View Full Version : New LS1 Owners - Newbie Tech
  1. Ls6 free-mods?
  2. Need Some Opinions Please....
  3. Header Advice - Suggestions Welcome
  4. Under $5000 Mods
  5. ss hood...
  6. Need some stock specs help?
  7. Headlights
  8. prc 5.3 59cc heads?
  9. Besides H/C what other "power mods" can i do?
  10. putting my magnaflow system back on
  11. remove tail lights
  12. center mount exhaust
  13. is it possible to go slower after long tube install??
  14. shifter
  15. Anti-balooning plate
  16. Driver's Side Window Problem!!!
  17. edelbrock ls1 victor jr intake with EFI elbow
  18. possible 98 t/a purchase... what to look for???
  19. 1988 firebird rearend problem
  20. Interesting symptom
  21. Fun modding?
  22. true duals?
  23. Chromoly vs Mild Steel
  24. BMR Tunnell Brace
  25. Loudmouth vs LM2
  26. Over heating problems..
  27. A good daily driver with these Mods??
  28. LS1 compared to LS6?
  29. camaro calipers
  30. hypertech tuners. worth the price???
  31. My car is an asshole and i need your help.. codes and car problems
  32. lost on cam ?
  33. 98 Trans Am down on power
  34. Alright need to know how much to pay for mod install
  35. Air/Egr/SLP?!
  36. True Duals
  37. what to do
  38. Tune and Mod questions
  39. Special radiator for LS style engines
  40. Converting from Manual to Auto
  41. Cam? Louder exhaust?
  42. I'm really sorry for being NOOB......
  43. Are my gears chipped??
  44. what mod should i do next?
  45. 00-02 shorty headers on 98-99???
  46. Spark Plugs?
  47. Auto to Manual Tranny Swap.
  48. What's wrong with the car?
  49. 475 rwhp possible?
  50. Need the LQ4 block casting/part numbers...
  51. free mod directions
  52. LS1TECH Stickers.
  53. p0174 Running Lean? IAT sensor?
  54. removing cats
  55. Price for SS passenger seat??
  56. SS seat with blemish
  57. PCV questions
  58. How much are these heads and engine worth..........?
  59. newbie grease question
  60. Best way to spend $3500 on mods?
  61. Special edition power ratings ??
  62. lt1 vs ls1 t-56 tranny
  63. Burnouts
  64. Oil pressure vs. oil temperature gauge
  65. which blocks work...
  66. c5 Z06 rims on my 2000 camaro??
  67. kooks
  68. Tune my 160 therm
  69. 01 Z28 SS VS. 02 Z28....any difference???
  70. Headers, Exhaust, Intake
  71. Issues with a/c vents.
  72. Quick stall question.
  73. EXHAUST what sounds the best?
  74. engine/trans storage
  75. True SS or not....
  76. newb question...
  77. normal oil pressure and temperature readings?
  78. Mixing different brands of oil?
  79. 02 Nbm T/a
  80. I need some help
  81. Need cat-back
  82. Good Setup???
  83. Need Help!!!
  84. Motor Pulling
  85. is it safe to use 0w30
  86. Gears or Stall??
  87. heads / cam please clarify
  88. 5.3 vs 6.0
  89. C5 Z06 headers question...
  90. computerchips
  91. ?Need Tune?
  92. updated TB porting write-up?
  93. Need The Name Of This Piece????
  94. Mail order tune?
  95. Lifespan of tint?
  96. Symptoms for running way too rich?
  97. Build number
  98. cam setup...
  99. why is 00 grouped with 00-02 headers?
  100. LSx? What is it?
  101. head and cam and block questions
  102. People with ASR
  103. Gallons to fill up?
  104. Headers installed now ory
  105. put in an 02 steering wheel
  106. Good Deal for a stock/used 346?
  107. need help with a few things.
  108. I want to start working on my car but where to start?
  109. ls6 intake install help
  110. 454 BB in 01 ws6
  111. Piston/Valve clearance w/ L92 heads ?
  112. Trans Am Spoiler?
  113. Cam Lsa Question
  114. 00 Z28
  115. 98 trans am ws6 performance chip?
  116. Weak Burnout?
  117. Can High Flow cats be used with LT's and ORY?
  118. yay, first power mod.
  119. 5.3 (LM4) what vehicles?
