View Full Version : New LS1 Owners - Newbie Tech
  1. cooling system
  2. Oil Pan Gasket
  3. Quick question....
  4. PCV Mod
  5. 383 stroker
  6. power steering cooler
  7. grinding noise
  8. exhaust help?
  9. Exhaust Question
  10. just got my first ls1
  11. What should happen next?
  12. ls1 daily driver?
  13. Valve train noise
  14. quick question
  15. LS1/T56 help...need advice!
  16. Need help
  17. weld draglites
  18. Looking to buy another ws6
  19. dumb and new exhausts
  20. Prothane poly mounts
  21. bad idle/misfire? after new spark plugs and wires
  22. Couple Swap Questions
  23. 6.0 Chevy
  24. Should I drive my SS to the HLO Drags
  25. How do I take off my rear bumper?
  26. OBX headers
  27. Brake Question
  28. do you think my car is ok
  29. Can anyone tell me what this is???
  30. moving from 6000ft to sea level!
  31. Custom camaro taillight panel
  32. Rear question and expected hp
  33. Aftermarket Airbox Lid comparisons
  34. is therea new design for o2's?
  35. Idle problems after free ram air mod
  36. where to start?
  37. Passenger side air bag removal
  38. Max revs for stock LS1
  39. Short stick shifter.
  40. Help picking a motor
  41. FAST Intake for sale $250 Shipped
  42. v8 swap question not the typical one
  43. Free ram Air?
  44. 2002 Trans Am Headlight Door bangs hood
  45. What to do next?
  46. what does my car weigh?
  47. Couple of problems recently
  48. Quick question
  49. I have a ?....
  50. header and ypipe question
  51. Where Can I find Black SS 35th stripes??
  52. just bought my first 99 z28
  53. Got a $1000, what to buy??
  54. What a nightmare - (PLEASE READ)
  55. Poor throttle Response From Take OFF
  56. 6.0 Vortech Heads
  57. HELP Lq4 bolt up to 5 speed
  58. deleting cats =loss of hp
  59. how to get to 350wrhp?
  60. Firehawk a girly car???
  61. want my car to sound and perform like this!!
  62. I need a visual, jacking up car
  63. thinking of getting ls3 block some ??'s first
  64. Need some ides
  65. computer questions
  66. "Preoiling"
  67. entirely new cam/converter question.
  68. Free-Mods?
  69. Slp maf
  70. Help.
  71. TB clip thingy
  72. Thought I had it sussed, now I'm not so sure...
  73. LQ9 vs. LS6 1971 el camino
  74. o2 sensor part number
  75. Mysterious oil pressure issue. HELP!!!
  76. AIR Injection
  77. How much f$$ for supercharging??
  78. A few Questions
  79. Hey
  80. looking for someone
  81. 1955 s10 5.3 change over???
  82. help!!!
  83. LS2 conversion
  84. o2 sensors
  85. catch can
  86. 98 v6bird issues please help
  87. My c5 wont start
  88. My c5 wont start
  89. I need advice
  90. WS.6 intake manifolds
  91. Vette Parts
  92. Lost factory keyless entry pad-help
  93. Whats Wrong!
  94. How many miles do you get off a full tank?Only getting 200 driving granny style!
  95. just looking for some pointers
  96. help with my o2s
  97. stock rockers
  98. arp ls1 stud kit
  99. Does anyone need any LS1 technical diagrams or info?
  100. Jack points - 01 Firebird?
  101. First F-body-1998 Camaro Z28
  102. skip shift?
  103. AC compressor bolt size for rear flange
  104. Quickie Question
  105. parking outside :(
  106. Timing Chain Replacement
  107. Electrical issue?
  108. Worth the buy?!?!
  109. Help with LQ4 6.0
  110. Battery relocation 02 Z28
  111. 408 vs 402 ???
  112. need help please
  113. what to use for a reliable 450hp
  114. vacum leak?
  115. convert to ram air
  116. Losing Oil
  117. Dual Exhaust!!!
  118. paint
  119. Full suspension
  120. howling noise???
  121. GM Hot Cam?
  122. Edelbrock Shorty headers
  123. headlight pop up disable
  124. Throttle Body
  125. Cam L.S.A
  126. LS6 block?????????????
  127. Got new tires on, now have a different problem.
  128. Block bolts
  129. noise over bumps?
  130. Went to Daily driver
  131. 1970 12 bolt swap
  132. Battery died now P0134
  133. Car sitting?
  134. buy 2000 ls1 formula?
