View Full Version : New LS1 Owners - Newbie Tech
  1. Building Dry Sump system
  2. Can anybody help?
  3. new here
  4. First run at the track with my Formula...
  5. Need help on shocks...bilstein or edelbrock ias monotube
  6. Pcv System
  7. Koni adjustable Shocks
  8. Need electric cutout placement advice quick!
  9. Ftra/ssra & jaam/sealed&debaffeled? ??
  10. So Annoying
  11. Need some help please
  12. Hose running in the side of SLP lid?? And Cleaning MAF
  13. 6.0 for LT1?
  14. Mechanic costs??
  15. open headers on stock manifold
  16. cam pvc question
  17. Noobie
  18. Couple of new pics of the new Formula
  19. First time at track
  20. powersteering pulley
  21. What brand for front o2?
  22. This a good deal? Will it fit my Trans Am?
  23. 1999 camaro
  24. noob question about lower air box
  25. LS6 Manifold worth it on stock LS1?
  26. Install university down..
  27. stock rearend build
  28. questions to ask when buying a use car
  29. Towing with a 1999 Z28 Convert
  30. Gear and mod question
  31. Heater hose problem anyone else?
  32. budget mods for now?
  33. supercharger
  34. Typhoon IM
  35. tune after free mods?
  36. Fumes in car.
  37. Bearing Dynamics - How Your Bearings Work
  38. #853 heads
  39. 5.3 questions/problems
  40. My 99 Z/28
  41. Destroyed my rear end
  42. 1st LS1 but which one?
  43. please tell me:98 steering fit 2002
  44. LS1 Pricing
  45. Drifting A4 WS6, what problems??
  46. launching...
  47. Starting Problems?
  48. gear change-tuning help
  49. ls2 clutch kit with a 5.3 and t56.. will this work?
  50. "rolling the fender"?????????????
  51. "rolling the render"?????????????
  52. noob question. fuel pressure and wires
  53. Jack stand on rear trailing arm mount?
  54. DD cam?
  55. To buy or not to buy?
  56. I remember buying my SS..
  57. Worth Buying?
  58. computer problems
  59. PCM Info
  60. HO2 problem
  61. Need help to fit my new zo6 rims on my ta
  62. Electric Cutout?
  63. Remanufactured A/C compressor
  64. losing charge
  65. ground behind driver side head?
  66. PCV Valve too breathers
  67. Oil Change
  68. aftermarket fuel injectors
  69. Wondering what the time would be
  70. harmonic balancer question
  71. Installed new manifold... Few questions
  72. who to tune my car? (mailorder, dyno, etc?)
  73. What kind of gain should i expect ?
  74. M6?
  75. Interior Panel Scratches
  76. Complete Bolt on List
  77. first time to the track thought it would be faster
  78. first time at the drag strip
  79. A/C high pressure line.
  80. Having sputtering issues since headder install
  81. Installed new bbk long tube headers
  82. slow ls1 240sx
  83. FUEL PROBLEMS, need advice
  84. Air Lids 2009
  85. n00b question
  86. which oil?
  87. 1999 camaro Z28
  88. Tuning out codes
  89. Oil Pressure is pissing me off!
  90. What part am I looking for to replace the wiper blade ~holder~?
  91. For the H/C guys...please post!
  92. Water temp?
  93. how much power???
  94. Water in my exhaust?
  95. screeching noise
  96. help with my rear end
  97. O2 simulators for "check engine light?"
  98. Descreening MAF
  99. What are the benifets to iridium plugs in LS?
  100. Granatelli lid question
  101. Royal Purple's Royal Embarassment
  102. Ram Air vs SLP Air
  103. anybody lookin to trade a AUTO trans for 6 speed
  104. My first camaro
  105. ls1 shortblock with crane cam for 6.0 iorn block trade
  106. a few powersteering questions
  107. LS1 Programmers
  108. Lsx compression #'s
  109. oil catch cans?
  110. Budget build
  111. SLP air duct
  112. Need Help Quick!!!
  113. Cutout worth it?
  114. Any help?
  115. HELP My Firebird is doggy after header install
  116. how do you change the rear studs on a 99 ss?
  117. Swap won't start!!!
  118. Is it possible adding traction control?
  119. seafoam question
  120. New Car!
  121. High flow cats. or cut them out?
  122. Is this a good setup?
  123. Light greasy build up on inside of tb around where valve rests.
  124. pullies?
  125. upgrade lifters?
  126. overkill??
