View Full Version : New LS1 Owners - Newbie Tech
  1. 00 or 01 LS1?
  2. Worth me getting LCA relocation brackets?
  3. parking light problem
  4. SLP Options
  5. yes this is a real question
  6. Oil gauge sweep ?
  7. problem with dropping in a ls2 ?
  8. Cylinder Head Size on My 04 GTO
  9. Steering wheel control trouble
  10. Pulling motor from the top, what is the easiest tool to use?
  11. Ticking Noise
  12. gauges sweep
  13. NKGs or AC delco Pro
  14. SLP Ram Air Intake Air Box
  15. LS1 vs. LT1?
  16. are they worth it?????
  17. Rear Ends.
  18. Exhaust Systems
  19. Wear/failure items to look for when buying a LS1??
  20. Best mods for stock 02 SS M6?
  21. need backup
  22. Starter problem.....stuck at school help!
  23. creaking? help
  24. SLP Exhaust
  25. SES light
  26. whats more reliable ?
  27. electrical problem.
  28. Winter Storage
  29. cam question
  30. LPP headers on the way...do i HAVE to have o2 crap?
  31. Front shock removal
  32. fog lights
  33. egr intake freeze plug q
  34. Power Door Locks
  35. led lights
  36. Y-Pipe for Shortty headers..
  37. License plate cover? How to put it on?
  38. normal?
  39. Need a lil advice.
  40. Help Me!! I'm only a boy!
  41. Best Power Programer for 2000 B4C?
  42. cam swap??
  43. Bogging around 2,500 rpms
  44. how do you hook up a wideband on TDs?
  45. Stock SLP exhaust
  46. rpms hang
  47. What gear comes stock 1998 Camero ss?
  48. what is a stall suppose to feel like
  49. ses light after tsp catback install?
  50. electrical problems
  51. Goal: 400hp dream: 450 to the wheels
  52. opinions needed
  53. texas speed heads n cam package
  54. PCm recalibration after gear change
  55. car cuts out when shifting?
  56. Future selling question
  57. What cam is this
  58. SLP Flowpac
  59. Rattleing
  60. Factory service manual.
  61. Mobil 1 Full Synthetic 10W 30
  62. Security alert problem?????
  63. can I run a performance cam on a stock motor?
  64. Header difference
  65. Advice:6 spd/clutch or A4...reliability & longevity?
  66. How to pick up .3 tenths @ the track???
  67. Weired problem???
  68. LS6 Block
  69. New member, engine tick
  70. mti cam question from newbie
  71. What cam?intake?
  72. What mods would I *not* want on an LS1 I want to buy?
  73. So I'm a newbie
  74. noisy rocker!
  75. tuned
  76. Tire sizes??? help
  77. 2001/2002 LS1 change...EGR removal?
  78. removing valve cover bolt grommets?
  79. question
  80. Battery
  81. o2 sensors
  82. OD at the track?
  83. Cant get out of the driveway!!!
  84. patriot camshaft
  85. HEADERS: OBX or the tempting $179 ebay
  86. Gas? Probably been asked..but i searched.
  87. Help! All I want to do is drive my Trans Am.
  88. AIR an EGR
  89. need some help
  90. Car won't start up. PLEASE HELP!
  91. Headlight vacuum pump
  92. o2 question
  93. 98-99 ls1 problems???
  94. are Fbody/Vette wheels 5 X 4.5? aka 5X114.3
  95. Idle Surge, Running lean?
  96. Dr.Gas... what do you think?
  97. Is There A Hoover Vacuum In This Engine Or WTF Is Going On?
  98. LT How To
  99. Is this worth it?
  100. will i be fine with just 4 new plugs & wires on the drivers side?
  101. Christmas Crisis...:read:
  102. ls1 gas gauge fix?
  103. Why do i get terrible gas mileage?
  104. Side mirrors
  105. Cam Positioning Sensor??
  106. traction control
  107. deep and throaty, LM2 vs. magnaflow + cutout
  108. ANOTHER mysterious sound...
  109. Brake fluid Reservoir Cracked?
  110. Weird noise? help please
  111. Best price on stock-replacement fuel pump (1998)
  112. What gear to race in?
  113. MS3 vs. MTI X1
  114. air and egr block off plates
  115. tune out or sim 02 sensors?
  116. ls1, snowboarding, gas mileage?
  117. would i get away with just changing the plugs and not the wires?
  118. torque converter not staying locked. help
  119. Post your setup and hp ratings!
  120. fast are weiand intake
  121. what next
  122. hypertech programer
  123. My heat sucks, whats the fix
  124. Poilsh hood latch?
  125. is my clutch fluid boiling?
