- a little help with the numbers???
- What's this LS1 Worth?? (how much would you pay?)
- Exhaust/header install questions
- How do I hook up my gauges?
- if i have an a4 why does my shifter only have 2,d ,and od!!!!
- A couple Questions
- another question
- Windshiled wiper problem.
- Need Help about a 4.8 and 6.0 truck
- Possible tuning issue??
- Cutout questions for noob..
- new to these engines and have some questions
- cam lobe
- stall???
- looking for headers
- How much for an LS1 block?
- Archives
- GTO Tranny bolt up to a 98 LS1?
- Vibrating LS1??
- Is it possible?
- Buyer Advice, ran VIN
- vacuum line on the back of the Intake manifold
- How do I install a torque converter?
- Sorry but another exhaust question!
- cutout ?
- tire size?
- Mounting gauges in a T/A
- newbie here
- stock heads
- 15 x10 and 15x8 drag wheel question? please help with pics
- Upgrading things??? Whats best???
- Cutouts with X-Pipe???
- Car acting strange when trying to charge battery??
- best cam for a daily driven car
- Full exhaust question....
- C5R titanium connecting rods?
- 2000 firehawk rear end?
- LS7 Parts on LS1
- New Member from Memphis
- ls6 intake...
- ??rwhp??
- Air/fuel gauge ?
- AIR pump questions...
- Oil Problem?
- Max tire size i can fit???
- where can i find this y pipe?
- winter project- engine rebuild
- exhaust issue
- Will an aftermarket lid fit?
- 98 ls1 block
- Oil pressure for my mechanical oil pressure gauge
- 02 Camaro LS1 question
- Gains w/ Ported TB?
- Codes ?
- 853 heads???
- Want to run 12s
- Cover above oil filter....
- Ls1,6,7,x/lt1,4
- rev matching?
- ???removing gauge lights???
- mti clear lid install problems on 99 ss
- grinding and unplugged sensors?
- Manual Rack Worth it?
- Service Engine Light
- 2001 Trans Am---What Should be next??
- trans cooler
- ADDING MODS=1/4 mile time???
- 243 heads
- trans am rear end question
- steering issues
- Have a ?
- U-joints without shaft removal?
- lid vs. volant
- Exhaust decision is driving me crazy..help!
- Worth putting money into?
- Tomzwheels. Still in business?
- Mail order tune questions
- Can i make more power with a stock 6.0 block
- Do 5.3 heads fit ls1
- New to the LS1
- Z28 vs RS vs SS
- speedometer
- Simple question.
- why would someone set my car to shift at 6500 rpm's?
- Headlight Motor Install
- B0026 Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit
- TH400 LS1 Car
- LS1 clutch/flywheel in 06 LQ4?
- 04 Vette LS1 into Miata
- ls6 cam in lq9?
- Need help choosing block
- PCM/temp questions
- driveshaft
- Rearend and Tranny Fluid change.?
- Ls1 Throttle Body Bypass
- newbiee NOS questions on stock motor
- shock question, street and strip use...
- stock LS6 intake 78mm or 90mm??
- 400 for CME?
- is my flowmaster holding me back?
- exhaust for ss. this is my plan is it a good one?
- exhaust smoke????
- Buying a TBSS, Need Help! ...Please...
- Tail shaft and extension seals
- Slp question
- Front End Noise (2004 GTO A4)
- What kind of cam is this??
- gauge readings
- QTP question.
- Newbie with some wiring questions
- vin tags?
- in the market for an LS1...need some opinions
- Worried I am hurting my car. Am I?
- k&n air filters. whats the deal.
- Which cam should I run????
- How to tell LQ9 from LQ4?
- lower control arm
- American Racing Wheels
- What clutch to buy on a budget?
- Header install question
- Who has best brake kit for tight budget?
- Shopping for a ram air hood, need some words of wisdom.
- no cats + slower ls1
- Would these fit?
- My theory on 98 and up F-bod Vs. 2001 and up F-bod, is this right?
- In Search of advice! Please help
- FTRA, SSRA on a daily driver
- any1 hear of these headers?