  127. extra p in PPRND21?
  128. removing baffles from lower air box?
  129. Water pump
  130. camber adjustment?
  131. spare tire jack
  132. Headers
  133. basic FPR / fuel rail question
  134. Shocks
  135. Tranny slipping?
  136. Exhaust Questions
  137. gear ratio?
  138. Belt Loop
  139. powersteering pump replacement?
  140. diff question
  141. Which header bolts?
  142. Swapping cams for increased driveability..
  143. 02 WS6 Engine swap in 98 Trans am
  144. brakes
  145. Lifter install Question?
  146. very noob question
  147. clips that hold the lid to the airbox
  148. part values...
  149. New Ls1 ?s
  150. random misfire
  151. Help with cats
  152. don't understand
  153. whats does a 90k service do?
  154. Cant turn keys back all the way to shut power off or ge them out of ignition :S
  155. Tuner question
  156. Ground strap on passengers side????
  157. Vararam VR-3, does it actually make any hp?
  158. shifting gears?
  159. Replacing Thermostat Question
  160. Buyin a LS6 Intake.
  161. 5.3/4L60E in 1948 Chevy pickup
  162. Cloudy headlights.
  163. front license plate
  164. O2 sensors and headers
  165. What u joint to buy?
  166. Misfire after header install ?!
  167. rear shocks
  168. Very Very noobish questiions
  169. what do you guys think?
  170. Mail order tune question?
  171. what should my oil pressure be reading
  172. what should i put in the heads?
  173. wtf is a speed density tune
  174. Tires ?????
  175. I am looking for wheels and tires for my 98 z28
  176. oil and filter question
  177. Pictures of my first ls1!!!!
  178. Charging problem CANNOT figure it out
  179. How can I tell if my Z28 came with the ls1 or ls6 intake manifold?
  180. looking for ls1 camaro in richmond, va
  181. How much power can i make with bolt on and cam
  182. ls1 bolts
  183. noob straight pipes question
  184. header bolt help
  185. Problem with install... It's 1AM and I'm frustrated.
  186. simple gto question
  187. zMAX worth it?
  188. 2000 corvette ABS codes.....
  189. rear shocks
  190. arp head stud / arp head bolt kit
  191. pics of my first LS1
  192. Open Headers. I have a question?
  193. Spark Plugs and Wires
  194. Is there a way to adjust the fog lights on a 98 WS6?
  195. Car symptoms...
  196. what springs should i use?
  197. Any bad ass 6.0 Iron block motor out there
  198. Idea on cooling issue?
  199. Possible tranny problem... lil help!
  200. newbie ls1 owner
  201. How much oil w/ filter in LS-1??
  202. 2002 ss
  203. ls1 cams
  204. Should I spray this car?? Or Install heads
  205. help
  206. New Suspension Sucks?
  207. 145k BIRD
  208. Ok, so what makes a car "full bolt-on"?
  209. No low end power?
  210. yes another noob ????
  211. BFH Mod
  212. 223,XXX miles and still strong...
  213. just bought my first ls1
  214. price/hp/problems?
  215. electrical box under driverside frame raiL?
  216. Helix Power Tower Plus
  217. 5.3 L head question
  218. oil pan mod for a 69 camaro
  219. question about replacing engine
  220. How much of an increase?
  221. Skip shift
  222. inline fuel pump ?
  223. Electric problems while driving
  224. "High Performance" air filter actually worth power?
  225. Code P0137 and P0157
  226. stall/gear....tune?
  227. what mods next for the money
  228. 5.3 head questions
  229. how to swap my steering-wheel
  230. Help needed w/ headlight.
  231. head/cam/manifold worth it?
  232. What should I do with this E-cutout??!?!
  233. I SAY BULLSH!t
  234. Give me advice on what to do to my car
  235. SLP LM1 vs. Magnaflow Catback
  236. wiring diagram help
  237. Engine Shake Video, Big Cam, Safe?
  238. Max LS1 displacement
  239. Tire Pressure Monitoring System
  240. O2 sims and po430 code
  241. ls1 swap 63 nova
  242. 5 speed manual
  243. how much can u resurface stock flywheel
  244. Little Confusion need Clearing... Lids and MAF sensor combo
  245. SLP loudmouth exhausts
  246. Code p0420
  247. Firehawk Exhaust
  248. Normal noises, please respond!
  249. Installed clutch master cylinder now turn signal doesnt work?
  250. BlackWing Air Intake System question