  120. Plugs
  121. premium gas debate
  122. Material
  123. What will I need to make it run?
  124. local tune
  125. LT's installation parts?
  126. quick question
  127. SES light hp loss??
  128. Instructions of doing bump stop mod with volt-meter, not autotap?
  129. ? about c5 z06
  130. Gas mileage on a 02WS6?
  131. Air bag help????
  132. Can Someone Please Help
  133. First posts... and a hell of a start
  134. How much power
  135. What to expect-been posted many times
  136. Clutch not fully disengaging?
  137. ford fab9 rear end
  138. FAIR PRICE ON A GMMG EXHAUST? "GMMG=audible sex sounds" or so i have heard
  139. Muffler Placement
  140. In Afghanistan without resources...
  141. High flow cat's
  142. Loss of power?
  143. Do you guys know....
  144. Intakes
  145. 2001 - 2002 F-Body Y-Pipe
  146. Where to buy clear/smoked corners???
  147. fuel pump help
  148. Whats the problem
  149. 2K to spend. Help me.
  150. First Bird/Shifter Knobs
  151. alarm going off when i lock car?
  152. need help with alarm system
  153. TB Spacers??
  154. Does the manual fan switch mod make fans not kick on automatically when needed?
  155. Noob rear diff question
  156. Removing A.I.R. from an 01 WS6, good idea?
  157. help
  158. Ory!
  159. Just got SLP lid, missing AIR hose connector
  160. newb question
  161. coolant light
  162. how is the trick flow head/cam package
  163. gto exhaust Q
  164. SES codes
  165. Can I get your opinion?
  166. Question?
  167. Super conservative gas gauge
  168. newb @ shifting. need help!
  169. lights
  170. exhaust question about headers on a 2000 camaro
  171. Turning parking lights off
  172. New LS1 owner
  173. LS6 intake or LT's
  174. Another newb question, 346 or 350?
  175. intakes LS2 vs LS6
  176. Check engine light with headers?
  177. What is a 2000 Camaro SS NBM M6 W/35,000 miles worth??
  178. Help Needed with 98' camaro V6 to V8 swap
  179. dumb question
  180. Just made the Big Leap from Ford to GM Need ideas
  181. Questions about O2 sensors
  182. 01 WS6-200000mi and running. Need Advice
  183. Bad iac motor?
  184. ls6 intake
  185. How much would i expect to pay for headers and a ORY install?
  186. shavings in bottom of pan
  187. A4 Gear selector: Does yours suck?
  188. Cutting into the hood?
  189. Will a ls2 intake manifold bolt right up to a ls1?
  190. Identified my weird problem, put a hole in the power steering rail
  191. Header research...
  192. Why are longtubes louder?
  193. Question about 02 sensor
  194. Top end job
  195. weld up header kit for ls6
  196. Best way to spend 1500-2000$
  197. Is buying Heads a good investment?? couple newb questions inside...
  198. question about my y-pipe
  199. Headers *Important*
  200. Typhoon 96mm intake manifold w/fuel rails VS LS6 Manifold
  201. Stay 3.23 or go 3.73
  202. looking for a turnkey LS1 in NewZealand
  203. GMMG Vs. Cutout sound
  204. Taking off a/c belt
  205. difference between ls1 long and short blocks
  206. FAST 92 install question
  207. Security light on?
  208. Cam
  209. Trouble starting/ running
  210. Service Eng. light
  211. cooling fan switch mod?
  212. 02 ZO6 LS1 vs Fbody LS1, Whats Different?
  213. Collector's Plates?
  214. throttle body seal
  215. Best-value high-flow cat?
  216. Slight miss around 2200 rpm
  217. Longtubes?? Shorties??
  218. Newb looking for a place to start
  219. What Does This Mean???
  220. advice on small parts?
  221. P0443 and P0481 Code Help
  222. Installed a ported TB...
  223. Power stearing pullie
  224. Bolt Pattern
  225. A couple things...
  226. Car may be totaled what can i expect??????
  227. Noob Exhaust Question
  228. Help me with spark plug wires?
  229. so what is this
  230. Is my clutch going bad??
  231. What kind of power is expected? And how much $$$?
  232. radio noise
  233. Is it worth buying these pulleys??
  234. Spark plug question?
  235. Buying my first LS1...
  236. 3" TD's with an h pipe as a first mod?
  237. master and slave cylinder question
  238. black zo6 rims?
  239. Looking to buy Sunset Orange 01 SS (need input)
  240. 160* thermo stat and SES light?!
  241. 17 X 11 torque thrust question
  242. Removing pass. seat belt?
  243. Any LS1tech sponsor vendors for sensors?
  244. Bigger MAF= better or worse gas mileage?
  245. Ordering Handheld
  246. new here
  247. Full exhaust with California emissions?
  248. stall or nitrous???
  249. water damage, possible hydro lock HELP!
  250. Cam Stall Gas Mileage?
