...
  3. Fans won't shut off/AC doesn't blow cold
  4. OEM parts
  5. Escalade Help
  6. 2001 5.7 ta problems
  7. Oil - Electric sending unit for LS1 ??
  8. breather cap? mini air filter?
  9. New Horn.
  10. should i go a4 or m6?
  11. What is porting?
  12. tach not working
  13. bulding bottom end
  14. Starting engine with no 02 sensors?
  15. motor/ tranny mount question
  16. another newbee question
  17. there is some kind of clicking nosie
  18. 385 to 427
  19. 98 ls1 ?
  20. parts ordered
  21. reuse ls1 main cap bolts?
  22. are my pushrods too short? *vid inside
  23. Installation considerations LS6 Intake
  24. Why are there flames from the exhaust?
  25. Intermittent Starting problem
  26. Cam Question...
  27. ms4 cam power numbers?
  28. So I just bought an aluminum 5.3 out of 2008 silverado
  29. What ecm to use on my ls1
  30. clinking?
  31. Rebuild or not?
  32. Hows my mod?
  33. no fans after ac removal
  34. ls1 timing chain
  35. 5.3 wiring harness
  36. Tune up success but....
  37. Stock thermostat
  38. oil pump question
  39. intake bolt length and thread
  40. Magnaflow catback.
  41. coolant temp sensor
  42. Engine operating temperature
  43. Rotating top water pump outlet
  44. how to check timing?
  45. clutch line removal
  46. Fans arnt turning on :( help
  47. please help why is my car reving up?
  48. Battery Clamp
  49. PORTED 75mm OR 80MM THROTTLE BODY
  50. Bearings in oil pan
  51. Wtf gives man! My avatar?
  52. A.C dryer 2002 T/A
  53. Got a 99 TA today!
  54. Is there a best drop in cam only install?
  55. got my car put back together please help
  56. lowered car issues
  57. 99 TA lowering kit and Raptor hood
  58. 160 Thermostat?
  59. Im A Complete Newbie!
  60. Need some advice
  61. Newbie mod questions need help!!!!!
  62. Camshafts
  63. Newb question?
  64. whats this part called?
  65. Does anyone know what this part is??
  66. Help on best ideas for LS2 rebuild...
  67. Slp udp
  68. L92 swaps
  69. Vacuum leak
  70. What Shifter Do I Have?
  71. ls6 intake aftermath problem
  72. LS1 ppl
  73. buying a 01 ss camaro...
  74. ls1 buyers guide
  75. Motor mount ?
  76. Tell the difference?
  77. I need Tech Advice! Please!
  78. Buying a LS1 - Mileage question
  79. Need 400 hp. (camaro ss ls1)
  80. LM7 Intake Swap Questions
  81. newbie ls1 owner with some questions.
  82. car is leaning
  83. SLP Loudmouth question?
  84. ls6 intake queistion
  85. WOT TB only opening 84 %...
  86. 6.0L into 01 camaro swap help
  87. Bellhousing Bolts - 2000 LS1/T56 6spd
  88. Getting an F-Bod !!!
  89. 243's with big cam???
  90. Rear Diff. questions
  91. I thought I could resist...
  92. need help,
  93. swapping a ls1 harness in a lt1
  94. Strange noise coming from the engine
  95. Guage Cluster not workin :(
  96. Smog legal camshaft...California
  97. 408 Build or buy a shortblock
  98. Bracket for throttle cables
  99. change of plans need some advice
  100. budget build, needing some ideas
  101. I wonder...
  102. Buying a 99TA next week
  103. LS1 noob...Exhaust backfire??
  104. ls6 manifold problems
  105. oil question
  106. Which gauge?
  107. Oil change question
  108. Just got a free 5.3L...mod's
  109. newb question
  110. Newbie questions
  111. Need help!
  112. SLP exhaust
  113. oil pressure sensor
  114. Advice on mods
  115. Ls7
  116. Basic Tune Question
  117. Excuse my newbness please...
  118. ASP underdrive pulley question
  119. New guy looking for a power source (wiring)
  120. My LS1 Project
  121. Getting rid of the air injection system
  122. Installing my LS6 Intake
  123. Parts Catalog
  124. Might walk away with an LS1 Tomorrow
  125. What tool..
  126. Good deal?
  127. Bad lpp header vibration please help!
  128. lq4 vs ls1 head gasket
  129. ect's
  130. Noise at idle...
  131. List of Stock 1/4 and rwh
  132. Newbi with question!
  133. My first LS1...let the modding begin. Need opinions
  134. Finally got my camaro!!!! Pics inside
  135. The LS1 Is Here
  136. ok to drive?
