View Full Version : New LS1 Owners - Newbie Tech
  1. a4 and m6
  2. ?żż? Gas Milage
  3. How do I tell what size my Fast TB is?
  4. What should a stock 98 z28 a4 run?
  5. A4 or M6???
  6. Traction control??
  7. Which bolts can I reuse in my LM7?
  8. Cam-Will it be too much?
  9. piston slap
  10. check my wheels
  11. Ls1 Rebuild
  12. a4 to m6 swap someone help please
  13. So i seafoamed my car today
  14. Stainless 'Trans Am' door emblems
  15. Are Cutouts Bad In Anyway?
  16. What muffler?
  17. door panel screws
  18. what is the difference in the cast ls1 and ls6 blocks?
  19. Finally got LS1!!!
  20. kansas city area code deletion???
  21. Newbie.. What to do????
  22. Cutout-Where to put it
  23. MPG, Insurance, winter driving
  24. new member, couple questions.
  25. Worth any hp??
  26. LS6 LS2 throttle bodies
  27. cam
  28. I don't get it..
  29. A couple of newbew questions??
  30. electric waterpump
  31. charging issues?
  32. how do you call it??
  33. Help. New Brakes Still Squeaking
  34. PCV Catch Can
  35. Overdrive Problem
  36. Mid frame noise, need help.
  37. Did tuneup/wires, how to make sure I pushed wires in all the way?
  38. Release bearing question! Need help please!
  39. fuel issues
  40. plz help....weird problem
  41. Dohnuts! What Damage?
  42. Porting and Polshing MAF questions
  43. A/C problem
  44. Bad pulley?
  45. Adding performance to an 02' WS6
  46. Steering wheel controls
  47. coolant sensor?
  48. Open y pipe?
  49. Need help With first BUY
  50. Fuel Pressure Regulator Question
  51. Engine/Trans weight comparisons
  52. Belt walk
  53. Cold start ticking?
  54. Next mod
  55. Gettin a ws6
  56. DS Loop Exhaust questions???
  57. help please. need to know what goes where.
  58. emission test failed
  59. Gauge guru's-A/F
  60. Belt loosing?
  61. really bad electrical problem
  62. What is needed to bolt up a FAST 92mm
  63. Slight clutch rattle?
  64. breaking in a clutch
  65. Driving on open headers?
  66. Just got my first LS1 Last week
  67. Free Ram Air??
  68. Anyone here know what size screws are needed to bolt up front license plate cover?
  69. MAF Question
  70. been thinking of joining the lsx side. . .
  71. cam ?
  72. Aftermarket Fuel Rail
  73. Lean Code Help
  74. difference between A4 M6 and T56 transmissions?
  75. ??driving Light???
  76. Ls1 or Ls6 intake, how to tell?
  77. where can i find....
  78. emblem peeling away... how to fix or remove?
  79. Hey guys!
  80. Possible to have a misfire w/o a code?
  81. altitude diff. in power (please read)
  82. Does this sound right
  83. Engine Identifciation
  84. What consists of a good y-pipe system
  85. LT Dimensions
  86. Brake Lights
  87. doesnt want to idle
  88. How Do I Tell if Its a Real WS6?
  89. 315's
  90. T/a Ws6 Ram Air Hood Restricted?
  91. Trans Am Buy...
  92. Buying a cam
  93. Power steering pump
  94. haulin a$$
  95. Best Prices on tune up parts?
  96. Ls1 shortblock identification
  97. For the same money, what would you do?
  98. Building?...
  99. how much of a gain...
  100. Temperature Help????
  101. car gives out at high rpms
  102. New to the forums...
  103. Front speakers compared to sail panel
  104. Miles on LS1
  105. In-tank fuel pump for 8.1L on MEFI-4
  106. LS1 Swap parts
  107. pulling out of gear
  108. Wher to Find theses
  109. t-56 fluid and diff fluid?
  110. stock rockers and push rods with head&cam package?
  111. door speaker help!!!
  112. I need to get rid of burnout marks
  113. My First LS1!
  114. Monsoon Help
  115. Speedometet
  116. G-TECH PRO do they work well?
  117. What to look for when buying used H/C??
  118. Bottom End Question
  119. Best acceleration moment
  120. 04 Vette intake for $150, worth buying for 99 TA?
  121. Cuting the cats..compared ta headers
  122. Monsoon to Ipod
  123. Best way to go about tuning
  124. Fuel pump Q's?
  125. Service engine light
  126. car wont start.
  127. Dash lights stopped working
  128. Used Engines
  129. really dumb question about the oil pump
  130. In need of some serious electrical geniuses!
  131. 40 roll... 1st or 2nd?