  135. found 03 vette heads for 150 bucks
  136. 315/35/zr17's
  137. ENGINE SWAP?? v6 3.4 to an Lt1 or Ls1
  138. Air pump removal? help please
  139. Noob here..Need lots of advice & info
  140. Cigarette lighter plug removal HELP please!
  141. What do I need to rehang my magnaflow exit pipe?
  142. LT1 Magnaflow on a '98 Z28?
  143. Smoke In The Cold
  144. torque arms
  145. headlights
  146. wierd headlight problem;pontiac guys come on in!
  147. oxygen sensor help
  148. BBK longtubes?
  149. Please help is my engine blown.
  150. Computer question
  151. just curious
  152. Need some advice!
  153. 186,000 miles on ls1 need advice
  154. 02 collector to 03 cobra and back again
  155. T56 hydraulics - what am I looking at?
  156. header question
  157. Any tips?
  158. 98-02 SS 3rd brake light
  159. Any recommendations?
  160. Need Info Fast!!!
  161. DBW pedal
  162. Hooker vs. Magnaflow.
  163. N20 on stock ls1
  164. stock trans syncro upgrade??
  165. Started my car today, popped the hood and noticed some problems (PICTURES)
  166. Can I hard wire my window motors to the fuse box?
  167. Oil Pressure Gauge Readings
  168. hey...
  169. Just bought my first LS1
  170. part throttle hesitation
  171. cags
  172. P0440A code ?
  173. MPH in each gear T-56 QUICK!!!
  174. Are Polly MM worth it?
  175. Performance parts installation - have a few questions
  176. Suspension Choices? - What spring to choose!
  177. daily driver cam questions
  178. Shifter Moves During throttle...
  179. stupid rear end question
  180. Question about aftermarket exhaust options.
  181. best plugs
  182. Price - Cam & Head Install???
  183. Non daily drivers
  184. Skip shift mod...
  185. Blueprint engines help
  186. potential new TA owner
  187. Best Shocks for Eibach Pro Kit?
  188. oil sending unit
  189. New LS1 Owner!!.Pics Inside.
  190. should I be really worried?
  191. Gauges... sweeping? WTF?
  192. High Idle Issues
  193. Halo headlights ???
  194. Looking to buy a 1998 Z-28 and looking for some advice on LS1's w/ high miles, SES...
  195. Off-road Y pipe question
  196. No X or H Pipe??
  197. 6.0l gas mileage
  198. how difficult...
  199. MAF code?
  200. Cam install
  201. Confused...
  202. good deal?
  203. I need help buying a 1996 Caprice. What to and not to look for????
  204. New to site. Just bought WS6
  205. Oil change light
  206. What makes a Corvette LS1 sound nastier than the f body LS1?
  207. Free Bellow mod
  208. whats the name?
  209. Stock idle
  210. LS1 Fan Temps for 66 Chevelle Project
  211. I dont no what type of cat back 4 my ws6
  212. I just bought a new SS!
  213. Noisey spring!>!?!>?
  214. I thought this was supposed to be a no brainer...
  215. oil pan holes
  216. Drive by wire peddels
  217. Valve Tick
  218. piston slap?
  219. LS6 head gains over stock?
  220. MS3 cam smog legal ca?
  221. Roller Rockers Gains?
  222. Problem...Car Whines
  223. The 1300$ header job :S
  224. confused
  225. Tube from PS Valve Cover to TB after swap to LS6 valley cover and GMPP Valve Covers
  226. new with ls1 need some help
  227. Free mods??
  228. *Wanted* I Need Stock OIL Pan For Trans am 5.7 LS1
  229. Possible Headers
  230. best way to luanch a a4?
  231. Need help asap !!!
  232. motor mount clamshell bolts - which lube?
  233. diablosport
  234. trouble bleeding clutch!! plz help
  235. What is a torque arm?
  236. What is the abutment bracket?
  237. Whats a Good cam for the street
  238. off road y pipe
  239. Which route to go?
  240. WOT Hesitation??
  241. 2002 Trans Am Headlight Motor Electrical pigtail
  242. fuel injector retaining clips. where to buy them
  243. Best Spark plugs?
  244. what can you shim your oil pump out with?
  245. what cut out size???
  246. How to tell true SS??
  247. Help me ID this 4.8
  248. ls1 problem. help
  249. To stall or not to stall?
  250. ls6 intake picture
