View Full Version : New LS1 Owners - Newbie Tech
  1. 1st spark plug install
  2. HELP! 4.5" backspacing?
  3. Help
  4. Somebody please help me
  5. stupid oil capacity question
  6. How to fine tune the LSx motors?
  7. odometer says "Error"?
  8. good LS1 manual to buy...
  9. 50 HP Chip??
  10. Question about emission legal performance?
  11. Looking for a Good Build Sheet
  12. Pacesetter or Hooker LT's?
  13. vehicle towing ?
  14. Corvette Rims?!
  15. some questions about taking out the cats
  16. High Idle Problem **SOLVED**
  17. Traction Mods-What Really Works? What's the Best?
  18. oil change light
  19. LS2 - How much HP can you run thru them?
  20. Need some advice on next mod to do
  21. annoying clicking noise wen i accelerate
  22. Racing Seats
  23. really bad newbie suspension questions
  24. Drove car in rain, now having misfire problem
  25. Instrument Cluster Dimensions
  26. Lingenfelter Intake
  27. new clutch / ls7 clutch
  28. Fog Light Missin Peice???
  29. Rpo code sheet
  30. Vin Number! SS or Z28
  31. LS6 stock springs with new cam
  32. driver door interior light switch
  33. Pics- Halo Halo Halo .. assistance needed
  34. Help
  35. Drivetrain clunk!!! Help
  36. WS6 vs. Mach 1
  37. LS1 in 68 Camaro install advice
  38. patriot heads w/stock pistions
  39. Misfiring and backfiring-yes I have tried searches
  40. Taking intake off...ls6
  41. new car..
  42. Best mod for 500$
  43. HELP!!! SLP Flo Pac
  44. 1999 Bright Blue Metallic Camaro z28
  45. Where To Adapt Fuel Pressure Regulator?
  46. 853 and 241 heads, aluminum and steel driveshafts
  47. Cam / Intake combo?
  48. first time slp header install
  49. installed SLP Lid, now SES light
  50. Header install weird feeling?
  51. Fog lamps pig tails?
  52. Long Tube Header Install
  53. rksport power antenna
  54. Seafoam engine? YES OR NO?
  55. Better Fuel Mileage with a Full Tank?
  56. need so help asap please
  57. Just wanted to thank GM
  58. Tuners In Ky
  59. Can a tune fix all my A/F issues?
  60. *PICS* Am i lifting properly?
  61. turbo LS1 set up
  62. quick exahaust question
  63. Will this hurt my performance?
  64. some noob questions!
  65. what size bolts for fuel rails?
  66. Tranny slip?
  67. Opinions... fair cost of assembled LS6 heads and LS2 intake?
  68. What Exaust Is This?!?!
  69. older z06 ls6 heads and cam selection???
  70. 1999 ws6 inner door panel removal
  71. fluid in the exhaust...help?
  72. what do you think?
  73. oil change light
  74. Suspension Build?!?!?!?
  75. weird mods on car...
  76. Tcs????
  77. Grrrrr....
  78. Blowing belts since BBK underdrive pullys
  79. Hard To Start Since Install Of New Granatelli Fuel Pump
  80. can some one donate their car to....
  81. More problems....
  82. FREE engine rebuild book!!! (strings attached)
  83. A Little Advice On Some Small Mods
  84. the t-56 transmission
  85. NEW WS6 Owner
  86. how fast do these motors get tired?
  87. A little help please....with PICS
  88. Help on 2000 camaro ss or z28? SLP
  89. slp header question
  90. anyone know where to get this?
  91. LS1 LS6 intake how can you tell
  92. skip shift ?
  93. kenne bell question and general info.
  94. Dash Question
  95. Where to go?
  96. Does it exist 1998 Formula ws6 1le Sport Gold
  97. What else am i missing>?? **pic**
  98. Learning to Launch
  99. Engine Hoist Hooks
  100. Camaro material?
  101. manual driving advice/tips
  102. LOW MILEAGE SS 6 speed
  103. seal leaking water/
  104. Newbie tune/exhaust ?
  105. So here's the problem...
  106. Good Place To Purchase Oxygen Sensors for LS1?
  107. ASR --- Affects Gas Mileage???
  108. shifter ?
  109. Got the Car...
  110. ls1 with zo6 head,cam,intake Dyno graph?
  111. Just a question
  112. racing seats
  113. Airbox clips
  114. Whats the typical gain with Fast 90/90 intake over the Ls6 intake?
  115. Best place to buy decals
  116. will i gain HP if i cut my muffler off
  117. Faster with traction controll on or off?
  118. 02 senser questions
  119. Rough start on engine
  120. Burnin' OIL
  121. running 89 octane instead of 87 in a SBC??