- ExHauSt
- what performance upgrade?
- torq-arm or subframe connectors?
- About to buy a new Z28!
- new project found
- will 255's fit?
- 5.3 heads and texas speed tr3 cam
- bellow
- whats causing this?
- Shift kit questions, A4.
- Skip shift. Blocking me out of third too?
- Question about throttle body
- To Borla or not to Borla...
- exhaust manifold question
- HELP! popS from muffler and intake.
- starting problems
- Flickering Oil Pressure--Help
- budget build?
- Will this hurt my car?
- What wideband a/f gauge w/sensor should i get
- A4 to M6
- any help
- SERIOUSLY CONFUSED!!! HELP!! (with pics!)
- Emission questions
- are these power steering pumps worth a crap?
- Thinking of doing this- for mods- will it do 11's?
- LS1 GEAR HEADS.Please chime in!!
- Question: LT1 to a LS1 Dash
- rear main seal repair
- Will 4 ch axle work in 3 ch rear end
- question about what heads to use?
- Might have slight dirt in my 5.3 when I picked it up
- Big clutch issues??
- new car.. only front brakes work.. wtf?
- New cam on a budget.
- Throwing code P1416
- LS6 valley cover vs LS1
- Cam question?
- I have a lid and a car back should I do a stall
- Has anybody paint their SLP Lid
- 5.3L stroker doner for 1980 camaro
- traction control problem
- Squeaking under hood
- throttle bodies
- Is a radiator from a 98 interchangeable from an 02
- What gear?
- New to the LS1...
- Car Running lean/High Idle?
- Confused newbie, lots of questions.
- SS hood I.D. numbers???
- sequential tail lights??
- Descreening MAF question?
- 2000 WS6 auto
- My car is making a grinding sound. What could it be?
- Where can i buy a rear axle? for a 10 bolt
- Would an SLP MAF cause problems running rich?
- brand of oil and filter
- REAR End question
- LID Vs Custom Intake
- When does a Y pipe become restrictive?
- Why am i still having problems???
- oil change
- need help with 2000 ws6 info
- looking to reach 400 ro 450 rwhp
- Temp gauge
- still sputtering and extreme lack of power
- exhaust problem
- ls1 no fire. Fuel is the issue. Not sure what to do next
- no fire???? have gas soaked wrag and starts
- will ported heads make.....
- cut out pics..needed
- WTS: superchips 99-02 tuner
- LS6 intake?
- Noticible decibel change with cutout?
- Want to reach 300rwhp
- Can you show my a pick of a LID
- what are these buttons??
- Quick question on bolt size... pic
- thunder racing CheatR packege
- Safe to run my car??????
- Im tired of knowing nothing...
- Another quick "noob" question
- Headers for 99 vert Camaro
- OK...I am getting confused...
- best possible upgrades for 1,000 dollars?
- This sucks. Is this normal?
- Valley covers LS1 or LS6
- ???doesnt the stock tach pick up rpm signal from the alternator???
- Have a few "noob" questions I need answers to...
- Pros/Cons to removing AIR/EGR & Headers Question
- fpr install vacume line question
- motor/mileage
- A4 shifter
- 98 Differences then 99-02?
- engine weights
- Any ideas or mods to help my setup. I'm all ears!
- need help with a new combination
- Lt1 vs. Ls1
- Need a little help
- Coolant Bypass Questions
- engine weight
- Whistler Mod
- blinkerbulb replacement question & octane preferred
- Wheels?
- Really need help!!! Tire wont last!!!
- A4 to M6?
- Is a 90mm Throttle Body overkill?
- LS1 LS2 sawp on f-body
- engine smoke?...intake
- Help... Nipple on radiator broke...
- Are there better fitting lids?
- Thermostat problems
- Trans am Ram Air
- new motor build
- Flow master muffler 80 series
- Automatic Or Manual
- More Alternator Woes
- Shock and springs combo preferance?
- Plan on doing a re-build .. any tips ?
- rusting rotors
- New spark plugs, NGK & MSD?
- In need of opinions