  132. Anything I can do about the fading Trans Am red lettering in the back?
  133. Less than three months for LSX Shootout II.
  134. Worth switching A4 to M6??
  135. Shocks ??????
  136. How much slower does a car feel when it's hot and humid out?
  137. 00 WS6 value?
  138. Are the '01-'02 exhaust manifolds really as good as headers?
  139. Help what is this!??
  140. 88 IROC on Juice???
  141. SLP lid tight
  142. website won't come up!!!!
  143. Specs are 218/228 .525/.525 on a 112 lsa CAM
  144. ECM Issue
  145. 98 Camaro 3.8 to 99 LS1
  146. WS6 m6 tranny to a Z/28 will it work?
  147. Firehawk custom license plate???
  148. Salt in gas tank
  149. ss hood...
  150. LS1 or LS6 in 2001 TA
  151. SLP cold air Vs Free ram air
  152. IAT sensor
  153. fumes
  154. 2002 z28
  155. New Fluids
  156. Anything i should look out for
  157. Question about gears on a 2001 Trans WS6
  158. SLP Cold Air Package
  159. DiabloSport Predator Or SFC'S?
  160. Please help. Considering late model engine/trans swap
  161. Please help. Considering late model engine/trans swap
  162. suggestions asap...
  163. Header Gaskets-ahhhhhhhhhh
  164. SS spoiler
  165. Newbie questions
  166. buying a used LS1 and T56.....what do I need to know?
  167. Minimizing powertrain loss?
  168. Amsoil air filter, Vs K&N,Vs paper
  169. vette engine block for use in f-body
  170. Which power adder: Nitrous or Cam?
  171. Need help with parts install
  172. LS1 600whp NA or 900whp turbo???
  173. need some help
  174. Basic, probably dumb question
  175. Just Bought Headers
  176. Some good head lol!!
  177. Catted-y and GMMG
  178. Wiring Harness & PCM Compatibility
  179. RPM's on highway
  180. Buying headers.. need help
  181. Stock fuel pump...
  182. Programmer
  183. K&N air filter help
  184. quick nubie question
  185. What to replace in stock heads? Trying to eliminate "ticking sounds"
  186. where can i find Oval mandral bent exhaust piping??
  187. 98 trans am LS6 intake swap questions
  188. cam only ls1
  189. gm hot cam only
  190. What size cutout to go with?
  191. Headlight wiring problem?
  192. Low RPM question
  193. Ls1 conversion
  194. what would i run?
  195. Muffler shop guy just told me the factory cats are better than aftermarket hi-flows.
  196. True Duals????
  197. 1st time looking under the car
  198. fixing paint
  199. Long Tube question
  200. tunnel brace bolts help
  201. Newbie question on launching..
  202. ls1 xtreme?
  203. Auto tranny to M6 swap
  204. clutch choice
  205. need more boost
  206. Sleeper Q
  207. cant excite alternator
  208. o2 help please
  209. Factory Paint
  210. Steering wheel shake? Rotor related?
  211. 4.11's rpms in sixth@60mph
  212. Port stock intake and TB till i get FAST 90/90 worth it?
  213. my new LS1 what hp should it make?
  214. SLP loudmouth exhaust what is the difference?
  215. clutch choice
  216. SLP Y-pipe?
  217. Can we use the 6L trannies?
  218. Good price?
  219. exhaust advice...
  220. Wanting to know about first mods!
  221. ram air box?
  222. Alternator-Electrical Question
  223. Dumb question, could use a picture maybe
  224. 2000 Camaro Z28/Pro Stock Johns ex.
  225. 02 sensors
  226. HELP!! 0 oil pressure!
  227. What is needed for LS1 install into 92' RS?
  228. cold air vs. air lid
  229. how to get to the LS lifters?
  230. drop in cylindrs
  231. What do I need to get before tackling my cam swap?
  232. possible motor swap idea help me out
  233. Is it ok to....
  234. just a random ?
  235. Any help?
  236. Where to find misc little parts to mount my spare tire?
  237. Headers and Spark plugs ??? Please Help!!!
  238. How to remove Camaro front bumper
  239. Did any 99's have permeter valve covers?
  240. cant find the ngk tr55's
  241. cheap plug wires?
  242. Leaky Header/Heads Issue....Need Advise!!!
  243. P&P tb Write Up ?
  244. Are the front oxygen sensors a pain to change?
  245. Blinker light
  246. What next!?!?
  247. Anti Drainback Valve????
  248. A Complete LS1 Re Build ?
  249. What motor should I run?
  250. is it safe to run no rear O2 sensors witout tune?