  122. Throw out bearing noise
  123. HELP about to buy a car and need imput
  124. exhaust pipe size
  125. need help making noise
  126. Got A Good Deal
  127. Dual dual tips pics
  128. Camaro Keeps Overheating! Help Please!
  129. ls1/2 vs lq4/l94
  130. Pully question
  131. is my car running good?
  132. Cutout and Cat-converter?
  133. LS6 intake swap questions
  134. Need Help Identifying Engine/Casting Numbers--pics included
  135. oil drain bolt
  136. Stock ram air baffle qustion.
  137. What would happen If You.....
  138. Here is a brain buster for those electronic wizzes
  139. 20-50 oil
  140. How do you test for a bad fuel pump?
  141. 2001 Z28
  142. LQ4>LS2.... any thoughts....
  143. Ls2/ls6 Maf
  144. Some Newb Questions
  145. Ground effects removal
  146. Where2buy locking fuel filler door?
  147. O2 Simulators!!
  148. What to do first to make my hawk rock!
  149. What does "bump" mean?
  150. stall question
  151. change thermostat on ls1
  152. What next? can't decide?
  153. Tap Tap Tap
  154. just bought an ls1!
  155. Typhoon Intakes?
  156. Dude, I bent my car
  157. Looking for a good ls shop in chicagoland area HELP???
  158. Sometimes my passenger side headlight won't pop up?
  159. Ok, what are CUTOUTS?
  160. Tranny upgrades?
  161. Does anyone know what this is?
  162. SLP Air Lid?
  163. Knock sensors
  164. New to this FIREHAWK. couple newb questions.
  165. Mac Longubes or Pacesetters
  166. Difference in these two ram air hoods?
  167. locked out of 3rd gear
  168. Car turns over but wont start most of the time
  169. Will dyno tune help????
  170. SS feels held back
  171. Went on 1.5 hour roadtrip today, AC felt much weaker and less cool on the highway
  172. Placement of Cutout
  173. Auto ECM with T56?
  174. Knock
  175. Direct fit muffler vs. Catback
  176. ls1 ls3 ls7 lsx
  177. New ls1 owner.. not sure where to start
  178. Hooker Aerochamber or Magnaflow
  179. what exhaust should i get?
  180. looking for a new clucth
  181. P0420 Stayed Gone Once Cleard. Is It Ok Now?
  182. Minor question and bad drawing.
  183. Iat resistor trick
  184. Fog light / clear blinkers
  185. What is this cap? It blew up. Sadness ensued.
  186. Serious Exhaust or SXP ?
  187. poly motor mounts
  188. headlights
  189. Rebuilt Engine: Any precautions I should take??
  190. stock motor mounts
  191. 99vette
  192. Learn from my MISTAKES
  193. alternator question
  194. 01' suburban ls1?
  195. Bolt On 515 HP Trick Flow kit....Any good?
  196. Piston Slap?
  197. Can new cat converters smell?
  198. Buying a High Mileage LS1 - What to look for?
  199. Catalytic Question
  200. Need advise which LS engine for my project
  201. Transmission HELP
  202. Car was under water. NEED help ASAP
  203. Sail Panel Sub question HELP ??
  204. Building First 403 LS Car - What can expect?
  205. Didn't mention the sweet deal I got!!!
  206. Front bumper push pin removal
  207. Exhaust Question!!
  208. Full Bolt-ons
  209. Maf Do Ya Need It
  210. Direct Fit Muffler
  211. What Performance Parts To Buy Next??
  212. The Best Muffler With Cats Removed??
  213. 5.3 heads on ls1?
  214. K&n Versus Lid
  215. performance shop
  216. ls1
  217. Thermostat interchange between LS1 and LS2
  218. Torsion Bar issues
  219. hi i finally got my dream car i got a camaro
  220. finally got my f-body ls1
  221. New Ls1.. need help pls
  222. Can broken cats cause more damage?
  223. my goal need some help
  224. need help on cam
  225. how to replace a lens and a socket for a trans am?
  226. pcv....help
  227. starting issues...
  228. Doors mid-basses don't play, tweeters only
  229. From the sounds of it...
  230. What is this and where does it go??
  231. charging problems!
  232. Still lost...
  233. Cme Package
  234. Koni's from Strano
  235. Trouble shoot Rough idle at start up(NEED HELP!!!!)
  236. suspension or true dual
  237. Are these long tubes?
  238. quest to beat a c6
  239. best mods
  240. z28 and SS
  241. Aweful gas milage with no ses code what could it be?
  242. Is there any common problems on the 98 z28?
  243. me again BCM electrical problem
  244. 98 slp lid to 2000 z28
  245. few noobie questions
  246. Sail Panel Sub question
  247. Noob questions (big boobs inside)
  248. Cut out ?
  249. i want to whore my SS but can't.
  250. im so confused