  137. about to trade my stock dd z28 for a race car 490whp trans am...good idea or bad idea
  138. When switching from automatic to manual
  139. Advice when looking at a purchasing LS1 car?
  140. traction control noob
  141. help rearend ?
  142. Ls6 iintake mani installation question
  143. would u guys get this????
  144. Royal purple 0w-40
  145. CAM and A/C
  146. Ls quiz
  147. 6.0 block issues
  148. running car with no o2's
  149. How can i tell if my motor mounts are bad?
  150. headrest removal
  151. Swap started like a champ!!!!
  152. question 6.0 heads
  153. lq4 motor mounts
  154. Scatter Shield
  155. 5.3 vs 5.7
  156. Fixing My Speedometer
  157. v6 firebird mods
  158. little modifying
  159. door question?
  160. quick question
  161. bbk 80mm tb
  162. Plugs and wires
  163. SLP Smooth Bellow RIP OFF OR NOT!!!OPINIONS WELCOME!!!
  164. sub frame connects and susp questions
  165. LS6 Intake...Noob Question
  166. !!!newbie exhaust question!!!
  167. Best way to delete the MAF
  168. too much oil?
  169. MAF location
  170. LS1 in full view
  171. Not a newb necessarily, but have a few questions.
  172. Question!!
  173. anyone know if vfn still do 10% off for ls1tech members?
  174. Headers w or w/o EGR/AIR and motor mounts
  175. Yet another LQ4 question
  176. Many questions, need answers........
  177. engine number
  178. Need help, car boggin down poppin 02 sensor codes
  179. Engine problems....Help....
  180. A/C alternatives?
  181. heat shield...
  182. k&n air filter do i need the gasket that comes with it
  183. 137 & 157 tcodes - changed o2 a.cat bk 1 still probs?
  184. Problems with my car! Please help
  185. Battery relocation help handling?
  186. reall ss or not?
  187. Free mods?
  188. hesitation problem
  189. Foam on bottom of ls6 intake?
  190. New here and new car
  191. Headers!
  192. If you had...
  193. Quick Questions...
  194. Service Engine Soon.. Left AND Right bank running lean... wtf
  195. Trouble Code PO157 / BBH02S22
  196. EVAP... is it needed?
  197. Steering Wheel
  198. Mid-Grade in LS1s?
  199. Intake question
  200. quick question
  201. Due to firebird Values Which way to go ?
  202. Ls6 intake manifold
  203. Rear o2 question
  204. shorty hp vs long tube hp?
  205. genIII conversion using getrag mg5??
  206. Need help with enging blocks
  207. Open headers question, please help!
  208. need help choosing an engine for my buggy
  209. Please excuse the total Newbness of this question, but WTF is a spun bearing?
  210. 04 gto cylinder compression
  211. Little smoke at startup.
  212. 4l60e transmission help
  213. New to Forum...Need Some Help PLZ..
  214. Throttle Body on LS6 intake
  215. Mods for better gas mileage in 07 Tahoe 5.3
  216. Increasing compression ratio??
  217. Starting to mod
  218. Just got a 2000 Vette with dead LS1,what interchanges without mods?
  219. just got my ls1
  220. 6.0 performance questions
  221. spray or no?
  222. Bang 4 Buck intake ?
  223. noob here
  224. Whats the deal?
  225. Trans Mount Bad?
  226. window off the track
  227. 6.0L questions
  228. Hello everybody
  229. which fuse?
  230. virginia speed tuning
  231. chirping
  232. code p0107 but the wiring is ok
  233. 1.75 rocker arm ?
  234. Another oil pan question
  235. radiator help?
  236. AIR/EGR problem??
  237. cut it out!
  238. is the trans go shift kit easy to install??????
  239. 01 ta gear help
  240. ls2 intake on a ls1 ?
  241. Whats going to happen if i used hose water to mix with Dexcool?
  242. Where are the TORQUE SPECS?
  243. Smooth Bellows
  244. Trans go shift kit going to make my car chirp second?????
  245. Back on ,LQ4 RX7
  246. ASR and brake light keep coming on?
  247. Building Dry Sump system
  248. Can anybody help?
  249. new here
  250. First run at the track with my Formula...