  126. cost to rebuild my ls1
  127. LS6 intake swap question
  128. Production Number?
  129. would the "ram air mod" make our engine eat more "shit" as opposed to stock?
  130. Spark Knock after Tune-up
  131. where do i ask
  132. when i was replacing my air filter i noticed this... normal? (PICS)
  133. Stock I-Pipe Diameter?
  134. TR55's vs platinum plugs?
  135. Dose anyone else have to do this after they change there oil?
  136. How do I know rearend destruction is upon me?
  137. Could a Bad Motor Mount Cause...
  138. vette vs. camaro LS1 alternator mount
  139. stock LS1 heads...
  140. something whistling
  141. tranny swap
  142. 98 TA A4 problem
  143. HP on stock crank
  144. air in, boom, air out. i want synergy. confused!!
  145. Rack and Pinion
  146. ngk 55's
  147. If you understand piping, please come in.
  148. Coolant Flow Direction
  149. which trans to use?
  150. 2009 LS1Tech Calendar -- AVAILABLE NOW!
  151. Clutch guys I need some help figuring this one out!
  152. taking off my cats
  153. What's The Best Coolant for The LS1? Help needed as well!!
  154. 02 codes
  155. good tune?
  156. Oil cap breather.....
  157. ls2 cam in a ls1(lq4)
  158. 2000 LS1 rebuild - 4.000 stroke?
  159. Hp Ls1
  160. removing PCV system
  161. what is flycutting?
  162. looking into an LS1
  163. New to ls1s need help finding parts
  164. Car delays starting when cold
  165. Couple questions.
  166. How much does the T56 weigh?
  167. ss question
  168. LSX shop near CHI!!!
  169. LT1 to a LS2 swap
  170. How much for a granny fluid change?
  171. holding rpm at shift points and throttle release
  172. embarassing question about head gaskets
  173. 99 v6 spark plug change...am i stupid??
  174. Bolt Length Questions, Please Help!!!
  175. New with a few questions
  176. Possible new owner (98TA)... Questions?
  177. Water in turn signals
  178. Mac Y Pipe
  179. Free ram air mod
  180. crazy burnout / loss of control lol
  181. Quick ?: Which end of the stock cam is the part # on?
  182. how often should we change our differential and transmission fluid?
  183. Hey Whats up Guys
  184. Can a Dealer change my Key's Code?
  185. whats different in the z28s
  186. proper way to break in new built motor
  187. rear gears and ABS
  188. Need help with a beast
  189. DIY sfc?
  190. Exhaust Question
  191. ls1 rebuild
  192. ls1 oil what to use
  193. Don't want to use Duralast brakes from AutoZone
  194. Popping noise from behind...
  195. rear end question
  196. Do you think LS1 cars will drop in price with the lauch of the 5th Gen?
  197. what to get?
  198. Hey Corvette guys...
  199. 02 chevy 2500 6.0
  200. exhaust
  201. compression ratio ????
  202. Cam questions: how much? Labor costs? Will I get robbed of gas mileage?
  203. Oil pressure Gauge... Help
  204. Want to purchase this WS6, strange lack of power, need advice
  205. Speedy turn signals.... cold?
  206. is it a ss
  207. change oil before storeage?
  208. Officially an LS1 Owner... Again!
  209. In Need of MAJOR Help!!
  210. What to do? should my 3rd gen or 4th gen get the faster ls powerplant?
  211. Question about o2 sensor wiring, with pic
  212. I need help identifying my exhaust..
  213. need some advice ??
  214. newbie question
  215. remote start rarely works
  216. Does anyone know how i can get a front liscense plate cover for my 02 ws6 trans am?
  217. will a key fob from a diff car work?
  218. Cam Question
  219. engine knock
  220. Buying my 1st f-bod, need advice
  221. AD244 alternator wiring
  222. Tranny or Tune Problem?
  223. Hose mod
  224. Please help, need some advice / information.
  225. Lid problem
  226. How long?
  227. car Feels like a slug....
  228. inspection HELP!!!
  229. Free mods???
  230. Burning oil
  231. Tuning advise
  232. EBAY uncut VATS?
  233. lil help
  234. Momma Needs Help!
  235. What is a lid?
  236. Welded subframe connector question
  237. mpg help
  238. 10-bolt torque specs?
  239. ls6 intake question
  240. What!!!!!
  241. Cammed and Sprayed Or Supercharged
  242. newbie here
  243. Exhaust Recommendation for Impala
  244. My First LS1
  245. WS6 hood orignal or repo????
  246. catalytic converter
  247. cd changer???
  248. Will this mod be RICE?**pic inside**
  249. How much should LS1 to LS6 Heads swap cost?
  250. ASP Underdrive Pulley For Sale
